| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: bsdf.c,v 2.8 2010/09/26 15:43:26 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Routines for handling BSDF data |
| 6 |
| 7 |
| 8 |
#include "standard.h" |
| 9 |
#include "bsdf.h" |
| 10 |
#include "paths.h" |
| 11 |
#include "ezxml.h" |
| 12 |
#include <ctype.h> |
| 13 |
| 14 |
#define MAXLATS 46 /* maximum number of latitudes */ |
| 15 |
| 16 |
/* BSDF angle specification */ |
| 17 |
typedef struct { |
| 18 |
char name[64]; /* basis name */ |
| 19 |
int nangles; /* total number of directions */ |
| 20 |
struct { |
| 21 |
float tmin; /* starting theta */ |
| 22 |
short nphis; /* number of phis (0 term) */ |
| 23 |
} lat[MAXLATS+1]; /* latitudes */ |
| 24 |
} ANGLE_BASIS; |
| 25 |
| 26 |
#define MAXABASES 7 /* limit on defined bases */ |
| 27 |
| 28 |
static ANGLE_BASIS abase_list[MAXABASES] = { |
| 29 |
| 30 |
"LBNL/Klems Full", 145, |
| 31 |
{ {-5., 1}, |
| 32 |
{5., 8}, |
| 33 |
{15., 16}, |
| 34 |
{25., 20}, |
| 35 |
{35., 24}, |
| 36 |
{45., 24}, |
| 37 |
{55., 24}, |
| 38 |
{65., 16}, |
| 39 |
{75., 12}, |
| 40 |
{90., 0} } |
| 41 |
| 42 |
"LBNL/Klems Half", 73, |
| 43 |
{ {-6.5, 1}, |
| 44 |
{6.5, 8}, |
| 45 |
{19.5, 12}, |
| 46 |
{32.5, 16}, |
| 47 |
{46.5, 20}, |
| 48 |
{61.5, 12}, |
| 49 |
{76.5, 4}, |
| 50 |
{90., 0} } |
| 51 |
| 52 |
"LBNL/Klems Quarter", 41, |
| 53 |
{ {-9., 1}, |
| 54 |
{9., 8}, |
| 55 |
{27., 12}, |
| 56 |
{46., 12}, |
| 57 |
{66., 8}, |
| 58 |
{90., 0} } |
| 59 |
| 60 |
| 61 |
| 62 |
static int nabases = 3; /* current number of defined bases */ |
| 63 |
| 64 |
#define FEQ(a,b) ((a)-(b) <= 1e-6 && (b)-(a) <= 1e-6) |
| 65 |
| 66 |
static int |
| 67 |
fequal(double a, double b) |
| 68 |
| 69 |
if (b != .0) |
| 70 |
a = a/b - 1.; |
| 71 |
return((a <= 1e-6) & (a >= -1e-6)); |
| 72 |
| 73 |
| 74 |
// returns the name of the given tag |
| 75 |
#ifdef ezxml_name |
| 76 |
#undef ezxml_name |
| 77 |
static char * |
| 78 |
ezxml_name(ezxml_t xml) |
| 79 |
| 80 |
if (xml == NULL) |
| 81 |
return(NULL); |
| 82 |
return(xml->name); |
| 83 |
| 84 |
#endif |
| 85 |
| 86 |
// returns the given tag's character content or empty string if none |
| 87 |
#ifdef ezxml_txt |
| 88 |
#undef ezxml_txt |
| 89 |
static char * |
| 90 |
ezxml_txt(ezxml_t xml) |
| 91 |
| 92 |
if (xml == NULL) |
| 93 |
return(""); |
| 94 |
return(xml->txt); |
| 95 |
| 96 |
#endif |
| 97 |
| 98 |
| 99 |
static int |
| 100 |
ab_getvec( /* get vector for this angle basis index */ |
| 101 |
FVECT v, |
| 102 |
int ndx, |
| 103 |
void *p |
| 104 |
| 105 |
| 106 |
ANGLE_BASIS *ab = (ANGLE_BASIS *)p; |
| 107 |
int li; |
| 108 |
double pol, azi, d; |
| 109 |
| 110 |
if ((ndx < 0) | (ndx >= ab->nangles)) |
| 111 |
return(0); |
| 112 |
for (li = 0; ndx >= ab->lat[li].nphis; li++) |
| 113 |
ndx -= ab->lat[li].nphis; |
| 114 |
pol = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin); |
| 115 |
azi = 2.*PI*ndx/ab->lat[li].nphis; |
