root/radiance/ray/src/common/bsdf.c
Revision: 2.2
Committed: Fri Jun 19 06:49:25 2009 UTC (16 years, 1 month ago) by greg
Changes since 2.1: +70 -30 lines
Improved error-checking
2 static const char RCSid[] = "$Id: bsdf.c,v 2.1 2009/06/17 20:41:47 greg Exp $";
5 * Routines for handling BSDF data
6 */
7
8 #include "standard.h"
9 #include "bsdf.h"
10 #include "paths.h"
11 #include "ezxml.h"
12 #include <ctype.h>
13
14 #define MAXLATS 46 /* maximum number of latitudes */
15
16 /* BSDF angle specification */
17 typedef struct {
18 char name[64]; /* basis name */
19 int nangles; /* total number of directions */
20 struct {
21 float tmin; /* starting theta */
22 short nphis; /* number of phis (0 term) */
23 } lat[MAXLATS+1]; /* latitudes */
24 } ANGLE_BASIS;
25
26 #define MAXABASES 3 /* limit on defined bases */
27
28 static ANGLE_BASIS abase_list[MAXABASES] = {
29 {
30 "LBNL/Klems Full", 145,
31 { {-5., 1},
32 {5., 8},
33 {15., 16},
34 {25., 20},
35 {35., 24},
36 {45., 24},
37 {55., 24},
38 {65., 16},
39 {75., 12},
40 {90., 0} }
41 }, {
42 "LBNL/Klems Half", 73,
43 { {-6.5, 1},
44 {6.5, 8},
45 {19.5, 12},
46 {32.5, 16},
47 {46.5, 20},
48 {61.5, 12},
49 {76.5, 4},
50 {90., 0} }
51 }, {
52 "LBNL/Klems Quarter", 41,
53 { {-9., 1},
54 {9., 8},
55 {27., 12},
56 {46., 12},
57 {66., 8},
58 {90., 0} }
59 }
60 };
61
62 static int nabases = 3; /* current number of defined bases */
63
64
65 static int
66 ab_getvec( /* get vector for this angle basis index */
67 FVECT v,
68 int ndx,
69 void *p
70 )
71 {
72 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
73 int li;
74 double pol, azi, d;
75
76 if ((ndx < 0) | (ndx >= ab->nangles))
77 return(0);
78 for (li = 0; ndx >= ab->lat[li].nphis; li++)
79 ndx -= ab->lat[li].nphis;
80 pol = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin);
81 azi = 2.*PI*ndx/ab->lat[li].nphis;
82 v[2] = d = cos(pol);
83 d = sqrt(1. - d*d); /* sin(pol) */
84 v[0] = cos(azi)*d;
85 v[1] = sin(azi)*d;
86 return(1);
87 }
88
89
90 static int
91 ab_getndx( /* get index corresponding to the given vector */
92 FVECT v,
93 void *p
94 )
95 {
96 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
97 int li, ndx;
98 double pol, azi, d;
99
100 if ((v[2] < -1.0) | (v[2] > 1.0))
101 return(-1);
102 pol = 180.0/PI*acos(v[2]);
103 azi = 180.0/PI*atan2(v[1], v[0]);
104 if (azi < 0.0) azi += 360.0;
105 for (li = 1; ab->lat[li].tmin <= pol; li++)
106 if (!ab->lat[li].nphis)
107 return(-1);
108 --li;
109 ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
110 if (ndx >= ab->lat[li].nphis) ndx = 0;
111 while (li--)
112 ndx += ab->lat[li].nphis;
113 return(ndx);
114 }
115
116
117 static double
118 ab_getohm( /* get solid angle for this angle basis index */
119 int ndx,
120 void *p
121 )
122 {
123 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
124 int li;
125 double theta, theta1;
126
127 if ((ndx < 0) | (ndx >= ab->nangles))
128 return(0);
129 for (li = 0; ndx >= ab->lat[li].nphis; li++)
130 ndx -= ab->lat[li].nphis;
131 theta1 = PI/180. * ab->lat[li+1].tmin;
132 if (ab->lat[li].nphis == 1) { /* special case */
133 if (ab->lat[li].tmin > FTINY)
134 error(USER, "unsupported BSDF coordinate system");
135 return(2.*PI*(1. - cos(theta1)));
136 }
137 theta = PI/180. * ab->lat[li].tmin;
138 return(2.*PI*(cos(theta) - cos(theta1))/(double)ab->lat[li].nphis);
139 }
140
141
142 static int
143 ab_getvecR( /* get reverse vector for this angle basis index */
144 FVECT v,
145 int ndx,
146 void *p
