| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf.c,v 2.4 2010/07/03 05:28:05 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for handling BSDF data
| 6 |
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include "bsdf.h"
| 10 |
#include "paths.h"
| 11 |
#include "ezxml.h"
| 12 |
#include <ctype.h>
| 13 |
| 14 |
#define MAXLATS 46 /* maximum number of latitudes */
| 15 |
| 16 |
/* BSDF angle specification */
| 17 |
typedef struct {
| 18 |
char name[64]; /* basis name */
| 19 |
int nangles; /* total number of directions */
| 20 |
struct {
| 21 |
float tmin; /* starting theta */
| 22 |
short nphis; /* number of phis (0 term) */
| 23 |
} lat[MAXLATS+1]; /* latitudes */
| 24 |
} ANGLE_BASIS;
| 25 |
| 26 |
#define MAXABASES 7 /* limit on defined bases */
| 27 |
| 28 |
static ANGLE_BASIS abase_list[MAXABASES] = {
| 29 |
| 30 |
"LBNL/Klems Full", 145,
| 31 |
{ {-5., 1},
| 32 |
{5., 8},
| 33 |
{15., 16},
| 34 |
{25., 20},
| 35 |
{35., 24},
| 36 |
{45., 24},
| 37 |
{55., 24},
| 38 |
{65., 16},
| 39 |
{75., 12},
| 40 |
{90., 0} }
| 41 |
| 42 |
"LBNL/Klems Half", 73,
| 43 |
{ {-6.5, 1},
| 44 |
{6.5, 8},
| 45 |
{19.5, 12},
| 46 |
{32.5, 16},
| 47 |
{46.5, 20},
| 48 |
{61.5, 12},
| 49 |
{76.5, 4},
| 50 |
{90., 0} }
| 51 |
| 52 |
"LBNL/Klems Quarter", 41,
| 53 |
{ {-9., 1},
| 54 |
{9., 8},
| 55 |
{27., 12},
| 56 |
{46., 12},
| 57 |
{66., 8},
| 58 |
{90., 0} }
| 59 |
| 60 |
| 61 |
| 62 |
static int nabases = 3; /* current number of defined bases */
| 63 |
| 64 |
#define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
| 65 |
| 66 |
// returns the name of the given tag
| 67 |
#ifdef ezxml_name
| 68 |
#undef ezxml_name
| 69 |
static char *
| 70 |
ezxml_name(ezxml_t xml)
| 71 |
| 72 |
if (xml == NULL)
| 73 |
return(NULL);
| 74 |
return(xml->name);
| 75 |
| 76 |
#endif
| 77 |
| 78 |
// returns the given tag's character content or empty string if none
| 79 |
#ifdef ezxml_txt
| 80 |
#undef ezxml_txt
| 81 |
static char *
| 82 |
ezxml_txt(ezxml_t xml)
| 83 |
| 84 |
if (xml == NULL)
| 85 |
return("");
| 86 |
return(xml->txt);
| 87 |
| 88 |
#endif
| 89 |
| 90 |
| 91 |
static int
| 92 |
ab_getvec( /* get vector for this angle basis index */
| 93 |
FVECT v,
| 94 |
int ndx,
| 95 |
void *p
| 96 |
| 97 |
| 98 |
ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
| 99 |
int li;
| 100 |
double pol, azi, d;
| 101 |
| 102 |
if ((ndx < 0) | (ndx >= ab->nangles))
| 103 |
return(0);
| 104 |
for (li = 0; ndx >= ab->lat[li].nphis; li++)
| 105 |
ndx -= ab->lat[li].nphis;
| 106 |
pol = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin);
| 107 |
azi = 2.*PI*ndx/ab->lat[li].nphis;
| 108 |
v[2] = d = cos(pol);
| 109 |
d = sqrt(1. - d*d); /* sin(pol) */
| 110 |
v[0] = cos(azi)*d;
| 111 |
v[1] = sin(azi)*d;
| 112 |
return(1);
| 113 |
