root/radiance/ray/src/common/bsdf.c
Revision: 2.43
Committed: Sat Oct 13 20:15:43 2012 UTC (12 years, 6 months ago) by greg
Changes since 2.42: +56 -761 lines
2 static const char RCSid[] = "$Id: bsdf.c,v 2.42 2012/09/02 15:33:15 greg Exp $";
5 * bsdf.c
6 *
7 * Definitions for bidirectional scattering distribution functions.
8 *
9 * Created by Greg Ward on 1/10/11.
10 *
11 */
12
13 #define _USE_MATH_DEFINES
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <string.h>
17 #include <math.h>
18 #include <ctype.h>
19 #include "ezxml.h"
20 #include "hilbert.h"
21 #include "bsdf.h"
22 #include "bsdf_m.h"
23 #include "bsdf_t.h"
24
25 /* English ASCII strings corresponding to ennumerated errors */
26 const char *SDerrorEnglish[] = {
27 "No error",
28 "Memory error",
29 "File input/output error",
30 "File format error",
31 "Illegal argument",
32 "Invalid data",
33 "Unsupported feature",
34 "Internal program error",
35 "Unknown error"
36 };
37
38 /* Additional information on last error (ASCII English) */
39 char SDerrorDetail[256];
40
41 /* Empty distribution for getCDist() calls that fail for some reason */
42 const SDCDst SDemptyCD;
43
44 /* Cache of loaded BSDFs */
45 struct SDCache_s *SDcacheList = NULL;
46
47 /* Retain BSDFs in cache list */
48 int SDretainSet = SDretainNone;
49
50 /* Report any error to the indicated stream (in English) */
51 SDError
52 SDreportEnglish(SDError ec, FILE *fp)
53 {
54 if (!ec)
55 return SDEnone;
56 if ((ec < SDEnone) | (ec > SDEunknown)) {
57 SDerrorDetail[0] = '\0';
58 ec = SDEunknown;
59 }
60 if (fp == NULL)
61 return ec;
62 fputs(SDerrorEnglish[ec], fp);
63 if (SDerrorDetail[0]) {
64 fputs(": ", fp);
65 fputs(SDerrorDetail, fp);
66 }
67 fputc('\n', fp);
68 if (fp != stderr)
69 fflush(fp);
70 return ec;
71 }
72
73 static double
74 to_meters( /* return factor to convert given unit to meters */
75 const char *unit
76 )
77 {
78 if (unit == NULL) return(1.); /* safe assumption? */
79 if (!strcasecmp(unit, "Meter")) return(1.);
80 if (!strcasecmp(unit, "Foot")) return(.3048);
81 if (!strcasecmp(unit, "Inch")) return(.0254);
82 if (!strcasecmp(unit, "Centimeter")) return(.01);
83 if (!strcasecmp(unit, "Millimeter")) return(.001);
84 sprintf(SDerrorDetail, "Unknown dimensional unit '%s'", unit);
85 return(-1.);
86 }
87
88 /* Load geometric dimensions and description (if any) */
89 static SDError
90 SDloadGeometry(SDData *sd, ezxml_t wtl)
91 {
92 ezxml_t node, matl, geom;
93 double cfact;
94 const char *fmt = NULL, *mgfstr;
95
96 SDerrorDetail[0] = '\0';
97 sd->matn[0] = '\0'; sd->makr[0] = '\0';
98 sd->dim[0] = sd->dim[1] = sd->dim[2] = 0;
99 matl = ezxml_child(wtl, "Material");
100 if (matl != NULL) { /* get material info. */
101 if ((node = ezxml_child(matl, "Name")) != NULL) {
102 strncpy(sd->matn, ezxml_txt(node), SDnameLn);
103 if (sd->matn[SDnameLn-1])
104 strcpy(sd->matn+(SDnameLn-4), "...");
105 }
106 if ((node = ezxml_child(matl, "Manufacturer")) != NULL) {
107 strncpy(sd->makr, ezxml_txt(node), SDnameLn);
108 if (sd->makr[SDnameLn-1])