| 116 |
v[2] = d = cos(pol); |
| 117 |
d = sqrt(1. - d*d); /* sin(pol) */ |
| 118 |
v[0] = cos(azi)*d; |
| 119 |
v[1] = sin(azi)*d; |
| 120 |
return(1); |
| 121 |
| 122 |
| 123 |
| 124 |
static int |
| 125 |
ab_getndx( /* get index corresponding to the given vector */ |
| 126 |
FVECT v, |
| 127 |
void *p |
| 128 |
| 129 |
| 130 |
| 131 |
int li, ndx; |
| 132 |
| 133 |
| 134 |
if ((v[2] < -1.0) | (v[2] > 1.0)) |
| 135 |
return(-1); |
| 136 |
pol = 180.0/PI*acos(v[2]); |
| 137 |
azi = 180.0/PI*atan2(v[1], v[0]); |
| 138 |
if (azi < 0.0) azi += 360.0; |
| 139 |
for (li = 1; ab->lat[li].tmin <= pol; li++) |
| 140 |
if (!ab->lat[li].nphis) |
| 141 |
return(-1); |
| 142 |
--li; |
| 143 |
ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5); |
| 144 |
if (ndx >= ab->lat[li].nphis) ndx = 0; |
| 145 |
while (li--) |
| 146 |
ndx += ab->lat[li].nphis; |
| 147 |
return(ndx); |
| 148 |
| 149 |
| 150 |
| 151 |
static double |
| 152 |
ab_getohm( /* get solid angle for this angle basis index */ |
| 153 |
int ndx, |
| 154 |
void *p |
| 155 |
| 156 |
| 157 |
| 158 |
int li; |
| 159 |
double theta, theta1; |
| 160 |
| 161 |
| 162 |
return(0); |
| 163 |
| 164 |
| 165 |
theta1 = PI/180. * ab->lat[li+1].tmin; |
| 166 |
if (ab->lat[li].nphis == 1) { /* special case */ |
| 167 |
if (ab->lat[li].tmin > FTINY) |
| 168 |
error(USER, "unsupported BSDF coordinate system"); |
| 169 |
return(2.*PI*(1. - cos(theta1))); |
| 170 |
| 171 |
theta = PI/180. * ab->lat[li].tmin; |
| 172 |
return(2.*PI*(cos(theta) - cos(theta1))/(double)ab->lat[li].nphis); |
| 173 |
| 174 |
| 175 |
| 176 |
static int |
| 177 |
ab_getvecR( /* get reverse vector for this angle basis index */ |
| 178 |
FVECT v, |
| 179 |
int ndx, |
| 180 |
void *p |
| 181 |
| 182 |
| 183 |
if (!ab_getvec(v, ndx, p)) |
| 184 |
return(0); |
| 185 |
| 186 |
v[0] = -v[0]; |
| 187 |
v[1] = -v[1]; |
| 188 |
v[2] = -v[2]; |
| 189 |
| 190 |
return(1); |
| 191 |
| 192 |
| 193 |
| 194 |
static int |
| 195 |
ab_getndxR( /* get index corresponding to the reverse vector */ |
| 196 |
FVECT v, |
| 197 |
void *p |
| 198 |
| 199 |
| 200 |
FVECT v2; |
| 201 |
| 202 |
v2[0] = -v[0]; |
| 203 |
v2[1] = -v[1]; |
| 204 |
v2[2] = -v[2]; |
| 205 |
| 206 |
return ab_getndx(v2, p); |
| 207 |
| 208 |
| 209 |
| 210 |
static void |
| 211 |
load_angle_basis( /* load custom BSDF angle basis */ |
| 212 |
ezxml_t wab |
| 213 |
| 214 |
| 215 |
char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName")); |
| 216 |
ezxml_t wbb; |
| 217 |
int i; |
| 218 |
| 219 |
if (!abname || !*abname) |
| 220 |
return; |
| 221 |
for (i = nabases; i--; ) |
| 222 |
if (!strcmp(abname, abase_list[i].name)) |
| 223 |
return; /* assume it's the same */ |
| 224 |
if (nabases >= MAXABASES) |
| 225 |
error(INTERNAL, "too many angle bases"); |
| 226 |
strcpy(abase_list[nabases].name, abname); |
| 227 |
abase_list[nabases].nangles = 0; |
| 228 |
for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock"); |
