root/radiance/ray/src/common/bsdf.h
Revision: 2.7
Committed: Sat Feb 19 23:42:09 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.6: +4 -5 lines
Fixes to BSDF including blurring of angle boundaries
1 /* RCSid $Id: bsdf.h,v 2.6 2011/02/19 01:48:59 greg Exp $ */
2 /*
3 * bsdf.h
4 *
5 * Declarations for bidirectional scattering distribution functions.
6 * Assumes <stdio.h> already included.
7 *
8 * A material is oriented in right-hand coordinate system with X-axis
9 * in the surface plane pointed to the right as seen from the front.
10 * This means the Y-axis is "up" and the Z-axis is the surface normal.
11 *
12 * BSDF vectors always oriented away from surface, even when "incident."
13 *
14 * Created by Greg Ward on 1/10/11.
15 *
16 */
17
18 #ifndef _BSDF_H_
19 #define _BSDF_H_
20
21 #include "fvect.h"
22 #include "ccolor.h"
23
24 #ifdef __cplusplus
25 extern "C" {
26 #endif
27
28 #define SDnameLn 128 /* maximum BSDF name length */
29 #define SDmaxCh 3 /* maximum # spectral channels */
30
31 /* Component flags for SDsampBSDF() and SDhemiScatter() */
32 #define SDsampR 0x1 /* include reflection */
33 #define SDsampT 0x2 /* include transmission */
34 #define SDsampS 0x3 /* include scattering (R+T) */
35 #define SDsampSp 0x4 /* include non-diffuse portion */
36 #define SDsampDf 0x8 /* include diffuse portion */
37 #define SDsampSpR 0x5 /* include non-diffuse reflection */
38 #define SDsampSpT 0x6 /* include non-diffuse transmission */
39 #define SDsampSpS 0x7 /* include non-diffuse scattering */
40 #define SDsampAll 0xF /* include everything */
41
42 /* Projected solid angle query flags fos SDsizeBSDF() */
43 #define SDqueryVal 0x0 /* query single value */
44 #define SDqueryMin 0x1 /* query minimum proj. solid angle */
45 #define SDqueryMax 0x2 /* query maximum proj. solid angle */
46
47 /* Error codes: normal return, out of memory, file i/o, file format, bad argument,
48 bad data, unsupported feature, internal error, unknown error */
49 typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
50 SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
51
52 /* English ASCII strings corresponding to ennumerated errors */
53 extern const char *SDerrorEnglish[];
54
55 /* Additional information on last error (ASCII English) */
56 extern char SDerrorDetail[];
57
58 /* Holder for BSDF value and spectral color */
59 typedef struct {
60 double cieY; /* photopic BSDF (Y) value */
61 C_COLOR spec; /* spectral and (x,y) color */
62 } SDValue;
63
64 /* Cached, encoded, cumulative distribution for one incident (solid) angle */
65 #define SD_CDIST_BASE double cTotal; \
66 struct SDCDst_s *next
67 typedef struct SDCDst_s {
68 SD_CDIST_BASE; /* base fields first */
69 /* ...encoded distribution extends struct */
70 } SDCDst;
71
72 /* Forward declaration of BSDF component */
73 typedef struct SDComp_s SDComponent;
74
75 /* Methods needed to handle BSDF components (nothing is optional) */
76 typedef const struct {
77 /* return non-diffuse BSDF */
78 int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec,
79 const FVECT inVec, const void *dist);
80 /* query non-diffuse PSA for vector */
81 SDError (*queryProjSA)(double *psa, const FVECT vec,
82 int qflags, const void *dist);
83 /* get cumulative distribution */
84 const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
85 /* sample cumulative distribution */
86 SDError (*sampCDist)(FVECT outVec, double randX,
87 const SDCDst *cdp);
88 /* free a spectral BSDF component */
89 void (*freeSC)(void *dist);
90 } SDFunc;
91
92 /* Structure to hold a spectral BSDF component (typedef SDComponent above) */
93 struct SDComp_s {