147 )
148 {
149 if (!ab_getvec(v, ndx, p))
150 return(0);
151
152 v[0] = -v[0];
153 v[1] = -v[1];
154 v[2] = -v[2];
155
156 return(1);
157 }
158
159
160 static int
161 ab_getndxR( /* get index corresponding to the reverse vector */
162 FVECT v,
163 void *p
164 )
165 {
166 FVECT v2;
167
168 v2[0] = -v[0];
169 v2[1] = -v[1];
170 v2[2] = -v[2];
171
172 return ab_getndx(v2, p);
173 }
174
175
176 static void
177 load_bsdf_data( /* load BSDF distribution for this wavelength */
178 struct BSDF_data *dp,
179 ezxml_t wdb
180 )
181 {
182 char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
183 char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
184 char *sdata;
185 int i;
186
187 if ((cbasis == NULL) | (rbasis == NULL)) {
188 error(WARNING, "missing column/row basis for BSDF");
189 return;
190 }
191 /* XXX need to add routines for loading in foreign bases */
192 for (i = nabases; i--; )
193 if (!strcmp(cbasis, abase_list[i].name)) {
194 dp->ninc = abase_list[i].nangles;
195 dp->ib_priv = (void *)&abase_list[i];
196 dp->ib_vec = ab_getvecR;
197 dp->ib_ndx = ab_getndxR;
198 dp->ib_ohm = ab_getohm;
199 break;
200 }
201 if (i < 0) {
202 sprintf(errmsg, "unsupported ColumnAngleBasis '%s'", cbasis);
203 error(WARNING, errmsg);
204 return;
205 }
206 for (i = nabases; i--; )
207 if (!strcmp(rbasis, abase_list[i].name)) {
208 dp->nout = abase_list[i].nangles;
209 dp->ob_priv = (void *)&abase_list[i];
210 dp->ob_vec = ab_getvec;
211 dp->ob_ndx = ab_getndx;
212 dp->ob_ohm = ab_getohm;
213 break;
214 }
215 if (i < 0) {
216 sprintf(errmsg, "unsupported RowAngleBasis '%s'", cbasis);
217 error(WARNING, errmsg);
218 return;
219 }
220 /* read BSDF data */
221 sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData"));
222 if (sdata == NULL) {
223 error(WARNING, "missing BSDF ScatteringData");
224 return;
225 }
226 dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout);
227 if (dp->bsdf == NULL)
228 error(SYSTEM, "out of memory in load_bsdf_data");
229 for (i = 0; i < dp->ninc*dp->nout; i++) {
230 char *sdnext = fskip(sdata);
231 if (sdnext == NULL) {
232 error(WARNING, "bad/missing BSDF ScatteringData");
233 free(dp->bsdf); dp->bsdf = NULL;
234 return;
235 }
236 while (*sdnext && isspace(*sdnext))
237 sdnext++;
238 if (*sdnext == ',') sdnext++;
239 dp->bsdf[i] = atof(sdata);
240 sdata = sdnext;
241 }
242 while (isspace(*sdata))
243 sdata++;
244 if (*sdata) {
245 sprintf(errmsg, "%d extra characters after BSDF ScatteringData",
246 strlen(sdata));
247 error(WARNING, errmsg);
248 }
249 }
250
251
252 static int
253 check_bsdf_data( /* check that BSDF data is sane */
254 struct BSDF_data *dp
255 )
256 {
257 double *omega_iarr, *omega_oarr;
258 double dom, contrib, hemi_total;
259 int nneg;
260 FVECT v;
261 int i, o;
262
263 if (dp == NULL || dp->bsdf == NULL)
264 return(0);
265 omega_iarr = (double *)calloc(dp->ninc, sizeof(double));
266 omega_oarr = (double *)calloc(dp->nout, sizeof(double));
267 if ((omega_iarr == NULL) | (omega_oarr == NULL))
268 error(SYSTEM, "out of memory in check_bsdf_data");
269 /* incoming projected solid angles */
270 hemi_total = .0;
271 for (i = dp->ninc; i--; ) {
272 dom = getBSDF_incohm(dp,i);
273 if (dom <= .0) {
274 error(WARNING, "zero/negative incoming solid angle");
275 continue;
276 }
277 if (!getBSDF_incvec(v,dp,i) || v[2] > FTINY) {
278 error(WARNING, "illegal incoming BSDF direction");
279 free(omega_iarr); free(omega_oarr);
280 return(0);
281 }