109 strcpy(sd->makr+(SDnameLn-4), "...");
110 }
111 if ((node = ezxml_child(matl, "Width")) != NULL)
112 sd->dim[0] = atof(ezxml_txt(node)) *
113 to_meters(ezxml_attr(node, "unit"));
114 if ((node = ezxml_child(matl, "Height")) != NULL)
115 sd->dim[1] = atof(ezxml_txt(node)) *
116 to_meters(ezxml_attr(node, "unit"));
117 if ((node = ezxml_child(matl, "Thickness")) != NULL)
118 sd->dim[2] = atof(ezxml_txt(node)) *
119 to_meters(ezxml_attr(node, "unit"));
120 if ((sd->dim[0] < 0) | (sd->dim[1] < 0) | (sd->dim[2] < 0)) {
121 if (!SDerrorDetail[0])
122 sprintf(SDerrorDetail, "Negative dimension in \"%s\"",
123 sd->name);
124 return SDEdata;
125 }
126 }
127 sd->mgf = NULL;
128 geom = ezxml_child(wtl, "Geometry");
129 if (geom == NULL) /* no actual geometry? */
130 return SDEnone;
131 fmt = ezxml_attr(geom, "format");
132 if (fmt != NULL && strcasecmp(fmt, "MGF")) {
133 sprintf(SDerrorDetail,
134 "Unrecognized geometry format '%s' in \"%s\"",
135 fmt, sd->name);
136 return SDEsupport;
137 }
138 if ((node = ezxml_child(geom, "MGFblock")) == NULL ||
139 (mgfstr = ezxml_txt(node)) == NULL)
140 return SDEnone;
141 while (isspace(*mgfstr))
142 ++mgfstr;
143 if (!*mgfstr)
144 return SDEnone;
145 cfact = to_meters(ezxml_attr(node, "unit"));
146 if (cfact <= 0)
147 return SDEformat;
148 sd->mgf = (char *)malloc(strlen(mgfstr)+32);
149 if (sd->mgf == NULL) {
150 strcpy(SDerrorDetail, "Out of memory in SDloadGeometry");
151 return SDEmemory;
152 }
153 if (cfact < 0.99 || cfact > 1.01)
154 sprintf(sd->mgf, "xf -s %.5f\n%s\nxf\n", cfact, mgfstr);
155 else
156 strcpy(sd->mgf, mgfstr);
157 return SDEnone;
158 }
159
160 /* Load a BSDF struct from the given file (free first and keep name) */
161 SDError
162 SDloadFile(SDData *sd, const char *fname)
163 {
164 SDError lastErr;
165 ezxml_t fl, wtl;
166
167 if ((sd == NULL) | (fname == NULL || !*fname))
168 return SDEargument;
169 /* free old data, keeping name */
170 SDfreeBSDF(sd);
171 /* parse XML file */
172 fl = ezxml_parse_file(fname);
173 if (fl == NULL) {
174 sprintf(SDerrorDetail, "Cannot open BSDF \"%s\"", fname);
175 return SDEfile;
176 }
177 if (ezxml_error(fl)[0]) {
178 sprintf(SDerrorDetail, "BSDF \"%s\" %s", fname, ezxml_error(fl));
179 ezxml_free(fl);
180 return SDEformat;
181 }
182 if (strcmp(ezxml_name(fl), "WindowElement")) {
183 sprintf(SDerrorDetail,
184 "BSDF \"%s\": top level node not 'WindowElement'",
185 sd->name);
186 ezxml_free(fl);
187 return SDEformat;
188 }
189 wtl = ezxml_child(fl, "FileType");
190 if (wtl != NULL && strcmp(ezxml_txt(wtl), "BSDF")) {
191 sprintf(SDerrorDetail,
192 "XML \"%s\": wrong FileType (must be 'BSDF')",
193 sd->name);
194 ezxml_free(fl);
195 return SDEformat;
196 }
197 wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
198 if (wtl == NULL) {
199 sprintf(SDerrorDetail, "BSDF \"%s\": no optical layers'",
200 sd->name);
201 ezxml_free(fl);
202 return SDEformat;
203 }
204 /* load geometry if present */
205 lastErr = SDloadGeometry(sd, wtl);
206 if (lastErr) {
