root/Development/ray/src/common/bsdf.h
Revision: 2.27
Committed: Thu May 14 19:20:13 2020 UTC (5 years, 7 months ago) by greg
Changes since 2.26: +2 -1 lines
Added cumulative cache size limit (per loaded BSDF)
# User Rev Content
1 greg 2.27 /* RCSid $Id: bsdf.h,v 2.26 2018/01/05 21:00:24 greg Exp $ */
2 greg 2.4 /*
3     * bsdf.h
4     *
5     * Declarations for bidirectional scattering distribution functions.
6     * Assumes <stdio.h> already included.
7     *
8     * A material is oriented in right-hand coordinate system with X-axis
9     * in the surface plane pointed to the right as seen from the front.
10     * This means the Y-axis is "up" and the Z-axis is the surface normal.
11     *
12 greg 2.8 * Note that we reverse the identification of "front" and "back" from
13     * the conventions used in WINDOW 6. "Front" in our library points
14     * in the +Z direction, towards the interior of the space rather
15     * than the exterior.
16     *
17 greg 2.13 * BSDF incident & exiting vectors are always oriented away from surface.
18 greg 2.4 *
19     * Created by Greg Ward on 1/10/11.
20     *
21     */
22
23     #ifndef _BSDF_H_
24     #define _BSDF_H_
25
26     #include "fvect.h"
27     #include "ccolor.h"
28 schorsch 2.24 #include "platform.h"
29 greg 2.4
30     #ifdef __cplusplus
31     extern "C" {
32     #endif
33
34     #define SDnameLn 128 /* maximum BSDF name length */
35     #define SDmaxCh 3 /* maximum # spectral channels */
36
37 greg 2.9 /* Component flags for SDsampBSDF() and SDdirectHemi() */
38 greg 2.4 #define SDsampR 0x1 /* include reflection */
39     #define SDsampT 0x2 /* include transmission */
40     #define SDsampS 0x3 /* include scattering (R+T) */
41     #define SDsampSp 0x4 /* include non-diffuse portion */
42     #define SDsampDf 0x8 /* include diffuse portion */
43     #define SDsampSpR 0x5 /* include non-diffuse reflection */
44     #define SDsampSpT 0x6 /* include non-diffuse transmission */
45     #define SDsampSpS 0x7 /* include non-diffuse scattering */
46     #define SDsampAll 0xF /* include everything */
47
48 greg 2.9 /* Projected solid angle query flags for SDsizeBSDF() */
49 greg 2.7 #define SDqueryVal 0x0 /* query single value */
50     #define SDqueryMin 0x1 /* query minimum proj. solid angle */
51     #define SDqueryMax 0x2 /* query maximum proj. solid angle */
52 greg 2.4
53     /* Error codes: normal return, out of memory, file i/o, file format, bad argument,
54     bad data, unsupported feature, internal error, unknown error */
55     typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
56     SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
57
58 greg 2.22 /* English strings corresponding to ennumerated errors */
59 greg 2.4 extern const char *SDerrorEnglish[];
60
61 greg 2.22 /* Pointer to error list in preferred language */
62     extern const char **SDerrorList;
63
64     /* Additional information on last error (generally in English) */
65 greg 2.4 extern char SDerrorDetail[];
66
67     /* Holder for BSDF value and spectral color */
68     typedef struct {
69     double cieY; /* photopic BSDF (Y) value */
70     C_COLOR spec; /* spectral and (x,y) color */
71     } SDValue;
72
73     /* Cached, encoded, cumulative distribution for one incident (solid) angle */
74 greg 2.16 #define SD_CDIST_BASE(styp) double cTotal; \
75     struct styp *next
76 greg 2.4 typedef struct SDCDst_s {
