--- ray/src/common/bsdf.c 2011/06/23 16:00:37 2.32 +++ ray/src/common/bsdf.c 2013/04/21 21:36:23 2.44 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf.c,v 2.32 2011/06/23 16:00:37 greg Exp $"; +static const char RCSid[] = "$Id: bsdf.c,v 2.44 2013/04/21 21:36:23 greg Exp $"; #endif /* * bsdf.c @@ -35,18 +35,24 @@ const char *SDerrorEnglish[] = { "Unknown error" }; +/* Pointer to error list in preferred language */ +const char **SDerrorList = SDerrorEnglish; + /* Additional information on last error (ASCII English) */ char SDerrorDetail[256]; +/* Empty distribution for getCDist() calls that fail for some reason */ +const SDCDst SDemptyCD; + /* Cache of loaded BSDFs */ struct SDCache_s *SDcacheList = NULL; /* Retain BSDFs in cache list */ int SDretainSet = SDretainNone; -/* Report any error to the indicated stream (in English) */ +/* Report any error to the indicated stream */ SDError -SDreportEnglish(SDError ec, FILE *fp) +SDreportError(SDError ec, FILE *fp) { if (!ec) return SDEnone; @@ -56,7 +62,7 @@ SDreportEnglish(SDError ec, FILE *fp) } if (fp == NULL) return ec; - fputs(SDerrorEnglish[ec], fp); + fputs(SDerrorList[ec], fp); if (SDerrorDetail[0]) { fputs(": ", fp); fputs(SDerrorDetail, fp); @@ -84,43 +90,64 @@ to_meters( /* return factor to convert given unit to /* Load geometric dimensions and description (if any) */ static SDError -SDloadGeometry(SDData *sd, ezxml_t wdb) +SDloadGeometry(SDData *sd, ezxml_t wtl) { - ezxml_t geom; + ezxml_t node, matl, geom; double cfact; - const char *fmt, *mgfstr; + const char *fmt = NULL, *mgfstr; - if (wdb == NULL) /* no geometry section? */ - return SDEnone; - sd->dim[0] = sd->dim[1] = sd->dim[2] = .0; - if ((geom = ezxml_child(wdb, "Width")) != NULL) - sd->dim[0] = atof(ezxml_txt(geom)) * - to_meters(ezxml_attr(geom, "unit")); - if ((geom = ezxml_child(wdb, "Height")) != NULL) - sd->dim[1] = atof(ezxml_txt(geom)) * - to_meters(ezxml_attr(geom, "unit")); - if ((geom = ezxml_child(wdb, "Thickness")) != NULL) - sd->dim[2] = atof(ezxml_txt(geom)) * - to_meters(ezxml_attr(geom, "unit")); - if ((sd->dim[0] < 0) | (sd->dim[1] < 0) | (sd->dim[2] < 0)) { - sprintf(SDerrorDetail, "Negative size in \"%s\"", sd->name); - return SDEdata; + SDerrorDetail[0] = '\0'; + sd->matn[0] = '\0'; sd->makr[0] = '\0'; + sd->dim[0] = sd->dim[1] = sd->dim[2] = 0; + matl = ezxml_child(wtl, "Material"); + if (matl != NULL) { /* get material info. */ + if ((node = ezxml_child(matl, "Name")) != NULL) { + strncpy(sd->matn, ezxml_txt(node), SDnameLn); + if (sd->matn[SDnameLn-1]) + strcpy(sd->matn+(SDnameLn-4), "..."); + } + if ((node = ezxml_child(matl, "Manufacturer")) != NULL) { + strncpy(sd->makr, ezxml_txt(node), SDnameLn); + if (sd->makr[SDnameLn-1]) + strcpy(sd->makr+(SDnameLn-4), "..."); + } + if ((node = ezxml_child(matl, "Width")) != NULL) + sd->dim[0] = atof(ezxml_txt(node)) * + to_meters(ezxml_attr(node, "unit")); + if ((node = ezxml_child(matl, "Height")) != NULL) + sd->dim[1] = atof(ezxml_txt(node)) * + to_meters(ezxml_attr(node, "unit")); + if ((node = ezxml_child(matl, "Thickness")) != NULL) + sd->dim[2] = atof(ezxml_txt(node)) * + to_meters(ezxml_attr(node, "unit")); + if ((sd->dim[0] < 0) | (sd->dim[1] < 0) | (sd->dim[2] < 0)) { + if (!SDerrorDetail[0]) + sprintf(SDerrorDetail, "Negative dimension in \"%s\"", + sd->name); + return SDEdata; + } } - if ((geom = ezxml_child(wdb, "Geometry")) == NULL || - (mgfstr = ezxml_txt(geom)) == NULL) + sd->mgf = NULL; + geom = ezxml_child(wtl, "Geometry"); + if (geom == NULL) /* no actual geometry? */ return SDEnone; - while (isspace(*mgfstr)) - ++mgfstr; - if (!