--- ray/src/common/bsdf.c 2011/04/17 17:45:13 2.21 +++ ray/src/common/bsdf.c 2011/06/09 17:09:39 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf.c,v 2.21 2011/04/17 17:45:13 greg Exp $"; +static const char RCSid[] = "$Id: bsdf.c,v 2.30 2011/06/09 17:09:39 greg Exp $"; #endif /* * bsdf.c @@ -10,6 +10,7 @@ static const char RCSid[] = "$Id: bsdf.c,v 2.21 2011/0 * */ +#define _USE_MATH_DEFINES #include #include #include @@ -99,7 +100,7 @@ SDloadGeometry(SDData *sd, ezxml_t wdb) if ((geom = ezxml_child(wdb, "Thickness")) != NULL) sd->dim[2] = atof(ezxml_txt(geom)) * to_meters(ezxml_attr(geom, "unit")); - if ((sd->dim[0] < .0) | (sd->dim[1] < .0) | (sd->dim[2] < .0)) { + if ((sd->dim[0] < 0) | (sd->dim[1] < 0) | (sd->dim[2] < 0)) { sprintf(SDerrorDetail, "Negative size in \"%s\"", sd->name); return SDEdata; } @@ -169,15 +170,9 @@ SDloadFile(SDData *sd, const char *fname) /* try loading variable resolution data */ lastErr = SDloadTre(sd, wtl); /* check our result */ - switch (lastErr) { - case SDEformat: - case SDEdata: - case SDEsupport: /* possibly we just tried the wrong format */ + if (lastErr == SDEsupport) /* try matrix BSDF if not tree data */ lastErr = SDloadMtx(sd, wtl); - break; - default: /* variable res. OK else serious error */ - break; - } + /* done with XML file */ ezxml_free(fl); @@ -405,34 +400,35 @@ SDfreeCache(const SDData *sd) /* Sample an individual BSDF component */ SDError -SDsampComponent(SDValue *sv, FVECT outVec, const FVECT inVec, - double randX, SDComponent *sdc) +SDsampComponent(SDValue *sv, FVECT ioVec, double randX, SDComponent *sdc) { float coef[SDmaxCh]; SDError ec; + FVECT inVec; const SDCDst *cd; double d; int n; /* check arguments */ - if ((sv == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)) + if ((sv == NULL) | (ioVec == NULL) | (sdc == NULL)) return SDEargument; /* get cumulative distribution */ + VCOPY(inVec, ioVec); cd = (*sdc->func->getCDist)(inVec, sdc); if (cd == NULL) return SDEmemory; if (cd->cTotal <= 1e-7) { /* anything to sample? */ sv->spec = c_dfcolor; sv->cieY = .0; - memset(outVec, 0, 3*sizeof(double)); + memset(ioVec, 0, 3*sizeof(double)); return SDEnone; } sv->cieY = cd->cTotal; /* compute sample direction */ - ec = (*sdc->func->sampCDist)(outVec, randX, cd); + ec = (*sdc->func->sampCDist)(ioVec, randX, cd); if (ec) return ec; /* get BSDF color */ - n = (*sdc->func->getBSDFs)(coef, outVec, inVec, sdc->dist); + n = (*sdc->func->getBSDFs)(coef, ioVec, inVec, sdc); if (n <= 0) { strcpy(SDerrorDetail, "BSDF sample value error"); return SDEinternal; @@ -480,7 +476,7 @@ SDdiffuseSamp(FVECT outVec, int outFront, double randX SDmultiSamp(outVec, 2, randX); SDsquare2disk(outVec, outVec[0], outVec[1]); outVec[2] = 1. - outVec[0]*outVec[0] - outVec[1]*outVec[1]; - if (outVec[2] > .0) /* a bit of paranoia */ + if (outVec[2] > 0) /* a bit of paranoia */ outVec[2] = sqrt(outVec[2]); if (!outFront) /* going out back? */ outVec[2] = -outVec[2]; @@ -488,13 +484,14 @@ SDdiffuseSamp(FVECT outVec, int outFront, double randX /* Query projected solid angle coverage for non-diffuse BSDF direction */ SDError -SDsizeBSDF(double *projSA, const FVECT vec, int qflags, const SDData *sd) +SDsizeBSDF(double *projSA, const FVECT v1, const RREAL *v2, + int qflags, const SDData *sd) { - SDSpectralDF *rdf; + SDSpectralDF *rdf, *tdf; SDError