root/radiance/ray/src/common/bsdf.h
Revision: 2.19
Committed: Sun Sep 2 15:33:15 2012 UTC (12 years, 10 months ago) by greg
Changes since 2.18: +5 -2 lines
1 /* RCSid $Id: bsdf.h,v 2.18 2012/03/05 00:17:06 greg Exp $ */
2 /*
3 * bsdf.h
4 *
5 * Declarations for bidirectional scattering distribution functions.
6 * Assumes <stdio.h> already included.
7 *
8 * A material is oriented in right-hand coordinate system with X-axis
9 * in the surface plane pointed to the right as seen from the front.
10 * This means the Y-axis is "up" and the Z-axis is the surface normal.
11 *
12 * Note that we reverse the identification of "front" and "back" from
13 * the conventions used in WINDOW 6. "Front" in our library points
14 * in the +Z direction, towards the interior of the space rather
15 * than the exterior.
16 *
17 * BSDF incident & exiting vectors are always oriented away from surface.
18 *
19 * Created by Greg Ward on 1/10/11.
20 *
21 */
22
23 #ifndef _BSDF_H_
24 #define _BSDF_H_
25
26 #include "fvect.h"
27 #include "ccolor.h"
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32
33 #ifdef _WIN32
34 #define strcasecmp stricmp
35 #endif
36
37 #define SDnameLn 128 /* maximum BSDF name length */
38 #define SDmaxCh 3 /* maximum # spectral channels */
39
40 /* Component flags for SDsampBSDF() and SDdirectHemi() */
41 #define SDsampR 0x1 /* include reflection */
42 #define SDsampT 0x2 /* include transmission */
43 #define SDsampS 0x3 /* include scattering (R+T) */
44 #define SDsampSp 0x4 /* include non-diffuse portion */
45 #define SDsampDf 0x8 /* include diffuse portion */
46 #define SDsampSpR 0x5 /* include non-diffuse reflection */
47 #define SDsampSpT 0x6 /* include non-diffuse transmission */
48 #define SDsampSpS 0x7 /* include non-diffuse scattering */
49 #define SDsampAll 0xF /* include everything */
50
51 /* Projected solid angle query flags for SDsizeBSDF() */
52 #define SDqueryVal 0x0 /* query single value */
53 #define SDqueryMin 0x1 /* query minimum proj. solid angle */
54 #define SDqueryMax 0x2 /* query maximum proj. solid angle */
55
56 /* Error codes: normal return, out of memory, file i/o, file format, bad argument,
57 bad data, unsupported feature, internal error, unknown error */
58 typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
59 SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
60
61 /* English ASCII strings corresponding to ennumerated errors */
62 extern const char *SDerrorEnglish[];
63
64 /* Additional information on last error (ASCII English) */
65 extern char SDerrorDetail[];
66
67 /* Holder for BSDF value and spectral color */
68 typedef struct {
69 double cieY; /* photopic BSDF (Y) value */
70 C_COLOR spec; /* spectral and (x,y) color */
71 } SDValue;
72
73 /* Cached, encoded, cumulative distribution for one incident (solid) angle */
74 #define SD_CDIST_BASE(styp) double cTotal; \
75 struct styp *next
76 typedef struct SDCDst_s {
77 SD_CDIST_BASE(SDCDst_s); /* base fields first */
78 /* ...encoded distribution extends struct */
79 } SDCDst;
80
81 extern const SDCDst SDemptyCD; /* empty distribution */
82
83 /* Forward declaration of BSDF component */
84 typedef struct SDComp_s SDComponent;
85
86 /* Methods needed to handle BSDF components (nothing is optional) */
87 typedef const struct {
88 /* return non-diffuse BSDF */
89 int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec,
90 const FVECT inVec, SDComponent *sdc);
91 /* query non-diffuse PSA for vector */
92 SDError (*queryProjSA)(double *psa, const FVECT v1,
93 const RREAL *v2, int qflags,
94 SDComponent *sdc);
95 /* get cumulative distribution */
96 const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
97 /* sample cumulative distribution */
98 SDError (*sampCDist)(FVECT ioVec, double randX,
99 const SDCDst *cdp);
100 /* free a spectral BSDF component */
101 void (*freeSC)(void *dist);
102 } SDFunc;
103
