refactor: moved SDdisk2square() and SDsquare2disk() declarations to fvect.h
Added cumulative cache size limit (per loaded BSDF)
Fix for C++ compilers, which don't like "typedef const struct"
Shut up c++ compiler warning
Switched to double for device dimensions
Added pointer indirection to make error reporting in other languages simpler
Added missing (but implied) "extern" modifiers
Added recording of product and manufacturer names
Added routine for adding spectral distribution components
Minor improvements to direct specular sampling
Fixes for Windows and bug fix in bsdf_m.c
Stratified specular sampling with -ss > 1
Fixed comments and potential bug in BSDF tree traversal
Partial implementation of variable-resolution BSDFs
Fixed interface for determining BSDF solid angles
Final fix to Klems angles -- I hope
Fixed issue with coordinate orientation for front transmission
Corrected notion of "front" and "back" to coincide with surface normals
Fixes to BSDF including blurring of angle boundaries
Minor changes and fixes -- first working version of BSDF material
Minor fixes and adjustments
Added #ifdef for inclusion
