root/radiance/ray/src/common/bsdf.h
Revision: 2.29
Committed: Tue Dec 7 23:49:50 2021 UTC (3 years, 5 months ago) by greg
Changes since 2.28: +5 -5 lines
1 /* RCSid $Id: bsdf.h,v 2.28 2021/03/27 17:50:18 greg Exp $ */
2 /*
3 * bsdf.h
4 *
5 * Declarations for bidirectional scattering distribution functions.
6 * Assumes <stdio.h> already included.
7 *
8 * A material is oriented in right-hand coordinate system with X-axis
9 * in the surface plane pointed to the right as seen from the front.
10 * This means the Y-axis is "up" and the Z-axis is the surface normal.
11 *
12 * Note that we reverse the identification of "front" and "back" from
13 * the conventions used in WINDOW 6. "Front" in our library points
14 * in the +Z direction, towards the interior of the space rather
15 * than the exterior.
16 *
17 * BSDF incident & exiting vectors are always oriented away from surface.
18 *
19 * Created by Greg Ward on 1/10/11.
20 *
21 */
22
23 #ifndef _BSDF_H_
24 #define _BSDF_H_
25
26 #include "fvect.h"
27 #include "ccolor.h"
28 #include "platform.h"
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif
33
34 #define SDnameLn 128 /* maximum BSDF name length */
35 #define SDmaxCh 3 /* maximum # spectral channels */
36
37 /* Component flags for SDsampBSDF() and SDdirectHemi() */
38 #define SDsampR 0x1 /* include reflection */
39 #define SDsampT 0x2 /* include transmission */
40 #define SDsampS 0x3 /* include scattering (R+T) */
41 #define SDsampSp 0x4 /* include non-diffuse portion */
42 #define SDsampDf 0x8 /* include diffuse portion */
43 #define SDsampSpR 0x5 /* include non-diffuse reflection */
44 #define SDsampSpT 0x6 /* include non-diffuse transmission */
45 #define SDsampSpS 0x7 /* include non-diffuse scattering */
46 #define SDsampAll 0xF /* include everything */
47
48 /* Projected solid angle query flags for SDsizeBSDF() */
49 #define SDqueryVal 0x0 /* query single value */
50 #define SDqueryMin 0x1 /* query minimum proj. solid angle */
51 #define SDqueryMax 0x2 /* query maximum proj. solid angle */
52
53 /* Error codes: normal return, out of memory, file i/o, file format, bad argument,
54 bad data, unsupported feature, internal error, unknown error */
55 typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
56 SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
57
58 /* English strings corresponding to ennumerated errors */
59 extern const char *SDerrorEnglish[];
60
61 /* Pointer to error list in preferred language */
62 extern const char **SDerrorList;
63
64 /* Additional information on last error (generally in English) */
65 extern char SDerrorDetail[];
66
67 /* Holder for BSDF value and spectral color */
68 typedef struct {
69 double cieY; /* photopic BSDF (Y) value */
70 C_COLOR spec; /* spectral and (x,y) color */
71 } SDValue;
72
73 /* Cached, encoded, cumulative distribution for one incident (solid) angle */
74 #define SD_CDIST_BASE(styp) double cTotal; \
75 struct styp *next
76 typedef struct SDCDst_s {
77 SD_CDIST_BASE(SDCDst_s); /* base fields first */
78 /* ...encoded distribution extends struct */
79 } SDCDst;
80
81 extern const SDCDst SDemptyCD; /* empty distribution */
82
83 /* Forward declaration of BSDF component */
84 typedef struct SDComp_s SDComponent;
85
86 /* Methods needed to handle BSDF components (nothing is optional) */
87 typedef struct {
88 /* return non-diffuse BSDF */
89 int (*getBSDFs)(float coef[SDmaxCh], const FVECT inVec,
90 const FVECT outVec, SDComponent *sdc);
91 /* query non-diffuse PSA for vector */
92 SDError (*queryProjSA)(double *psa, const FVECT v1,
93 const RREAL *v2, int qflags,
94 SDComponent *sdc);
95 /* get cumulative distribution */
96 const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
97 /* sample cumulative distribution */
98 SDError (*sampCDist)(FVECT ioVec, double randX,
99 const SDCDst *cdp);
100 /* free a spectral BSDF component */
101 void (*freeSC)(void *dist);
102 } SDFunc;
103
104 /* Structure to hold a spectral BSDF component (typedef SDComponent above) */
105 struct SDComp_s {
106 C_COLOR cspec[SDmaxCh]; /* component spectral bases */
107 const SDFunc *func; /* methods for this component */
108 void *dist; /* loaded distribution data */
109 SDCDst *cdList; /* cumulative distribution cache */
110 };
111
112 /* Container for non-diffuse BSDF components */
113 typedef struct {
114 double minProjSA; /* minimum projected solid angle */
115 double maxHemi; /* maximum directional hemispherical */
116 int ncomp; /* number of separate components */
117 SDComponent comp[1]; /* BSDF components (extends struct) */
118 } SDSpectralDF;
119
120 /* Loaded BSDF data */
121 typedef struct {
122 char name[SDnameLn]; /* BSDF name (usu. derived from file) */
123 char matn[SDnameLn]; /* material name */
124 char makr[SDnameLn]; /* manufacturer */
125 char *mgf; /* geometric description (if any) */
126 double dim[3]; /* width, height, thickness (meters) */
127 SDValue rLambFront; /* diffuse front reflectance */
128 SDValue rLambBack; /* diffuse rear reflectance */
129 SDValue tLambFront; /* diffuse front transmittance */
130 SDValue tLambBack; /* diffuse back transmittance */
131 SDSpectralDF *rf, *rb; /* non-diffuse BRDF components */
132 SDSpectralDF *tf, *tb; /* non-diffuse BTDF components */
133 } SDData;
134
135 /* List of loaded BSDFs */
136 extern struct SDCache_s {
137 SDData bsdf; /* BSDF data */
138 unsigned refcnt; /* how many callers are using us? */
139 struct SDCache_s /* next in cache list */
140 *next;
141 } *SDcacheList; /* Global BSDF cache */
142
143 /* BSDF cache retention policies */
144 #define SDretainNone 0 /* free unreferenced BSDF data */
145 #define SDretainBSDFs 1 /* keep loaded BSDFs in memory */
146 #define SDretainAll 2 /* also keep cumulative cache data */
147
148 extern int SDretainSet; /* =SDretainNone by default */
149 extern unsigned long SDmaxCache; /* =0 (unlimited) by default */
150
151 /*****************************************************************
152 * The following routines are less commonly used by applications.