207 ezxml_free(fl);
208 return lastErr;
209 }
210 /* try loading variable resolution data */
211 lastErr = SDloadTre(sd, wtl);
212 /* check our result */
213 if (lastErr == SDEsupport) /* try matrix BSDF if not tree data */
214 lastErr = SDloadMtx(sd, wtl);
215
216 /* done with XML file */
217 ezxml_free(fl);
218
219 if (lastErr) { /* was there a load error? */
220 SDfreeBSDF(sd);
221 return lastErr;
222 }
223 /* remove any insignificant components */
224 if (sd->rf != NULL && sd->rf->maxHemi <= .001) {
225 SDfreeSpectralDF(sd->rf); sd->rf = NULL;
226 }
227 if (sd->rb != NULL && sd->rb->maxHemi <= .001) {
228 SDfreeSpectralDF(sd->rb); sd->rb = NULL;
229 }
230 if (sd->tf != NULL && sd->tf->maxHemi <= .001) {
231 SDfreeSpectralDF(sd->tf); sd->tf = NULL;
232 }
233 if (sd->tb != NULL && sd->tb->maxHemi <= .001) {
234 SDfreeSpectralDF(sd->tb); sd->tb = NULL;
235 }
236 /* return success */
237 return SDEnone;
238 }
239
240 /* Allocate new spectral distribution function */
241 SDSpectralDF *
242 SDnewSpectralDF(int nc)
243 {
244 SDSpectralDF *df;
245
246 if (nc <= 0) {
247 strcpy(SDerrorDetail, "Zero component spectral DF request");
248 return NULL;
249 }
250 df = (SDSpectralDF *)malloc(sizeof(SDSpectralDF) +
251 (nc-1)*sizeof(SDComponent));
252 if (df == NULL) {
253 sprintf(SDerrorDetail,
254 "Cannot allocate %d component spectral DF", nc);
255 return NULL;
256 }
257 df->minProjSA = .0;
258 df->maxHemi = .0;
259 df->ncomp = nc;
260 memset(df->comp, 0, nc*sizeof(SDComponent));
261 return df;
262 }
263
264 /* Add component(s) to spectral distribution function */
265 SDSpectralDF *
266 SDaddComponent(SDSpectralDF *odf, int nadd)
267 {
268 SDSpectralDF *df;
269
270 if (odf == NULL)
271 return SDnewSpectralDF(nadd);
272 if (nadd <= 0)
273 return odf;
274 df = (SDSpectralDF *)realloc(odf, sizeof(SDSpectralDF) +
275 (odf->ncomp+nadd-1)*sizeof(SDComponent));
276 if (df == NULL) {
277 sprintf(SDerrorDetail,
278 "Cannot add %d component(s) to spectral DF", nadd);
279 SDfreeSpectralDF(odf);
280 return NULL;
281 }
282 memset(df->comp+df->ncomp, 0, nadd*sizeof(SDComponent));
283 df->ncomp += nadd;
284 return df;
285 }
286
287 /* Free cached cumulative distributions for BSDF component */
288 void
289 SDfreeCumulativeCache(SDSpectralDF *df)
290 {
291 int n;
292 SDCDst *cdp;
293
294 if (df == NULL)
295 return;
296 for (n = df->ncomp; n-- > 0; )
297 while ((cdp = df->comp[n].cdList) != NULL) {
298 df->comp[n].cdList = cdp->next;
299 free(cdp);
300 }
301 }
302
303 /* Free a spectral distribution function */
304 void
305 SDfreeSpectralDF(SDSpectralDF *df)
306 {
307 int n;
308
309 if (df == NULL)
310 return;
311 SDfreeCumulativeCache(df);
312 for (n = df->ncomp; n-- > 0; )
313 if (df->comp[n].dist != NULL)
314 (*df->comp[n].func->freeSC)(df->comp[n].dist);
315 free(df);
316 }
317
318 /* Shorten file path to useable BSDF name, removing suffix */
319 void
320 SDclipName(char *res, const char *fname)
321 {
322 const char *cp, *dot = NULL;
323
324 for (cp = fname; *cp; cp++)
325 if (*cp == '.')
