root/radiance/ray/src/common/bsdf.h
Revision: 2.1
Committed: Wed Jun 17 20:41:47 2009 UTC (15 years, 10 months ago) by greg
1 /* RCSid $Id: bsdf.h,v 2.1 2009/06/12 17:37:37 greg Exp $ */
2 /*
3 * Header for BSDF i/o and access routines
4 */
5 /* up directions */
6 typedef enum {
7 UDzneg=-3,
8 UDyneg=-2,
9 UDxneg=-1,
10 UDunknown=0,
11 UDxpos=1,
12 UDypos=2,
13 UDzpos=3
14 } UpDir;
15 /* BSDF coordinate calculation routines */
16 /* vectors always point away from surface */
17 typedef int b_vecf(FVECT, int, void *);
18 typedef int b_ndxf(FVECT, void *);
19 typedef double b_radf(int, void *);
20
21 /* Bidirectional Scattering Distribution Function */
22 struct BSDF_data {
23 int ninc; /* number of incoming directions */
24 int nout; /* number of outgoing directions */
25 void *ib_priv; /* input basis private data */
26 b_vecf *ib_vec; /* get input vector from index */
27 b_ndxf *ib_ndx; /* get input index from vector */
28 b_radf *ib_ohm; /* get input radius for index */
29 void *ob_priv; /* output basis private data */
30 b_vecf *ob_vec; /* get output vector from index */
31 b_ndxf *ob_ndx; /* get output index from vector */
32 b_radf *ob_ohm; /* get output radius for index */
33 float *bsdf; /* scattering distribution data */
34 }; /* bidirectional scattering distrib. func. */
35
36 #define getBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
37 #define getBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
38 #define getBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
39 #define getBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
40 #define getBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
41 #define getBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
42 #define BSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
43
44 extern struct BSDF_data *load_BSDF(char *fname);
45 extern void free_BSDF(struct BSDF_data *b);
46 extern int r_BSDF_incvec(FVECT v, struct BSDF_data *b, int i,
47 double rv, MAT4 xm);
48 extern int r_BSDF_outvec(FVECT v, struct BSDF_data *b, int o,
49 double rv, MAT4 xm);
50 extern int getBSDF_xfm(MAT4 xm, FVECT nrm, UpDir ud);