153 */
154
155 #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
156
157 /* Report an error to the indicated stream */
158 extern SDError SDreportError(SDError ec, FILE *fp);
159
160 /* Shorten file path to useable BSDF name, removing suffix */
161 extern void SDclipName(char res[SDnameLn], const char *fname);
162
163 /* Allocate new spectral distribution function */
164 extern SDSpectralDF *SDnewSpectralDF(int nc);
165
166 /* Add component(s) to spectral distribution function */
167 extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd);
168
169 /* Free a spectral distribution function */
170 extern void SDfreeSpectralDF(SDSpectralDF *df);
171
172 /* Initialize an unused BSDF struct and assign name (calls SDclipName) */
173 extern void SDclearBSDF(SDData *sd, const char *fname);
174
175 /* Load a BSDF struct from the given file (keeps name unchanged) */
176 extern SDError SDloadFile(SDData *sd, const char *fname);
177
178 /* Free data associated with BSDF struct */
179 extern void SDfreeBSDF(SDData *sd);
180
181 /* Find writeable BSDF by name, or allocate new cache entry if absent */
182 extern SDData *SDgetCache(const char *bname);
183
184 /* Free cached cumulative distributions for BSDF component */
185 extern void SDfreeCumulativeCache(SDSpectralDF *df);
186
187 /* Sample an individual BSDF component */
188 extern SDError SDsampComponent(SDValue *sv, FVECT ioVec,
189 double randX, SDComponent *sdc);
190
191 /* Convert 1-dimensional random variable to N-dimensional */
192 extern void SDmultiSamp(double t[], int n, double randX);
193
194 /* Map a [0,1]^2 square to a unit radius disk */
195 extern void SDsquare2disk(double ds[2], double seedx, double seedy);
196
197 /* Map point on unit disk to a unit square in [0,1]^2 range */
198 extern void SDdisk2square(double sq[2], double diskx, double disky);
199
200 /*****************************************************************
201 * The calls below are the ones most applications require.
202 * All directions are assumed to be unit vectors.
203 */
204
205 /* Get BSDF from cache (or load and cache it on first call) */
206 /* Report any problems to stderr, return NULL on failure */
207 extern const SDData *SDcacheFile(const char *fname);
208
209 /* Free a BSDF from our cache (clear all if sd==NULL) */
210 extern void SDfreeCache(const SDData *sd);
211
212 /* Query projected solid angle resolution for non-diffuse BSDF direction(s) */
213 extern SDError SDsizeBSDF(double *projSA, const FVECT v1,
214 const RREAL *v2, int qflags,
215 const SDData *sd);
216
217 /* Return BSDF for the given incident and scattered ray vectors */
218 extern SDError SDevalBSDF(SDValue *sv, const FVECT inVec,
219 const FVECT outVec, const SDData *sd);
220
221 /* Compute directional hemispherical scattering at given incident angle */
222 extern double SDdirectHemi(const FVECT inVec,
223 int sflags, const SDData *sd);
224
225 /* Sample BSDF direction based on the given random variable */
226 extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX,
227 int sflags, const SDData *sd);
228
229 /*****************************************************************
230 * Vector math for getting between world and local BSDF coordinates.
231 * Directions may be passed unnormalized to these routines.
232 */
233
234 /* Compute World->BSDF transform from surface normal and BSDF up vector */
235 extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
236 const FVECT uVec);
237
238 /* Compute inverse transform */
239 extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
240
241 /* Transform and normalize direction (column) vector */
242 extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
243 const FVECT inpVec);
244
245 /* Application-specific BSDF loading routine (not part of our library) */
246 extern SDData *loadBSDF(char *name);
247
248 /* Application-specific BSDF error translator (not part of our library) */
249 extern char *transSDError(SDError ec);
250
251 #ifdef __cplusplus
252 }
253 #endif
254 #endif /* ! _BSDF_H_ */