| 229 |
wbb != NULL; i++, wbb = wbb->next) { |
| 230 |
if (i >= MAXLATS) |
| 231 |
error(INTERNAL, "too many latitudes in custom basis"); |
| 232 |
abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt( |
| 233 |
ezxml_child(ezxml_child(wbb, |
| 234 |
"ThetaBounds"), "UpperTheta"))); |
| 235 |
if (!i) |
| 236 |
abase_list[nabases].lat[i].tmin = |
| 237 |
-abase_list[nabases].lat[i+1].tmin; |
| 238 |
else if (!fequal(atof(ezxml_txt(ezxml_child(ezxml_child(wbb, |
| 239 |
"ThetaBounds"), "LowerTheta"))), |
| 240 |
abase_list[nabases].lat[i].tmin)) |
| 241 |
error(WARNING, "theta values disagree in custom basis"); |
| 242 |
abase_list[nabases].nangles += |
| 243 |
abase_list[nabases].lat[i].nphis = |
| 244 |
atoi(ezxml_txt(ezxml_child(wbb, "nPhis"))); |
| 245 |
| 246 |
abase_list[nabases++].lat[i].nphis = 0; |
| 247 |
| 248 |
| 249 |
| 250 |
static double |
| 251 |
to_meters( /* return factor to convert given unit to meters */ |
| 252 |
const char *unit |
| 253 |
| 254 |
| 255 |
if (unit == NULL) return(1.); /* safe assumption? */ |
| 256 |
if (!strcasecmp(unit, "Meter")) return(1.); |
| 257 |
if (!strcasecmp(unit, "Foot")) return(.3048); |
| 258 |
if (!strcasecmp(unit, "Inch")) return(.0254); |
| 259 |
if (!strcasecmp(unit, "Centimeter")) return(.01); |
| 260 |
if (!strcasecmp(unit, "Millimeter")) return(.001); |
| 261 |
sprintf(errmsg, "unknown dimensional unit '%s'", unit); |
| 262 |
error(USER, errmsg); |
| 263 |
| 264 |
| 265 |
| 266 |
static void |
| 267 |
load_geometry( /* load geometric dimensions and description (if any) */ |
| 268 |
struct BSDF_data *dp, |
| 269 |
ezxml_t wdb |
| 270 |
| 271 |
| 272 |
ezxml_t geom; |
| 273 |
double cfact; |
| 274 |
const char *fmt, *mgfstr; |
| 275 |
| 276 |
dp->dim[0] = dp->dim[1] = dp->dim[2] = 0; |
| 277 |
dp->mgf = NULL; |
| 278 |
if ((geom = ezxml_child(wdb, "Width")) != NULL) |
| 279 |
dp->dim[0] = atof(ezxml_txt(geom)) * |
| 280 |
to_meters(ezxml_attr(geom, "unit")); |
| 281 |
if ((geom = ezxml_child(wdb, "Height")) != NULL) |
| 282 |
dp->dim[1] = atof(ezxml_txt(geom)) * |
| 283 |
| 284 |
if ((geom = ezxml_child(wdb, "Thickness")) != NULL) |
| 285 |
dp->dim[2] = atof(ezxml_txt(geom)) * |
| 286 |
| 287 |
if ((geom = ezxml_child(wdb, "Geometry")) == NULL || |
| 288 |
(mgfstr = ezxml_txt(geom)) == NULL) |
| 289 |
return; |
| 290 |
if ((fmt = ezxml_attr(geom, "format")) != NULL && |
| 291 |
strcasecmp(fmt, "MGF")) { |
| 292 |
sprintf(errmsg, "unrecognized geometry format '%s'", fmt); |
| 293 |
error(WARNING, errmsg); |
| 294 |
return; |
| 295 |
| 296 |
cfact = to_meters(ezxml_attr(geom, "unit")); |
| 297 |
dp->mgf = (char *)malloc(strlen(mgfstr)+32); |
| 298 |
if (dp->mgf == NULL) |
| 299 |
error(SYSTEM, "out of memory in load_geometry"); |
| 300 |
if (cfact < 0.99 || cfact > 1.01) |
| 301 |
sprintf(dp->mgf, "xf -s %.5f\n%s\nxf\n", cfact, mgfstr); |
| 302 |
else |
| 303 |
