1 |
/* RCSid $Id$ */ |
2 |
3 |
* bsdf.h |
4 |
5 |
* Declarations for bidirectional scattering distribution functions. |
6 |
* Assumes <stdio.h> already included. |
7 |
8 |
* A material is oriented in right-hand coordinate system with X-axis |
9 |
* in the surface plane pointed to the right as seen from the front. |
10 |
* This means the Y-axis is "up" and the Z-axis is the surface normal. |
11 |
12 |
* BSDF vectors always oriented away from surface, even when "incident." |
13 |
14 |
* Created by Greg Ward on 1/10/11. |
15 |
16 |
17 |
18 |
#ifndef _BSDF_H_ |
19 |
#define _BSDF_H_ |
20 |
21 |
#include "fvect.h" |
22 |
#include "ccolor.h" |
23 |
24 |
#ifdef __cplusplus |
25 |
extern "C" { |
26 |
#endif |
27 |
28 |
#define SDnameLn 128 /* maximum BSDF name length */ |
29 |
#define SDmaxCh 3 /* maximum # spectral channels */ |
30 |
31 |
/* Component flags for SDsampBSDF() and SDhemiScatter() */ |
32 |
#define SDsampR 0x1 /* include reflection */ |
33 |
#define SDsampT 0x2 /* include transmission */ |
34 |
#define SDsampS 0x3 /* include scattering (R+T) */ |
35 |
#define SDsampSp 0x4 /* include non-diffuse portion */ |
36 |
#define SDsampDf 0x8 /* include diffuse portion */ |
37 |
#define SDsampSpR 0x5 /* include non-diffuse reflection */ |
38 |
#define SDsampSpT 0x6 /* include non-diffuse transmission */ |
39 |
#define SDsampSpS 0x7 /* include non-diffuse scattering */ |
40 |
#define SDsampAll 0xF /* include everything */ |
41 |
42 |
/* Projected solid angle query flags fos SDsizeBSDF() */ |
43 |
#define SDqueryInc 0x1 /* query incoming vector */ |
44 |
#define SDqueryOut 0x2 /* query outgoing vector */ |
45 |
#define SDqueryMin 0x4 /* query minimum proj. solid angle */ |
46 |
#define SDqueryMax 0x8 /* query maximum proj. solid angle */ |
47 |
48 |
/* Error codes: normal return, out of memory, file i/o, file format, bad argument, |
49 |
bad data, unsupported feature, internal error, unknown error */ |
50 |
typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument, |
51 |
SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError; |
52 |
53 |
/* English ASCII strings corresponding to ennumerated errors */ |
54 |
extern const char *SDerrorEnglish[]; |
55 |
56 |
/* Additional information on last error (ASCII English) */ |
57 |
extern char SDerrorDetail[]; |
58 |
59 |
/* Holder for BSDF value and spectral color */ |
60 |
typedef struct { |
61 |
double cieY; /* photopic BSDF (Y) value */ |
62 |
C_COLOR spec; /* spectral and (x,y) color */ |
63 |
} SDValue; |
64 |
65 |
/* Cached, encoded, cumulative distribution for one incident (solid) angle */ |
66 |
#define SD_CDIST_BASE double cTotal; \ |
67 |
struct SDCDst_s *next |
68 |
typedef struct SDCDst_s { |
69 |
SD_CDIST_BASE; /* base fields first */ |
70 |
/* ...encoded distribution extends struct */ |
71 |
} SDCDst; |
72 |
73 |
/* Forward declaration of BSDF component */ |
74 |
typedef struct SDComp_s SDComponent; |
75 |
76 |
/* Methods needed to handle BSDF components (nothing is optional) */ |
77 |
typedef const struct { |
78 |
/* return non-diffuse BSDF */ |
79 |
int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec, |
80 |
const FVECT inVec, const void *dist); |
81 |
/* query non-diffuse PSA for vector */ |
82 |
SDError (*queryProjSA)(double *psa, const FVECT vec, |
83 |
int qflags, const void *dist); |
84 |
/* get cumulative distribution */ |
85 |
const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc); |
86 |
/* sample cumulative distribution */ |
87 |
SDError (*sampCDist)(FVECT outVec, double randX, |
88 |
const SDCDst *cdp); |
89 |
/* free a spectral BSDF component */ |
90 |
void (*freeSC)(void *dist); |
91 |
} SDFunc; |
92 |
93 |
/* Structure to hold a spectral BSDF component (typedef SDComponent above) */ |
94 |
struct SDComp_s { |
95 |
C_COLOR cspec[SDmaxCh]; /* component spectral bases */ |
96 |
SDFunc *func; /* methods for this component */ |