| 114 |
| 115 |
| 116 |
static int
| 117 |
ab_getndx( /* get index corresponding to the given vector */
| 118 |
FVECT v,
| 119 |
void *p
| 120 |
| 121 |
| 122 |
| 123 |
int li, ndx;
| 124 |
double pol, azi, d;
| 125 |
| 126 |
if ((v[2] < -1.0) | (v[2] > 1.0))
| 127 |
return(-1);
| 128 |
pol = 180.0/PI*acos(v[2]);
| 129 |
azi = 180.0/PI*atan2(v[1], v[0]);
| 130 |
if (azi < 0.0) azi += 360.0;
| 131 |
for (li = 1; ab->lat[li].tmin <= pol; li++)
| 132 |
if (!ab->lat[li].nphis)
| 133 |
return(-1);
| 134 |
--li;
| 135 |
ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
| 136 |
if (ndx >= ab->lat[li].nphis) ndx = 0;
| 137 |
while (li--)
| 138 |
ndx += ab->lat[li].nphis;
| 139 |
return(ndx);
| 140 |
| 141 |
| 142 |
| 143 |
static double
| 144 |
ab_getohm( /* get solid angle for this angle basis index */
| 145 |
int ndx,
| 146 |
void *p
| 147 |
| 148 |
| 149 |
| 150 |
int li;
| 151 |
double theta, theta1;
| 152 |
| 153 |
| 154 |
return(0);
| 155 |
| 156 |
| 157 |
theta1 = PI/180. * ab->lat[li+1].tmin;
| 158 |
if (ab->lat[li].nphis == 1) { /* special case */
| 159 |
if (ab->lat[li].tmin > FTINY)
| 160 |
error(USER, "unsupported BSDF coordinate system");
| 161 |
return(2.*PI*(1. - cos(theta1)));
| 162 |
| 163 |
theta = PI/180. * ab->lat[li].tmin;
| 164 |
return(2.*PI*(cos(theta) - cos(theta1))/(double)ab->lat[li].nphis);
| 165 |
| 166 |
| 167 |
| 168 |
static int
| 169 |
ab_getvecR( /* get reverse vector for this angle basis index */
| 170 |
FVECT v,
| 171 |
int ndx,
| 172 |
void *p
| 173 |
| 174 |
| 175 |
if (!ab_getvec(v, ndx, p))
| 176 |
return(0);
| 177 |
| 178 |
v[0] = -v[0];
| 179 |
v[1] = -v[1];
| 180 |
v[2] = -v[2];
| 181 |
| 182 |
return(1);
| 183 |
| 184 |
| 185 |
| 186 |
static int
| 187 |
ab_getndxR( /* get index corresponding to the reverse vector */
| 188 |
FVECT v,
| 189 |
void *p
| 190 |
| 191 |
| 192 |
FVECT v2;
| 193 |
| 194 |
v2[0] = -v[0];
| 195 |
v2[1] = -v[1];
| 196 |
v2[2] = -v[2];
| 197 |
| 198 |
return ab_getndx(v2, p);
| 199 |
| 200 |
| 201 |
| 202 |
static void
| 203 |
load_angle_basis( /* load custom BSDF angle basis */
| 204 |
ezxml_t wab
| 205 |
| 206 |
| 207 |
char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName"));
| 208 |
ezxml_t wbb;
| 209 |
int i;
| 210 |
| 211 |
if (!abname || !*abname)
| 212 |
return;
| 213 |
for (i = nabases; i--; )
| 214 |
if (!strcmp(abname, abase_list[i].name))
| 215 |
return; /* assume it's the same */
| 216 |
if (nabases >= MAXABASES)
| 217 |
error(INTERNAL, "too many angle bases");
| 218 |
strcpy(abase_list[nabases].name, abname);
| 219 |
abase_list[nabases].nangles = 0;
| 220 |
for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock");
| 221 |
wbb != NULL; i++, wbb = wbb->next) {
| 222 |
if (i >= MAXLATS)
| 223 |
error(INTERNAL, "too many latitudes in custom basis");
