root/radiance/ray/src/common/bsdf.h
Sat Jun 7 05:09:45 2025 UTC (12 days, 23 hours ago) by greg
Changes since 2.30: +2 -3 lines
Diff to previous 2.30 , to selected 2.28
Mon Dec 13 21:05:00 2021 UTC (3 years, 6 months ago) by greg
Changes since 2.29: +1 -7 lines
Diff to previous 2.29 , to selected 2.28
refactor: moved SDdisk2square() and SDsquare2disk() declarations to fvect.h
Tue Dec 7 23:49:50 2021 UTC (3 years, 6 months ago) by greg
Changes since 2.28: +5 -5 lines
Diff to previous 2.28
Revision 2.28 - (view) (download) (annotate) - [selected]
Sat Mar 27 17:50:18 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.27: +3 -2 lines
Diff to previous 2.27
Thu May 14 19:20:13 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.26: +2 -1 lines
Diff to previous 2.26 , to selected 2.28
Added cumulative cache size limit (per loaded BSDF)
Fri Jan 5 21:00:24 2018 UTC (7 years, 5 months ago) by greg
Changes since 2.25: +2 -9 lines
Diff to previous 2.25 , to selected 2.28
Fix for C++ compilers, which don't like "typedef const struct"
Fri Jan 5 20:15:50 2018 UTC (7 years, 5 months ago) by schorsch
Changes since 2.24: +8 -1 lines
Diff to previous 2.24 , to selected 2.28
Shut up c++ compiler warning
Sun Mar 6 01:13:17 2016 UTC (9 years, 3 months ago) by schorsch
Changes since 2.23: +2 -5 lines
Diff to previous 2.23 , to selected 2.28
Wed Feb 3 01:54:51 2016 UTC (9 years, 4 months ago) by greg
Diff to previous 2.22 , to selected 2.28
Switched to double for device dimensions
Sun Apr 21 21:36:23 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.21: +9 -6 lines
Diff to previous 2.21 , to selected 2.28
Added pointer indirection to make error reporting in other languages simpler
Sat Jan 26 04:00:25 2013 UTC (12 years, 4 months ago) by greg
Diff to previous 2.20 , to selected 2.28
Added missing (but implied) "extern" modifiers
Sat Oct 13 20:15:43 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.19: +1 -61 lines
Diff to previous 2.19 , to selected 2.28
Sun Sep 2 15:33:15 2012 UTC (12 years, 9 months ago) by greg
Changes since 2.18: +5 -2 lines
Diff to previous 2.18 , to selected 2.28
Mon Mar 5 00:17:06 2012 UTC (13 years, 3 months ago) by greg
Changes since 2.17: +3 -1 lines
Diff to previous 2.17 , to selected 2.28
Added recording of product and manufacturer names
Sun Mar 4 20:11:10 2012 UTC (13 years, 3 months ago) by greg
Diff to previous 2.16 , to selected 2.28
Added routine for adding spectral distribution components
Sun Aug 21 22:38:12 2011 UTC (13 years, 10 months ago) by greg
Diff to previous 2.15 , to selected 2.28
Minor improvements to direct specular sampling
Thu Jun 9 17:09:39 2011 UTC (14 years ago) by greg
Changes since 2.14: +5 -1 lines
Diff to previous 2.14 , to selected 2.28
Fixes for Windows and bug fix in bsdf_m.c
Wed Jun 8 15:37:46 2011 UTC (14 years ago) by greg
Diff to previous 2.13 , to selected 2.28
Stratified specular sampling with -ss > 1
Sun Jun 5 20:27:14 2011 UTC (14 years ago) by greg
Changes since 2.12: +10 -10 lines
Diff to previous 2.12 , to selected 2.28
Fixed comments and potential bug in BSDF tree traversal
Sun Apr 24 19:39:21 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.11: +7 -9 lines
Diff to previous 2.11 , to selected 2.28
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.10: +8 -6 lines
Diff to previous 2.10 , to selected 2.28
Fixed interface for determining BSDF solid angles
Mon Apr 11 03:47:46 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.9: +3 -3 lines
Diff to previous 2.9 , to selected 2.28
Final fix to Klems angles -- I hope
Wed Feb 23 21:58:31 2011 UTC (14 years, 3 months ago) by greg
Diff to previous 2.8 , to selected 2.28
Fixed issue with coordinate orientation for front transmission
Mon Feb 21 22:50:37 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.7: +6 -1 lines
Diff to previous 2.7 , to selected 2.28
Corrected notion of "front" and "back" to coincide with surface normals
Sat Feb 19 23:42:09 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.6: +4 -5 lines
Diff to previous 2.6 , to selected 2.28
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 2.5 , to selected 2.28
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.4: +7 -1 lines
Diff to previous 2.4 , to selected 2.28
Minor fixes and adjustments
Fri Feb 18 00:40:25 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.3: +246 -13 lines
Diff to previous 2.3 , to selected 2.28
Fri Sep 3 23:53:50 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.2: +4 -2 lines
Diff to previous 2.2 , to selected 2.28
Mon Jun 14 22:02:22 2010 UTC (15 years ago) by greg
Diff to previous 2.1 , to selected 2.28
Added #ifdef for inclusion
Wed Jun 17 20:41:47 2009 UTC (16 years ago) by greg
Diff to selected 2.28
