| 1 |
/* RCSid $Id: bsdf.h,v 2.26 2018/01/05 21:00:24 greg Exp $ */
| 2 |
| 3 |
* bsdf.h
| 4 |
| 5 |
* Declarations for bidirectional scattering distribution functions.
| 6 |
* Assumes <stdio.h> already included.
| 7 |
| 8 |
* A material is oriented in right-hand coordinate system with X-axis
| 9 |
* in the surface plane pointed to the right as seen from the front.
| 10 |
* This means the Y-axis is "up" and the Z-axis is the surface normal.
| 11 |
| 12 |
* Note that we reverse the identification of "front" and "back" from
| 13 |
* the conventions used in WINDOW 6. "Front" in our library points
| 14 |
* in the +Z direction, towards the interior of the space rather
| 15 |
* than the exterior.
| 16 |
| 17 |
* BSDF incident & exiting vectors are always oriented away from surface.
| 18 |
| 19 |
* Created by Greg Ward on 1/10/11.
| 20 |
| 21 |
| 22 |
| 23 |
#ifndef _BSDF_H_
| 24 |
#define _BSDF_H_
| 25 |
| 26 |
#include "fvect.h"
| 27 |
#include "ccolor.h"
| 28 |
#include "platform.h"
| 29 |
| 30 |
#ifdef __cplusplus
| 31 |
extern "C" {
| 32 |
#endif
| 33 |
| 34 |
#define SDnameLn 128 /* maximum BSDF name length */
| 35 |
#define SDmaxCh 3 /* maximum # spectral channels */
| 36 |
| 37 |
/* Component flags for SDsampBSDF() and SDdirectHemi() */
| 38 |
#define SDsampR 0x1 /* include reflection */
| 39 |
#define SDsampT 0x2 /* include transmission */
| 40 |
#define SDsampS 0x3 /* include scattering (R+T) */
| 41 |
#define SDsampSp 0x4 /* include non-diffuse portion */
| 42 |
#define SDsampDf 0x8 /* include diffuse portion */
| 43 |
#define SDsampSpR 0x5 /* include non-diffuse reflection */
| 44 |
#define SDsampSpT 0x6 /* include non-diffuse transmission */
| 45 |
#define SDsampSpS 0x7 /* include non-diffuse scattering */
| 46 |
#define SDsampAll 0xF /* include everything */
| 47 |
| 48 |
/* Projected solid angle query flags for SDsizeBSDF() */
| 49 |
#define SDqueryVal 0x0 /* query single value */
| 50 |
#define SDqueryMin 0x1 /* query minimum proj. solid angle */
| 51 |
#define SDqueryMax 0x2 /* query maximum proj. solid angle */
| 52 |
| 53 |
/* Error codes: normal return, out of memory, file i/o, file format, bad argument,
| 54 |
bad data, unsupported feature, internal error, unknown error */
| 55 |
typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
| 56 |
SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
| 57 |
| 58 |
/* English strings corresponding to ennumerated errors */
| 59 |
extern const char *SDerrorEnglish[];
| 60 |
| 61 |
/* Pointer to error list in preferred language */
| 62 |
extern const char **SDerrorList;
| 63 |
| 64 |
/* Additional information on last error (generally in English) */
| 65 |
extern char SDerrorDetail[];
| 66 |
| 67 |
/* Holder for BSDF value and spectral color */
| 68 |
typedef struct {
| 69 |
double cieY; /* photopic BSDF (Y) value */
| 70 |
C_COLOR spec; /* spectral and (x,y) color */
| 71 |
} SDValue;
| 72 |
| 73 |
/* Cached, encoded, cumulative distribution for one incident (solid) angle */
| 74 |
#define SD_CDIST_BASE(styp) double cTotal; \
| 75 |
struct styp *next
| 76 |
typedef struct SDCDst_s {
| 77 |
SD_CDIST_BASE(SDCDst_s); /* base fields first */