326 dot = cp;
327 if ((dot == NULL) | (dot < fname+2))
328 dot = cp;
329 if (dot - fname >= SDnameLn)
330 fname = dot - SDnameLn + 1;
331 while (fname < dot)
332 *res++ = *fname++;
333 *res = '\0';
334 }
335
336 /* Initialize an unused BSDF struct (simply clears to zeroes) */
337 void
338 SDclearBSDF(SDData *sd, const char *fname)
339 {
340 if (sd == NULL)
341 return;
342 memset(sd, 0, sizeof(SDData));
343 if (fname == NULL)
344 return;
345 SDclipName(sd->name, fname);
346 }
347
348 /* Free data associated with BSDF struct */
349 void
350 SDfreeBSDF(SDData *sd)
351 {
352 if (sd == NULL)
353 return;
354 if (sd->mgf != NULL) {
355 free(sd->mgf);
356 sd->mgf = NULL;
357 }
358 if (sd->rf != NULL) {
359 SDfreeSpectralDF(sd->rf);
360 sd->rf = NULL;
361 }
362 if (sd->rb != NULL) {
363 SDfreeSpectralDF(sd->rb);
364 sd->rb = NULL;
365 }
366 if (sd->tf != NULL) {
367 SDfreeSpectralDF(sd->tf);
368 sd->tf = NULL;
369 }
370 if (sd->tb != NULL) {
371 SDfreeSpectralDF(sd->tb);
372 sd->tb = NULL;
373 }
374 sd->rLambFront.cieY = .0;
375 sd->rLambFront.spec.flags = 0;
376 sd->rLambBack.cieY = .0;
377 sd->rLambBack.spec.flags = 0;
378 sd->tLamb.cieY = .0;
379 sd->tLamb.spec.flags = 0;
380 }
381
382 /* Find writeable BSDF by name, or allocate new cache entry if absent */
383 SDData *
384 SDgetCache(const char *bname)
385 {
386 struct SDCache_s *sdl;
387 char sdnam[SDnameLn];
388
389 if (bname == NULL)
390 return NULL;
391
392 SDclipName(sdnam, bname);
393 for (sdl = SDcacheList; sdl != NULL; sdl = sdl->next)
394 if (!strcmp(sdl->bsdf.name, sdnam)) {
395 sdl->refcnt++;
396 return &sdl->bsdf;
397 }
398
399 sdl = (struct SDCache_s *)calloc(1, sizeof(struct SDCache_s));
400 if (sdl == NULL)
401 return NULL;
402
403 strcpy(sdl->bsdf.name, sdnam);
404 sdl->next = SDcacheList;
405 SDcacheList = sdl;
406
407 sdl->refcnt = 1;
408 return &sdl->bsdf;
409 }
410
411 /* Get loaded BSDF from cache (or load and cache it on first call) */
412 /* Report any problem to stderr and return NULL on failure */
413 const SDData *
414 SDcacheFile(const char *fname)
415 {
416 SDData *sd;
417 SDError ec;
418
419 if (fname == NULL || !*fname)
420 return NULL;
421 SDerrorDetail[0] = '\0';
422 if ((sd = SDgetCache(fname)) == NULL) {
423 SDreportEnglish(SDEmemory, stderr);
424 return NULL;
425 }
426 if (!SDisLoaded(sd) && (ec = SDloadFile(sd, fname))) {
427 SDreportEnglish(ec, stderr);
428 SDfreeCache(sd);
429 return NULL;
430 }
431 return sd;
432 }
433
434 /* Free a BSDF from our cache (clear all if NULL) */
435 void
436 SDfreeCache(const SDData *sd)
437 {
438 struct SDCache_s *sdl, *sdLast = NULL;
439
440 if (sd == NULL) { /* free entire list */
441 while ((sdl = SDcacheList) != NULL) {
442 SDcacheList = sdl->next;
443 SDfreeBSDF(&sdl->bsdf);
444 free(sdl);
445 }
446 return;
447 }
448 for (sdl = SDcacheList; sdl != NULL; sdl = (sdLast=sdl)->next)
449 if (&sdl->bsdf == sd)
450 break;
451 if (sdl == NULL || (sdl->refcnt -= (sdl->refcnt > 0)))
452 return; /* missing or still in use */
453 /* keep unreferenced data? */
454 if (SDisLoaded(sd) && SDretainSet) {
455 if (SDretainSet == SDretainAll)
456 return; /* keep everything */
457 /* else free cumulative data */
458 SDfreeCumulativeCache(sd->rf);
459 SDfreeCumulativeCache(sd->rb);
460 SDfreeCumulativeCache(sd->tf);
461 SDfreeCumulativeCache(sd->tb);
462 return;
463 }
464 /* remove from list and free */
465 if (sdLast == NULL)
466 SDcacheList = sdl->next;
467 else
468 sdLast->next = sdl->next;
469 SDfreeBSDF(&sdl->bsdf);
470 free(sdl);
471 }
472
473 /* Sample an individual BSDF component */
474 SDError
475 SDsampComponent(SDValue *sv, FVECT ioVec, double randX, SDComponent *sdc)