strcpy(dp->mgf, mgfstr); |
| 304 |
| 305 |
| 306 |
| 307 |
static void |
| 308 |
load_bsdf_data( /* load BSDF distribution for this wavelength */ |
| 309 |
| 310 |
ezxml_t wdb |
| 311 |
| 312 |
| 313 |
char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis")); |
| 314 |
char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis")); |
| 315 |
char *sdata; |
| 316 |
int i; |
| 317 |
| 318 |
if ((!cbasis || !*cbasis) | (!rbasis || !*rbasis)) { |
| 319 |
error(WARNING, "missing column/row basis for BSDF"); |
| 320 |
return; |
| 321 |
| 322 |
| 323 |
if (!strcmp(cbasis, abase_list[i].name)) { |
| 324 |
dp->ninc = abase_list[i].nangles; |
| 325 |
dp->ib_priv = (void *)&abase_list[i]; |
| 326 |
dp->ib_vec = ab_getvecR; |
| 327 |
dp->ib_ndx = ab_getndxR; |
| 328 |
dp->ib_ohm = ab_getohm; |
| 329 |
break; |
| 330 |
| 331 |
if (i < 0) { |
| 332 |
sprintf(errmsg, "undefined ColumnAngleBasis '%s'", cbasis); |
| 333 |
| 334 |
return; |
| 335 |
| 336 |
| 337 |
if (!strcmp(rbasis, abase_list[i].name)) { |
| 338 |
dp->nout = abase_list[i].nangles; |
| 339 |
dp->ob_priv = (void *)&abase_list[i]; |
| 340 |
dp->ob_vec = ab_getvec; |
| 341 |
dp->ob_ndx = ab_getndx; |
| 342 |
dp->ob_ohm = ab_getohm; |
| 343 |
break; |
| 344 |
| 345 |
if (i < 0) { |
| 346 |
sprintf(errmsg, "undefined RowAngleBasis '%s'", cbasis); |
| 347 |
| 348 |
return; |
| 349 |
| 350 |
/* read BSDF data */ |
| 351 |
sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); |
| 352 |
if (!sdata || !*sdata) { |
| 353 |
error(WARNING, "missing BSDF ScatteringData"); |
| 354 |
return; |
| 355 |
| 356 |
dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout); |
| 357 |
if (dp->bsdf == NULL) |
| 358 |
error(SYSTEM, "out of memory in load_bsdf_data"); |
| 359 |
for (i = 0; i < dp->ninc*dp->nout; i++) { |
| 360 |
char *sdnext = fskip(sdata); |
| 361 |
if (sdnext == NULL) { |
| 362 |
error(WARNING, "bad/missing BSDF ScatteringData"); |
| 363 |
free(dp->bsdf); dp->bsdf = NULL; |
| 364 |
return; |
| 365 |
| 366 |
while (*sdnext && isspace(*sdnext)) |
| 367 |
sdnext++; |
| 368 |
if (*sdnext == ',') sdnext++; |
| 369 |
dp->bsdf[i] = atof(sdata); |
| 370 |
sdata = sdnext; |
| 371 |
| 372 |
while (isspace(*sdata)) |
| 373 |
sdata++; |
| 374 |
if (*sdata) { |
| 375 |
sprintf(errmsg, "%d extra characters after BSDF ScatteringData", |
| 376 |
(int)strlen(sdata)); |
| 377 |
| 378 |
| 379 |
| 380 |
| 381 |
| 382 |
static int |
| 383 |
check_bsdf_data( /* check that BSDF data is sane */ |
| 384 |
struct BSDF_data *dp |
| 385 |
| 386 |
| 387 |
double *omega_iarr, *omega_oarr; |
| 388 |
double dom, contrib, hemi_total, full_total; |
| 389 |
int nneg; |
| 390 |
FVECT v; |
| 391 |
int i, o; |
| 392 |
| 393 |
if (dp == NULL || dp->bsdf == NULL) |
| 394 |
return(0); |
| 395 |
omega_iarr = (double *)calloc(dp->ninc, sizeof(double)); |
| 396 |
omega_oarr = (double *)calloc(dp->nout, sizeof(double)); |
| 397 |
if ((omega_iarr == NULL) | (omega_oarr == NULL)) |