94 C_COLOR cspec[SDmaxCh]; /* component spectral bases */
95 SDFunc *func; /* methods for this component */
96 void *dist; /* loaded distribution data */
97 SDCDst *cdList; /* cumulative distribution cache */
98 };
99
100 /* Container for non-diffuse BSDF components */
101 typedef struct {
102 double minProjSA; /* minimum projected solid angle */
103 double maxHemi; /* maximum directional hemispherical */
104 int ncomp; /* number of separate components */
105 SDComponent comp[1]; /* BSDF components (extends struct) */
106 } SDSpectralDF;
107
108 /* Loaded BSDF data */
109 typedef struct {
110 char name[SDnameLn]; /* BSDF name (derived from file) */
111 char *mgf; /* geometric description (if any) */
112 float dim[3]; /* width, height, thickness (meters) */
113 SDValue rLambFront; /* diffuse front reflectance */
114 SDValue rLambBack; /* diffuse rear reflectance */
115 SDValue tLamb; /* diffuse transmission */
116 SDSpectralDF *rf, *rb, *tf; /* non-diffuse BSDF components */
117 } SDData;
118
119 /* List of loaded BSDFs */
120 extern struct SDCache_s {
121 SDData bsdf; /* BSDF data */
122 unsigned refcnt; /* how many callers are using us? */
123 struct SDCache_s /* next in cache list */
124 *next;
125 } *SDcacheList; /* Global BSDF cache */
126
127 /* BSDF cache retention preference */
128 #define SDretainNone 0 /* free unreferenced data (default) */
129 #define SDretainBSDFs 1 /* keep loaded BSDFs in cache */
130 #define SDretainAll 2 /* also keep cumulative cache data */
131
132 extern int SDretainSet; /* set to SDretainNone by default */
133
134 /*****************************************************************
135 * The following routines are less commonly used by applications.
136 */
137
138 #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
139
140 /* Report an error to the indicated stream (in English) */
141 extern SDError SDreportEnglish(SDError ec, FILE *fp);
142
143 /* Shorten file path to useable BSDF name, removing suffix */
144 extern void SDclipName(char res[SDnameLn], const char *fname);
145
146 /* Allocate new spectral distribution function */
147 extern SDSpectralDF *SDnewSpectralDF(int nc);
148
149 /* Free a spectral distribution function */
150 extern void SDfreeSpectralDF(SDSpectralDF *df);
151
152 /* Initialize an unused BSDF struct (clears to zeroes) */
153 extern void SDclearBSDF(SDData *sd);
154
155 /* Load a BSDF struct from the given file (keeps name unchanged) */
156 extern SDError SDloadFile(SDData *sd, const char *fname);
157
158 /* Free data associated with BSDF struct */
159 extern void SDfreeBSDF(SDData *sd);
160
161 /* Find writeable BSDF by name, or allocate new cache entry if absent */
162 extern SDData *SDgetCache(const char *bname);
163
164 /* Free cached cumulative distributions for BSDF component */
165 extern void SDfreeCumulativeCache(SDSpectralDF *df);
166
167 /* Sample an individual BSDF component */
168 extern SDError SDsampComponent(SDValue *sv, FVECT outVec,
169 const FVECT inVec, double randX,
170 SDComponent *sdc);
171
172 /* Convert 1-dimensional random variable to N-dimensional */
173 extern void SDmultiSamp(double t[], int n, double randX);
174
175 /* Map a [0,1]^2 square to a unit radius disk */
176 void SDsquare2disk(double ds[2], double seedx, double seedy);
177
178 /* Map point on unit disk to a unit square in [0,1]^2 range */
179 void SDdisk2square(double sq[2], double diskx, double disky);
180
181 /*****************************************************************
182 * The calls below are the ones most applications require.
183 * All directions are assumed to be unit vectors.
