--- ray/src/common/bsdf.h 2011/02/19 23:42:09 2.7 +++ ray/src/common/bsdf.h 2021/03/27 17:50:18 2.28 @@ -1,4 +1,4 @@ -/* RCSid $Id: bsdf.h,v 2.7 2011/02/19 23:42:09 greg Exp $ */ +/* RCSid $Id: bsdf.h,v 2.28 2021/03/27 17:50:18 greg Exp $ */ /* * bsdf.h * @@ -9,8 +9,13 @@ * in the surface plane pointed to the right as seen from the front. * This means the Y-axis is "up" and the Z-axis is the surface normal. * - * BSDF vectors always oriented away from surface, even when "incident." + * Note that we reverse the identification of "front" and "back" from + * the conventions used in WINDOW 6. "Front" in our library points + * in the +Z direction, towards the interior of the space rather + * than the exterior. * + * BSDF incident & exiting vectors are always oriented away from surface. + * * Created by Greg Ward on 1/10/11. * */ @@ -20,6 +25,7 @@ #include "fvect.h" #include "ccolor.h" +#include "platform.h" #ifdef __cplusplus extern "C" { @@ -28,7 +34,7 @@ extern "C" { #define SDnameLn 128 /* maximum BSDF name length */ #define SDmaxCh 3 /* maximum # spectral channels */ -/* Component flags for SDsampBSDF() and SDhemiScatter() */ +/* Component flags for SDsampBSDF() and SDdirectHemi() */ #define SDsampR 0x1 /* include reflection */ #define SDsampT 0x2 /* include transmission */ #define SDsampS 0x3 /* include scattering (R+T) */ @@ -39,7 +45,7 @@ extern "C" { #define SDsampSpS 0x7 /* include non-diffuse scattering */ #define SDsampAll 0xF /* include everything */ -/* Projected solid angle query flags fos SDsizeBSDF() */ +/* Projected solid angle query flags for SDsizeBSDF() */ #define SDqueryVal 0x0 /* query single value */ #define SDqueryMin 0x1 /* query minimum proj. solid angle */ #define SDqueryMax 0x2 /* query maximum proj. solid angle */ @@ -49,10 +55,13 @@ extern "C" { typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument, SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError; -/* English ASCII strings corresponding to ennumerated errors */ +/* English strings corresponding to ennumerated errors */ extern const char *SDerrorEnglish[]; -/* Additional information on last error (ASCII English) */ +/* Pointer to error list in preferred language */ +extern const char **SDerrorList; + +/* Additional information on last error (generally in English) */ extern char SDerrorDetail[]; /* Holder for BSDF value and spectral color */ @@ -62,28 +71,31 @@ typedef struct { } SDValue; /* Cached, encoded, cumulative distribution for one incident (solid) angle */ -#define SD_CDIST_BASE double cTotal; \ - struct SDCDst_s *next +#define SD_CDIST_BASE(styp) double cTotal; \ + struct styp *next typedef struct SDCDst_s { - SD_CDIST_BASE; /* base fields first */ + SD_CDIST_BASE(SDCDst_s); /* base fields first */ /* ...encoded distribution extends struct */ } SDCDst; +extern const SDCDst SDemptyCD; /* empty distribution */ + /* Forward declaration of BSDF component */ typedef struct SDComp_s SDComponent; /* Methods needed to handle BSDF components (nothing is optional) */ -typedef const struct { +typedef struct { /* return non-diffuse BSDF */ int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec, - const FVECT inVec, const void *dist); + const FVECT inVec, SDComponent *sdc); /* query non-diffuse PSA for vector */ - SDError (*queryProjSA)(double *psa, const FVECT vec, - int qflags, const void *dist); + SDError (*queryProjSA)(double *psa, const FVECT v1, + const RREAL *v2, int qflags, + SDComponent *sdc); /* get cumulative distribution */ const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc); /* sample cumulative distribution */ - SDError (*sampCDist)(FVECT outVec, double randX, + SDError (*sampCDist)(FVECT ioVec, double randX, const SDCDst *cdp); /* free a spectral BSDF component */ void (*freeSC)(void *dist); @@ -92,7 +104,7 @@ typedef const struct { /* Structure to hold a spectral BSDF component (typedef SDComponent above) */ struct SDComp_s { C_COLOR cspec[SDmaxCh]; /* component spectral bases */ - SDFunc *func; /* methods for this component */ + const SDFunc *func; /* methods for this component */ void *dist; /* loaded distribution data */ SDCDst *cdList; /* cumulative distribution cache */ }; @@ -107,13 +119,17 @@ typedef struct { /* Loaded BSDF data */ typedef struct { - char name[SDnameLn]; /* BSDF name (derived from file) */ + char name[SDnameLn]; /* BSDF name (usu. derived from file) */ + char matn[SDnameLn]; /* material name */ + char makr[SDnameLn]; /* manufacturer */ char *mgf; /* geometric description (if any) */ - float dim[3]; /* width, height, thickness (meters) */ + double dim[3]; /* width, height, thickness (meters) */ SDValue rLambFront; /* diffuse front reflectance */ SDValue rLambBack; /* diffuse rear reflectance */ - SDValue tLamb; /* diffuse transmission */ - SDSpectralDF *rf, *rb, *tf; /* non-diffuse BSDF components */ + SDValue tLambFront; /* diffuse front transmittance */ + SDValue tLambBack; /* diffuse back transmittance */ + SDSpectralDF *rf, *rb; /* non-diffuse BRDF components */ + SDSpectralDF *tf, *tb; /* non-diffuse BTDF components */ } SDData; /* List of loaded BSDFs */ @@ -124,12 +140,13 @@ extern struct SDCache_s { *next; } *SDcacheList; /* Global BSDF cache */ -/* BSDF cache retention preference */ -#define SDretainNone 0 /* free unreferenced data (default) */ -#define SDretainBSDFs 1 /* keep loaded BSDFs in cache */ +/* BSDF cache retention policies */ +#define SDretainNone 0 /* free unreferenced BSDF data */ +#define SDretainBSDFs 1 /* keep loaded BSDFs in memory */ #define SDretainAll 2 /* also keep cumulative cache data */ -extern int SDretainSet; /* set to SDretainNone by default */ +extern int SDretainSet; /* =SDretainNone by default */ +extern unsigned long SDmaxCache; /* =0 (unlimited) by default */ /***************************************************************** * The following routines are less commonly used by applications. @@ -137,8 +154,8 @@ extern int SDretainSet; /* set to SDretainNone by def #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0) -/* Report an error to the indicated stream (in English) */ -extern SDError SDreportEnglish(SDError ec, FILE *fp); +/* Report an error to the indicated stream */ +extern SDError SDreportError(SDError ec, FILE *fp); /* Shorten file path to useable BSDF name, removing suffix */ extern void SDclipName(char res[SDnameLn], const char *fname); @@ -146,11 +163,14 @@ extern void SDclipName(char res[SDnameLn], const char /* Allocate new spectral distribution function */ extern SDSpectralDF *SDnewSpectralDF(int nc); +/* Add component(s) to spectral distribution function */ +extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd); + /* Free a spectral distribution function */ extern void SDfreeSpectralDF(SDSpectralDF *df); -/* Initialize an unused BSDF struct (clears to zeroes) */ -extern void SDclearBSDF(SDData *sd); +/* Initialize an unused BSDF struct and assign name (calls SDclipName) */ +extern void SDclearBSDF(SDData *sd, const char *fname); /* Load a BSDF struct from the given file (keeps name unchanged) */ extern SDError SDloadFile(SDData *sd, const char *fname); @@ -165,18 +185,17 @@ extern SDData *SDgetCache(const char *bname); extern void SDfreeCumulativeCache(SDSpectralDF *df); /* Sample an individual BSDF component */ -extern SDError SDsampComponent(SDValue *sv, FVECT outVec, - const FVECT inVec, double randX, - SDComponent *sdc); +extern SDError SDsampComponent(SDValue *sv, FVECT ioVec, + double randX, SDComponent *sdc); /* Convert 1-dimensional random variable to N-dimensional */ extern void SDmultiSamp(double t[], int n, double randX); /* Map a [0,1]^2 square to a unit radius disk */ -void SDsquare2disk(double ds[2], double seedx, double seedy); +extern void SDsquare2disk(double ds[2], double seedx, double seedy); /* Map point on unit disk to a unit square in [0,1]^2 range */ -void SDdisk2square(double sq[2], double diskx, double disky); +extern void SDdisk2square(double sq[2], double diskx, double disky); /***************************************************************** * The calls below are the ones most applications require. @@ -184,15 +203,16 @@ void SDdisk2square(double sq[2], double diskx, doubl */ /* Get BSDF from cache (or load and cache it on first call) */ -/* Report any problems to stderr and return NULL on failure */ +/* Report any problems to stderr, return NULL on failure */ extern const SDData *SDcacheFile(const char *fname); -/* Free a BSDF from