root/radiance/ray/src/common/bsdf.h
Revision: 2.3
Committed: Fri Sep 3 23:53:50 2010 UTC (14 years, 11 months ago) by greg
Changes since 2.2: +4 -2 lines
1 /* RCSid $Id: bsdf.h,v 2.2 2010/06/14 22:02:22 greg Exp $ */
2 /*
3 * Header for BSDF i/o and access routines
4 */
5
6 #ifndef _RAD_BSDF_H_
7 #define _RAD_BSDF_H_
8 /* up directions */
9 typedef enum {
10 UDzneg=-3,
11 UDyneg=-2,
12 UDxneg=-1,
13 UDunknown=0,
14 UDxpos=1,
15 UDypos=2,
16 UDzpos=3
17 } UpDir;
18 /* BSDF coordinate calculation routines */
19 /* vectors always point away from surface */
20 typedef int b_vecf(FVECT, int, void *);
21 typedef int b_ndxf(FVECT, void *);
22 typedef double b_radf(int, void *);
23
24 /* Bidirectional Scattering Distribution Function */
25 struct BSDF_data {
26 int ninc; /* number of incoming directions */
27 int nout; /* number of outgoing directions */
28 float dim[3]; /* width, height, thickness (meters) */
29 char *mgf; /* geometric description (if any) */
30 void *ib_priv; /* input basis private data */
31 b_vecf *ib_vec; /* get input vector from index */
32 b_ndxf *ib_ndx; /* get input index from vector */
33 b_radf *ib_ohm; /* get input radius for index */
34 void *ob_priv; /* output basis private data */
35 b_vecf *ob_vec; /* get output vector from index */
36 b_ndxf *ob_ndx; /* get output index from vector */
37 b_radf *ob_ohm; /* get output radius for index */
38 float *bsdf; /* scattering distribution data */
39 }; /* bidirectional scattering distrib. func. */
40
41 #define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
42 #define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
43 #define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
44 #define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
45 #define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
46 #define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
47 #define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
48
49 extern struct BSDF_data *load_BSDF(char *fname);
50 extern void free_BSDF(struct BSDF_data *b);
51 extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i,
52 double rv, MAT4 xm);
53 extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o,
54 double rv, MAT4 xm);
55 extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud, char *xfbuf);
56
57 #endif /* ! _RAD_BSDF_H_ */