184 */
185
186 /* Get BSDF from cache (or load and cache it on first call) */
187 /* Report any problems to stderr and return NULL on failure */
188 extern const SDData *SDcacheFile(const char *fname);
189
190 /* Free a BSDF from our cache (clear all if NULL) */
191 extern void SDfreeCache(const SDData *sd);
192
193 /* Query projected solid angle resolution for non-diffuse BSDF direction */
194 extern SDError SDsizeBSDF(double *projSA, const FVECT vec,
195 int qflags, const SDData *sd);
196
197 /* Return BSDF for the given incident and scattered ray vectors */
198 extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec,
199 const FVECT inVec, const SDData *sd);
200
201 /* Compute directional hemispherical scattering at given incident angle */
202 extern double SDdirectHemi(const FVECT inVec,
203 int sflags, const SDData *sd);
204
205 /* Sample BSDF direction based on the given random variable */
206 extern SDError SDsampBSDF(SDValue *sv, FVECT outVec,
207 const FVECT inVec, double randX,
208 int sflags, const SDData *sd);
209
210 /*****************************************************************
211 * Vector math for getting between world and local BSDF coordinates.
212 * Directions may be passed unnormalized to these routines.
213 */
214
215 /* Compute World->BSDF transform from surface normal and up (Y) vector */
216 extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
217 const FVECT uVec);
218
219 /* Compute inverse transform */
220 extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
221
222 /* Transform and normalize direction (column) vector */
223 extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
224 const FVECT inpVec);
225
226 /* System-specific BSDF loading routine (not part of our library) */
227 extern SDData *loadBSDF(char *name);
228
229 /* System-specific BSDF error translator (not part of our library) */
230 extern char *transSDError(SDError ec);
231
232 /*################################################################*/
233 /*######### DEPRECATED DEFINITIONS AWAITING PERMANENT REMOVAL #######*/
234 /*
235 * Header for BSDF i/o and access routines
236 */
237
238 #include "mat4.h"
239 /* up directions */
240 typedef enum {
241 UDzneg=-3,
242 UDyneg=-2,
243 UDxneg=-1,
244 UDunknown=0,
245 UDxpos=1,
246 UDypos=2,
247 UDzpos=3
248 } UpDir;
249 /* BSDF coordinate calculation routines */
250 /* vectors always point away from surface */
251
252 typedef int b_vecf2(FVECT v, int n, void *cd);
253 typedef int b_ndxf2(FVECT v, void *cd);
254 typedef double b_radf2(int n, void *cd);
255
256 /* Bidirectional Scattering Distribution Function */
257 struct BSDF_data {
258 int ninc; /* number of incoming directions */
259 int nout; /* number of outgoing directions */
260 float dim[3]; /* width, height, thickness (meters) */
261 char *mgf; /* geometric description (if any) */
262 void *ib_priv; /* input basis private data */
263 b_vecf2 *ib_vec; /* get input vector from index */
264 b_ndxf2 *ib_ndx; /* get input index from vector */
265 b_radf2 *ib_ohm; /* get input radius for index */
266 void *ob_priv; /* output basis private data */
267 b_vecf2 *ob_vec; /* get output vector from index */
268 b_ndxf2 *ob_ndx; /* get output index from vector */
269 b_radf2 *ob_ohm; /* get output radius for index */
270 float *bsdf; /* scattering distribution data */
271 }; /* bidirectional scattering distrib. func. */
272
273 #define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
274 #define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
275 #define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
276 #define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
277 #define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
278 #define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
279 #define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
280
281 extern struct BSDF_data *load_BSDF(char *fname);
282 extern void free_BSDF(struct BSDF_data *b);
283 extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i,
284 double rv, MAT4 xm);
285 extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o,
286 double rv, MAT4 xm);
287 extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud, char *xfbuf);
288
289 /*######### END DEPRECATED DEFINITIONS #######*/
290 /*################################################################*/
291
292 #ifdef __cplusplus
293 }
294 #endif
295 #endif /* ! _BSDF_H_ */