| 398 |
error(SYSTEM, "out of memory in check_bsdf_data"); |
| 399 |
/* incoming projected solid angles */ |
| 400 |
hemi_total = .0; |
| 401 |
for (i = dp->ninc; i--; ) { |
| 402 |
dom = getBSDF_incohm(dp,i); |
| 403 |
if (dom <= .0) { |
| 404 |
error(WARNING, "zero/negative incoming solid angle"); |
| 405 |
continue; |
| 406 |
| 407 |
if (!getBSDF_incvec(v,dp,i) || v[2] > FTINY) { |
| 408 |
error(WARNING, "illegal incoming BSDF direction"); |
| 409 |
free(omega_iarr); free(omega_oarr); |
| 410 |
return(0); |
| 411 |
| 412 |
hemi_total += omega_iarr[i] = dom * -v[2]; |
| 413 |
| 414 |
if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) { |
| 415 |
sprintf(errmsg, "incoming BSDF hemisphere off by %.1f%%", |
| 416 |
100.*(hemi_total/PI - 1.)); |
| 417 |
| 418 |
| 419 |
dom = PI / hemi_total; /* fix normalization */ |
| 420 |
for (i = dp->ninc; i--; ) |
| 421 |
omega_iarr[i] *= dom; |
| 422 |
/* outgoing projected solid angles */ |
| 423 |
hemi_total = .0; |
| 424 |
for (o = dp->nout; o--; ) { |
| 425 |
dom = getBSDF_outohm(dp,o); |
| 426 |
if (dom <= .0) { |
| 427 |
error(WARNING, "zero/negative outgoing solid angle"); |
| 428 |
continue; |
| 429 |
| 430 |
if (!getBSDF_outvec(v,dp,o) || v[2] < -FTINY) { |
| 431 |
error(WARNING, "illegal outgoing BSDF direction"); |
| 432 |
| 433 |
return(0); |
| 434 |
| 435 |
hemi_total += omega_oarr[o] = dom * v[2]; |
| 436 |
| 437 |
| 438 |
sprintf(errmsg, "outgoing BSDF hemisphere off by %.1f%%", |
| 439 |
| 440 |
| 441 |
| 442 |
| 443 |
for (o = dp->nout; o--; ) |
| 444 |
omega_oarr[o] *= dom; |
| 445 |
nneg = 0; /* check outgoing totals */ |
| 446 |
for (i = 0; i < dp->ninc; i++) { |
| 447 |
hemi_total = .0; |
| 448 |
| 449 |
double f = BSDF_value(dp,i,o); |
| 450 |
if (f >= .0) |
| 451 |
hemi_total += f*omega_oarr[o]; |
| 452 |
else { |
| 453 |
nneg += (f < -FTINY); |
| 454 |
BSDF_value(dp,i,o) = .0f; |
| 455 |
| 456 |
| 457 |
if (hemi_total > 1.01) { |
| 458 |
sprintf(errmsg, |
| 459 |
"incoming BSDF direction %d passes %.1f%% of light", |
| 460 |
i, 100.*hemi_total); |
| 461 |
| 462 |
| 463 |
| 464 |
if (nneg) { |
| 465 |
sprintf(errmsg, "%d negative BSDF values (ignored)", nneg); |
| 466 |
| 467 |
| 468 |
full_total = .0; /* reverse roles and check again */ |
| 469 |
for (o = 0; o < dp->nout; o++) { |
| 470 |
hemi_total = .0; |
| 471 |
| 472 |
hemi_total += BSDF_value(dp,i,o) * omega_iarr[i]; |
| 473 |
| 474 |
| 475 |
sprintf(errmsg, |
| 476 |
"outgoing BSDF direction %d collects %.1f%% of light", |
| 477 |
o, 100.*hemi_total); |
| 478 |
| 479 |
| 480 |
full_total += hemi_total*omega_oarr[o]; |
| 481 |
| 482 |
full_total /= PI; |
| 483 |
if (full_total > 1.00001) { |
| 484 |
sprintf(errmsg, "BSDF transfers %.4f%% of light", |
| 485 |
100.*full_total); |
| 486 |
| 487 |
| 488 |
| 489 |
return(1); |
| 490 |
| 491 |
| 492 |
| 493 |
struct BSDF_data * |
| 494 |
load_BSDF( /* load BSDF data from file */ |
