root/radiance/ray/src/common/bsdf.h
Revision: 2.18
Committed: Mon Mar 5 00:17:06 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.17: +3 -1 lines
Added recording of product and manufacturer names
1 /* RCSid $Id: bsdf.h,v 2.17 2012/03/04 20:11:10 greg Exp $ */
2 /*
3 * bsdf.h
4 *
5 * Declarations for bidirectional scattering distribution functions.
6 * Assumes <stdio.h> already included.
7 *
8 * A material is oriented in right-hand coordinate system with X-axis
9 * in the surface plane pointed to the right as seen from the front.
10 * This means the Y-axis is "up" and the Z-axis is the surface normal.
11 *
12 * Note that we reverse the identification of "front" and "back" from
13 * the conventions used in WINDOW 6. "Front" in our library points
14 * in the +Z direction, towards the interior of the space rather
15 * than the exterior.
16 *
17 * BSDF incident & exiting vectors are always oriented away from surface.
18 *
19 * Created by Greg Ward on 1/10/11.
20 *
21 */
22
23 #ifndef _BSDF_H_
24 #define _BSDF_H_
25
26 #include "fvect.h"
27 #include "ccolor.h"
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32
33 #ifdef _WIN32
34 #define strcasecmp stricmp
35 #endif
36
37 #define SDnameLn 128 /* maximum BSDF name length */
38 #define SDmaxCh 3 /* maximum # spectral channels */
39
40 /* Component flags for SDsampBSDF() and SDdirectHemi() */
41 #define SDsampR 0x1 /* include reflection */
42 #define SDsampT 0x2 /* include transmission */
43 #define SDsampS 0x3 /* include scattering (R+T) */
44 #define SDsampSp 0x4 /* include non-diffuse portion */
45 #define SDsampDf 0x8 /* include diffuse portion */
46 #define SDsampSpR 0x5 /* include non-diffuse reflection */
47 #define SDsampSpT 0x6 /* include non-diffuse transmission */
48 #define SDsampSpS 0x7 /* include non-diffuse scattering */
49 #define SDsampAll 0xF /* include everything */
50
51 /* Projected solid angle query flags for SDsizeBSDF() */
52 #define SDqueryVal 0x0 /* query single value */
53 #define SDqueryMin 0x1 /* query minimum proj. solid angle */
54 #define SDqueryMax 0x2 /* query maximum proj. solid angle */
55
56 /* Error codes: normal return, out of memory, file i/o, file format, bad argument,
57 bad data, unsupported feature, internal error, unknown error */
58 typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
59 SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
60
61 /* English ASCII strings corresponding to ennumerated errors */
62 extern const char *SDerrorEnglish[];
63
64 /* Additional information on last error (ASCII English) */
65 extern char SDerrorDetail[];
66
67 /* Holder for BSDF value and spectral color */
68 typedef struct {
69 double cieY; /* photopic BSDF (Y) value */
70 C_COLOR spec; /* spectral and (x,y) color */
71 } SDValue;
72
73 /* Cached, encoded, cumulative distribution for one incident (solid) angle */
74 #define SD_CDIST_BASE(styp) double cTotal; \
75 struct styp *next
76 typedef struct SDCDst_s {
77 SD_CDIST_BASE(SDCDst_s); /* base fields first */
78 /* ...encoded distribution extends struct */
79 } SDCDst;
80
81 /* Forward declaration of BSDF component */
82 typedef struct SDComp_s SDComponent;
83
84 /* Methods needed to handle BSDF components (nothing is optional) */
85 typedef const struct {
86 /* return non-diffuse BSDF */
87 int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec,
88 const FVECT inVec, SDComponent *sdc);
89 /* query non-diffuse PSA for vector */
90 SDError (*queryProjSA)(double *psa, const FVECT v1,
91 const RREAL *v2, int qflags,
92 SDComponent *sdc);
93 /* get cumulative distribution */
94 const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
95 /* sample cumulative distribution */
96 SDError (*sampCDist)(FVECT ioVec, double randX,
97 const SDCDst *cdp);
98 /* free a spectral BSDF component */
99 void (*freeSC)(void *dist);
100 } SDFunc;
101