77 greg 2.16 SD_CDIST_BASE(SDCDst_s); /* base fields first */
78 greg 2.4 /* ...encoded distribution extends struct */
79     } SDCDst;
80
81 greg 2.19 extern const SDCDst SDemptyCD; /* empty distribution */
82
83 greg 2.4 /* Forward declaration of BSDF component */
84     typedef struct SDComp_s SDComponent;
85
86     /* Methods needed to handle BSDF components (nothing is optional) */
87 schorsch 2.25 typedef struct {
88 greg 2.4 /* return non-diffuse BSDF */
89     int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec,
90 greg 2.12 const FVECT inVec, SDComponent *sdc);
91 greg 2.4 /* query non-diffuse PSA for vector */
92 greg 2.11 SDError (*queryProjSA)(double *psa, const FVECT v1,
93     const RREAL *v2, int qflags,
94 greg 2.12 SDComponent *sdc);
95 greg 2.4 /* get cumulative distribution */
96     const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
97     /* sample cumulative distribution */
98 greg 2.12 SDError (*sampCDist)(FVECT ioVec, double randX,
99 greg 2.4 const SDCDst *cdp);
100     /* free a spectral BSDF component */
101     void (*freeSC)(void *dist);
102     } SDFunc;
103
104     /* Structure to hold a spectral BSDF component (typedef SDComponent above) */
105     struct SDComp_s {
106     C_COLOR cspec[SDmaxCh]; /* component spectral bases */
107 greg 2.26 const SDFunc *func; /* methods for this component */
108 greg 2.4 void *dist; /* loaded distribution data */
109     SDCDst *cdList; /* cumulative distribution cache */
110     };
111
112     /* Container for non-diffuse BSDF components */
113     typedef struct {
114     double minProjSA; /* minimum projected solid angle */
115     double maxHemi; /* maximum directional hemispherical */
116     int ncomp; /* number of separate components */
117     SDComponent comp[1]; /* BSDF components (extends struct) */
118     } SDSpectralDF;
119
120     /* Loaded BSDF data */
121     typedef struct {
122 greg 2.13 char name[SDnameLn]; /* BSDF name (usu. derived from file) */
123 greg 2.18 char matn[SDnameLn]; /* material name */
124     char makr[SDnameLn]; /* manufacturer */
125 greg 2.4 char *mgf; /* geometric description (if any) */
126 greg 2.23 double dim[3]; /* width, height, thickness (meters) */
127 greg 2.4 SDValue rLambFront; /* diffuse front reflectance */
128     SDValue rLambBack; /* diffuse rear reflectance */
129     SDValue tLamb; /* diffuse transmission */
130 greg 2.19 SDSpectralDF *rf, *rb; /* non-diffuse BRDF components */
131     SDSpectralDF *tf, *tb; /* non-diffuse BTDF components */
132 greg 2.4 } SDData;
133
134     /* List of loaded BSDFs */
135     extern struct SDCache_s {
136     SDData bsdf; /* BSDF data */
137     unsigned refcnt; /* how many callers are using us? */
138     struct SDCache_s /* next in cache list */
139     *next;
140     } *SDcacheList; /* Global BSDF cache */
141
142 greg 2.14 /* BSDF cache retention policies */
143     #define SDretainNone 0 /* free unreferenced BSDF data */
144     #define SDretainBSDFs 1 /* keep loaded BSDFs in memory */
145 greg 2.4 #define SDretainAll 2 /* also keep cumulative cache data */
146
147 greg 2.13 extern int SDretainSet; /* =SDretainNone by default */
148 greg 2.27 extern unsigned long SDmaxCache; /* =0 (unlimited) by default */
149 greg 2.4
150     /*****************************************************************
151     * The following routines are less commonly used by applications.
