root/radiance/ray/src/common/bsdf.c
Revision: 2.13
Committed: Thu Jan 6 22:27:56 2011 UTC (13 years, 5 months ago) by greg
Changes since 2.12: +12 -8 lines
Fixed handling of multiple WavelengthDataBlock's
2 static const char RCSid[] = "$Id: bsdf.c,v 2.12 2011/01/06 04:40:22 greg Exp $";
5 * Routines for handling BSDF data
6 */
7
8 #include "standard.h"
9 #include "bsdf.h"
10 #include "paths.h"
11 #include "ezxml.h"
12 #include <ctype.h>
13
14 #define MAXLATS 46 /* maximum number of latitudes */
15
16 /* BSDF angle specification */
17 typedef struct {
18 char name[64]; /* basis name */
19 int nangles; /* total number of directions */
20 struct {
21 float tmin; /* starting theta */
22 short nphis; /* number of phis (0 term) */
23 } lat[MAXLATS+1]; /* latitudes */
24 } ANGLE_BASIS;
25
26 #define MAXABASES 7 /* limit on defined bases */
27
28 static ANGLE_BASIS abase_list[MAXABASES] = {
29 {
30 "LBNL/Klems Full", 145,
31 { {-5., 1},
32 {5., 8},
33 {15., 16},
34 {25., 20},
35 {35., 24},
36 {45., 24},
37 {55., 24},
38 {65., 16},
39 {75., 12},
40 {90., 0} }
41 }, {
42 "LBNL/Klems Half", 73,
43 { {-6.5, 1},
44 {6.5, 8},
45 {19.5, 12},
46 {32.5, 16},
47 {46.5, 20},
48 {61.5, 12},
49 {76.5, 4},
50 {90., 0} }
51 }, {
52 "LBNL/Klems Quarter", 41,
53 { {-9., 1},
54 {9., 8},
55 {27., 12},
56 {46., 12},
57 {66., 8},
58 {90., 0} }
59 }
60 };
61
62 static int nabases = 3; /* current number of defined bases */
63
64 #define FEQ(a,b) ((a)-(b) <= 1e-6 && (b)-(a) <= 1e-6)
65
66 static int
67 fequal(double a, double b)
68 {
69 if (b != .0)
70 a = a/b - 1.;
71 return((a <= 1e-6) & (a >= -1e-6));
72 }
73
74 // returns the name of the given tag
75 #ifdef ezxml_name
76 #undef ezxml_name
77 static char *
78 ezxml_name(ezxml_t xml)
79 {
80 if (xml == NULL)
81 return(NULL);
82 return(xml->name);
83 }
84 #endif
85
86 // returns the given tag's character content or empty string if none
87 #ifdef ezxml_txt
88 #undef ezxml_txt
89 static char *
90 ezxml_txt(ezxml_t xml)
91 {
92 if (xml == NULL)
93 return("");
94 return(xml->txt);
95 }
96 #endif
97
98
99 static int
100 ab_getvec( /* get vector for this angle basis index */
101 FVECT v,
102 int ndx,
103 void *p
104 )
105 {
106 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
107 int li;
108 double pol, azi, d;
109
110 if ((ndx < 0) | (ndx >= ab->nangles))
111 return(0);
112 for (li = 0; ndx >= ab->lat[li].nphis; li++)
113 ndx -= ab->lat[li].nphis;
114 pol = PI/180.*0.5*(ab->lat[li].tmin + ab->lat[li+1].tmin);
115 azi = 2.*PI*ndx/ab->lat[li].nphis;
116 v[2] = d = cos(pol);
117 d = sqrt(1. - d*d); /* sin(pol) */
118 v[0] = cos(azi)*d;
119 v[1] = sin(azi)*d;
120 return(1);
121 }
122
123
124 static int
125 ab_getndx( /* get index corresponding to the given vector */
126 FVECT v,
127 void *p
128 )
129 {
130 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
131 int li, ndx;
132 double pol, azi, d;
133
134 if ((v[2] < -1.0) | (v[2] > 1.0))
135 return(-1);
136 pol = 180.0/PI*acos(v[2]);
137 azi = 180.0/PI*atan2(v[1], v[0]);
138 if (azi < 0.0) azi += 360.0;
139 for (li = 1; ab->lat[li].tmin <= pol; li++)
140 if (!ab->lat[li].nphis)
141 return(-1);
142 --li;
