root/radiance/ray/src/common/bsdf.c
Mon Mar 24 04:00:45 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.47: +2 -3 lines
Diff to previous 2.47
Minor optimizations should not affect results
Sun Mar 23 23:15:53 2014 UTC (11 years, 1 month ago) by greg
Diff to previous 2.46
Fixed bug in SDsampBSDF()
Thu Jul 4 15:14:45 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.45: +3 -2 lines
Diff to previous 2.45
Added extra checks where projected solid angle is undefined
Wed Jul 3 18:56:19 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.44: +11 -15 lines
Diff to previous 2.44
Eliminated memory error caused by stray ray samples
Sun Apr 21 21:36:23 2013 UTC (12 years ago) by greg
Changes since 2.43: +9 -6 lines
Diff to previous 2.43
Added pointer indirection to make error reporting in other languages simpler
Sat Oct 13 20:15:43 2012 UTC (12 years, 7 months ago) by greg
Changes since 2.42: +56 -761 lines
Diff to previous 2.42
Sun Sep 2 15:33:15 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.41: +39 -19 lines
Diff to previous 2.41
Sat Jun 23 16:47:39 2012 UTC (12 years, 10 months ago) by greg
Changes since 2.40: +12 -4 lines
Diff to previous 2.40
Fixed incorrect call to multisamp()
Mon Mar 5 15:27:08 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.39: +5 -3 lines
Diff to previous 2.39
Tweak on last change to recording name & manufacturer
Mon Mar 5 00:17:06 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.38: +9 -1 lines
Diff to previous 2.38
Added recording of product and manufacturer names
Sun Mar 4 23:28:34 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.37: +8 -3 lines
Diff to previous 2.37
Improved error diagnostics
Sun Mar 4 20:11:10 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.36: +24 -1 lines
Diff to previous 2.36
Added routine for adding spectral distribution components
Sat Sep 17 22:09:33 2011 UTC (13 years, 8 months ago) by greg
Changes since 2.35: +4 -2 lines
Diff to previous 2.35
Added missing call to free EZXML structures on error
Sun Aug 21 22:38:12 2011 UTC (13 years, 8 months ago) by greg
Diff to previous 2.34
Minor improvements to direct specular sampling
Thu Jul 7 15:25:09 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.33: +8 -5 lines
Diff to previous 2.33
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Tue Jun 28 21:11:04 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.32: +3 -3 lines
Diff to previous 2.32
Minor compile fixes
Thu Jun 23 16:00:37 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.31: +6 -2 lines
Diff to previous 2.31
Additional check for empty MGF string
Fri Jun 10 01:11:26 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.30: +2 -1 lines
Diff to previous 2.30
Added missing header
Thu Jun 9 17:09:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29
Fixes for Windows and bug fix in bsdf_m.c
Fri Jun 3 18:12:58 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.28: +3 -9 lines
Diff to previous 2.28
Fixed bugs in variable-resolution isotropic BSDFs
Thu Apr 28 00:24:43 2011 UTC (14 years ago) by greg
Changes since 2.27: +1 -3 lines
Diff to previous 2.27
Removed debugging
Wed Apr 27 23:05:51 2011 UTC (14 years ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26
First test of variable-res BSDFs
Mon Apr 25 15:48:05 2011 UTC (14 years ago) by greg
Changes since 2.25: +8 -7 lines
Diff to previous 2.25
Fix from last change
Sun Apr 24 20:16:52 2011 UTC (14 years ago) by greg
Changes since 2.24: +6 -6 lines
Diff to previous 2.24
Bug fixes to last change
Sun Apr 24 19:39:21 2011 UTC (14 years ago) by greg
Changes since 2.23: +17 -15 lines
Diff to previous 2.23
Partial implementation of variable-resolution BSDFs
Wed Apr 20 14:44:05 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.22: +27 -22 lines
Diff to previous 2.22
Fixes to last change -- tested
Tue Apr 19 21:31:22 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.21: +9 -8 lines
Diff to previous 2.21
Fixed interface for determining BSDF solid angles
Sun Apr 17 17:45:13 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.20: +9 -5 lines
Diff to previous 2.20
Minor fixes
Mon Apr 11 03:47:46 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.19: +8 -4 lines
Diff to previous 2.19
Final fix to Klems angles -- I hope
Sat Apr 9 15:39:16 2011 UTC (14 years, 1 month ago) by greg
Diff to previous 2.18
Fixed range of rand() -> double conversion
Fri Apr 8 23:23:28 2011 UTC (14 years, 1 month ago) by greg
Diff to previous 2.17
Eliminated calls to drand48()
Sat Feb 19 23:42:09 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.16: +11 -5 lines
Diff to previous 2.16
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.15: +56 -25 lines
Diff to previous 2.15
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 00:40:25 2011 UTC (14 years, 3 months ago) by greg
Changes since 2.14: +756 -19 lines
Diff to previous 2.14
Fri Feb 11 17:31:25 2011 UTC (14 years, 3 months ago) by greg
Diff to previous 2.13
Fixed comment type
Thu Jan 6 22:27:56 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.12: +12 -8 lines
Diff to previous 2.12
Fixed handling of multiple WavelengthDataBlock's
Thu Jan 6 04:40:22 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.11: +6 -6 lines
Typo!
Thu Jan 6 04:39:08 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.10: +6 -6 lines
Removed some case-dependent string comparisons
Thu Jan 6 04:36:16 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.9: +11 -1 lines
Added check to ensure column ordering of BTDF
Mon Jan 3 19:27:00 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.8: +11 -3 lines
Slight improvement to conditional
Sun Sep 26 15:43:26 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.7: +6 -5 lines
Slight change to reporting thresholds for dubious BSDFs
Tue Sep 7 23:10:50 2010 UTC (14 years, 8 months ago) by greg
Changes since 2.6: +10 -3 lines
Added test for full light transfer in BSDF
Fri Sep 3 23:53:50 2010 UTC (14 years, 8 months ago) by greg
Changes since 2.5: +72 -2 lines
Sun Aug 1 22:26:37 2010 UTC (14 years, 9 months ago) by greg
Minor warning for 64-bit architectures
Sat Jul 3 05:28:05 2010 UTC (14 years, 10 months ago) by greg
Changes since 2.3: +9 -10 lines
Minor changes related to angle basis support
Sat Jul 3 02:50:22 2010 UTC (14 years, 10 months ago) by greg
Changes since 2.2: +72 -6 lines
Added support for custom angle bases
Fri Jun 19 06:49:25 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.1: +70 -30 lines
Improved error-checking
Wed Jun 17 20:41:47 2009 UTC (15 years, 11 months ago) by greg
