--- ray/src/common/bsdf.c 2013/04/21 21:36:23 2.44 +++ ray/src/common/bsdf.c 2020/05/14 19:20:13 2.58 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf.c,v 2.44 2013/04/21 21:36:23 greg Exp $"; +static const char RCSid[] = "$Id: bsdf.c,v 2.58 2020/05/14 19:20:13 greg Exp $"; #endif /* * bsdf.c @@ -47,9 +47,12 @@ const SDCDst SDemptyCD; /* Cache of loaded BSDFs */ struct SDCache_s *SDcacheList = NULL; -/* Retain BSDFs in cache list */ +/* Retain BSDFs in cache list? */ int SDretainSet = SDretainNone; +/* Maximum cache size for any given BSDF? */ +unsigned long SDmaxCache = 0; /* 0 == unlimited */ + /* Report any error to the indicated stream */ SDError SDreportError(SDError ec, FILE *fp) @@ -199,7 +202,7 @@ SDloadFile(SDData *sd, const char *fname) } wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer"); if (wtl == NULL) { - sprintf(SDerrorDetail, "BSDF \"%s\": no optical layers'", + sprintf(SDerrorDetail, "BSDF \"%s\": no optical layers", sd->name); ezxml_free(fl); return SDEformat; @@ -422,6 +425,7 @@ SDcacheFile(const char *fname) if (fname == NULL || !*fname) return NULL; SDerrorDetail[0] = '\0'; + /* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */ if ((sd = SDgetCache(fname)) == NULL) { SDreportError(SDEmemory, stderr); return NULL; @@ -429,8 +433,9 @@ SDcacheFile(const char *fname) if (!SDisLoaded(sd) && (ec = SDloadFile(sd, fname))) { SDreportError(ec, stderr); SDfreeCache(sd); - return NULL; + sd = NULL; } + /* END MUTEX LOCK */ return sd; } @@ -488,16 +493,15 @@ SDsampComponent(SDValue *sv, FVECT ioVec, double randX return SDEargument; /* get cumulative distribution */ VCOPY(inVec, ioVec); + sv->cieY = 0; cd = (*sdc->func->getCDist)(inVec, sdc); - if (cd == NULL) - return SDEmemory; - if (cd->cTotal <= 1e-6) { /* anything to sample? */ + if (cd != NULL) + sv->cieY = cd->cTotal; + if (sv->cieY <= 1e-6) { /* nothing to sample? */ sv->spec = c_dfcolor; - sv->cieY = .0; - memset(ioVec, 0, 3*sizeof(double)); + memset(ioVec, 0, sizeof(FVECT)); return SDEnone; } - sv->cieY = cd->cTotal; /* compute sample direction */ ec = (*sdc->func->sampCDist)(ioVec, randX, cd); if (ec) @@ -514,8 +518,7 @@ SDsampComponent(SDValue *sv, FVECT ioVec, double randX c_cmix(&sv->spec, d, &sv->spec, coef[n], &sdc->cspec[n]); d += coef[n]; } - /* make sure everything is set */ - c_ccvt(&sv->spec, C_CSXY+C_CSSPEC); + c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */ return SDEnone; } @@ -559,8 +562,7 @@ SDdiffuseSamp(FVECT outVec, int outFront, double randX SDmultiSamp(outVec, 2, randX); SDsquare2disk(outVec, outVec[0], outVec[1]); outVec[2] = 1. - outVec[0]*outVec[0] - outVec[1]*outVec[1]; - if (outVec[2] > 0) /* a bit of paranoia */ - outVec[2] = sqrt(outVec[2]); + outVec[2] = sqrt(outVec[2]*(outVec[2]>0)); if (!outFront) /* going out back? */ outVec[2] = -outVec[2]; } @@ -597,11 +599,12 @@ SDsizeBSDF(double *projSA, const FVECT v1, const RREAL rdf = sd->rb; tdf = (sd->tb != NULL) ? sd->tb : sd->tf; } - if (v2 != NULL) /* bidirectional? */ + if (v2 != NULL) { /* bidirectional? */ if (v1[2] > 0 ^ v2[2] > 0) rdf = NULL; else tdf = NULL; + } ec = SDEdata; /* run through components */ for (i = (rdf==NULL) ? 0 : rdf->ncomp; i--; ) { ec = (*rdf->comp[i].func->queryProjSA)(projSA, v1, v2, @@ -619,7 +622,8 @@ SDsizeBSDF(double *projSA, const FVECT v1, const RREAL projSA[0] = M_PI; if (qflags == SDqueryMin+SDqueryMax) projSA[1] = M_PI; - } + } else if (qflags == SDqueryMin+SDqueryMax && projSA[0] > projSA[1]) + projSA[0] = projSA[1]; return SDEnone; } @@ -647,7 +651,7 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC } else if (inFront) { *sv = sd->tLamb; sdf = (sd->tf != NULL) ? sd->tf : sd->tb; - } else /* inBack */ { + } else /* outFront & !inFront */ { *sv = sd->tLamb; sdf = (sd->tb != NULL) ? sd->tb : sd->tf; } @@ -663,8 +667,7 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC sv->cieY += coef[nch]; } } - /* make sure everything is set */ - c_ccvt(&sv->spec, C_CSXY+C_CSSPEC); + c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */ return SDEnone; } @@ -756,23 +759,19 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int return SDEmemory; while (j-- > 0) { /* non-diffuse transmission */ cdarr[i+j] = (*tdf->comp[j].func->getCDist)(inVec, &tdf->comp[j]); - if (cdarr[i+j] == NULL) { - free(cdarr); - return SDEmemory; - } + if (cdarr[i+j] == NULL) + cdarr[i+j] = &SDemptyCD; sv->cieY += cdarr[i+j]->cTotal; } while (i-- > 0) { /* non-diffuse reflection */ cdarr[i] = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]); - if (cdarr[i] == NULL) { - free(cdarr); - return SDEmemory; - } + if (cdarr[i] == NULL) + cdarr[i] = &SDemptyCD; sv->cieY += cdarr[i]->cTotal; } if (sv->cieY <= 1e-6) { /* anything to sample? */ sv->cieY = .0; - memset(ioVec, 0, 3*sizeof(double)); + memset(ioVec, 0, sizeof(FVECT)); return SDEnone; } /* scale random variable */ @@ -793,7 +792,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int randX -= sd->tLamb.cieY; } /* else one of cumulative dist. */ - for (i = 0; i < n && randX < cdarr[i]->cTotal; i++) + for (i = 0; i < n && randX >= cdarr[i]->cTotal; i++) randX -= cdarr[i]->cTotal; if (i >= n) return SDEinternal; @@ -818,8 +817,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int done: if (cdarr != NULL) free(cdarr); - /* make sure everything is set */ - c_ccvt(&sv->spec, C_CSXY+C_CSSPEC); + c_ccvt(&sv->spec, C_CSXY); /* make sure (x,y) is set */ return SDEnone; }
