root/radiance/ray/src/common/bsdf.h
Sun Apr 21 21:36:23 2013 UTC (11 years, 1 month ago) by greg
Changes since 2.21: +9 -6 lines
Diff to previous 2.21 , to selected 2.10
Added pointer indirection to make error reporting in other languages simpler
Sat Jan 26 04:00:25 2013 UTC (11 years, 3 months ago) by greg
Diff to previous 2.20 , to selected 2.10
Added missing (but implied) "extern" modifiers
Sat Oct 13 20:15:43 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.19: +1 -61 lines
Diff to previous 2.19 , to selected 2.10
Sun Sep 2 15:33:15 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.18: +5 -2 lines
Diff to previous 2.18 , to selected 2.10
Mon Mar 5 00:17:06 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.17: +3 -1 lines
Diff to previous 2.17 , to selected 2.10
Added recording of product and manufacturer names
Sun Mar 4 20:11:10 2012 UTC (12 years, 2 months ago) by greg
Diff to previous 2.16 , to selected 2.10
Added routine for adding spectral distribution components
Sun Aug 21 22:38:12 2011 UTC (12 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.10
Minor improvements to direct specular sampling
Thu Jun 9 17:09:39 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.14: +5 -1 lines
Fixes for Windows and bug fix in bsdf_m.c
Wed Jun 8 15:37:46 2011 UTC (12 years, 11 months ago) by greg
Stratified specular sampling with -ss > 1
Sun Jun 5 20:27:14 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.12: +10 -10 lines
Fixed comments and potential bug in BSDF tree traversal
Sun Apr 24 19:39:21 2011 UTC (13 years ago) by greg
Changes since 2.11: +7 -9 lines
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.10: +8 -6 lines
Fixed interface for determining BSDF solid angles
Mon Apr 11 03:47:46 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.9: +3 -3 lines
Final fix to Klems angles -- I hope
Wed Feb 23 21:58:31 2011 UTC (13 years, 2 months ago) by greg
Fixed issue with coordinate orientation for front transmission
Mon Feb 21 22:50:37 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.7: +6 -1 lines
Corrected notion of "front" and "back" to coincide with surface normals
Sat Feb 19 23:42:09 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.6: +4 -5 lines
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (13 years, 3 months ago) by greg
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.4: +7 -1 lines
Minor fixes and adjustments
Changes since 2.3: +246 -13 lines
Fri Sep 3 23:53:50 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.2: +4 -2 lines
Mon Jun 14 22:02:22 2010 UTC (13 years, 11 months ago) by greg
Added #ifdef for inclusion
Wed Jun 17 20:41:47 2009 UTC (14 years, 11 months ago) by greg
Diff to selected 2.10