104 /* Structure to hold a spectral BSDF component (typedef SDComponent above) */
105 struct SDComp_s {
106 C_COLOR cspec[SDmaxCh]; /* component spectral bases */
107 SDFunc *func; /* methods for this component */
108 void *dist; /* loaded distribution data */
109 SDCDst *cdList; /* cumulative distribution cache */
110 };
111
112 /* Container for non-diffuse BSDF components */
113 typedef struct {
114 double minProjSA; /* minimum projected solid angle */
115 double maxHemi; /* maximum directional hemispherical */
116 int ncomp; /* number of separate components */
117 SDComponent comp[1]; /* BSDF components (extends struct) */
118 } SDSpectralDF;
119
120 /* Loaded BSDF data */
121 typedef struct {
122 char name[SDnameLn]; /* BSDF name (usu. derived from file) */
123 char matn[SDnameLn]; /* material name */
124 char makr[SDnameLn]; /* manufacturer */
125 char *mgf; /* geometric description (if any) */
126 float dim[3]; /* width, height, thickness (meters) */
127 SDValue rLambFront; /* diffuse front reflectance */
128 SDValue rLambBack; /* diffuse rear reflectance */
129 SDValue tLamb; /* diffuse transmission */
130 SDSpectralDF *rf, *rb; /* non-diffuse BRDF components */
131 SDSpectralDF *tf, *tb; /* non-diffuse BTDF components */
132 } SDData;
133
134 /* List of loaded BSDFs */
135 extern struct SDCache_s {
136 SDData bsdf; /* BSDF data */
137 unsigned refcnt; /* how many callers are using us? */
138 struct SDCache_s /* next in cache list */
139 *next;
140 } *SDcacheList; /* Global BSDF cache */
141
142 /* BSDF cache retention policies */
143 #define SDretainNone 0 /* free unreferenced BSDF data */
144 #define SDretainBSDFs 1 /* keep loaded BSDFs in memory */
145 #define SDretainAll 2 /* also keep cumulative cache data */
146
147 extern int SDretainSet; /* =SDretainNone by default */
148
149 /*****************************************************************
150 * The following routines are less commonly used by applications.
151 */
152
153 #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
154
155 /* Report an error to the indicated stream (in English) */
156 extern SDError SDreportEnglish(SDError ec, FILE *fp);
157
158 /* Shorten file path to useable BSDF name, removing suffix */
159 extern void SDclipName(char res[SDnameLn], const char *fname);
160
161 /* Allocate new spectral distribution function */
162 extern SDSpectralDF *SDnewSpectralDF(int nc);
163
164 /* Add component(s) to spectral distribution function */
165 extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd);
166
167 /* Free a spectral distribution function */
168 extern void SDfreeSpectralDF(SDSpectralDF *df);
169
170 /* Initialize an unused BSDF struct and assign name (calls SDclipName) */
171 extern void SDclearBSDF(SDData *sd, const char *fname);
172
173 /* Load a BSDF struct from the given file (keeps name unchanged) */
174 extern SDError SDloadFile(SDData *sd, const char *fname);
175
176 /* Free data associated with BSDF struct */
177 extern void SDfreeBSDF(SDData *sd);
178
179 /* Find writeable BSDF by name, or allocate new cache entry if absent */
180 extern SDData *SDgetCache(const char *bname);
181
182 /* Free cached cumulative distributions for BSDF component */
183 extern void SDfreeCumulativeCache(SDSpectralDF *df);
184
185 /* Sample an individual BSDF component */
186 extern SDError SDsampComponent(SDValue *sv, FVECT ioVec,
187 double randX, SDComponent *sdc);
188
189 /* Convert 1-dimensional random variable to N-dimensional */
190 extern void SDmultiSamp(double t[], int n, double randX);
191
192 /* Map a [0,1]^2 square to a unit radius disk */
193 void SDsquare2disk(double ds[2], double seedx, double seedy);
194
195 /* Map point on unit disk to a unit square in [0,1]^2 range */
196 void SDdisk2square(double sq[2], double diskx, double disky);
197
198 /*****************************************************************
199 * The calls below are the ones most applications require.