282 hemi_total += omega_iarr[i] = dom * -v[2];
283 }
284 if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) {
285 sprintf(errmsg, "incoming BSDF hemisphere off by %.1f%%",
286 100.*(hemi_total/PI - 1.));
287 error(WARNING, errmsg);
288 }
289 dom = PI / hemi_total; /* fix normalization */
290 for (i = dp->ninc; i--; )
291 omega_iarr[i] *= dom;
292 /* outgoing projected solid angles */
293 hemi_total = .0;
294 for (o = dp->nout; o--; ) {
295 dom = getBSDF_outohm(dp,o);
296 if (dom <= .0) {
297 error(WARNING, "zero/negative outgoing solid angle");
298 continue;
299 }
300 if (!getBSDF_outvec(v,dp,o) || v[2] < -FTINY) {
301 error(WARNING, "illegal outgoing BSDF direction");
302 free(omega_iarr); free(omega_oarr);
303 return(0);
304 }
305 hemi_total += omega_oarr[o] = dom * v[2];
306 }
307 if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) {
308 sprintf(errmsg, "outgoing BSDF hemisphere off by %.1f%%",
309 100.*(hemi_total/PI - 1.));
310 error(WARNING, errmsg);
311 }
312 dom = PI / hemi_total; /* fix normalization */
313 for (o = dp->nout; o--; )
314 omega_oarr[o] *= dom;
315 nneg = 0; /* check outgoing totals */
316 for (i = 0; i < dp->ninc; i++) {
317 hemi_total = .0;
318 for (o = dp->nout; o--; ) {
319 double f = BSDF_value(dp,i,o);
320 if (f >= .0)
321 hemi_total += f*omega_oarr[o];
322 else {
323 nneg += (f < -FTINY);
324 BSDF_value(dp,i,o) = .0f;
325 }
326 }
327 if (hemi_total > 1.02) {
328 sprintf(errmsg,
329 "incoming BSDF direction %d passes %.1f%% of light",
330 i, 100.*hemi_total);
331 error(WARNING, errmsg);
332 }
333 }
334 if (nneg) {
335 sprintf(errmsg, "%d negative BSDF values (ignored)", nneg);
336 error(WARNING, errmsg);
337 }
338 /* reverse roles and check again */
339 for (o = 0; o < dp->nout; o++) {
340 hemi_total = .0;
341 for (i = dp->ninc; i--; )
342 hemi_total += BSDF_value(dp,i,o) * omega_iarr[i];
343
344 if (hemi_total > 1.02) {
345 sprintf(errmsg,
346 "outgoing BSDF direction %d collects %.1f%% of light",
347 o, 100.*hemi_total);
348 error(WARNING, errmsg);
349 }
350 }
351 free(omega_iarr); free(omega_oarr);
352 return(1);
353 }
354
355 struct BSDF_data *
356 load_BSDF( /* load BSDF data from file */
357 char *fname
358 )
359 {
360 char *path;
361 ezxml_t fl, wtl, wld, wdb;
362 struct BSDF_data *dp;
363
364 path = getpath(fname, getrlibpath(), R_OK);
365 if (path == NULL) {
366 sprintf(errmsg, "cannot find BSDF file \"%s\"", fname);
367 error(WARNING, errmsg);
368 return(NULL);
369 }
370 fl = ezxml_parse_file(path);
371 if (fl == NULL) {
372 sprintf(errmsg, "cannot open BSDF \"%s\"", path);
373 error(WARNING, errmsg);
374 return(NULL);
375 }
376 if (ezxml_error(fl)[0]) {
377 sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl));
378 error(WARNING, errmsg);
379 ezxml_free(fl);
380 return(NULL);
381 }
382 if (strcmp(ezxml_name(fl), "WindowElement")) {
383 sprintf(errmsg,
384 "BSDF \"%s\": top level node not 'WindowElement'",
385 path);
386 error(WARNING, errmsg);
387 ezxml_free(fl);
388 return(NULL);
389 }
390 wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
391 dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data));
392 for (wld = ezxml_child(wtl, "WavelengthData");
393 wld != NULL; wld = wld->next) {
394 if (strcmp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible"))
395 continue;
396 wdb = ezxml_child(wld, "WavelengthDataBlock");
397 if (wdb == NULL) continue;
398 if (strcmp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")),
399 "Transmission Front"))
