--- ray/src/common/bsdf_m.c 2011/04/08 18:13:48 3.9 +++ ray/src/common/bsdf_m.c 2011/04/19 21:31:22 3.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.9 2011/04/08 18:13:48 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.10 2011/04/19 21:31:22 greg Exp $"; #endif /* * bsdf_m.c @@ -81,7 +81,7 @@ static int nabases = 3; /* current number of defined b static int fequal(double a, double b) { - if (b != .0) + if (b != 0) a = a/b - 1.; return (a <= 1e-6) & (a >= -1e-6); } @@ -193,7 +193,7 @@ fo_getndx(const FVECT v, void *p) if (v == NULL) return -1; - if ((v[2] < .0) | (v[2] > 1.0)) + if ((v[2] < 0) | (v[2] > 1.)) return -1; pol = 180.0/M_PI*acos(v[2]); azi = 180.0/M_PI*atan2(v[1], v[0]); @@ -507,7 +507,7 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) df->comp[0].dist = dp; df->comp[0].func = &SDhandleMtx; /* read BSDF data */ - sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); + sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); if (!sdata || !*sdata) { sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'", sd->name); @@ -651,16 +651,19 @@ SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec, /* Query solid angle for vector */ static SDError -SDqueryMtxProjSA(double *psa, const FVECT vec, int qflags, const void *dist) +SDqueryMtxProjSA(double *psa, const FVECT v1, const RREAL *v2, + int qflags, const void *dist) { const SDMat *dp = (const SDMat *)dist; double inc_psa, out_psa; /* check arguments */ - if ((psa == NULL) | (vec == NULL) | (dp == NULL)) + if ((psa == NULL) | (v1 == NULL) | (dp == NULL)) return SDEargument; + if (v2 == NULL) + v2 = v1; /* get projected solid angles */ - inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, vec)); - out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, vec)); + out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v1)); + inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v2)); switch (qflags) { /* record based on flag settings */ case SDqueryVal: @@ -679,14 +682,14 @@ SDqueryMtxProjSA(double *psa, const FVECT vec, int qfl psa[1] = out_psa; /* fall through */ case SDqueryMin: - if ((inc_psa > .0) & (inc_psa < psa[0])) + if ((inc_psa > 0) & (inc_psa < psa[0])) psa[0] = inc_psa; - if ((out_psa > .0) & (out_psa < psa[0])) + if ((out_psa > 0) & (out_psa < psa[0])) psa[0] = out_psa; break; } /* make sure it's legal */ - return (psa[0] <= .0) ? SDEinternal : SDEnone; + return (psa[0] <= 0) ? SDEinternal : SDEnone; } /* Compute new cumulative distribution from BSDF */