| 78 |
/* ...encoded distribution extends struct */
| 79 |
} SDCDst;
| 80 |
| 81 |
extern const SDCDst SDemptyCD; /* empty distribution */
| 82 |
| 83 |
/* Forward declaration of BSDF component */
| 84 |
typedef struct SDComp_s SDComponent;
| 85 |
| 86 |
/* Methods needed to handle BSDF components (nothing is optional) */
| 87 |
typedef struct {
| 88 |
/* return non-diffuse BSDF */
| 89 |
int (*getBSDFs)(float coef[SDmaxCh], const FVECT outVec,
| 90 |
const FVECT inVec, SDComponent *sdc);
| 91 |
/* query non-diffuse PSA for vector */
| 92 |
SDError (*queryProjSA)(double *psa, const FVECT v1,
| 93 |
const RREAL *v2, int qflags,
| 94 |
SDComponent *sdc);
| 95 |
/* get cumulative distribution */
| 96 |
const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
| 97 |
/* sample cumulative distribution */
| 98 |
SDError (*sampCDist)(FVECT ioVec, double randX,
| 99 |
const SDCDst *cdp);
| 100 |
/* free a spectral BSDF component */
| 101 |
void (*freeSC)(void *dist);
| 102 |
} SDFunc;
| 103 |
| 104 |
/* Structure to hold a spectral BSDF component (typedef SDComponent above) */
| 105 |
struct SDComp_s {
| 106 |
C_COLOR cspec[SDmaxCh]; /* component spectral bases */
| 107 |
const SDFunc *func; /* methods for this component */
| 108 |
void *dist; /* loaded distribution data */
| 109 |
SDCDst *cdList; /* cumulative distribution cache */
| 110 |
| 111 |
| 112 |
/* Container for non-diffuse BSDF components */
| 113 |
typedef struct {
| 114 |
double minProjSA; /* minimum projected solid angle */
| 115 |
double maxHemi; /* maximum directional hemispherical */
| 116 |
int ncomp; /* number of separate components */
| 117 |
SDComponent comp[1]; /* BSDF components (extends struct) */
| 118 |
} SDSpectralDF;
| 119 |
| 120 |
/* Loaded BSDF data */
| 121 |
typedef struct {
| 122 |
char name[SDnameLn]; /* BSDF name (usu. derived from file) */
| 123 |
char matn[SDnameLn]; /* material name */
| 124 |
char makr[SDnameLn]; /* manufacturer */
| 125 |
char *mgf; /* geometric description (if any) */
| 126 |
double dim[3]; /* width, height, thickness (meters) */
| 127 |
SDValue rLambFront; /* diffuse front reflectance */
| 128 |
SDValue rLambBack; /* diffuse rear reflectance */
| 129 |
SDValue tLamb; /* diffuse transmission */
| 130 |
SDSpectralDF *rf, *rb; /* non-diffuse BRDF components */
| 131 |
SDSpectralDF *tf, *tb; /* non-diffuse BTDF components */
| 132 |
} SDData;
| 133 |
| 134 |
/* List of loaded BSDFs */
| 135 |
extern struct SDCache_s {
| 136 |
SDData bsdf; /* BSDF data */
| 137 |
unsigned refcnt; /* how many callers are using us? */
| 138 |
struct SDCache_s /* next in cache list */
| 139 |
*next;
| 140 |
} *SDcacheList; /* Global BSDF cache */
| 141 |
| 142 |
/* BSDF cache retention policies */
| 143 |
#define SDretainNone 0 /* free unreferenced BSDF data */
| 144 |
#define SDretainBSDFs 1 /* keep loaded BSDFs in memory */
| 145 |
#define SDretainAll 2 /* also keep cumulative cache data */
| 146 |
| 147 |
extern int SDretainSet; /* =SDretainNone by default */
| 148 |
extern unsigned long SDmaxCache; /* =0 (unlimited) by default */
| 149 |
| 150 |
| 151 |
* The following routines are less commonly used by applications.