400 continue;
401 load_bsdf_data(dp, wdb); /* load front BTDF */
402 break; /* ignore the rest */
403 }
404 ezxml_free(fl); /* done with XML file */
405 if (!check_bsdf_data(dp)) {
406 sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path);
407 error(WARNING, errmsg);
408 free_BSDF(dp);
409 dp = NULL;
410 }
411 return(dp);
412 }
413
414
415 void
416 free_BSDF( /* free BSDF data structure */
417 struct BSDF_data *b
418 )
419 {
420 if (b == NULL)
421 return;
422 if (b->bsdf != NULL)
423 free(b->bsdf);
424 free(b);
425 }
426
427
428 int
429 r_BSDF_incvec( /* compute random input vector at given location */
430 FVECT v,
431 struct BSDF_data *b,
432 int i,
433 double rv,
434 MAT4 xm
435 )
436 {
437 FVECT pert;
438 double rad;
439 int j;
440
441 if (!getBSDF_incvec(v, b, i))
442 return(0);
443 rad = sqrt(getBSDF_incohm(b, i) / PI);
444 multisamp(pert, 3, rv);
445 for (j = 0; j < 3; j++)
446 v[j] += rad*(2.*pert[j] - 1.);
447 if (xm != NULL)
448 multv3(v, v, xm);
449 return(normalize(v) != 0.0);
450 }
451
452
453 int
454 r_BSDF_outvec( /* compute random output vector at given location */
455 FVECT v,
456 struct BSDF_data *b,
457 int o,
458 double rv,
459 MAT4 xm
460 )
461 {
462 FVECT pert;
463 double rad;
464 int j;
465
466 if (!getBSDF_outvec(v, b, o))
467 return(0);
468 rad = sqrt(getBSDF_outohm(b, o) / PI);
469 multisamp(pert, 3, rv);
470 for (j = 0; j < 3; j++)
471 v[j] += rad*(2.*pert[j] - 1.);
472 if (xm != NULL)
473 multv3(v, v, xm);
474 return(normalize(v) != 0.0);
475 }
476
477
478 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
479
480 static int
481 addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
482 char *xfarg[],
483 FVECT xp,
484 FVECT yp,
485 FVECT zp
486 )
487 {
488 static char bufs[3][16];
489 int bn = 0;
490 char **xfp = xfarg;
491 double theta;
492
493 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
494 /* Special case for X' along Z-axis */
495 theta = -atan2(yp[0], yp[1]);
496 *xfp++ = "-ry";
497 *xfp++ = xp[2] < 0.0 ? "90" : "-90";
498 *xfp++ = "-rz";
499 sprintf(bufs[bn], "%f", theta*(180./PI));
500 *xfp++ = bufs[bn++];
501 return(xfp - xfarg);
502 }
503 theta = atan2(yp[2], zp[2]);
504 if (!FEQ(theta,0.0)) {
505 *xfp++ = "-rx";
506 sprintf(bufs[bn], "%f", theta*(180./PI));
507 *xfp++ = bufs[bn++];
508 }
509 theta = asin(-xp[2]);
510 if (!FEQ(theta,0.0)) {
511 *xfp++ = "-ry";
512 sprintf(bufs[bn], " %f", theta*(180./PI));
513 *xfp++ = bufs[bn++];
514 }
515 theta = atan2(xp[1], xp[0]);
516 if (!FEQ(theta,0.0)) {
517 *xfp++ = "-rz";
518 sprintf(bufs[bn], "%f", theta*(180./PI));
519 *xfp++ = bufs[bn++];
520 }
521 *xfp = NULL;
522 return(xfp - xfarg);
523 }
524
525
526 int
527 getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */
528 MAT4 xm,
529 FVECT nrm,
530 UpDir ud
531 )
532 {
533 char *xfargs[7];
534 XF myxf;
535 FVECT updir, xdest, ydest;
536
537 updir[0] = updir[1] = updir[2] = 0.;
538 switch (ud) {
539 case UDzneg:
540 updir[2] = -1.;
541 break;
542 case UDyneg:
543 updir[1] = -1.;
544 break;
545 case UDxneg:
546 updir[0] = -1.;
547 break;
548 case UDxpos:
549 updir[0] = 1.;
550 break;
551 case UDypos:
552 updir[1] = 1.;
553 break;
554 case UDzpos:
555 updir[2] = 1.;
556 break;
557 case UDunknown:
558 return(0);
559 }
560 fcross(xdest, updir, nrm);
561 if (normalize(xdest) == 0.0)
562 return(0);
563 fcross(ydest, nrm, xdest);
564 xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs);
565 copymat4(xm, myxf.xfm);
566 return(1);
567 }