ec; int i; /* check arguments */ - if ((projSA == NULL) | (vec == NULL) | (sd == NULL)) + if ((projSA == NULL) | (v1 == NULL) | (sd == NULL)) return SDEargument; /* initialize extrema */ switch (qflags) { @@ -510,20 +507,26 @@ SDsizeBSDF(double *projSA, const FVECT vec, int qflags case 0: return SDEargument; } - if (vec[2] > .0) /* front surface query? */ + if (v1[2] > 0) /* front surface query? */ rdf = sd->rf; else rdf = sd->rb; + tdf = sd->tf; + if (v2 != NULL) /* bidirectional? */ + if (v1[2] > 0 ^ v2[2] > 0) + rdf = NULL; + else + tdf = NULL; ec = SDEdata; /* run through components */ for (i = (rdf==NULL) ? 0 : rdf->ncomp; i--; ) { - ec = (*rdf->comp[i].func->queryProjSA)(projSA, vec, qflags, - rdf->comp[i].dist); + ec = (*rdf->comp[i].func->queryProjSA)(projSA, v1, v2, + qflags, &rdf->comp[i]); if (ec) return ec; } - for (i = (sd->tf==NULL) ? 0 : sd->tf->ncomp; i--; ) { - ec = (*sd->tf->comp[i].func->queryProjSA)(projSA, vec, qflags, - sd->tf->comp[i].dist); + for (i = (tdf==NULL) ? 0 : tdf->ncomp; i--; ) { + ec = (*tdf->comp[i].func->queryProjSA)(projSA, v1, v2, + qflags, &tdf->comp[i]); if (ec) return ec; } @@ -547,8 +550,8 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC if ((sv == NULL) | (outVec == NULL) | (inVec == NULL) | (sd == NULL)) return SDEargument; /* whose side are we on? */ - inFront = (inVec[2] > .0); - outFront = (outVec[2] > .0); + inFront = (inVec[2] > 0); + outFront = (outVec[2] > 0); /* start with diffuse portion */ if (inFront & outFront) { *sv = sd->rLambFront; @@ -565,7 +568,7 @@ SDevalBSDF(SDValue *sv, const FVECT outVec, const FVEC i = (sdf != NULL) ? sdf->ncomp : 0; while (i-- > 0) { nch = (*sdf->comp[i].func->getBSDFs)(coef, outVec, inVec, - sdf->comp[i].dist); + &sdf->comp[i]); while (nch-- > 0) { c_cmix(&sv->spec, sv->cieY, &sv->spec, coef[nch], &sdf->comp[i].cspec[nch]); @@ -589,7 +592,7 @@ SDdirectHemi(const FVECT inVec, int sflags, const SDDa if ((inVec == NULL) | (sd == NULL)) return .0; /* gather diffuse components */ - if (inVec[2] > .0) { + if (inVec[2] > 0) { hsum = sd->rLambFront.cieY; rdf = sd->rf; } else /* !inFront */ { @@ -620,10 +623,10 @@ SDdirectHemi(const FVECT inVec, int sflags, const SDDa /* Sample BSDF direction based on the given random variable */ SDError -SDsampBSDF(SDValue *sv, FVECT outVec, const FVECT inVec, - double randX, int sflags, const SDData *sd) +SDsampBSDF(SDValue *sv, FVECT ioVec, double randX, int sflags, const SDData *sd) { SDError ec; + FVECT inVec; int inFront; SDSpectralDF *rdf; double rdiff; @@ -632,11 +635,12 @@ SDsampBSDF(SDValue *sv, FVECT outVec, const FVECT inVe SDComponent *sdc; const SDCDst **cdarr = NULL; /* check arguments */ - if ((sv == NULL) | (outVec == NULL) | (inVec == NULL) | (sd == NULL) | - (randX < .0) | (randX >= 1.)) + if ((sv == NULL) | (ioVec == NULL) | (sd == NULL) | + (randX < 0) | (randX >= 1.)) return SDEargument; /* whose side are we on? */ - inFront = (inVec[2] > .0); + VCOPY(inVec, ioVec); + inFront = (inVec[2] > 0); /* remember diffuse portions */ if (inFront) { *sv = sd->rLambFront; @@ -676,14 +680,14 @@ SDsampBSDF(SDValue *sv, FVECT outVec, const FVECT inVe } if (sv->cieY <= 1e-7) { /* anything to sample? */ sv->cieY = .0; - memset(outVec, 0, 3*sizeof(double)); + memset(ioVec, 0, 3*sizeof(double)); return SDEnone; } /* scale random variable */ randX *= sv->cieY; /* diffuse reflection? */ if (randX < rdiff) { - SDdiffuseSamp(outVec, inFront, randX/rdiff); + SDdiffuseSamp(ioVec, inFront, randX/rdiff); goto done; } randX -= rdiff; @@ -691,7 +695,7 @@ SDsampBSDF(SDValue *sv, FVECT outVec, const FVECT inVe if ((sflags & SDsampDf+SDsampT) == SDsampDf+SDsampT) { if (randX < sd->tLamb.cieY) { sv->spec = sd->tLamb.spec; - SDdiffuseSamp(outVec, !inFront, randX/sd->tLamb.cieY); + SDdiffuseSamp(ioVec, !inFront, randX/sd->tLamb.cieY); goto done; } randX -= sd->tLamb.cieY; @@ -703,11 +707,11 @@ SDsampBSDF(SDValue *sv, FVECT outVec, const FVECT inVe return SDEinternal; /* compute sample direction */ sdc = (i < nr) ? &rdf->comp[i] : &sd->tf->comp[i-nr]; - ec = (*sdc->func->sampCDist)(outVec, randX/cdarr[i]->cTotal, cdarr[i]); + ec = (*sdc->func->sampCDist)(ioVec, randX/cdarr[i]->cTotal, cdarr[i]); if (ec) return ec; /* compute color */ - j = (*sdc->func->getBSDFs)(coef, outVec, inVec, sdc->dist); + j = (*sdc->func->getBSDFs)(coef, ioVec, inVec, sdc); if (j <= 0) { sprintf(SDerrorDetail, "BSDF \"%s\" sampling value error", sd->name); @@ -734,10 +738,10 @@ SDcompXform(RREAL vMtx[3][3], const FVECT sNrm, const if ((vMtx == NULL) | (sNrm == NULL) | (uVec == NULL)) return SDEargument; VCOPY(vMtx[2], sNrm); - if (normalize(vMtx[2]) == .0) + if (normalize(vMtx[2]) == 0) return SDEargument; fcross(vMtx[0], uVec, vMtx[2]); - if (normalize(vMtx[0]) == .0) + if (normalize(vMtx[0]) == 0) return SDEargument; fcross(vMtx[1], vMtx[2], vMtx[0]); return SDEnone; @@ -757,7 +761,7 @@ SDinvXform(RREAL iMtx[3][3], RREAL vMtx[3][3]) mTmp[0][1] = vMtx[2][1]*vMtx[0][2] - vMtx[2][2]*vMtx[0][1]; mTmp[0][2] = vMtx[1][2]*vMtx[0][1] - vMtx[1][1]*vMtx[0][2]; d = vMtx[0][0]*mTmp[0][0] + vMtx[1][0]*mTmp[0][1] + vMtx[2][0]*mTmp[0][2]; - if (d == .0) { + if (d == 0) { strcpy(SDerrorDetail, "Zero determinant in matrix inversion"); return SDEargument; } @@ -784,12 +788,12 @@ SDmapDir(FVECT resVec, RREAL vMtx[3][3], const FVECT i if (vMtx == NULL) { /* assume they just want to normalize */ if (resVec != inpVec) VCOPY(resVec, inpVec); - return (normalize(resVec) > .0) ? SDEnone : SDEargument; + return (normalize(resVec) > 0) ? SDEnone : SDEargument; } vTmp[0] = DOT(vMtx[0], inpVec); vTmp[1] = DOT(vMtx[1], inpVec); vTmp[2] = DOT(vMtx[2], inpVec); - if (normalize(vTmp) == .0) + if (normalize(vTmp) == 0) return SDEargument; VCOPY(resVec, vTmp); return SDEnone; @@ -861,7 +865,7 @@ static int nabases = 3; /* current number of defined b static int fequal(double a, double b) { - if (b != .0) + if (b != 0) a = a/b - 1.; return((a <= 1e-6) & (a >= -1e-6)); } @@ -1179,7 +1183,7 @@ check_bsdf_data( /* check that BSDF data is sane */ hemi_total = .0; for (i = dp->ninc; i--; ) { dom = getBSDF_incohm(dp,i); - if (dom <= .0) { + if (dom <= 0) { error(WARNING, "zero/negative incoming solid angle"); continue; } @@ -1202,7 +1206,7 @@ check_bsdf_data( /* check that BSDF data is sane */ hemi_total = .0; for (o = dp->nout; o--; ) { dom = getBSDF_outohm(dp,o); - if (dom <= .0) { + if (dom <= 0) { error(WARNING, "zero/negative outgoing solid angle"); continue; } @@ -1226,7 +1230,7 @@ check_bsdf_data( /* check that BSDF data is sane */ hemi_total = .0; for (o = dp->nout; o--; ) { double f = BSDF_value(dp,i,o); - if (f >= .0) + if (f >= 0) hemi_total += f*omega_oarr[o]; else { nneg += (f < -FTINY);
