--- ray/src/common/bsdf.c 2015/02/08 22:14:50 2.50 +++ ray/src/common/bsdf.c 2020/05/14 19:20:13 2.58 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf.c,v 2.50 2015/02/08 22:14:50 greg Exp $"; +static const char RCSid[] = "$Id: bsdf.c,v 2.58 2020/05/14 19:20:13 greg Exp $"; #endif /* * bsdf.c @@ -47,9 +47,12 @@ const SDCDst SDemptyCD; /* Cache of loaded BSDFs */ struct SDCache_s *SDcacheList = NULL; -/* Retain BSDFs in cache list */ +/* Retain BSDFs in cache list? */ int SDretainSet = SDretainNone; +/* Maximum cache size for any given BSDF? */ +unsigned long SDmaxCache = 0; /* 0 == unlimited */ + /* Report any error to the indicated stream */ SDError SDreportError(SDError ec, FILE *fp) @@ -422,6 +425,7 @@ SDcacheFile(const char *fname) if (fname == NULL || !*fname) return NULL; SDerrorDetail[0] = '\0'; + /* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */ if ((sd = SDgetCache(fname)) == NULL) { SDreportError(SDEmemory, stderr); return NULL; @@ -429,8 +433,9 @@ SDcacheFile(const char *fname) if (!SDisLoaded(sd) && (ec = SDloadFile(sd, fname))) { SDreportError(ec, stderr); SDfreeCache(sd); - return NULL; + sd = NULL; } + /* END MUTEX LOCK */ return sd; } @@ -494,7 +499,7 @@ SDsampComponent(SDValue *sv, FVECT ioVec, double randX sv->cieY = cd->cTotal; if (sv->cieY <= 1e-6) { /* nothing to sample? */ sv->spec = c_dfcolor; - memset(ioVec, 0, 3*sizeof(double)); + memset(ioVec, 0, sizeof(FVECT)); return SDEnone; } /* compute sample direction */ @@ -513,8 +518,7 @@ SDsampComponent(SDValue *sv, FVECT ioVec, double randX c_cmix(&sv->spec, d, &sv->spec, coef[n], &sdc->cspec[n]); d += coef[n]; } - /* make sure everything is set */ - c_ccvt(&sv->spec, C_CSXY+C_CSSPEC); + c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */ return SDEnone; } @@ -595,11 +599,12 @@ SDsizeBSDF(double *projSA, const FVECT v1, const RREAL rdf = sd->rb; tdf = (sd->tb != NULL) ? sd->tb : sd->tf; } - if (v2 != NULL) /* bidirectional? */ + if (v2 != NULL) { /* bidirectional? */ if (v1[2] > 0 ^ v2[2] > 0) rdf = NULL; else tdf = NULL; + } ec = SDEdata; /* run through components */ for (i = (rdf==NULL) ? 0 : rdf->ncomp; i--; ) { ec = (*rdf->comp[i].func->queryProjSA)(projSA, v1, v2, @@ -646,7 +651,7 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC } else if (inFront) { *sv = sd->tLamb; sdf = (sd->tf != NULL) ? sd->tf : sd->tb; - } else /* inBack */ { + } else /* outFront & !inFront */ { *sv = sd->tLamb; sdf = (sd->tb != NULL) ? sd->tb : sd->tf; } @@ -662,8 +667,7 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC sv->cieY += coef[nch]; } } - /* make sure everything is set */ - c_ccvt(&sv->spec, C_CSXY+C_CSSPEC); + c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */ return SDEnone; } @@ -767,7 +771,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int } if (sv->cieY <= 1e-6) { /* anything to sample? */ sv->cieY = .0; - memset(ioVec, 0, 3*sizeof(double)); + memset(ioVec, 0, sizeof(FVECT)); return SDEnone; } /* scale random variable */ @@ -788,7 +792,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int randX -= sd->tLamb.cieY; } /* else one of cumulative dist. */ - for (i = 0; i < n && randX > cdarr[i]->cTotal; i++) + for (i = 0; i < n && randX >= cdarr[i]->cTotal; i++) randX -= cdarr[i]->cTotal; if (i >= n) return SDEinternal; @@ -813,8 +817,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int done: if (cdarr != NULL) free(cdarr); - /* make sure everything is set */ - c_ccvt(&sv->spec, C_CSXY+C_CSSPEC); + c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */ return SDEnone; }
