root/radiance/ray/src/common/bsdf.h
Revision: 2.31
Committed: Sat Jun 7 05:09:45 2025 UTC (2 weeks, 2 days ago) by greg
Changes since 2.30: +2 -3 lines
1 /* RCSid $Id: bsdf.h,v 2.30 2021/12/13 21:05:00 greg Exp $ */
2 /*
3 * bsdf.h
4 *
5 * Declarations for bidirectional scattering distribution functions.
6 *
7 * A material is oriented in right-hand coordinate system with X-axis
8 * in the surface plane pointed to the right as seen from the front.
9 * This means the Y-axis is "up" and the Z-axis is the surface normal.
10 *
11 * Note that we reverse the identification of "front" and "back" from
12 * the conventions used in WINDOW 6. "Front" in our library points
13 * in the +Z direction, towards the interior of the space rather
14 * than the exterior.
15 *
16 * BSDF incident & exiting vectors are always oriented away from surface.
17 *
18 * Created by Greg Ward on 1/10/11.
19 *
20 */
21
22 #ifndef _BSDF_H_
23 #define _BSDF_H_
24
25 #include "platform.h"
26 #include "fvect.h"
27 #include "ccolor.h"
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32
33 #define SDnameLn 128 /* maximum BSDF name length */
34 #define SDmaxCh 3 /* maximum # spectral channels */
35
36 /* Component flags for SDsampBSDF() and SDdirectHemi() */
37 #define SDsampR 0x1 /* include reflection */
38 #define SDsampT 0x2 /* include transmission */
39 #define SDsampS 0x3 /* include scattering (R+T) */
40 #define SDsampSp 0x4 /* include non-diffuse portion */
41 #define SDsampDf 0x8 /* include diffuse portion */
42 #define SDsampSpR 0x5 /* include non-diffuse reflection */
43 #define SDsampSpT 0x6 /* include non-diffuse transmission */
44 #define SDsampSpS 0x7 /* include non-diffuse scattering */
45 #define SDsampAll 0xF /* include everything */
46
47 /* Projected solid angle query flags for SDsizeBSDF() */
48 #define SDqueryVal 0x0 /* query single value */
49 #define SDqueryMin 0x1 /* query minimum proj. solid angle */
50 #define SDqueryMax 0x2 /* query maximum proj. solid angle */
51
52 /* Error codes: normal return, out of memory, file i/o, file format, bad argument,
53 bad data, unsupported feature, internal error, unknown error */
54 typedef enum {SDEnone=0, SDEmemory, SDEfile, SDEformat, SDEargument,
55 SDEdata, SDEsupport, SDEinternal, SDEunknown} SDError;
56
57 /* English strings corresponding to ennumerated errors */
58 extern const char *SDerrorEnglish[];
59
60 /* Pointer to error list in preferred language */
61 extern const char **SDerrorList;
62
63 /* Additional information on last error (generally in English) */
64 extern char SDerrorDetail[];
65
66 /* Holder for BSDF value and spectral color */
67 typedef struct {
68 double cieY; /* photopic BSDF (Y) value */
69 C_COLOR spec; /* spectral and (x,y) color */
70 } SDValue;
71
72 /* Cached, encoded, cumulative distribution for one incident (solid) angle */
73 #define SD_CDIST_BASE(styp) double cTotal; \
74 struct styp *next
75 typedef struct SDCDst_s {
76 SD_CDIST_BASE(SDCDst_s); /* base fields first */
77 /* ...encoded distribution extends struct */
78 } SDCDst;
79
80 extern const SDCDst SDemptyCD; /* empty distribution */
81
82 /* Forward declaration of BSDF component */
83 typedef struct SDComp_s SDComponent;
84
85 /* Methods needed to handle BSDF components (nothing is optional) */
86 typedef struct {
87 /* return non-diffuse BSDF */
88 int (*getBSDFs)(float coef[SDmaxCh], const FVECT inVec,
89 const FVECT outVec, SDComponent *sdc);
90 /* query non-diffuse PSA for vector */
91 SDError (*queryProjSA)(double *psa, const FVECT v1,
92 const RREAL *v2, int qflags,
93 SDComponent *sdc);
94 /* get cumulative distribution */
95 const SDCDst *(*getCDist)(const FVECT inVec, SDComponent *sdc);
96 /* sample cumulative distribution */
97 SDError (*sampCDist)(FVECT ioVec, double randX,
98 const SDCDst *cdp);
99 /* free a spectral BSDF component */
100 void (*freeSC)(void *dist);
101 } SDFunc;
102
103 /* Structure to hold a spectral BSDF component (typedef SDComponent above) */
104 struct SDComp_s {
105 C_COLOR cspec[SDmaxCh]; /* component spectral bases */
106 const SDFunc *func; /* methods for this component */
107 void *dist; /* loaded distribution data */
108 SDCDst *cdList; /* cumulative distribution cache */
109 };
110
111 /* Container for non-diffuse BSDF components */
112 typedef struct {
113 double minProjSA; /* minimum projected solid angle */
114 double maxHemi; /* maximum directional hemispherical */
115 int ncomp; /* number of separate components */
116 SDComponent comp[1]; /* BSDF components (extends struct) */
117 } SDSpectralDF;
118
119 /* Loaded BSDF data */
120 typedef struct {
121 char name[SDnameLn]; /* BSDF name (usu. derived from file) */
122 char matn[SDnameLn]; /* material name */
123 char makr[SDnameLn]; /* manufacturer */
124 char *mgf; /* geometric description (if any) */
125 double dim[3]; /* width, height, thickness (meters) */
126 SDValue rLambFront; /* diffuse front reflectance */
127 SDValue rLambBack; /* diffuse rear reflectance */
128 SDValue tLambFront; /* diffuse front transmittance */
129 SDValue tLambBack; /* diffuse back transmittance */
130 SDSpectralDF *rf, *rb; /* non-diffuse BRDF components */
131 SDSpectralDF *tf, *tb; /* non-diffuse BTDF components */
132 } SDData;
133
134 /* List of loaded BSDFs */
135 extern struct SDCache_s {
136 SDData bsdf; /* BSDF data */
137 unsigned refcnt; /* how many callers are using us? */
138 struct SDCache_s /* next in cache list */
139 *next;
140 } *SDcacheList; /* Global BSDF cache */
141
142 /* BSDF cache retention policies */
143 #define SDretainNone 0 /* free unreferenced BSDF data */
144 #define SDretainBSDFs 1 /* keep loaded BSDFs in memory */
145 #define SDretainAll 2 /* also keep cumulative cache data */
146
147 extern int SDretainSet; /* =SDretainNone by default */
148 extern unsigned long SDmaxCache; /* =0 (unlimited) by default */
149
150 /*****************************************************************
151 * The following routines are less commonly used by applications.