143 ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
144 if (ndx >= ab->lat[li].nphis) ndx = 0;
145 while (li--)
146 ndx += ab->lat[li].nphis;
147 return(ndx);
148 }
149
150
151 static double
152 ab_getohm( /* get solid angle for this angle basis index */
153 int ndx,
154 void *p
155 )
156 {
157 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
158 int li;
159 double theta, theta1;
160
161 if ((ndx < 0) | (ndx >= ab->nangles))
162 return(0);
163 for (li = 0; ndx >= ab->lat[li].nphis; li++)
164 ndx -= ab->lat[li].nphis;
165 theta1 = PI/180. * ab->lat[li+1].tmin;
166 if (ab->lat[li].nphis == 1) { /* special case */
167 if (ab->lat[li].tmin > FTINY)
168 error(USER, "unsupported BSDF coordinate system");
169 return(2.*PI*(1. - cos(theta1)));
170 }
171 theta = PI/180. * ab->lat[li].tmin;
172 return(2.*PI*(cos(theta) - cos(theta1))/(double)ab->lat[li].nphis);
173 }
174
175
176 static int
177 ab_getvecR( /* get reverse vector for this angle basis index */
178 FVECT v,
179 int ndx,
180 void *p
181 )
182 {
183 if (!ab_getvec(v, ndx, p))
184 return(0);
185
186 v[0] = -v[0];
187 v[1] = -v[1];
188 v[2] = -v[2];
189
190 return(1);
191 }
192
193
194 static int
195 ab_getndxR( /* get index corresponding to the reverse vector */
196 FVECT v,
197 void *p
198 )
199 {
200 FVECT v2;
201
202 v2[0] = -v[0];
203 v2[1] = -v[1];
204 v2[2] = -v[2];
205
206 return ab_getndx(v2, p);
207 }
208
209
210 static void
211 load_angle_basis( /* load custom BSDF angle basis */
212 ezxml_t wab
213 )
214 {
215 char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName"));
216 ezxml_t wbb;
217 int i;
218
219 if (!abname || !*abname)
220 return;
221 for (i = nabases; i--; )
222 if (!strcasecmp(abname, abase_list[i].name))
223 return; /* assume it's the same */
224 if (nabases >= MAXABASES)
225 error(INTERNAL, "too many angle bases");
226 strcpy(abase_list[nabases].name, abname);
227 abase_list[nabases].nangles = 0;
228 for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock");
229 wbb != NULL; i++, wbb = wbb->next) {
230 if (i >= MAXLATS)
231 error(INTERNAL, "too many latitudes in custom basis");
232 abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt(
233 ezxml_child(ezxml_child(wbb,
234 "ThetaBounds"), "UpperTheta")));
235 if (!i)
236 abase_list[nabases].lat[i].tmin =
237 -abase_list[nabases].lat[i+1].tmin;
238 else if (!fequal(atof(ezxml_txt(ezxml_child(ezxml_child(wbb,
239 "ThetaBounds"), "LowerTheta"))),
240 abase_list[nabases].lat[i].tmin))
241 error(WARNING, "theta values disagree in custom basis");
242 abase_list[nabases].nangles +=
243 abase_list[nabases].lat[i].nphis =
244 atoi(ezxml_txt(ezxml_child(wbb, "nPhis")));
245 }
246 abase_list[nabases++].lat[i].nphis = 0;
247 }
248
249
250 static double
251 to_meters( /* return factor to convert given unit to meters */
252 const char *unit
253 )
254 {
255 if (unit == NULL) return(1.); /* safe assumption? */
256 if (!strcasecmp(unit, "Meter")) return(1.);
257 if (!strcasecmp(unit, "Foot")) return(.3048);
258 if (!strcasecmp(unit, "Inch")) return(.0254);
259 if (!strcasecmp(unit, "Centimeter")) return(.01);
260 if (!strcasecmp(unit, "Millimeter")) return(.001);