476 {
477 float coef[SDmaxCh];
478 SDError ec;
479 FVECT inVec;
480 const SDCDst *cd;
481 double d;
482 int n;
483 /* check arguments */
484 if ((sv == NULL) | (ioVec == NULL) | (sdc == NULL))
485 return SDEargument;
486 /* get cumulative distribution */
487 VCOPY(inVec, ioVec);
488 cd = (*sdc->func->getCDist)(inVec, sdc);
489 if (cd == NULL)
490 return SDEmemory;
491 if (cd->cTotal <= 1e-6) { /* anything to sample? */
492 sv->spec = c_dfcolor;
493 sv->cieY = .0;
494 memset(ioVec, 0, 3*sizeof(double));
495 return SDEnone;
496 }
497 sv->cieY = cd->cTotal;
498 /* compute sample direction */
499 ec = (*sdc->func->sampCDist)(ioVec, randX, cd);
500 if (ec)
501 return ec;
502 /* get BSDF color */
503 n = (*sdc->func->getBSDFs)(coef, ioVec, inVec, sdc);
504 if (n <= 0) {
505 strcpy(SDerrorDetail, "BSDF sample value error");
506 return SDEinternal;
507 }
508 sv->spec = sdc->cspec[0];
509 d = coef[0];
510 while (--n) {
511 c_cmix(&sv->spec, d, &sv->spec, coef[n], &sdc->cspec[n]);
512 d += coef[n];
513 }
514 /* make sure everything is set */
515 c_ccvt(&sv->spec, C_CSXY+C_CSSPEC);
516 return SDEnone;
517 }
518
519 #define MS_MAXDIM 15
520
521 /* Convert 1-dimensional random variable to N-dimensional */
522 void
523 SDmultiSamp(double t[], int n, double randX)
524 {
525 unsigned nBits;
526 double scale;
527 bitmask_t ndx, coord[MS_MAXDIM];
528
529 if (n <= 0) /* check corner cases */
530 return;
531 if (randX < 0) randX = 0;
532 else if (randX >= 1.) randX = 0.999999999999999;
533 if (n == 1) {
534 t[0] = randX;
535 return;
536 }
537 while (n > MS_MAXDIM) /* punt for higher dimensions */
538 t[--n] = rand()*(1./(RAND_MAX+.5));
539 nBits = (8*sizeof(bitmask_t) - 1) / n;
540 ndx = randX * (double)((bitmask_t)1 << (nBits*n));
541 /* get coordinate on Hilbert curve */
542 hilbert_i2c(n, nBits, ndx, coord);
543 /* convert back to [0,1) range */
544 scale = 1. / (double)((bitmask_t)1 << nBits);
545 while (n--)
546 t[n] = scale * ((double)coord[n] + rand()*(1./(RAND_MAX+.5)));
547 }
548
549 #undef MS_MAXDIM
550
551 /* Generate diffuse hemispherical sample */
552 static void
553 SDdiffuseSamp(FVECT outVec, int outFront, double randX)
554 {
555 /* convert to position on hemisphere */
556 SDmultiSamp(outVec, 2, randX);
557 SDsquare2disk(outVec, outVec[0], outVec[1]);
558 outVec[2] = 1. - outVec[0]*outVec[0] - outVec[1]*outVec[1];
559 if (outVec[2] > 0) /* a bit of paranoia */
560 outVec[2] = sqrt(outVec[2]);
561 if (!outFront) /* going out back? */
562 outVec[2] = -outVec[2];
563 }
564
565 /* Query projected solid angle coverage for non-diffuse BSDF direction */
566 SDError
567 SDsizeBSDF(double *projSA, const FVECT v1, const RREAL *v2,
568 int qflags, const SDData *sd)
569 {
570 SDSpectralDF *rdf, *tdf;
571 SDError ec;
572 int i;
573 /* check arguments */
574 if ((projSA == NULL) | (v1 == NULL) | (sd == NULL))
575 return SDEargument;
576 /* initialize extrema */
577 switch (qflags) {
578 case SDqueryMax:
579 projSA[0] = .0;
580 break;
581 case SDqueryMin+SDqueryMax:
582 projSA[1] = .0;
583 /* fall through */
584 case SDqueryMin:
585 projSA[0] = 10.;
586 break;
587 case 0:
588 return SDEargument;
589 }
590 if (v1[2] > 0) { /* front surface query? */
591 rdf = sd->rf;
592 tdf = (sd->tf != NULL) ? sd->tf : sd->tb;
593 } else {
594 rdf = sd->rb;
595 tdf = (sd->tb != NULL) ? sd->tb : sd->tf;
596 }
597 if (v2 != NULL) /* bidirectional? */
598 if (v1[2] > 0 ^ v2[2] > 0)
599 rdf = NULL;
600 else
601 tdf = NULL;
602 ec = SDEdata; /* run through components */
603 for (i = (rdf==NULL) ? 0 : rdf->ncomp; i--; ) {