*mgfstr) - return SDEnone; - if ((fmt = ezxml_attr(geom, "format")) != NULL && - strcasecmp(fmt, "MGF")) { + fmt = ezxml_attr(geom, "format"); + if (fmt != NULL && strcasecmp(fmt, "MGF")) { sprintf(SDerrorDetail, "Unrecognized geometry format '%s' in \"%s\"", fmt, sd->name); return SDEsupport; } - cfact = to_meters(ezxml_attr(geom, "unit")); + if ((node = ezxml_child(geom, "MGFblock")) == NULL || + (mgfstr = ezxml_txt(node)) == NULL) + return SDEnone; + while (isspace(*mgfstr)) + ++mgfstr; + if (!*mgfstr) + return SDEnone; + cfact = to_meters(ezxml_attr(node, "unit")); + if (cfact <= 0) + return SDEformat; sd->mgf = (char *)malloc(strlen(mgfstr)+32); if (sd->mgf == NULL) { strcpy(SDerrorDetail, "Out of memory in SDloadGeometry"); @@ -162,17 +189,27 @@ SDloadFile(SDData *sd, const char *fname) ezxml_free(fl); return SDEformat; } + wtl = ezxml_child(fl, "FileType"); + if (wtl != NULL && strcmp(ezxml_txt(wtl), "BSDF")) { + sprintf(SDerrorDetail, + "XML \"%s\": wrong FileType (must be 'BSDF')", + sd->name); + ezxml_free(fl); + return SDEformat; + } wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer"); if (wtl == NULL) { - sprintf(SDerrorDetail, "BSDF \"%s\": no optical layer'", + sprintf(SDerrorDetail, "BSDF \"%s\": no optical layers'", sd->name); ezxml_free(fl); return SDEformat; } /* load geometry if present */ - lastErr = SDloadGeometry(sd, ezxml_child(wtl, "Material")); - if (lastErr) + lastErr = SDloadGeometry(sd, wtl); + if (lastErr) { + ezxml_free(fl); return lastErr; + } /* try loading variable resolution data */ lastErr = SDloadTre(sd, wtl); /* check our result */ @@ -196,6 +233,9 @@ SDloadFile(SDData *sd, const char *fname) if (sd->tf != NULL && sd->tf->maxHemi <= .001) { SDfreeSpectralDF(sd->tf); sd->tf = NULL; } + if (sd->tb != NULL && sd->tb->maxHemi <= .001) { + SDfreeSpectralDF(sd->tb); sd->tb = NULL; + } /* return success */ return SDEnone; } @@ -224,6 +264,29 @@ SDnewSpectralDF(int nc) return df; } +/* Add component(s) to spectral distribution function */ +SDSpectralDF * +SDaddComponent(SDSpectralDF *odf, int nadd) +{ + SDSpectralDF *df; + + if (odf == NULL) + return SDnewSpectralDF(nadd); + if (nadd <= 0) + return odf; + df = (SDSpectralDF *)realloc(odf, sizeof(SDSpectralDF) + + (odf->ncomp+nadd-1)*sizeof(SDComponent)); + if (df == NULL) { + sprintf(SDerrorDetail, + "Cannot add %d component(s) to spectral DF", nadd); + SDfreeSpectralDF(odf); + return NULL; + } + memset(df->comp+df->ncomp, 0, nadd*sizeof(SDComponent)); + df->ncomp += nadd; + return df; +} + /* Free cached cumulative distributions for BSDF component */ void SDfreeCumulativeCache(SDSpectralDF *df) @@ -250,7 +313,8 @@ SDfreeSpectralDF(SDSpectralDF *df) return; SDfreeCumulativeCache(df); for (n = df->ncomp; n-- > 0; ) - (*df->comp[n].func->freeSC)(df->comp[n].dist); + if (df->comp[n].dist != NULL) + (*df->comp[n].func->freeSC)(df->comp[n].dist); free(df); } @@ -306,6 +370,10 @@ SDfreeBSDF(SDData *sd) SDfreeSpectralDF(sd->tf); sd->tf = NULL; } + if (sd->tb != NULL) { + SDfreeSpectralDF(sd->tb); + sd->tb = NULL; + } sd->rLambFront.cieY = .0; sd->rLambFront.spec.flags = 0; sd->rLambBack.cieY = .0; @@ -355,11 +423,11 @@ SDcacheFile(const char *fname) return NULL; SDerrorDetail[0] = '\0'; if ((sd = SDgetCache(fname)) == NULL) { - SDreportEnglish(SDEmemory, stderr); + SDreportError(SDEmemory, stderr); return NULL; } if (!SDisLoaded(sd) && (ec = SDloadFile(sd, fname))) { - SDreportEnglish(ec, stderr); + SDreportError(ec, stderr); SDfreeCache(sd); return NULL; } @@ -393,6 +461,7 @@ SDfreeCache(const SDData *sd) SDfreeCumulativeCache(sd->rf); SDfreeCumulativeCache(sd->rb); SDfreeCumulativeCache(sd->tf); + SDfreeCumulativeCache(sd->tb); return; } /* remove