--- ray/src/common/bsdf.h 2011/02/18 02:41:55 2.5 +++ ray/src/common/bsdf.h 2011/02/19 23:42:09 2.7 @@ -1,4 +1,4 @@ -/* RCSid $Id: bsdf.h,v 2.5 2011/02/18 02:41:55 greg Exp $ */ +/* RCSid $Id: bsdf.h,v 2.7 2011/02/19 23:42:09 greg Exp $ */ /* * bsdf.h * @@ -40,10 +40,9 @@ extern "C" { #define SDsampAll 0xF /* include everything */ /* Projected solid angle query flags fos SDsizeBSDF() */ -#define SDqueryInc 0x1 /* query incoming vector */ -#define SDqueryOut 0x2 /* query outgoing vector */ -#define SDqueryMin 0x4 /* query minimum proj. solid angle */ -#define SDqueryMax 0x8 /* query maximum proj. solid angle */ +#define SDqueryVal 0x0 /* query single value */ +#define SDqueryMin 0x1 /* query minimum proj. solid angle */ +#define SDqueryMax 0x2 /* query maximum proj. solid angle */ /* Error codes: normal return, out of memory, file i/o, file format, bad argument, bad data, unsupported feature, internal error, unknown error */ @@ -136,7 +135,7 @@ extern int SDretainSet; /* set to SDretainNone by def * The following routines are less commonly used by applications. */ -#define SDisLoaded(sd) ((sd)->rLambFront.spec.clock != 0) +#define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0) /* Report an error to the indicated stream (in English) */ extern SDError SDreportEnglish(SDError ec, FILE *fp);