604 ec = (*rdf->comp[i].func->queryProjSA)(projSA, v1, v2,
605 qflags, &rdf->comp[i]);
606 if (ec)
607 return ec;
608 }
609 for (i = (tdf==NULL) ? 0 : tdf->ncomp; i--; ) {
610 ec = (*tdf->comp[i].func->queryProjSA)(projSA, v1, v2,
611 qflags, &tdf->comp[i]);
612 if (ec)
613 return ec;
614 }
615 if (ec) { /* all diffuse? */
616 projSA[0] = M_PI;
617 if (qflags == SDqueryMin+SDqueryMax)
618 projSA[1] = M_PI;
619 }
620 return SDEnone;
621 }
622
623 /* Return BSDF for the given incident and scattered ray vectors */
624 SDError
625 SDevalBSDF(SDValue *sv, const FVECT outVec, const FVECT inVec, const SDData *sd)
626 {
627 int inFront, outFront;
628 SDSpectralDF *sdf;
629 float coef[SDmaxCh];
630 int nch, i;
631 /* check arguments */
632 if ((sv == NULL) | (outVec == NULL) | (inVec == NULL) | (sd == NULL))
633 return SDEargument;
634 /* whose side are we on? */
635 inFront = (inVec[2] > 0);
636 outFront = (outVec[2] > 0);
637 /* start with diffuse portion */
638 if (inFront & outFront) {
639 *sv = sd->rLambFront;
640 sdf = sd->rf;
641 } else if (!(inFront | outFront)) {
642 *sv = sd->rLambBack;
643 sdf = sd->rb;
644 } else if (inFront) {
645 *sv = sd->tLamb;
646 sdf = (sd->tf != NULL) ? sd->tf : sd->tb;
647 } else /* inBack */ {
648 *sv = sd->tLamb;
649 sdf = (sd->tb != NULL) ? sd->tb : sd->tf;
650 }
651 sv->cieY *= 1./M_PI;
652 /* add non-diffuse components */
653 i = (sdf != NULL) ? sdf->ncomp : 0;
654 while (i-- > 0) {
655 nch = (*sdf->comp[i].func->getBSDFs)(coef, outVec, inVec,
656 &sdf->comp[i]);
657 while (nch-- > 0) {
658 c_cmix(&sv->spec, sv->cieY, &sv->spec,
659 coef[nch], &sdf->comp[i].cspec[nch]);
660 sv->cieY += coef[nch];
661 }
662 }
663 /* make sure everything is set */
664 c_ccvt(&sv->spec, C_CSXY+C_CSSPEC);
665 return SDEnone;
666 }
667
668 /* Compute directional hemispherical scattering at this incident angle */
669 double
670 SDdirectHemi(const FVECT inVec, int sflags, const SDData *sd)
671 {
672 double hsum;
673 SDSpectralDF *rdf, *tdf;
674 const SDCDst *cd;
675 int i;
676 /* check arguments */
677 if ((inVec == NULL) | (sd == NULL))
678 return .0;
679 /* gather diffuse components */
680 if (inVec[2] > 0) {
681 hsum = sd->rLambFront.cieY;
682 rdf = sd->rf;
683 tdf = (sd->tf != NULL) ? sd->tf : sd->tb;
684 } else /* !inFront */ {
685 hsum = sd->rLambBack.cieY;
686 rdf = sd->rb;
687 tdf = (sd->tb != NULL) ? sd->tb : sd->tf;
688 }
689 if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR)
690 hsum = .0;
691 if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT)
692 hsum += sd->tLamb.cieY;
693 /* gather non-diffuse components */
694 i = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) &
695 (rdf != NULL)) ? rdf->ncomp : 0;
696 while (i-- > 0) { /* non-diffuse reflection */
697 cd = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]);
698 if (cd != NULL)
699 hsum += cd->cTotal;
700 }
701 i = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) &
702 (tdf != NULL)) ? tdf->ncomp : 0;
703 while (i-- > 0) { /* non-diffuse transmission */
704 cd = (*tdf->comp[i].func->getCDist)(inVec, &tdf->comp[i]);
705 if (cd != NULL)
706 hsum += cd->cTotal;
707 }
708 return hsum;
709 }
710
711 /* Sample BSDF direction based on the given random variable */
712 SDError
713 SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int sflags, const SDData *sd)
714 {
715 SDError ec;
716 FVECT inVec;
717 int inFront;
718 SDSpectralDF *rdf, *tdf;
719 double rdiff;
720 float coef[SDmaxCh];
721 int i, j, n, nr;
722 SDComponent *sdc;
723 const SDCDst **cdarr = NULL;
724 /* check arguments */
725 if ((sv == NULL) | (ioVec == NULL) | (sd == NULL) |
726 (randX < 0) | (randX >= 1.))