from list and free */ @@ -422,7 +491,7 @@ SDsampComponent(SDValue *sv, FVECT ioVec, double randX cd = (*sdc->func->getCDist)(inVec, sdc); if (cd == NULL) return SDEmemory; - if (cd->cTotal <= 1e-7) { /* anything to sample? */ + if (cd->cTotal <= 1e-6) { /* anything to sample? */ sv->spec = c_dfcolor; sv->cieY = .0; memset(ioVec, 0, 3*sizeof(double)); @@ -459,7 +528,15 @@ SDmultiSamp(double t[], int n, double randX) unsigned nBits; double scale; bitmask_t ndx, coord[MS_MAXDIM]; - + + if (n <= 0) /* check corner cases */ + return; + if (randX < 0) randX = 0; + else if (randX >= 1.) randX = 0.999999999999999; + if (n == 1) { + t[0] = randX; + return; + } while (n > MS_MAXDIM) /* punt for higher dimensions */ t[--n] = rand()*(1./(RAND_MAX+.5)); nBits = (8*sizeof(bitmask_t) - 1) / n; @@ -513,11 +590,13 @@ SDsizeBSDF(double *projSA, const FVECT v1, const RREAL case 0: return SDEargument; } - if (v1[2] > 0) /* front surface query? */ + if (v1[2] > 0) { /* front surface query? */ rdf = sd->rf; - else + tdf = (sd->tf != NULL) ? sd->tf : sd->tb; + } else { rdf = sd->rb; - tdf = sd->tf; + tdf = (sd->tb != NULL) ? sd->tb : sd->tf; + } if (v2 != NULL) /* bidirectional? */ if (v1[2] > 0 ^ v2[2] > 0) rdf = NULL; @@ -565,9 +644,12 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC } else if (!(inFront | outFront)) { *sv = sd->rLambBack; sdf = sd->rb; - } else /* inFront ^ outFront */ { + } else if (inFront) { *sv = sd->tLamb; - sdf = sd->tf; + sdf = (sd->tf != NULL) ? sd->tf : sd->tb; + } else /* inBack */ { + *sv = sd->tLamb; + sdf = (sd->tb != NULL) ? sd->tb : sd->tf; } sv->cieY *= 1./M_PI; /* add non-diffuse components */ @@ -591,7 +673,7 @@ double SDdirectHemi(const FVECT inVec, int sflags, const SDData *sd) { double hsum; - SDSpectralDF *rdf; + SDSpectralDF *rdf, *tdf; const SDCDst *cd; int i; /* check arguments */ @@ -601,26 +683,28 @@ SDdirectHemi(const FVECT inVec, int sflags, const SDDa if (inVec[2] > 0) { hsum = sd->rLambFront.cieY; rdf = sd->rf; + tdf = (sd->tf != NULL) ? sd->tf : sd->tb; } else /* !inFront */ { hsum = sd->rLambBack.cieY; rdf = sd->rb; + tdf = (sd->tb != NULL) ? sd->tb : sd->tf; } if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR) hsum = .0; if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) hsum += sd->tLamb.cieY; /* gather non-diffuse components */ - i = ((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR && - rdf != NULL) ? rdf->ncomp : 0; + i = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) & + (rdf != NULL)) ? rdf->ncomp : 0; while (i-- > 0) { /* non-diffuse reflection */ cd = (*rdf->comp[i].func->getCDist)(inVec, &rdf->comp[i]); if (cd != NULL) hsum += cd->cTotal; } - i = ((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT && - sd->tf != NULL) ? sd->tf->ncomp : 0; + i = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) & + (tdf != NULL)) ? tdf->ncomp : 0; while (i-- > 0) { /* non-diffuse transmission */ - cd = (*sd->tf->comp[i].func->getCDist)(inVec, &sd->tf->comp[i]); + cd = (*tdf->comp[i].func->getCDist)(inVec, &tdf->comp[i]); if (cd != NULL) hsum += cd->cTotal; } @@ -634,7 +718,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int SDError ec; FVECT inVec; int inFront; - SDSpectralDF *rdf; + SDSpectralDF *rdf, *tdf; double rdiff; float coef[SDmaxCh]; int i, j, n, nr; @@ -651,9 +735,11 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int if (inFront) { *sv = sd->rLambFront; rdf = sd->rf; + tdf = (sd->tf != NULL) ? sd->tf : sd->tb; } else /* !inFront */ { *sv = sd->rLambBack; rdf = sd->rb; + tdf = (sd->tb != NULL) ? sd->tb : sd->tf; } if ((sflags & SDsampDf+SDsampR) != SDsampDf+SDsampR) sv->cieY = .0; @@ -661,15 +747,15 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) sv->cieY += sd->tLamb.cieY; /* gather non-diffuse components */ - i = nr = ((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR && - rdf != NULL) ? rdf->ncomp : 0; - j = ((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT && - sd->tf != NULL) ? sd->tf->ncomp : 0; + i = nr = (((sflags & SDsampSp+SDsampR) == SDsampSp+SDsampR) & + (rdf != NULL)) ? rdf->ncomp : 0; + j = (((sflags & SDsampSp+SDsampT) == SDsampSp+SDsampT) & + (tdf != NULL)) ? tdf->ncomp : 0; n = i + j; if (n > 0 && (cdarr = (const SDCDst **)malloc(n*sizeof(SDCDst *))) == NULL) return SDEmemory; while (j-- > 0) { /* non-diffuse transmission */ - cdarr[i+j] = (*sd->tf->comp[j].func->getCDist)(inVec, &sd->tf->comp[j]); + cdarr[i+j] = (*tdf->comp[j].func->getCDist)(inVec, &tdf->comp[j]); if (cdarr[i+j] == NULL) { free(cdarr); return SDEmemory; @@ -684,7 +770,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int } sv->cieY += cdarr[i]->cTotal; } - if (sv->cieY <= 1e-7) { /* anything to sample? */ + if (sv->cieY <= 1e-6) { /* anything to sample? */ sv->cieY = .0; memset(ioVec, 0, 3*sizeof(double)); return SDEnone; @@ -712,7 +798,7 @@ SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int if (i >= n) return SDEinternal; /* compute sample direction */ - sdc = (i < nr) ? &rdf->comp[i] : &sd->tf->comp[i-nr]; + sdc = (i < nr) ? &rdf->comp[i] : &tdf->comp[i-nr]; ec = (*sdc->func->sampCDist)(ioVec, randX/cdarr[i]->cTotal, cdarr[i]); if (ec) return ec; @@ -804,720 +890,3 @@ SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT i VCOPY(resVec, vTmp); return SDEnone; } - -/*################################################################*/ -/*######### DEPRECATED ROUTINES AWAITING PERMANENT REMOVAL #######*/ - -/* - * Routines for handling BSDF data - */ - -#include "standard.h" -#include "paths.h" - -#define MAXLATS 46 /* maximum number of latitudes */ - -/* BSDF angle specification */ -typedef struct { - char name[64]; /* basis name */ - int nangles; /* total number of directions */ - struct { - float tmin; /* starting theta */ - short nphis; /* number of phis (0 term) */ - } lat[MAXLATS+1]; /* latitudes */ -} ANGLE_BASIS; - -#define MAXABASES 7 /* limit on defined bases */ - -static ANGLE_BASIS abase_list[MAXABASES] = { - { - "LBNL/Klems Full", 145, - { {-5., 1}, - {5., 8}, - {15., 16}, - {25., 20}, - {35., 24}, - {45., 24}, - {55., 24}, - {65., 16}, - {75., 12}, - {90., 0} } - }, { - "LBNL/Klems Half", 73, - { {-6.5, 1}, - {6.5, 8}, - {19.5, 12}, - {32.5, 16}, - {46.5, 20}, - {61.5, 12}, - {76.5, 4}, - {90., 0} } - }, { - "LBNL/Klems Quarter", 41, - { {-9., 1}, - {9., 8}, - {27., 12}, - {46., 12}, - {66., 8}, - {90., 0} } - } -}; - -static int nabases = 3; /* current number of defined bases */ - -#define FEQ(a,b) ((a)-(b) <= 1e-6 && (b)-(a) <= 1e-6) - -static int -fequal(double a, double b) -{ - if (b != 0) - a = a/b - 1.; - return((a <= 1e-6) & (a >= -1e-6)); -} - -/* Returns the name of the given tag */ -#ifdef ezxml_name -#undef ezxml_name -static char * -ezxml_name(ezxml_t xml) -{ - if (xml == NULL) - return(NULL); - return(xml->name); -} -#endif - -/* Returns the given tag's character content or empty string if none */ -#ifdef ezxml_txt -#undef ezxml_txt -static char * -ezxml_txt(ezxml_t xml) -{ - if (xml == NULL) - return(""); - return(xml->txt); -} -#endif - - -static int -ab_getvec( /* get vector for this angle basis index */ - FVECT v, - int ndx, - void *p -) -{ - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; - int li; - double pol, azi, d; - - if ((ndx < 0) | (ndx >= ab->nangles)) - return(0); - for (li = 0; ndx >= ab->lat[li].nphis; li++) - ndx -= ab->lat[li].nphis; - pol = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin); - azi = 2.