our cache (clear all if NULL) */ +/* Free a BSDF from our cache (clear all if sd==NULL) */ extern void SDfreeCache(const SDData *sd); -/* Query projected solid angle resolution for non-diffuse BSDF direction */ -extern SDError SDsizeBSDF(double *projSA, const FVECT vec, - int qflags, const SDData *sd); +/* Query projected solid angle resolution for non-diffuse BSDF direction(s) */ +extern SDError SDsizeBSDF(double *projSA, const FVECT v1, + const RREAL *v2, int qflags, + const SDData *sd); /* Return BSDF for the given incident and scattered ray vectors */ extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec, @@ -203,8 +223,7 @@ extern double SDdirectHemi(const FVECT inVec, int sflags, const SDData *sd); /* Sample BSDF direction based on the given random variable */ -extern SDError SDsampBSDF(SDValue *sv, FVECT outVec, - const FVECT inVec, double randX, +extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int sflags, const SDData *sd); /***************************************************************** @@ -212,7 +231,7 @@ extern SDError SDsampBSDF(SDValue *sv, FVECT outVec, * Directions may be passed unnormalized to these routines. */ -/* Compute World->BSDF transform from surface normal and up (Y) vector */ +/* Compute World->BSDF transform from surface normal and BSDF up vector */ extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, const FVECT uVec); @@ -223,71 +242,11 @@ extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMt extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT inpVec); -/* System-specific BSDF loading routine (not part of our library) */ +/* Application-specific BSDF loading routine (not part of our library) */ extern SDData *loadBSDF(char *name); -/* System-specific BSDF error translator (not part of our library) */ +/* Application-specific BSDF error translator (not part of our library) */ extern char *transSDError(SDError ec); - -/*################################################################*/ -/*######### DEPRECATED DEFINITIONS AWAITING PERMANENT REMOVAL #######*/ -/* - * Header for BSDF i/o and access routines - */ - -#include "mat4.h" - /* up directions */ -typedef enum { - UDzneg=-3, - UDyneg=-2, - UDxneg=-1, - UDunknown=0, - UDxpos=1, - UDypos=2, - UDzpos=3 -} UpDir; - /* BSDF coordinate calculation routines */ - /* vectors always point away from surface */ - -typedef int b_vecf2(FVECT v, int n, void *cd); -typedef int b_ndxf2(FVECT v, void *cd); -typedef double b_radf2(int n, void *cd); - -/* Bidirectional Scattering Distribution Function */ -struct BSDF_data { - int ninc; /* number of incoming directions */ - int nout; /* number of outgoing directions */ - float dim[3]; /* width, height, thickness (meters) */ - char *mgf; /* geometric description (if any) */ - void *ib_priv; /* input basis private data */ - b_vecf2 *ib_vec; /* get input vector from index */ - b_ndxf2 *ib_ndx; /* get input index from vector */ - b_radf2 *ib_ohm; /* get input radius for index */ - void *ob_priv; /* output basis private data */ - b_vecf2 *ob_vec; /* get output vector from index */ - b_ndxf2 *ob_ndx; /* get output index from vector */ - b_radf2 *ob_ohm; /* get output radius for index */ - float *bsdf; /* scattering distribution data */ -}; /* bidirectional scattering distrib. func. */ - -#define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv) -#define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv) -#define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv) -#define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv) -#define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv) -#define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv) -#define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)] - -extern struct BSDF_data *load_BSDF(char *fname); -extern void free_BSDF(struct BSDF_data *b); -extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i, - double rv, MAT4 xm); -extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o, - double rv, MAT4 xm); -extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud, char *xfbuf); - -/*######### END DEPRECATED DEFINITIONS #######*/ -/*################################################################*/ #ifdef __cplusplus }