| 495 |
char *fname |
| 496 |
| 497 |
| 498 |
char *path; |
| 499 |
ezxml_t fl, wtl, wld, wdb; |
| 500 |
struct BSDF_data *dp; |
| 501 |
| 502 |
path = getpath(fname, getrlibpath(), R_OK); |
| 503 |
if (path == NULL) { |
| 504 |
sprintf(errmsg, "cannot find BSDF file \"%s\"", fname); |
| 505 |
| 506 |
return(NULL); |
| 507 |
| 508 |
fl = ezxml_parse_file(path); |
| 509 |
if (fl == NULL) { |
| 510 |
sprintf(errmsg, "cannot open BSDF \"%s\"", path); |
| 511 |
| 512 |
return(NULL); |
| 513 |
| 514 |
if (ezxml_error(fl)[0]) { |
| 515 |
sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl)); |
| 516 |
| 517 |
ezxml_free(fl); |
| 518 |
return(NULL); |
| 519 |
| 520 |
if (strcmp(ezxml_name(fl), "WindowElement")) { |
| 521 |
sprintf(errmsg, |
| 522 |
"BSDF \"%s\": top level node not 'WindowElement'", |
| 523 |
path); |
| 524 |
| 525 |
ezxml_free(fl); |
| 526 |
return(NULL); |
| 527 |
| 528 |
wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer"); |
| 529 |
load_angle_basis(ezxml_child(ezxml_child(wtl, |
| 530 |
"DataDefinition"), "AngleBasis")); |
| 531 |
dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data)); |
| 532 |
load_geometry(dp, ezxml_child(wtl, "Material")); |
| 533 |
for (wld = ezxml_child(wtl, "WavelengthData"); |
| 534 |
wld != NULL; wld = wld->next) { |
| 535 |
if (strcmp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible")) |
| 536 |
continue; |
| 537 |
wdb = ezxml_child(wld, "WavelengthDataBlock"); |
| 538 |
if (wdb == NULL) continue; |
| 539 |
if (strcmp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")), |
| 540 |
"Transmission Front")) |
| 541 |
continue; |
| 542 |
load_bsdf_data(dp, wdb); /* load front BTDF */ |
| 543 |
break; /* ignore the rest */ |
| 544 |
| 545 |
ezxml_free(fl); /* done with XML file */ |
| 546 |
if (!check_bsdf_data(dp)) { |
| 547 |
sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path); |
| 548 |
| 549 |
free_BSDF(dp); |
| 550 |
dp = NULL; |
| 551 |
| 552 |
return(dp); |
| 553 |
| 554 |
| 555 |
| 556 |
void |
| 557 |
free_BSDF( /* free BSDF data structure */ |
| 558 |
struct BSDF_data *b |
| 559 |
| 560 |
| 561 |
if (b == NULL) |
| 562 |
return; |
| 563 |
if (b->mgf != NULL) |
| 564 |
free(b->mgf); |
| 565 |
if (b->bsdf != NULL) |
| 566 |
free(b->bsdf); |
| 567 |
free(b); |
| 568 |
| 569 |
| 570 |
| 571 |
int |
| 572 |
r_BSDF_incvec( /* compute random input vector at given location */ |
| 573 |
FVECT v, |
| 574 |
struct BSDF_data *b, |
| 575 |
int i, |
| 576 |
double rv, |
| 577 |
MAT4 xm |
| 578 |
| 579 |
| 580 |
FVECT pert; |
| 581 |
double rad; |
| 582 |
int j; |
| 583 |
| 584 |
if (!getBSDF_incvec(v, b, i)) |
| 585 |
return(0); |
| 586 |
rad = sqrt(getBSDF_incohm(b, i) / PI); |
| 587 |
multisamp(pert, 3, rv); |
| 588 |
for (j = 0; j < 3; j++) |
| 589 |
v[j] += rad*(2.*pert[j] - 1.); |
| 590 |
if (xm != NULL) |
| 591 |
multv3(v, v, xm); |
| 592 |
return(normalize(v) != 0.0); |
| 593 |