152 */
153
154 #define SDisLoaded(sd) ((sd)->rLambFront.spec.flags != 0)
155
156 /* Report an error to the indicated stream */
157 extern SDError SDreportError(SDError ec, FILE *fp);
158
159 /* Shorten file path to useable BSDF name, removing suffix */
160 extern void SDclipName(char res[SDnameLn], const char *fname);
161
162 /* Allocate new spectral distribution function */
163 extern SDSpectralDF *SDnewSpectralDF(int nc);
164
165 /* Add component(s) to spectral distribution function */
166 extern SDSpectralDF *SDaddComponent(SDSpectralDF *odf, int nadd);
167
168 /* Free a spectral distribution function */
169 extern void SDfreeSpectralDF(SDSpectralDF *df);
170
171 /* Initialize an unused BSDF struct and assign name (calls SDclipName) */
172 extern void SDclearBSDF(SDData *sd, const char *fname);
173
174 /* Load a BSDF struct from the given file (keeps name unchanged) */
175 extern SDError SDloadFile(SDData *sd, const char *fname);
176
177 /* Free data associated with BSDF struct */
178 extern void SDfreeBSDF(SDData *sd);
179
180 /* Find writeable BSDF by name, or allocate new cache entry if absent */
181 extern SDData *SDgetCache(const char *bname);
182
183 /* Free cached cumulative distributions for BSDF component */
184 extern void SDfreeCumulativeCache(SDSpectralDF *df);
185
186 /* Sample an individual BSDF component */
187 extern SDError SDsampComponent(SDValue *sv, FVECT ioVec,
188 double randX, SDComponent *sdc);
189
190 /* Convert 1-dimensional random variable to N-dimensional */
191 extern void SDmultiSamp(double t[], int n, double randX);
192
193 /*****************************************************************
194 * The calls below are the ones most applications require.
195 * All directions are assumed to be unit vectors.
196 */
197
198 /* Get BSDF from cache (or load and cache it on first call) */
199 /* Report any problems to stderr, return NULL on failure */
200 extern const SDData *SDcacheFile(const char *fname);
201
202 /* Free a BSDF from our cache (clear all if sd==NULL) */
203 extern void SDfreeCache(const SDData *sd);
204
205 /* Query projected solid angle resolution for non-diffuse BSDF direction(s) */
206 extern SDError SDsizeBSDF(double *projSA, const FVECT v1,
207 const RREAL *v2, int qflags,
208 const SDData *sd);
209
210 /* Return BSDF for the given incident and scattered ray vectors */
211 extern SDError SDevalBSDF(SDValue *sv, const FVECT inVec,
212 const FVECT outVec, const SDData *sd);
213
214 /* Compute directional hemispherical scattering at given incident angle */
215 extern double SDdirectHemi(const FVECT inVec,
216 int sflags, const SDData *sd);
217
218 /* Sample BSDF direction based on the given random variable */
219 extern SDError SDsampBSDF(SDValue *sv, FVECT ioVec, double randX,
220 int sflags, const SDData *sd);
221
222 /*****************************************************************
223 * Vector math for getting between world and local BSDF coordinates.
224 * Directions may be passed unnormalized to these routines.
225 */
226
227 /* Compute World->BSDF transform from surface normal and BSDF up vector */
228 extern SDError SDcompXform(RREAL vMtx[3][3], const FVECT sNrm,
229 const FVECT uVec);
230
231 /* Compute inverse transform */
232 extern SDError SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]);
233
234 /* Transform and normalize direction (column) vector */
235 extern SDError SDmapDir(FVECT resVec, RREAL vMtx[3][3],
236 const FVECT inpVec);
237
238 /* Application-specific BSDF loading routine (not part of our library) */
239 extern SDData *loadBSDF(char *name);
240
241 /* Application-specific BSDF error translator (not part of our library) */
242 extern char *transSDError(SDError ec);
243
244 #ifdef __cplusplus
245 }
246 #endif
247 #endif /* ! _BSDF_H_ */