*PI*ndx/ab->lat[li].nphis; - v[2] = d = cos(pol); - d = sqrt(1. - d*d); /* sin(pol) */ - v[0] = cos(azi)*d; - v[1] = sin(azi)*d; - return(1); -} - - -static int -ab_getndx( /* get index corresponding to the given vector */ - FVECT v, - void *p -) -{ - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; - int li, ndx; - double pol, azi, d; - - if ((v[2] < -1.0) | (v[2] > 1.0)) - return(-1); - pol = 180.0/PI*acos(v[2]); - azi = 180.0/PI*atan2(v[1], v[0]); - if (azi < 0.0) azi += 360.0; - for (li = 1; ab->lat[li].tmin <= pol; li++) - if (!ab->lat[li].nphis) - return(-1); - --li; - ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5); - if (ndx >= ab->lat[li].nphis) ndx = 0; - while (li--) - ndx += ab->lat[li].nphis; - return(ndx); -} - - -static double -ab_getohm( /* get solid angle for this angle basis index */ - int ndx, - void *p -) -{ - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; - int li; - double theta, theta1; - - if ((ndx < 0) | (ndx >= ab->nangles)) - return(0); - for (li = 0; ndx >= ab->lat[li].nphis; li++) - ndx -= ab->lat[li].nphis; - theta1 = PI/180. * ab->lat[li+1].tmin; - if (ab->lat[li].nphis == 1) { /* special case */ - if (ab->lat[li].tmin > FTINY) - error(USER, "unsupported BSDF coordinate system"); - return(2.*PI*(1. - cos(theta1))); - } - theta = PI/180. * ab->lat[li].tmin; - return(2.*PI*(cos(theta) - cos(theta1))/(double)ab->lat[li].nphis); -} - - -static int -ab_getvecR( /* get reverse vector for this angle basis index */ - FVECT v, - int ndx, - void *p -) -{ - if (!ab_getvec(v, ndx, p)) - return(0); - - v[0] = -v[0]; - v[1] = -v[1]; - v[2] = -v[2]; - - return(1); -} - - -static int -ab_getndxR( /* get index corresponding to the reverse vector */ - FVECT v, - void *p -) -{ - FVECT v2; - - v2[0] = -v[0]; - v2[1] = -v[1]; - v2[2] = -v[2]; - - return ab_getndx(v2, p); -} - - -static void -load_angle_basis( /* load custom BSDF angle basis */ - ezxml_t wab -) -{ - char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName")); - ezxml_t wbb; - int i; - - if (!abname || !*abname) - return; - for (i = nabases; i--; ) - if (!strcasecmp(abname, abase_list[i].name)) - return; /* assume it's the same */ - if (nabases >= MAXABASES) - error(INTERNAL, "too many angle bases"); - strcpy(abase_list[nabases].name, abname); - abase_list[nabases].nangles = 0; - for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock"); - wbb != NULL; i++, wbb = wbb->next) { - if (i >= MAXLATS) - error(INTERNAL, "too many latitudes in custom basis"); - abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt( - ezxml_child(ezxml_child(wbb, - "ThetaBounds"), "UpperTheta"))); - if (!i) - abase_list[nabases].lat[i].tmin = - -abase_list[nabases].lat[i+1].tmin; - else if (!fequal(atof(ezxml_txt(ezxml_child(ezxml_child(wbb, - "ThetaBounds"), "LowerTheta"))), - abase_list[nabases].lat[i].tmin)) - error(WARNING, "theta values disagree in custom basis"); - abase_list[nabases].nangles += - abase_list[nabases].lat[i].nphis = - atoi(ezxml_txt(ezxml_child(wbb, "nPhis"))); - } - abase_list[nabases++].lat[i].nphis = 0; -} - - -static void -load_geometry( /* load geometric dimensions and description (if any) */ - struct BSDF_data *dp, - ezxml_t wdb -) -{ - ezxml_t geom; - double cfact; - const char *fmt, *mgfstr; - - dp->dim[0] = dp->dim[1] = dp->dim[2] = 0; - dp->mgf = NULL; - if ((geom = ezxml_child(wdb, "Width")) != NULL) - dp->dim[0] = atof(ezxml_txt(geom)) * - to_meters(ezxml_attr(geom, "unit")); - if ((geom = ezxml_child(wdb, "Height")) != NULL) - dp->dim[1] = atof(ezxml_txt(geom)) * - to_meters(ezxml_attr(geom, "unit")); - if ((geom = ezxml_child(wdb, "Thickness")) != NULL) - dp->dim[2] = atof(ezxml_txt(geom)) * - to_meters(ezxml_attr(geom, "unit")); - if ((geom = ezxml_child(wdb, "Geometry")) == NULL || - (mgfstr = ezxml_txt(geom)) == NULL) - return; - if ((fmt = ezxml_attr(geom, "format")) != NULL && - strcasecmp(fmt, "MGF")) { - sprintf(errmsg, "unrecognized geometry format '%s'", fmt); - error(WARNING, errmsg); - return; - } - cfact = to_meters(ezxml_attr(geom, "unit")); - dp->mgf = (char *)malloc(strlen(mgfstr)+32); - if (dp->mgf == NULL) - error(SYSTEM, "out of memory in load_geometry"); - if (cfact < 0.99 || cfact > 1.01) - sprintf(dp->mgf, "xf -s %.5f\n%s\nxf\n", cfact, mgfstr); - else - strcpy(dp->mgf, mgfstr); -} - - -static void -load_bsdf_data( /* load BSDF distribution for this wavelength */ - struct BSDF_data *dp, - ezxml_t wdb -) -{ - char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis")); - char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis")); - char *sdata; - int i; - - if ((!cbasis || !*cbasis) | (!rbasis || !*rbasis)) { - error(WARNING, "missing column/row basis for BSDF"); - return; - } - for (i = nabases; i--; ) - if (!strcasecmp(cbasis, abase_list[i].name)) { - dp->ninc = abase_list[i].nangles; - dp->ib_priv = (void *)&abase_list[i]; - dp->ib_vec = ab_getvecR; - dp->ib_ndx = ab_getndxR; - dp->ib_ohm = ab_getohm; - break; - } - if (i < 0) { - sprintf(errmsg, "undefined ColumnAngleBasis '%s'", cbasis); - error(WARNING, errmsg); - return; - } - for (i = nabases; i--; ) - if (!strcasecmp(rbasis, abase_list[i].name)) { - dp->nout = abase_list[i].nangles; - dp->ob_priv = (void *)&abase_list[i]; - dp->ob_vec = ab_getvec; - dp->ob_ndx = ab_getndx; - dp->ob_ohm = ab_getohm; - break; - } - if (i < 0) { - sprintf(errmsg, "undefined RowAngleBasis '%s'", rbasis); - error(WARNING, errmsg); - return; - } - /* read BSDF data */ - sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); - if (!sdata || !*sdata) { - error(WARNING, "missing BSDF ScatteringData"); - return; - } - dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout); - if (dp->bsdf == NULL) - error(SYSTEM, "out of memory in load_bsdf_data"); - for (i = 0; i < dp->ninc*dp->nout; i++) { - char *sdnext = fskip(sdata); - if (sdnext == NULL) { - error(WARNING, "bad/missing BSDF ScatteringData"); - free(dp->bsdf); dp->bsdf = NULL; - return; - } - while (*sdnext && isspace(*sdnext)) - sdnext++; - if (*sdnext == ',') sdnext++; - dp->bsdf[i] = atof(sdata); - sdata = sdnext; - } - while (isspace(*sdata)) - sdata++; - if (*sdata) { - sprintf(errmsg, "%d extra characters after BSDF ScatteringData", - (int)strlen(sdata)); - error(WARNING, errmsg); - } -} - - -static int -check_bsdf_data( /* check that BSDF data is sane */ - struct BSDF_data *dp -) -{ - double *omega_iarr, *omega_oarr; - double dom, contrib, hemi_total, full_total; - int nneg; - FVECT v; - int i, o; - - if (dp == NULL || dp->bsdf == NULL) - return(0); - omega_iarr = (double *)calloc(dp->ninc, sizeof(double)); - omega_oarr = (double *)calloc(dp->nout, sizeof(double)); - if ((omega_iarr == NULL) | (omega_oarr == NULL)) - error(SYSTEM, "out of memory in check_bsdf_data"); - /* incoming projected solid angles */ - hemi_total = .0; - for (i = dp->ninc; i--; ) { - dom = getBSDF_incohm(dp,i); - if (dom <= 0) { - error(WARNING, "zero/negative incoming solid angle"); - continue; - } - if (!getBSDF_incvec(v,dp,i) || v[2] > FTINY) { - error(WARNING, "illegal incoming BSDF direction"); - free(omega_iarr); free(omega_oarr); - return(0); - } - hemi_total += omega_iarr[i] = dom * -v[2]; - } - if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) { - sprintf(errmsg, "incoming BSDF hemisphere off by %.1f%%", - 100.