| 224 |
abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt(
| 225 |
ezxml_child(ezxml_child(wbb,
| 226 |
"ThetaBounds"), "UpperTheta")));
| 227 |
if (!i)
| 228 |
abase_list[nabases].lat[i].tmin =
| 229 |
-abase_list[nabases].lat[i+1].tmin;
| 230 |
else if (!FEQ(atof(ezxml_txt(ezxml_child(ezxml_child(wbb,
| 231 |
"ThetaBounds"), "LowerTheta"))),
| 232 |
abase_list[nabases].lat[i].tmin))
| 233 |
error(WARNING, "theta values disagree in custom basis");
| 234 |
abase_list[nabases].nangles +=
| 235 |
abase_list[nabases].lat[i].nphis =
| 236 |
atoi(ezxml_txt(ezxml_child(wbb, "nPhis")));
| 237 |
| 238 |
abase_list[nabases++].lat[i].nphis = 0;
| 239 |
| 240 |
| 241 |
| 242 |
static void
| 243 |
load_bsdf_data( /* load BSDF distribution for this wavelength */
| 244 |
struct BSDF_data *dp,
| 245 |
ezxml_t wdb
| 246 |
| 247 |
| 248 |
char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
| 249 |
char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
| 250 |
char *sdata;
| 251 |
int i;
| 252 |
| 253 |
if ((!cbasis || !*cbasis) | (!rbasis || !*rbasis)) {
| 254 |
error(WARNING, "missing column/row basis for BSDF");
| 255 |
return;
| 256 |
| 257 |
| 258 |
if (!strcmp(cbasis, abase_list[i].name)) {
| 259 |
dp->ninc = abase_list[i].nangles;
| 260 |
dp->ib_priv = (void *)&abase_list[i];
| 261 |
dp->ib_vec = ab_getvecR;
| 262 |
dp->ib_ndx = ab_getndxR;
| 263 |
dp->ib_ohm = ab_getohm;
| 264 |
break;
| 265 |
| 266 |
if (i < 0) {
| 267 |
sprintf(errmsg, "undefined ColumnAngleBasis '%s'", cbasis);
| 268 |
error(WARNING, errmsg);
| 269 |
return;
| 270 |
| 271 |
| 272 |
if (!strcmp(rbasis, abase_list[i].name)) {
| 273 |
dp->nout = abase_list[i].nangles;
| 274 |
dp->ob_priv = (void *)&abase_list[i];
| 275 |
dp->ob_vec = ab_getvec;
| 276 |
dp->ob_ndx = ab_getndx;
| 277 |
dp->ob_ohm = ab_getohm;
| 278 |
break;
| 279 |
| 280 |
if (i < 0) {
| 281 |
sprintf(errmsg, "undefined RowAngleBasis '%s'", cbasis);
| 282 |
| 283 |
return;
| 284 |
| 285 |
/* read BSDF data */
| 286 |
sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData"));
| 287 |
if (!sdata || !*sdata) {
| 288 |
error(WARNING, "missing BSDF ScatteringData");
| 289 |
return;
| 290 |
| 291 |
dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout);
| 292 |
if (dp->bsdf == NULL)
| 293 |
error(SYSTEM, "out of memory in load_bsdf_data");
| 294 |
for (i = 0; i < dp->ninc*dp->nout; i++) {
| 295 |
char *sdnext = fskip(sdata);
| 296 |
if (sdnext == NULL) {
| 297 |
error(WARNING, "bad/missing BSDF ScatteringData");
| 298 |
free(dp->bsdf); dp->bsdf = NULL;
| 299 |
return;
| 300 |
| 301 |
while (*sdnext && isspace(*sdnext))
| 302 |
sdnext++;
| 303 |
if (*sdnext == ',') sdnext++;
| 304 |
dp->bsdf[i] = atof(sdata);
| 305 |
sdata = sdnext;
| 306 |
| 307 |
