--- ray/src/common/bsdf.h 2011/02/23 21:58:31 2.9 +++ ray/src/common/bsdf.h 2011/08/21 22:38:12 2.16 @@ -1,4 +1,4 @@ -/* RCSid $Id: bsdf.h,v 2.9 2011/02/23 21:58:31 greg Exp $ */ +/* RCSid $Id: bsdf.h,v 2.16 2011/08/21 22:38:12 greg Exp $ */ /* * bsdf.h * @@ -14,7 +14,7 @@ * in the +Z direction, towards the interior of the space rather * than the exterior. * - * BSDF vectors always oriented away from surface, even when "incident." + * BSDF incident & exiting vectors are always oriented away from surface. * * Created by Greg Ward on 1/10/11. * @@ -30,6 +30,10 @@ extern "C" { #endif +#ifdef _WIN32 +#define strcasecmp stricmp +#endif + #define SDnameLn 128 /* maximum BSDF name length */ #define SDmaxCh 3 /* maximum # spectral channels */ @@ -67,10 +71,10 @@ typedef struct { } SDValue; /* Cached, encoded, cumulative distribution for one incident (solid) angle */ -#define SD_CDIST_BASE double cTotal; \ - struct SDCDst_s *next +#define SD_CDIST_BASE(styp) double cTotal; \ + struct styp *next typedef struct SDCDst_s { - SD_CDIST_BASE; /* base fields first */ + SD_CDIST_BASE(SDCDst_s); /* base fields first */ /* ...encoded distribution extends struct */ } SDCDst; @@ -81,14 +85,15 @@ typedef struct SDComp_s SDComponent; typedef const struct { /* return non-diffuse BSDF */ int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec, - const FVECT inVec, const void *dist); + const FVECT inVec, SDComponent *sdc); /* query non-diffuse PSA for vector */ - SDError (*queryProjSA)(double *psa, const FVECT vec, - int qflags, const void *dist); + SDError (*queryProjSA)(double *psa, const FVECT v1, + const RREAL *v2, int qflags, + SDComponent *sdc); /* get cumulative distribution */ const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc); /* sample cumulative distribution */ - SDError (*sampCDist)(FVECT outVec, double randX, + SDError (*sampCDist)(FVECT ioVec, double randX, const SDCDst *cdp); /* free a spectral BSDF component */ void (*freeSC)(void *dist); @@ -112,7 +117,7 @@ typedef struct { /* Loaded BSDF data */ typedef struct { - char name[SDnameLn]; /* BSDF name (derived from file) */ + char name[SDnameLn]; /* BSDF name (usu. derived from file) */ char *mgf; /* geometric description (if any) */ float dim[3]; /* width, height, thickness (meters) */ SDValue rLambFront; /* diffuse front reflectance */ @@ -129,12 +134,12 @@ extern struct SDCache_s { *next; } *SDcacheList; /* Global BSDF cache */ -/* BSDF cache retention preference */ -#define SDretainNone 0 /* free unreferenced data (default) */ -#define SDretainBSDFs 1 /* keep loaded BSDFs in cache */ +/* BSDF cache retention policies */ +#define SDretainNone 0 /* free unreferenced BSDF data */ +#define SDretainBSDFs 1 /* keep loaded BSDFs in memory */ #define SDretainAll 2 /* also keep cumulative cache data */ -extern int SDretainSet; /* set to SDretainNone by default */ +extern int SDretainSet; /* =SDretainNone by default */ /***************************************************************** * The following routines are less commonly used by applications. @@ -154,8 +159,8 @@ extern SDSpectralDF *SDnewSpectralDF(int nc); /* Free a spectral distribution function */ extern void SDfreeSpectralDF(SDSpectralDF *df); -/* Initialize an unused BSDF struct (clears to zeroes) */ -extern void SDclearBSDF(SDData *sd); +/* Initialize an unused BSDF struct and assign name (calls SDclipName) */ +extern void SDclearBSDF(SDData *sd, const char *fname); /* Load a BSDF struct from the given file (keeps name unchanged) */ extern SDError SDloadFile(SDData *sd, const char *fname); @@ -170,9 +175,8 @@ extern SDData *SDgetCache(const char *bname); extern void SDfreeCumulativeCache(SDSpectralDF *df); /* Sample an individual BSDF component */ -extern SDError SDsampComponent(SDValue *sv, FVECT outVec, - const FVECT inVec, double randX, - SDComponent *sdc); +extern SDError SDsampComponent(SDValue *sv, FVECT ioVec, + double randX, SDComponent *sdc); /* Convert 1-dimensional random variable to N-dimensional */ extern void SDmultiSamp(double t[], int n, double randX); @@ -189,15 +193,16 @@ void SDdisk2square(double sq[2], double diskx, doubl */ /* Get BSDF from cache (or load and cache it on first call) */ -/* Report any problems to stderr and return NULL on failure */ +/* Report any problems to stderr (in English), return NULL on failure */ extern const SDData *SDcacheFile(const char *fname); -/* Free a BSDF from our cache (clear all if NULL) */ +/* Free a BSDF from our cache (clear all if sd==NULL) */ extern void SDfreeCache(const SDData *sd); -/* Query projected solid angle resolution for non-diffuse BSDF direction */ -extern SDError SDsizeBSDF(double *projSA, const FVECT vec, - int qflags, const SDData *sd); +/* Query projected solid angle resolution for non-diffuse BSDF direction(s) */ +extern SDError SDsizeBSDF(double *projSA, const FVECT v1, + const RREAL *v2, int qflags, + const SDData *sd); /* Return BSDF for the given incident and scattered ray vectors */ extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec, @@ -208,8 +213,7 @@ extern double SDdirectHemi(const FVECT inVec, int sflags, const SDData *sd); /* Sample BSDF direction based on the given random variable */ -extern SDError SDsampBSDF(SDValue *sv, FVECT outVec, - const FVECT inVec, double randX, +extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int sflags, const SDData *sd); /***************************************************************** @@ -217,7 +221,7 @@ extern SDError SDsampBSDF(SDValue *sv, FVECT outVec, * Directions may be passed unnormalized to these routines. */ -/* Compute World->BSDF transform from surface normal and up (Y) vector */ +/* Compute World->BSDF transform from surface normal and BSDF up vector */ extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, const FVECT uVec); @@ -228,10 +232,10 @@ extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMt extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT inpVec); -/* System-specific BSDF loading routine (not part of our library) */ +/* Application-specific BSDF loading routine (not part of our library) */ extern SDData *loadBSDF(char *name); -/* System-specific BSDF error translator (not part of our library) */ +/* Application-specific BSDF error translator (not part of our library) */ extern char *transSDError(SDError ec); /*################################################################*/