| 594 |
| 595 |
| 596 |
int |
| 597 |
r_BSDF_outvec( /* compute random output vector at given location */ |
| 598 |
FVECT v, |
| 599 |
| 600 |
int o, |
| 601 |
double rv, |
| 602 |
MAT4 xm |
| 603 |
| 604 |
| 605 |
FVECT pert; |
| 606 |
double rad; |
| 607 |
int j; |
| 608 |
| 609 |
if (!getBSDF_outvec(v, b, o)) |
| 610 |
return(0); |
| 611 |
rad = sqrt(getBSDF_outohm(b, o) / PI); |
| 612 |
| 613 |
| 614 |
| 615 |
if (xm != NULL) |
| 616 |
multv3(v, v, xm); |
| 617 |
| 618 |
| 619 |
| 620 |
| 621 |
static int |
| 622 |
addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */ |
| 623 |
char *xfarg[], |
| 624 |
FVECT xp, |
| 625 |
FVECT yp, |
| 626 |
FVECT zp |
| 627 |
| 628 |
| 629 |
static char bufs[3][16]; |
| 630 |
int bn = 0; |
| 631 |
char **xfp = xfarg; |
| 632 |
double theta; |
| 633 |
| 634 |
if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) { |
| 635 |
/* Special case for X' along Z-axis */ |
| 636 |
theta = -atan2(yp[0], yp[1]); |
| 637 |
*xfp++ = "-ry"; |
| 638 |
*xfp++ = xp[2] < 0.0 ? "90" : "-90"; |
| 639 |
*xfp++ = "-rz"; |
| 640 |
sprintf(bufs[bn], "%f", theta*(180./PI)); |
| 641 |
*xfp++ = bufs[bn++]; |
| 642 |
return(xfp - xfarg); |
| 643 |
| 644 |
theta = atan2(yp[2], zp[2]); |
| 645 |
if (!FEQ(theta,0.0)) { |
| 646 |
*xfp++ = "-rx"; |
| 647 |
| 648 |
| 649 |
| 650 |
theta = asin(-xp[2]); |
| 651 |
| 652 |
*xfp++ = "-ry"; |
| 653 |
sprintf(bufs[bn], " %f", theta*(180./PI)); |
| 654 |
| 655 |
| 656 |
theta = atan2(xp[1], xp[0]); |
| 657 |
| 658 |
*xfp++ = "-rz"; |
| 659 |
| 660 |
| 661 |
| 662 |
*xfp = NULL; |
| 663 |
| 664 |
| 665 |
| 666 |
| 667 |
int |
| 668 |
getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */ |
| 669 |
MAT4 xm, |
| 670 |
FVECT nrm, |
| 671 |
UpDir ud, |
| 672 |
char *xfbuf |
| 673 |
| 674 |
| 675 |
char *xfargs[7]; |
| 676 |
XF myxf; |
| 677 |
FVECT updir, xdest, ydest; |
| 678 |
int i; |
| 679 |
| 680 |
updir[0] = updir[1] = updir[2] = 0.; |
| 681 |
switch (ud) { |
| 682 |
case UDzneg: |
| 683 |
updir[2] = -1.; |
| 684 |
break; |
| 685 |
case UDyneg: |
| 686 |
updir[1] = -1.; |
| 687 |
break; |
| 688 |
case UDxneg: |
| 689 |
updir[0] = -1.; |
| 690 |
break; |
| 691 |
case UDxpos: |
| 692 |
updir[0] = 1.; |
| 693 |
break; |
| 694 |
case UDypos: |
| 695 |
updir[1] = 1.; |
| 696 |
break; |
| 697 |
case UDzpos: |
| 698 |
updir[2] = 1.; |
| 699 |
break; |
| 700 |
case UDunknown: |
| 701 |
return(0); |
| 702 |
| 703 |
fcross(xdest, updir, nrm); |
| 704 |
if (normalize(xdest) == 0.0) |
| 705 |
return(0); |
| 706 |
fcross(ydest, nrm, xdest); |
| 707 |
xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs); |
| 708 |
copymat4(xm, myxf.xfm); |
| 709 |
if (xfbuf == NULL) |
| 710 |
return(1); |
| 711 |
/* return xf arguments as well */ |
| 712 |
for (i = 0; xfargs[i] != NULL; i++) { |
| 713 |
*xfbuf++ = ' '; |
| 714 |
strcpy(xfbuf, xfargs[i]); |
| 715 |
while (*xfbuf) ++xfbuf; |
| 716 |
| 717 |
return(1); |
| 718 |