102 /* Structure to hold a spectral BSDF component (typedef SDComponent above) */
103 struct SDComp_s {
104 C_COLOR cspec[SDmaxCh]; /* component spectral bases */
105 SDFunc *func; /* methods for this component */
106 void *dist; /* loaded distribution data */
107 SDCDst *cdList; /* cumulative distribution cache */
108 };
109
110 /* Container for non-diffuse BSDF components */
111 typedef struct {
112 double minProjSA; /* minimum projected solid angle */
113 double maxHemi; /* maximum directional hemispherical */
114 int ncomp; /* number of separate components */
115 SDComponent comp[1]; /* BSDF components (extends struct) */
116 } SDSpectralDF;
117
118 /* Loaded BSDF data */
119 typedef struct {
120 char name[SDnameLn]; /* BSDF name (usu. derived from file) */
121 char matn[SDnameLn]; /* material name */
122 char makr[SDnameLn]; /* manufacturer */
123 char *mgf; /* geometric description (if any) */
124 float dim[3]; /* width, height, thickness (meters) */
125 SDValue rLambFront; /* diffuse front reflectance */
126 SDValue rLambBack; /* diffuse rear reflectance */
127 SDValue tLamb; /* diffuse transmission */
128 SDSpectralDF *rf, *rb, *tf; /* non-diffuse BSDF components */
129 } SDData;
130
131 /* List of loaded BSDFs */
132 extern struct SDCache_s {
133 SDData bsdf; /* BSDF data */
134 unsigned refcnt; /* how many callers are using us? */
135 struct SDCache_s /* next in cache list */
136 *next;
137 } *SDcacheList; /* Global BSDF cache */
138
139 /* BSDF cache retention policies */
140 #define SDretainNone 0 /* free unreferenced BSDF data */
141 #define SDretainBSDFs 1 /* keep loaded BSDFs in memory */
142 #define SDretainAll 2 /* also keep cumulative cache data */
143
144 extern int SDretainSet; /* =SDretainNone by default */
145
146 /*****************************************************************
147 * The following routines are less commonly used by applications.
148 */
149
150 #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
151
152 /* Report an error to the indicated stream (in English) */
153 extern SDError SDreportEnglish(SDError ec, FILE *fp);
154
155 /* Shorten file path to useable BSDF name, removing suffix */
156 extern void SDclipName(char res[SDnameLn], const char *fname);
157
158 /* Allocate new spectral distribution function */
159 extern SDSpectralDF *SDnewSpectralDF(int nc);
160
161 /* Add component(s) to spectral distribution function */
162 extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd);
163
164 /* Free a spectral distribution function */
165 extern void SDfreeSpectralDF(SDSpectralDF *df);
166
167 /* Initialize an unused BSDF struct and assign name (calls SDclipName) */
168 extern void SDclearBSDF(SDData *sd, const char *fname);
169
170 /* Load a BSDF struct from the given file (keeps name unchanged) */
171 extern SDError SDloadFile(SDData *sd, const char *fname);
172
173 /* Free data associated with BSDF struct */
174 extern void SDfreeBSDF(SDData *sd);
175
176 /* Find writeable BSDF by name, or allocate new cache entry if absent */
177 extern SDData *SDgetCache(const char *bname);
178
179 /* Free cached cumulative distributions for BSDF component */
180 extern void SDfreeCumulativeCache(SDSpectralDF *df);
181
182 /* Sample an individual BSDF component */
183 extern SDError SDsampComponent(SDValue *sv, FVECT ioVec,
184 double randX, SDComponent *sdc);
185
186 /* Convert 1-dimensional random variable to N-dimensional */
187 extern void SDmultiSamp(double t[], int n, double randX);
188
189 /* Map a [0,1]^2 square to a unit radius disk */
190 void SDsquare2disk(double ds[2], double seedx, double seedy);
191
192 /* Map point on unit disk to a unit square in [0,1]^2 range */
193 void SDdisk2square(double sq[2], double diskx, double disky);
194
195 /*****************************************************************
196 * The calls below are the ones most applications require.