152     */
153
154 greg 2.6 #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
155 greg 2.4
156 greg 2.22 /* Report an error to the indicated stream */
157     extern SDError SDreportError(SDError ec, FILE *fp);
158 greg 2.4
159     /* Shorten file path to useable BSDF name, removing suffix */
160     extern void SDclipName(char res[SDnameLn], const char *fname);
161
162     /* Allocate new spectral distribution function */
163     extern SDSpectralDF *SDnewSpectralDF(int nc);
164
165 greg 2.17 /* Add component(s) to spectral distribution function */
166     extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd);
167
168 greg 2.4 /* Free a spectral distribution function */
169     extern void SDfreeSpectralDF(SDSpectralDF *df);
170
171 greg 2.10 /* Initialize an unused BSDF struct and assign name (calls SDclipName) */
172     extern void SDclearBSDF(SDData *sd, const char *fname);
173 greg 2.4
174     /* Load a BSDF struct from the given file (keeps name unchanged) */
175     extern SDError SDloadFile(SDData *sd, const char *fname);
176
177     /* Free data associated with BSDF struct */
178     extern void SDfreeBSDF(SDData *sd);
179
180     /* Find writeable BSDF by name, or allocate new cache entry if absent */
181     extern SDData *SDgetCache(const char *bname);
182
183     /* Free cached cumulative distributions for BSDF component */
184     extern void SDfreeCumulativeCache(SDSpectralDF *df);
185
186     /* Sample an individual BSDF component */
187 greg 2.12 extern SDError SDsampComponent(SDValue *sv, FVECT ioVec,
188     double randX, SDComponent *sdc);
189 greg 2.4
190     /* Convert 1-dimensional random variable to N-dimensional */
191     extern void SDmultiSamp(double t[], int n, double randX);
192
193     /* Map a [0,1]^2 square to a unit radius disk */
194 greg 2.21 extern void SDsquare2disk(double ds[2], double seedx, double seedy);
195 greg 2.4
196     /* Map point on unit disk to a unit square in [0,1]^2 range */
197 greg 2.21 extern void SDdisk2square(double sq[2], double diskx, double disky);
198 greg 2.4
199     /*****************************************************************
200     * The calls below are the ones most applications require.
201     * All directions are assumed to be unit vectors.
202     */
203
204     /* Get BSDF from cache (or load and cache it on first call) */
205 greg 2.22 /* Report any problems to stderr, return NULL on failure */
206 greg 2.4 extern const SDData *SDcacheFile(const char *fname);
207
208 greg 2.13 /* Free a BSDF from our cache (clear all if sd==NULL) */
209 greg 2.4 extern void SDfreeCache(const SDData *sd);
210
211 greg 2.11 /* Query projected solid angle resolution for non-diffuse BSDF direction(s) */
212     extern SDError SDsizeBSDF(double *projSA, const FVECT v1,
213     const RREAL *v2, int qflags,
214     const SDData *sd);
215 greg 2.4
216     /* Return BSDF for the given incident and scattered ray vectors */
217     extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec,
218     const FVECT inVec, const SDData *sd);
219
220     /* Compute directional hemispherical scattering at given incident angle */
221     extern double SDdirectHemi(const FVECT inVec,
222     int sflags, const SDData *sd);
223
224     /* Sample BSDF direction based on the given random variable */
225 greg 2.12 extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX,
226 greg 2.4 int sflags, const SDData *sd);
227
228     /*****************************************************************
229     * Vector math for getting between world and local BSDF coordinates.
230     * Directions may be passed unnormalized to these routines.
231     */
232
233 greg 2.13 /* Compute World->BSDF transform from surface normal and BSDF up vector */
234 greg 2.4 extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
235     const FVECT uVec);
236
237     /* Compute inverse transform */
238     extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
239
240     /* Transform and normalize direction (column) vector */
241     extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
242     const FVECT inpVec);
243
244 greg 2.13 /* Application-specific BSDF loading routine (not part of our library) */
245 greg 2.5 extern SDData *loadBSDF(char *name);
246
247 greg 2.13 /* Application-specific BSDF error translator (not part of our library) */
248 greg 2.5 extern char *transSDError(SDError ec);
249
250 greg 2.4 #ifdef __cplusplus
251     }
252     #endif
253     #endif /* ! _BSDF_H_ */