97 |
void *dist; /* loaded distribution data */ |
98 |
SDCDst *cdList; /* cumulative distribution cache */ |
99 |
100 |
101 |
/* Container for non-diffuse BSDF components */ |
102 |
typedef struct { |
103 |
double minProjSA; /* minimum projected solid angle */ |
104 |
double maxHemi; /* maximum directional hemispherical */ |
105 |
int ncomp; /* number of separate components */ |
106 |
SDComponent comp[1]; /* BSDF components (extends struct) */ |
107 |
} SDSpectralDF; |
108 |
109 |
/* Loaded BSDF data */ |
110 |
typedef struct { |
111 |
char name[SDnameLn]; /* BSDF name (derived from file) */ |
112 |
char *mgf; /* geometric description (if any) */ |
113 |
float dim[3]; /* width, height, thickness (meters) */ |
114 |
SDValue rLambFront; /* diffuse front reflectance */ |
115 |
SDValue rLambBack; /* diffuse rear reflectance */ |
116 |
SDValue tLamb; /* diffuse transmission */ |
117 |
SDSpectralDF *rf, *rb, *tf; /* non-diffuse BSDF components */ |
118 |
} SDData; |
119 |
120 |
/* List of loaded BSDFs */ |
121 |
extern struct SDCache_s { |
122 |
SDData bsdf; /* BSDF data */ |
123 |
unsigned refcnt; /* how many callers are using us? */ |
124 |
struct SDCache_s /* next in cache list */ |
125 |
*next; |
126 |
} *SDcacheList; /* Global BSDF cache */ |
127 |
128 |
/* BSDF cache retention preference */ |
129 |
#define SDretainNone 0 /* free unreferenced data (default) */ |
130 |
#define SDretainBSDFs 1 /* keep loaded BSDFs in cache */ |
131 |
#define SDretainAll 2 /* also keep cumulative cache data */ |
132 |
133 |
extern int SDretainSet; /* set to SDretainNone by default */ |
134 |
135 |
136 |
* The following routines are less commonly used by applications. |
137 |
138 |
139 |
#define SDisLoaded(sd) ((sd)->rLambFront.spec.clock != 0) |
140 |
141 |
/* Report an error to the indicated stream (in English) */ |
142 |
extern SDError SDreportEnglish(SDError ec, FILE *fp); |
143 |
144 |
/* Shorten file path to useable BSDF name, removing suffix */ |
145 |
extern void SDclipName(char res[SDnameLn], const char *fname); |
146 |
147 |
/* Allocate new spectral distribution function */ |
148 |
extern SDSpectralDF *SDnewSpectralDF(int nc); |
149 |
150 |
/* Free a spectral distribution function */ |
151 |
extern void SDfreeSpectralDF(SDSpectralDF *df); |
152 |
153 |
/* Initialize an unused BSDF struct (clears to zeroes) */ |
154 |
extern void SDclearBSDF(SDData *sd); |
155 |
156 |
/* Load a BSDF struct from the given file (keeps name unchanged) */ |
157 |
extern SDError SDloadFile(SDData *sd, const char *fname); |
158 |
159 |
/* Free data associated with BSDF struct */ |
160 |
extern void SDfreeBSDF(SDData *sd); |
161 |
162 |
/* Find writeable BSDF by name, or allocate new cache entry if absent */ |
163 |
extern SDData *SDgetCache(const char *bname); |
164 |
165 |
/* Free cached cumulative distributions for BSDF component */ |
166 |
extern void SDfreeCumulativeCache(SDSpectralDF *df); |
167 |
168 |
/* Sample an individual BSDF component */ |
169 |
extern SDError SDsampComponent(SDValue *sv, FVECT outVec, |
170 |
const FVECT inVec, double randX, |
171 |
172 |
173 |
/* Convert 1-dimensional random variable to N-dimensional */ |
174 |
extern void SDmultiSamp(double t[], int n, double randX); |
175 |
176 |
/* Map a [0,1]^2 square to a unit radius disk */ |
177 |
void SDsquare2disk(double ds[2], double seedx, double seedy); |
178 |
179 |
/* Map point on unit disk to a unit square in [0,1]^2 range */ |
180 |
void SDdisk2square(double sq[2], double diskx, double disky); |
181 |
182 |
183 |
* The calls below are the ones most applications require. |
184 |
* All directions are assumed to be unit vectors. |
185 |
186 |
187 |
/* Get BSDF from cache (or load and cache it on first call) */ |
188 |
/* Report any problems to stderr and return NULL on failure */ |
189 |
extern const SDData *SDcacheFile(const char *fname); |
190 |
191 |