| 152 |
| 153 |
| 154 |
#define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
| 155 |
| 156 |
/* Report an error to the indicated stream */
| 157 |
extern SDError SDreportError(SDError ec, FILE *fp);
| 158 |
| 159 |
/* Shorten file path to useable BSDF name, removing suffix */
| 160 |
extern void SDclipName(char res[SDnameLn], const char *fname);
| 161 |
| 162 |
/* Allocate new spectral distribution function */
| 163 |
extern SDSpectralDF *SDnewSpectralDF(int nc);
| 164 |
| 165 |
/* Add component(s) to spectral distribution function */
| 166 |
extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd);
| 167 |
| 168 |
/* Free a spectral distribution function */
| 169 |
extern void SDfreeSpectralDF(SDSpectralDF *df);
| 170 |
| 171 |
/* Initialize an unused BSDF struct and assign name (calls SDclipName) */
| 172 |
extern void SDclearBSDF(SDData *sd, const char *fname);
| 173 |
| 174 |
/* Load a BSDF struct from the given file (keeps name unchanged) */
| 175 |
extern SDError SDloadFile(SDData *sd, const char *fname);
| 176 |
| 177 |
/* Free data associated with BSDF struct */
| 178 |
extern void SDfreeBSDF(SDData *sd);
| 179 |
| 180 |
/* Find writeable BSDF by name, or allocate new cache entry if absent */
| 181 |
extern SDData *SDgetCache(const char *bname);
| 182 |
| 183 |
/* Free cached cumulative distributions for BSDF component */
| 184 |
extern void SDfreeCumulativeCache(SDSpectralDF *df);
| 185 |
| 186 |
/* Sample an individual BSDF component */
| 187 |
extern SDError SDsampComponent(SDValue *sv, FVECT ioVec,
| 188 |
double randX, SDComponent *sdc);
| 189 |
| 190 |
/* Convert 1-dimensional random variable to N-dimensional */
| 191 |
extern void SDmultiSamp(double t[], int n, double randX);
| 192 |
| 193 |
/* Map a [0,1]^2 square to a unit radius disk */
| 194 |
extern void SDsquare2disk(double ds[2], double seedx, double seedy);
| 195 |
| 196 |
/* Map point on unit disk to a unit square in [0,1]^2 range */
| 197 |
extern void SDdisk2square(double sq[2], double diskx, double disky);
| 198 |
| 199 |
| 200 |
* The calls below are the ones most applications require.
| 201 |
* All directions are assumed to be unit vectors.
| 202 |
| 203 |
| 204 |
/* Get BSDF from cache (or load and cache it on first call) */
| 205 |
/* Report any problems to stderr, return NULL on failure */
| 206 |
extern const SDData *SDcacheFile(const char *fname);
| 207 |
| 208 |
/* Free a BSDF from our cache (clear all if sd==NULL) */
| 209 |
extern void SDfreeCache(const SDData *sd);
| 210 |
| 211 |
/* Query projected solid angle resolution for non-diffuse BSDF direction(s) */
| 212 |
extern SDError SDsizeBSDF(double *projSA, const FVECT v1,
| 213 |
| 214 |
const SDData *sd);
| 215 |
| 216 |
/* Return BSDF for the given incident and scattered ray vectors */
| 217 |
extern SDError SDevalBSDF(SDValue *sv, const FVECT outVec,
| 218 |
const FVECT inVec, const SDData *sd);
| 219 |
| 220 |
/* Compute directional hemispherical scattering at given incident angle */
| 221 |
extern double SDdirectHemi(const FVECT inVec,
| 222 |
int sflags, const SDData *sd);
| 223 |
| 224 |
/* Sample BSDF direction based on the given random variable */
| 225 |
extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX,
| 226 |
| 227 |
| 228 |
| 229 |
* Vector math for getting between world and local BSDF coordinates.
| 230 |
* Directions may be passed unnormalized to these routines.
| 231 |
| 232 |
| 233 |
/* Compute World->BSDF transform from surface normal and BSDF up vector */
| 234 |
extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
| 235 |
const FVECT uVec);
| 236 |
| 237 |
/* Compute inverse transform */
| 238 |
extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
| 239 |
| 240 |
/* Transform and normalize direction (column) vector */
| 241 |
extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
| 242 |
const FVECT inpVec);
| 243 |
| 244 |
/* Application-specific BSDF loading routine (not part of our library) */
| 245 |
extern SDData *loadBSDF(char *name);
| 246 |
| 247 |
/* Application-specific BSDF error translator (not part of our library) */
| 248 |
extern char *transSDError(SDError ec);
| 249 |
| 250 |
#ifdef __cplusplus
| 251 |
| 252 |
#endif
| 253 |
#endif /* ! _BSDF_H_ */