while (isspace(*sdata))
| 308 |
sdata++;
| 309 |
if (*sdata) {
| 310 |
sprintf(errmsg, "%d extra characters after BSDF ScatteringData",
| 311 |
(int)strlen(sdata));
| 312 |
| 313 |
| 314 |
| 315 |
| 316 |
| 317 |
static int
| 318 |
check_bsdf_data( /* check that BSDF data is sane */
| 319 |
| 320 |
| 321 |
| 322 |
double *omega_iarr, *omega_oarr;
| 323 |
double dom, contrib, hemi_total;
| 324 |
int nneg;
| 325 |
FVECT v;
| 326 |
int i, o;
| 327 |
| 328 |
if (dp == NULL || dp->bsdf == NULL)
| 329 |
return(0);
| 330 |
omega_iarr = (double *)calloc(dp->ninc, sizeof(double));
| 331 |
omega_oarr = (double *)calloc(dp->nout, sizeof(double));
| 332 |
if ((omega_iarr == NULL) | (omega_oarr == NULL))
| 333 |
error(SYSTEM, "out of memory in check_bsdf_data");
| 334 |
/* incoming projected solid angles */
| 335 |
hemi_total = .0;
| 336 |
for (i = dp->ninc; i--; ) {
| 337 |
dom = getBSDF_incohm(dp,i);
| 338 |
if (dom <= .0) {
| 339 |
error(WARNING, "zero/negative incoming solid angle");
| 340 |
continue;
| 341 |
| 342 |
if (!getBSDF_incvec(v,dp,i) || v[2] > FTINY) {
| 343 |
error(WARNING, "illegal incoming BSDF direction");
| 344 |
free(omega_iarr); free(omega_oarr);
| 345 |
return(0);
| 346 |
| 347 |
hemi_total += omega_iarr[i] = dom * -v[2];
| 348 |
| 349 |
if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) {
| 350 |
sprintf(errmsg, "incoming BSDF hemisphere off by %.1f%%",
| 351 |
100.*(hemi_total/PI - 1.));
| 352 |
| 353 |
| 354 |
dom = PI / hemi_total; /* fix normalization */
| 355 |
| 356 |
omega_iarr[i] *= dom;
| 357 |
/* outgoing projected solid angles */
| 358 |
hemi_total = .0;
| 359 |
for (o = dp->nout; o--; ) {
| 360 |
dom = getBSDF_outohm(dp,o);
| 361 |
if (dom <= .0) {
| 362 |
error(WARNING, "zero/negative outgoing solid angle");
| 363 |
continue;
| 364 |
| 365 |
if (!getBSDF_outvec(v,dp,o) || v[2] < -FTINY) {
| 366 |
error(WARNING, "illegal outgoing BSDF direction");
| 367 |
| 368 |
return(0);
| 369 |
| 370 |
hemi_total += omega_oarr[o] = dom * v[2];
| 371 |
| 372 |
| 373 |
sprintf(errmsg, "outgoing BSDF hemisphere off by %.1f%%",
| 374 |
| 375 |
| 376 |
| 377 |
| 378 |
| 379 |
omega_oarr[o] *= dom;
| 380 |
nneg = 0; /* check outgoing totals */
| 381 |
for (i = 0; i < dp->ninc; i++) {
| 382 |
hemi_total = .0;
| 383 |
| 384 |
double f = BSDF_value(dp,i,o);
| 385 |
if (f >= .0)
| 386 |
hemi_total += f*omega_oarr[o];
| 387 |
else {
| 388 |
nneg += (f < -FTINY);
| 389 |
BSDF_value(dp,i,o) = .0f;
| 390 |
| 391 |
| 392 |
if (hemi_total > 1.02) {
| 393 |
sprintf(errmsg,
| 394 |
"incoming BSDF direction %d passes %.1f%% of light",
| 395 |
i, 100.*hemi_total);
| 396 |
| 397 |
| 398 |
| 399 |
if (nneg) {
| 400 |
sprintf(errmsg, "%d negative BSDF values (ignored)", nneg);
| 401 |
| 402 |
| 403 |
/* reverse roles and check again */