727 return SDEargument;
728 /* whose side are we on? */
729 VCOPY(inVec, ioVec);
730 inFront = (inVec[2] > 0);
731 /* remember diffuse portions */
732 if (inFront) {
733 *sv = sd->rLambFront;
734 rdf = sd->rf;
735 tdf = (sd->tf != NULL) ? sd->tf : sd->tb;
736 } else /* !inFront */ {
737 *sv = sd->rLambBack;
738 rdf = sd->rb;
739 tdf = (sd->tb != NULL) ? sd->tb : sd->tf;
740 }
741 if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR)
742 sv->cieY = .0;
743 rdiff = sv->cieY;
744 if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT)
745 sv->cieY += sd->tLamb.cieY;
746 /* gather non-diffuse components */
747 i = nr = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) &
748 (rdf != NULL)) ? rdf->ncomp : 0;
749 j = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) &
750 (tdf != NULL)) ? tdf->ncomp : 0;
751 n = i + j;
752 if (n > 0 && (cdarr = (const SDCDst **)malloc(n*sizeof(SDCDst *))) == NULL)
753 return SDEmemory;
754 while (j-- > 0) { /* non-diffuse transmission */
755 cdarr[i+j] = (*tdf->comp[j].func->getCDist)(inVec, &tdf->comp[j]);
756 if (cdarr[i+j] == NULL) {
757 free(cdarr);
758 return SDEmemory;
759 }
760 sv->cieY += cdarr[i+j]->cTotal;
761 }
762 while (i-- > 0) { /* non-diffuse reflection */
763 cdarr[i] = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]);
764 if (cdarr[i] == NULL) {
765 free(cdarr);
766 return SDEmemory;
767 }
768 sv->cieY += cdarr[i]->cTotal;
769 }
770 if (sv->cieY <= 1e-6) { /* anything to sample? */
771 sv->cieY = .0;
772 memset(ioVec, 0, 3*sizeof(double));
773 return SDEnone;
774 }
775 /* scale random variable */
776 randX *= sv->cieY;
777 /* diffuse reflection? */
778 if (randX < rdiff) {
779 SDdiffuseSamp(ioVec, inFront, randX/rdiff);
780 goto done;
781 }
782 randX -= rdiff;
783 /* diffuse transmission? */
784 if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) {
785 if (randX < sd->tLamb.cieY) {
786 sv->spec = sd->tLamb.spec;
787 SDdiffuseSamp(ioVec, !inFront, randX/sd->tLamb.cieY);
788 goto done;
789 }
790 randX -= sd->tLamb.cieY;
791 }
792 /* else one of cumulative dist. */
793 for (i = 0; i < n && randX < cdarr[i]->cTotal; i++)
794 randX -= cdarr[i]->cTotal;
795 if (i >= n)
796 return SDEinternal;
797 /* compute sample direction */
798 sdc = (i < nr) ? &rdf->comp[i] : &tdf->comp[i-nr];
799 ec = (*sdc->func->sampCDist)(ioVec, randX/cdarr[i]->cTotal, cdarr[i]);
800 if (ec)
801 return ec;
802 /* compute color */
803 j = (*sdc->func->getBSDFs)(coef, ioVec, inVec, sdc);
804 if (j <= 0) {
805 sprintf(SDerrorDetail, "BSDF \"%s\" sampling value error",
806 sd->name);
807 return SDEinternal;
808 }
809 sv->spec = sdc->cspec[0];