200 * All directions are assumed to be unit vectors.
201 */
202
203 /* Get BSDF from cache (or load and cache it on first call) */
204 /* Report any problems to stderr (in English), return NULL on failure */
205 extern const SDData *SDcacheFile(const char *fname);
206
207 /* Free a BSDF from our cache (clear all if sd==NULL) */
208 extern void SDfreeCache(const SDData *sd);
209
210 /* Query projected solid angle resolution for non-diffuse BSDF direction(s) */
211 extern SDError SDsizeBSDF(double *projSA, const FVECT v1,
212 const RREAL *v2, int qflags,
213 const SDData *sd);
214
215 /* Return BSDF for the given incident and scattered ray vectors */
216 extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec,
217 const FVECT inVec, const SDData *sd);
218
219 /* Compute directional hemispherical scattering at given incident angle */
220 extern double SDdirectHemi(const FVECT inVec,
221 int sflags, const SDData *sd);
222
223 /* Sample BSDF direction based on the given random variable */
224 extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX,
225 int sflags, const SDData *sd);
226
227 /*****************************************************************
228 * Vector math for getting between world and local BSDF coordinates.
229 * Directions may be passed unnormalized to these routines.
230 */
231
232 /* Compute World->BSDF transform from surface normal and BSDF up vector */
233 extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
234 const FVECT uVec);
235
236 /* Compute inverse transform */
237 extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
238
239 /* Transform and normalize direction (column) vector */
240 extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
241 const FVECT inpVec);
242
243 /* Application-specific BSDF loading routine (not part of our library) */
244 extern SDData *loadBSDF(char *name);
245
246 /* Application-specific BSDF error translator (not part of our library) */
247 extern char *transSDError(SDError ec);
248
249 /*################################################################*/
250 /*######### DEPRECATED DEFINITIONS AWAITING PERMANENT REMOVAL #######*/
251 /*
252 * Header for BSDF i/o and access routines
253 */
254
255 #include "mat4.h"
256 /* up directions */
257 typedef enum {
258 UDzneg=-3,
259 UDyneg=-2,
260 UDxneg=-1,
261 UDunknown=0,
262 UDxpos=1,
263 UDypos=2,
264 UDzpos=3
265 } UpDir;
266 /* BSDF coordinate calculation routines */
267 /* vectors always point away from surface */
268
269 typedef int b_vecf2(FVECT v, int n, void *cd);
270 typedef int b_ndxf2(FVECT v, void *cd);
271 typedef double b_radf2(int n, void *cd);
272
273 /* Bidirectional Scattering Distribution Function */
274 struct BSDF_data {
275 int ninc; /* number of incoming directions */
276 int nout; /* number of outgoing directions */
277 float dim[3]; /* width, height, thickness (meters) */
278 char *mgf; /* geometric description (if any) */
279 void *ib_priv; /* input basis private data */
280 b_vecf2 *ib_vec; /* get input vector from index */
281 b_ndxf2 *ib_ndx; /* get input index from vector */
282 b_radf2 *ib_ohm; /* get input radius for index */
283 void *ob_priv; /* output basis private data */
284 b_vecf2 *ob_vec; /* get output vector from index */
285 b_ndxf2 *ob_ndx; /* get output index from vector */
286 b_radf2 *ob_ohm; /* get output radius for index */
287 float *bsdf; /* scattering distribution data */
288 }; /* bidirectional scattering distrib. func. */
289
290 #define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
291 #define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
292 #define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
293 #define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
294 #define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
295 #define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
296 #define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
297
298 extern struct BSDF_data *load_BSDF(char *fname);
299 extern void free_BSDF(struct BSDF_data *b);
300 extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i,
301 double rv, MAT4 xm);
302 extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o,
303 double rv, MAT4 xm);
304 extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud, char *xfbuf);
305
306 /*######### END DEPRECATED DEFINITIONS #######*/
307 /*################################################################*/
308
309 #ifdef __cplusplus
310 }
311 #endif
312 #endif /* ! _BSDF_H_ */