| 404 |
for (o = 0; o < dp->nout; o++) {
| 405 |
hemi_total = .0;
| 406 |
| 407 |
hemi_total += BSDF_value(dp,i,o) * omega_iarr[i];
| 408 |
| 409 |
| 410 |
sprintf(errmsg,
| 411 |
"outgoing BSDF direction %d collects %.1f%% of light",
| 412 |
o, 100.*hemi_total);
| 413 |
| 414 |
| 415 |
| 416 |
| 417 |
return(1);
| 418 |
| 419 |
| 420 |
struct BSDF_data *
| 421 |
load_BSDF( /* load BSDF data from file */
| 422 |
char *fname
| 423 |
| 424 |
| 425 |
char *path;
| 426 |
ezxml_t fl, wtl, wld, wdb;
| 427 |
struct BSDF_data *dp;
| 428 |
| 429 |
path = getpath(fname, getrlibpath(), R_OK);
| 430 |
if (path == NULL) {
| 431 |
sprintf(errmsg, "cannot find BSDF file \"%s\"", fname);
| 432 |
| 433 |
return(NULL);
| 434 |
| 435 |
fl = ezxml_parse_file(path);
| 436 |
if (fl == NULL) {
| 437 |
sprintf(errmsg, "cannot open BSDF \"%s\"", path);
| 438 |
| 439 |
return(NULL);
| 440 |
| 441 |
if (ezxml_error(fl)[0]) {
| 442 |
sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl));
| 443 |
| 444 |
ezxml_free(fl);
| 445 |
return(NULL);
| 446 |
| 447 |
if (strcmp(ezxml_name(fl), "WindowElement")) {
| 448 |
sprintf(errmsg,
| 449 |
"BSDF \"%s\": top level node not 'WindowElement'",
| 450 |
path);
| 451 |
| 452 |
ezxml_free(fl);
| 453 |
return(NULL);
| 454 |
| 455 |
wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
| 456 |
load_angle_basis(ezxml_child(ezxml_child(wtl,
| 457 |
"DataDefinition"), "AngleBasis"));
| 458 |
dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data));
| 459 |
for (wld = ezxml_child(wtl, "WavelengthData");
| 460 |
wld != NULL; wld = wld->next) {
| 461 |
if (strcmp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible"))
| 462 |
continue;
| 463 |
wdb = ezxml_child(wld, "WavelengthDataBlock");
| 464 |
if (wdb == NULL) continue;
| 465 |
if (strcmp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")),
| 466 |
"Transmission Front"))
| 467 |
continue;
| 468 |
load_bsdf_data(dp, wdb); /* load front BTDF */
| 469 |
break; /* ignore the rest */
| 470 |
| 471 |
ezxml_free(fl); /* done with XML file */
| 472 |
if (!check_bsdf_data(dp)) {
| 473 |
sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path);
| 474 |
| 475 |
free_BSDF(dp);
| 476 |
dp = NULL;
| 477 |
| 478 |
return(dp);
| 479 |
| 480 |
| 481 |
| 482 |
void
| 483 |
free_BSDF( /* free BSDF data structure */
| 484 |
struct BSDF_data *b
| 485 |
| 486 |
| 487 |
if (b == NULL)
| 488 |
return;
| 489 |
if (b->bsdf != NULL)
| 490 |
free(b->bsdf);
| 491 |
free(b);
| 492 |
| 493 |
| 494 |
| 495 |
int
| 496 |
r_BSDF_incvec( /* compute random input vector at given location */
| 497 |
FVECT v,
| 498 |
struct BSDF_data *b,
| 499 |
int i,
| 500 |
double rv,
| 501 |
MAT4 xm
| 502 |
| 503 |
| 504 |
FVECT pert;
| 505 |
double rad;
| 506 |
int j;
| 507 |