*(hemi_total/PI - 1.)); - error(WARNING, errmsg); - } - dom = PI / hemi_total; /* fix normalization */ - for (i = dp->ninc; i--; ) - omega_iarr[i] *= dom; - /* outgoing projected solid angles */ - hemi_total = .0; - for (o = dp->nout; o--; ) { - dom = getBSDF_outohm(dp,o); - if (dom <= 0) { - error(WARNING, "zero/negative outgoing solid angle"); - continue; - } - if (!getBSDF_outvec(v,dp,o) || v[2] < -FTINY) { - error(WARNING, "illegal outgoing BSDF direction"); - free(omega_iarr); free(omega_oarr); - return(0); - } - hemi_total += omega_oarr[o] = dom * v[2]; - } - if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) { - sprintf(errmsg, "outgoing BSDF hemisphere off by %.1f%%", - 100.*(hemi_total/PI - 1.)); - error(WARNING, errmsg); - } - dom = PI / hemi_total; /* fix normalization */ - for (o = dp->nout; o--; ) - omega_oarr[o] *= dom; - nneg = 0; /* check outgoing totals */ - for (i = 0; i < dp->ninc; i++) { - hemi_total = .0; - for (o = dp->nout; o--; ) { - double f = BSDF_value(dp,i,o); - if (f >= 0) - hemi_total += f*omega_oarr[o]; - else { - nneg += (f < -FTINY); - BSDF_value(dp,i,o) = .0f; - } - } - if (hemi_total > 1.01) { - sprintf(errmsg, - "incoming BSDF direction %d passes %.1f%% of light", - i, 100.*hemi_total); - error(WARNING, errmsg); - } - } - if (nneg) { - sprintf(errmsg, "%d negative BSDF values (ignored)", nneg); - error(WARNING, errmsg); - } - full_total = .0; /* reverse roles and check again */ - for (o = 0; o < dp->nout; o++) { - hemi_total = .0; - for (i = dp->ninc; i--; ) - hemi_total += BSDF_value(dp,i,o) * omega_iarr[i]; - - if (hemi_total > 1.01) { - sprintf(errmsg, - "outgoing BSDF direction %d collects %.1f%% of light", - o, 100.*hemi_total); - error(WARNING, errmsg); - } - full_total += hemi_total*omega_oarr[o]; - } - full_total /= PI; - if (full_total > 1.00001) { - sprintf(errmsg, "BSDF transfers %.4f%% of light", - 100.*full_total); - error(WARNING, errmsg); - } - free(omega_iarr); free(omega_oarr); - return(1); -} - - -struct BSDF_data * -load_BSDF( /* load BSDF data from file */ - char *fname -) -{ - char *path; - ezxml_t fl, wtl, wld, wdb; - struct BSDF_data *dp; - - path = getpath(fname, getrlibpath(), R_OK); - if (path == NULL) { - sprintf(errmsg, "cannot find BSDF file \"%s\"", fname); - error(WARNING, errmsg); - return(NULL); - } - fl = ezxml_parse_file(path); - if (fl == NULL) { - sprintf(errmsg, "cannot open BSDF \"%s\"", path); - error(WARNING, errmsg); - return(NULL); - } - if (ezxml_error(fl)[0]) { - sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl)); - error(WARNING, errmsg); - ezxml_free(fl); - return(NULL); - } - if (strcmp(ezxml_name(fl), "WindowElement")) { - sprintf(errmsg, - "BSDF \"%s\": top level node not 'WindowElement'", - path); - error(WARNING, errmsg); - ezxml_free(fl); - return(NULL); - } - wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer"); - if (strcasecmp(ezxml_txt(ezxml_child(ezxml_child(wtl, - "DataDefinition"), "IncidentDataStructure")), - "Columns")) { - sprintf(errmsg, - "BSDF \"%s\": unsupported IncidentDataStructure", - path); - error(WARNING, errmsg); - ezxml_free(fl); - return(NULL); - } - load_angle_basis(ezxml_child(ezxml_child(wtl, - "DataDefinition"), "AngleBasis")); - dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data)); - load_geometry(dp, ezxml_child(wtl, "Material")); - for (wld = ezxml_child(wtl, "WavelengthData"); - wld != NULL; wld = wld->next) { - if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")), - "Visible")) - continue; - for (wdb = ezxml_child(wld, "WavelengthDataBlock"); - wdb != NULL; wdb = wdb->next) - if (!strcasecmp(ezxml_txt(ezxml_child(wdb, - "WavelengthDataDirection")), - "Transmission Front")) - break; - if (wdb != NULL) { /* load front BTDF */ - load_bsdf_data(dp, wdb); - break; /* ignore the rest */ - } - } - ezxml_free(fl); /* done with XML file */ - if (!check_bsdf_data(dp)) { - sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path); - error(WARNING, errmsg); - free_BSDF(dp); - dp = NULL; - } - return(dp); -} - - -void -free_BSDF( /* free BSDF data structure */ - struct BSDF_data *b -) -{ - if (b == NULL) - return; - if (b->mgf != NULL) - free(b->mgf); - if (b->bsdf != NULL) - free(b->bsdf); - free(b); -} - - -int -r_BSDF_incvec( /* compute random input vector at given location */ - FVECT v, - struct BSDF_data *b, - int i, - double rv, - MAT4 xm -) -{ - FVECT pert; - double rad; - int j; - - if (!getBSDF_incvec(v, b, i)) - return(0); - rad = sqrt(getBSDF_incohm(b, i) / PI); - multisamp(pert, 3, rv); - for (j = 0; j < 3; j++) - v[j] += rad*(2.*pert[j] - 1.); - if (xm != NULL) - multv3(v, v, xm); - return(normalize(v) != 0.0); -} - - -int -r_BSDF_outvec( /* compute random output vector at given location */ - FVECT v, - struct BSDF_data *b, - int o, - double rv, - MAT4 xm -) -{ - FVECT pert; - double rad; - int j; - - if (!getBSDF_outvec(v, b, o)) - return(0); - rad = sqrt(getBSDF_outohm(b, o) / PI); - multisamp(pert, 3, rv); - for (j = 0; j < 3; j++) - v[j] += rad*(2.*pert[j] - 1.); - if (xm != NULL) - multv3(v, v, xm); - return(normalize(v) != 0.0); -} - - -static int -addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */ - char *xfarg[], - FVECT xp, - FVECT yp, - FVECT zp -) -{ - static char bufs[3][16]; - int bn = 0; - char **xfp = xfarg; - double theta; - - if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) { - /* Special case for X' along Z-axis */ - theta = -atan2(yp[0], yp[1]); - *xfp++ = "-ry"; - *xfp++ = xp[2] < 0.0 ? "90" : "-90"; - *xfp++ = "-rz"; - sprintf(bufs[bn], "%f", theta*(180./PI)); - *xfp++ = bufs[bn++]; - return(xfp - xfarg); - } - theta = atan2(yp[2], zp[2]); - if (!FEQ(theta,0.0)) { - *xfp++ = "-rx"; - sprintf(bufs[bn], "%f", theta*(180./PI)); - *xfp++ = bufs[bn++]; - } - theta = asin(-xp[2]); - if (!FEQ(theta,0.0)) { - *xfp++ = "-ry"; - sprintf(bufs[bn], " %f", theta*(180./PI)); - *xfp++ = bufs[bn++]; - } - theta = atan2(xp[1], xp[0]); - if (!FEQ(theta,0.0)) { - *xfp++ = "-rz"; - sprintf(bufs[bn], "%f", theta*(180./PI)); - *xfp++ = bufs[bn++]; - } - *xfp = NULL; - return(xfp - xfarg); -} - - -int -getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */ - MAT4 xm, - FVECT nrm, - UpDir ud, - char *xfbuf -) -{ - char *xfargs[7]; - XF myxf; - FVECT updir, xdest, ydest; - int i; - - updir[0] = updir[1] = updir[2] = 0.; - switch (ud) { - case UDzneg: - updir[2] = -1.; - break; - case UDyneg: - updir[1] = -1.; - break; - case UDxneg: - updir[0] = -1.; - break; - case UDxpos: - updir[0] = 1.; - break; - case UDypos: - updir[1] = 1.; - break; - case UDzpos: - updir[2] = 1.; - break; - case UDunknown: - return(0); - } - fcross(xdest, updir, nrm); - if (normalize(xdest) == 0.0) - return(0); - fcross(ydest, nrm, xdest); - xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs); - copymat4(xm, myxf.xfm); - if (xfbuf == NULL) - return(1); - /* return xf arguments as well */ - for (i = 0; xfargs[i] != NULL; i++) { - *xfbuf++ = ' '; - strcpy(xfbuf, xfargs[i]); - while (*xfbuf) ++xfbuf; - } - return(1); -} - -/*######### END DEPRECATED ROUTINES #######*/ -/*################################################################*/