810 rdiff = coef[0];
811 while (--j) {
812 c_cmix(&sv->spec, rdiff, &sv->spec, coef[j], &sdc->cspec[j]);
813 rdiff += coef[j];
814 }
815 done:
816 if (cdarr != NULL)
817 free(cdarr);
818 /* make sure everything is set */
819 c_ccvt(&sv->spec, C_CSXY+C_CSSPEC);
820 return SDEnone;
821 }
822
823 /* Compute World->BSDF transform from surface normal and up (Y) vector */
824 SDError
825 SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, const FVECT uVec)
826 {
827 if ((vMtx == NULL) | (sNrm == NULL) | (uVec == NULL))
828 return SDEargument;
829 VCOPY(vMtx[2], sNrm);
830 if (normalize(vMtx[2]) == 0)
831 return SDEargument;
832 fcross(vMtx[0], uVec, vMtx[2]);
833 if (normalize(vMtx[0]) == 0)
834 return SDEargument;
835 fcross(vMtx[1], vMtx[2], vMtx[0]);
836 return SDEnone;
837 }
838
839 /* Compute inverse transform */
840 SDError
841 SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3])
842 {
843 RREAL mTmp[3][3];
844 double d;
845
846 if ((iMtx == NULL) | (vMtx == NULL))
847 return SDEargument;
848 /* compute determinant */
849 mTmp[0][0] = vMtx[2][2]*vMtx[1][1] - vMtx[2][1]*vMtx[1][2];
850 mTmp[0][1] = vMtx[2][1]*vMtx[0][2] - vMtx[2][2]*vMtx[0][1];
851 mTmp[0][2] = vMtx[1][2]*vMtx[0][1] - vMtx[1][1]*vMtx[0][2];
852 d = vMtx[0][0]*mTmp[0][0] + vMtx[1][0]*mTmp[0][1] + vMtx[2][0]*mTmp[0][2];
853 if (d == 0) {
854 strcpy(SDerrorDetail, "Zero determinant in matrix inversion");
855 return SDEargument;
856 }
857 d = 1./d; /* invert matrix */
858 mTmp[0][0] *= d; mTmp[0][1] *= d; mTmp[0][2] *= d;
859 mTmp[1][0] = d*(vMtx[2][0]*vMtx[1][2] - vMtx[2][2]*vMtx[1][0]);
860 mTmp[1][1] = d*(vMtx[2][2]*vMtx[0][0] - vMtx[2][0]*vMtx[0][2]);
861 mTmp[1][2] = d*(vMtx[1][0]*vMtx[0][2] - vMtx[1][2]*vMtx[0][0]);
862 mTmp[2][0] = d*(vMtx[2][1]*vMtx[1][0] - vMtx[2][0]*vMtx[1][1]);
863 mTmp[2][1] = d*(vMtx[2][0]*vMtx[0][1] - vMtx[2][1]*vMtx[0][0]);
864 mTmp[2][2] = d*(vMtx[1][1]*vMtx[0][0] - vMtx[1][0]*vMtx[0][1]);
865 memcpy(iMtx, mTmp, sizeof(mTmp));
866 return SDEnone;
867 }
868
869 /* Transform and normalize direction (column) vector */
870 SDError
871 SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT inpVec)
872 {
873 FVECT vTmp;
874
875 if ((resVec == NULL) | (inpVec == NULL))
876 return SDEargument;
877 if (vMtx == NULL) { /* assume they just want to normalize */
878 if (resVec != inpVec)
879 VCOPY(resVec, inpVec);
880 return (normalize(resVec) > 0) ? SDEnone : SDEargument;
881 }
882 vTmp[0] = DOT(vMtx[0], inpVec);
883 vTmp[1] = DOT(vMtx[1], inpVec);
884 vTmp[2] = DOT(vMtx[2], inpVec);
885 if (normalize(vTmp) == 0)
886 return SDEargument;
887 VCOPY(resVec, vTmp);
888 return SDEnone;
889 }