| 508 |
if (!getBSDF_incvec(v, b, i))
| 509 |
return(0);
| 510 |
rad = sqrt(getBSDF_incohm(b, i) / PI);
| 511 |
multisamp(pert, 3, rv);
| 512 |
for (j = 0; j < 3; j++)
| 513 |
v[j] += rad*(2.*pert[j] - 1.);
| 514 |
if (xm != NULL)
| 515 |
multv3(v, v, xm);
| 516 |
return(normalize(v) != 0.0);
| 517 |
| 518 |
| 519 |
| 520 |
int
| 521 |
r_BSDF_outvec( /* compute random output vector at given location */
| 522 |
FVECT v,
| 523 |
| 524 |
int o,
| 525 |
double rv,
| 526 |
MAT4 xm
| 527 |
| 528 |
| 529 |
FVECT pert;
| 530 |
double rad;
| 531 |
int j;
| 532 |
| 533 |
if (!getBSDF_outvec(v, b, o))
| 534 |
return(0);
| 535 |
rad = sqrt(getBSDF_outohm(b, o) / PI);
| 536 |
| 537 |
| 538 |
| 539 |
if (xm != NULL)
| 540 |
multv3(v, v, xm);
| 541 |
| 542 |
| 543 |
| 544 |
| 545 |
static int
| 546 |
addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
| 547 |
char *xfarg[],
| 548 |
FVECT xp,
| 549 |
FVECT yp,
| 550 |
FVECT zp
| 551 |
| 552 |
| 553 |
static char bufs[3][16];
| 554 |
int bn = 0;
| 555 |
char **xfp = xfarg;
| 556 |
double theta;
| 557 |
| 558 |
if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
| 559 |
/* Special case for X' along Z-axis */
| 560 |
theta = -atan2(yp[0], yp[1]);
| 561 |
*xfp++ = "-ry";
| 562 |
*xfp++ = xp[2] < 0.0 ? "90" : "-90";
| 563 |
*xfp++ = "-rz";
| 564 |
sprintf(bufs[bn], "%f", theta*(180./PI));
| 565 |
*xfp++ = bufs[bn++];
| 566 |
return(xfp - xfarg);
| 567 |
| 568 |
theta = atan2(yp[2], zp[2]);
| 569 |
if (!FEQ(theta,0.0)) {
| 570 |
*xfp++ = "-rx";
| 571 |
| 572 |
| 573 |
| 574 |
theta = asin(-xp[2]);
| 575 |
| 576 |
*xfp++ = "-ry";
| 577 |
sprintf(bufs[bn], " %f", theta*(180./PI));
| 578 |
| 579 |
| 580 |
theta = atan2(xp[1], xp[0]);
| 581 |
| 582 |
*xfp++ = "-rz";
| 583 |
| 584 |
| 585 |
| 586 |
*xfp = NULL;
| 587 |
| 588 |
| 589 |
| 590 |
| 591 |
int
| 592 |
getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */
| 593 |
MAT4 xm,
| 594 |
FVECT nrm,
| 595 |
UpDir ud
| 596 |
| 597 |
| 598 |
char *xfargs[7];
| 599 |
XF myxf;
| 600 |
FVECT updir, xdest, ydest;
| 601 |
| 602 |
updir[0] = updir[1] = updir[2] = 0.;
| 603 |
switch (ud) {
| 604 |
case UDzneg:
| 605 |
updir[2] = -1.;
| 606 |
break;
| 607 |
case UDyneg:
| 608 |
updir[1] = -1.;
| 609 |
break;
| 610 |
case UDxneg:
| 611 |
updir[0] = -1.;
| 612 |
break;
| 613 |
case UDxpos:
| 614 |
updir[0] = 1.;
| 615 |
break;
| 616 |
case UDypos:
| 617 |
updir[1] = 1.;
| 618 |
break;
| 619 |
case UDzpos:
| 620 |
updir[2] = 1.;
| 621 |
break;
| 622 |
case UDunknown:
| 623 |
return(0);
| 624 |
| 625 |
fcross(xdest, updir, nrm);
| 626 |
if (normalize(xdest) == 0.0)
| 627 |
return(0);
| 628 |
fcross(ydest, nrm, xdest);
| 629 |
xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs);
| 630 |
copymat4(xm, myxf.xfm);
| 631 |
return(1);
| 632 |