197 * All directions are assumed to be unit vectors.
198 */
199
200 /* Get BSDF from cache (or load and cache it on first call) */
201 /* Report any problems to stderr (in English), return NULL on failure */
202 extern const SDData *SDcacheFile(const char *fname);
203
204 /* Free a BSDF from our cache (clear all if sd==NULL) */
205 extern void SDfreeCache(const SDData *sd);
206
207 /* Query projected solid angle resolution for non-diffuse BSDF direction(s) */
208 extern SDError SDsizeBSDF(double *projSA, const FVECT v1,
209 const RREAL *v2, int qflags,
210 const SDData *sd);
211
212 /* Return BSDF for the given incident and scattered ray vectors */
213 extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec,
214 const FVECT inVec, const SDData *sd);
215
216 /* Compute directional hemispherical scattering at given incident angle */
217 extern double SDdirectHemi(const FVECT inVec,
218 int sflags, const SDData *sd);
219
220 /* Sample BSDF direction based on the given random variable */
221 extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX,
222 int sflags, const SDData *sd);
223
224 /*****************************************************************
225 * Vector math for getting between world and local BSDF coordinates.
226 * Directions may be passed unnormalized to these routines.
227 */
228
229 /* Compute World->BSDF transform from surface normal and BSDF up vector */
230 extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
231 const FVECT uVec);
232
233 /* Compute inverse transform */
234 extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
235
236 /* Transform and normalize direction (column) vector */
237 extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
238 const FVECT inpVec);
239
240 /* Application-specific BSDF loading routine (not part of our library) */
241 extern SDData *loadBSDF(char *name);
242
243 /* Application-specific BSDF error translator (not part of our library) */
244 extern char *transSDError(SDError ec);
245
246 /*################################################################*/
247 /*######### DEPRECATED DEFINITIONS AWAITING PERMANENT REMOVAL #######*/
248 /*
249 * Header for BSDF i/o and access routines
250 */
251
252 #include "mat4.h"
253 /* up directions */
254 typedef enum {
255 UDzneg=-3,
256 UDyneg=-2,
257 UDxneg=-1,
258 UDunknown=0,
259 UDxpos=1,
260 UDypos=2,
261 UDzpos=3
262 } UpDir;
263 /* BSDF coordinate calculation routines */
264 /* vectors always point away from surface */
265
266 typedef int b_vecf2(FVECT v, int n, void *cd);
267 typedef int b_ndxf2(FVECT v, void *cd);
268 typedef double b_radf2(int n, void *cd);
269
270 /* Bidirectional Scattering Distribution Function */
271 struct BSDF_data {
272 int ninc; /* number of incoming directions */
273 int nout; /* number of outgoing directions */
274 float dim[3]; /* width, height, thickness (meters) */
275 char *mgf; /* geometric description (if any) */
276 void *ib_priv; /* input basis private data */
277 b_vecf2 *ib_vec; /* get input vector from index */
278 b_ndxf2 *ib_ndx; /* get input index from vector */
279 b_radf2 *ib_ohm; /* get input radius for index */
280 void *ob_priv; /* output basis private data */
281 b_vecf2 *ob_vec; /* get output vector from index */
282 b_ndxf2 *ob_ndx; /* get output index from vector */
283 b_radf2 *ob_ohm; /* get output radius for index */
284 float *bsdf; /* scattering distribution data */
285 }; /* bidirectional scattering distrib. func. */
286
287 #define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
288 #define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
289 #define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
290 #define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
291 #define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
292 #define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
293 #define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
294
295 extern struct BSDF_data *load_BSDF(char *fname);
296 extern void free_BSDF(struct BSDF_data *b);
297 extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i,
298 double rv, MAT4 xm);
299 extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o,
300 double rv, MAT4 xm);
301 extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud, char *xfbuf);
302
303 /*######### END DEPRECATED DEFINITIONS #######*/
304 /*################################################################*/
305
306 #ifdef __cplusplus
307 }
308 #endif
309 #endif /* ! _BSDF_H_ */