/* Free a BSDF from our cache (clear all if NULL) */ |
192 |
extern void SDfreeCache(const SDData *sd); |
193 |
194 |
/* Query projected solid angle resolution for non-diffuse BSDF direction */ |
195 |
extern SDError SDsizeBSDF(double *projSA, const FVECT vec, |
196 |
int qflags, const SDData *sd); |
197 |
198 |
/* Return BSDF for the given incident and scattered ray vectors */ |
199 |
extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec, |
200 |
const FVECT inVec, const SDData *sd); |
201 |
202 |
/* Compute directional hemispherical scattering at given incident angle */ |
203 |
extern double SDdirectHemi(const FVECT inVec, |
204 |
int sflags, const SDData *sd); |
205 |
206 |
/* Sample BSDF direction based on the given random variable */ |
207 |
extern SDError SDsampBSDF(SDValue *sv, FVECT outVec, |
208 |
209 |
210 |
211 |
212 |
* Vector math for getting between world and local BSDF coordinates. |
213 |
* Directions may be passed unnormalized to these routines. |
214 |
215 |
216 |
/* Compute World->BSDF transform from surface normal and up (Y) vector */ |
217 |
extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, |
218 |
const FVECT uVec); |
219 |
220 |
/* Compute inverse transform */ |
221 |
extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]); |
222 |
223 |
/* Transform and normalize direction (column) vector */ |
224 |
extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3], |
225 |
const FVECT inpVec); |
226 |
227 |
228 |
/*######### DEPRECATED DEFINITIONS AWAITING PERMANENT REMOVAL #######*/ |
229 |
230 |
* Header for BSDF i/o and access routines |
231 |
232 |
233 |
#include "mat4.h" |
234 |
/* up directions */ |
235 |
typedef enum { |
236 |
UDzneg=-3, |
237 |
UDyneg=-2, |
238 |
UDxneg=-1, |
239 |
UDunknown=0, |
240 |
UDxpos=1, |
241 |
UDypos=2, |
242 |
UDzpos=3 |
243 |
} UpDir; |
244 |
/* BSDF coordinate calculation routines */ |
245 |
/* vectors always point away from surface */ |
246 |
247 |
typedef int b_vecf2(FVECT v, int n, void *cd); |
248 |
typedef int b_ndxf2(FVECT v, void *cd); |
249 |
typedef double b_radf2(int n, void *cd); |
250 |
251 |
/* Bidirectional Scattering Distribution Function */ |
252 |
struct BSDF_data { |
253 |
int ninc; /* number of incoming directions */ |
254 |
int nout; /* number of outgoing directions */ |
255 |
256 |
257 |
void *ib_priv; /* input basis private data */ |
258 |
b_vecf2 *ib_vec; /* get input vector from index */ |
259 |
b_ndxf2 *ib_ndx; /* get input index from vector */ |
260 |
b_radf2 *ib_ohm; /* get input radius for index */ |
261 |
void *ob_priv; /* output basis private data */ |
262 |
b_vecf2 *ob_vec; /* get output vector from index */ |
263 |
b_ndxf2 *ob_ndx; /* get output index from vector */ |
264 |
b_radf2 *ob_ohm; /* get output radius for index */ |
265 |
float *bsdf; /* scattering distribution data */ |
266 |
}; /* bidirectional scattering distrib. func. */ |
267 |
268 |
#define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv) |
269 |
#define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv) |
270 |
#define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv) |
271 |
#define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv) |
272 |
#define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv) |
273 |
#define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv) |
274 |
#define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)] |
275 |
276 |
extern struct BSDF_data *load_BSDF(char *fname); |
277 |
extern void free_BSDF(struct BSDF_data *b); |
278 |
extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i, |
279 |
double rv, MAT4 xm); |
280 |
extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o, |
281 |
282 |
extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud, char *xfbuf); |
283 |
284 |
/*######### END DEPRECATED DEFINITIONS #######*/ |
285 |
286 |
287 |
288 |
289 |
#endif |
290 |
#endif /* ! _BSDF_H_ */ |