261 sprintf(errmsg, "unknown dimensional unit '%s'", unit);
262 error(USER, errmsg);
263 }
264
265
266 static void
267 load_geometry( /* load geometric dimensions and description (if any) */
268 struct BSDF_data *dp,
269 ezxml_t wdb
270 )
271 {
272 ezxml_t geom;
273 double cfact;
274 const char *fmt, *mgfstr;
275
276 dp->dim[0] = dp->dim[1] = dp->dim[2] = 0;
277 dp->mgf = NULL;
278 if ((geom = ezxml_child(wdb, "Width")) != NULL)
279 dp->dim[0] = atof(ezxml_txt(geom)) *
280 to_meters(ezxml_attr(geom, "unit"));
281 if ((geom = ezxml_child(wdb, "Height")) != NULL)
282 dp->dim[1] = atof(ezxml_txt(geom)) *
283 to_meters(ezxml_attr(geom, "unit"));
284 if ((geom = ezxml_child(wdb, "Thickness")) != NULL)
285 dp->dim[2] = atof(ezxml_txt(geom)) *
286 to_meters(ezxml_attr(geom, "unit"));
287 if ((geom = ezxml_child(wdb, "Geometry")) == NULL ||
288 (mgfstr = ezxml_txt(geom)) == NULL)
289 return;
290 if ((fmt = ezxml_attr(geom, "format")) != NULL &&
291 strcasecmp(fmt, "MGF")) {
292 sprintf(errmsg, "unrecognized geometry format '%s'", fmt);
293 error(WARNING, errmsg);
294 return;
295 }
296 cfact = to_meters(ezxml_attr(geom, "unit"));
297 dp->mgf = (char *)malloc(strlen(mgfstr)+32);
298 if (dp->mgf == NULL)
299 error(SYSTEM, "out of memory in load_geometry");
300 if (cfact < 0.99 || cfact > 1.01)
301 sprintf(dp->mgf, "xf -s %.5f\n%s\nxf\n", cfact, mgfstr);
302 else
303 strcpy(dp->mgf, mgfstr);
304 }
305
306
307 static void
308 load_bsdf_data( /* load BSDF distribution for this wavelength */
309 struct BSDF_data *dp,
310 ezxml_t wdb
311 )
312 {
313 char *cbasis = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
314 char *rbasis = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
315 char *sdata;
316 int i;
317
318 if ((!cbasis || !*cbasis) | (!rbasis || !*rbasis)) {
319 error(WARNING, "missing column/row basis for BSDF");
320 return;
321 }
322 for (i = nabases; i--; )
323 if (!strcasecmp(cbasis, abase_list[i].name)) {
324 dp->ninc = abase_list[i].nangles;
325 dp->ib_priv = (void *)&abase_list[i];
326 dp->ib_vec = ab_getvecR;
327 dp->ib_ndx = ab_getndxR;
328 dp->ib_ohm = ab_getohm;
329 break;
330 }
331 if (i < 0) {
332 sprintf(errmsg, "undefined ColumnAngleBasis '%s'", cbasis);
333 error(WARNING, errmsg);
334 return;
335 }
336 for (i = nabases; i--; )
337 if (!strcasecmp(rbasis, abase_list[i].name)) {
338 dp->nout = abase_list[i].nangles;
339 dp->ob_priv = (void *)&abase_list[i];
340 dp->ob_vec = ab_getvec;
341 dp->ob_ndx = ab_getndx;
342 dp->ob_ohm = ab_getohm;
343 break;
344 }
345 if (i < 0) {
346 sprintf(errmsg, "undefined RowAngleBasis '%s'", cbasis);
347 error(WARNING, errmsg);
348 return;
349 }
350 /* read BSDF data */
351 sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData"));
352 if (!sdata || !*sdata) {
353 error(WARNING, "missing BSDF ScatteringData");
354 return;
355 }
356 dp->bsdf = (float *)malloc(sizeof(float)*dp->ninc*dp->nout);
357 if (dp->bsdf == NULL)
358 error(SYSTEM, "out of memory in load_bsdf_data");
359 for (i = 0; i < dp->ninc*dp->nout; i++) {
360 char *sdnext = fskip(sdata);
361 if (sdnext == NULL) {
362 error(WARNING, "bad/missing BSDF ScatteringData");
363 free(dp->bsdf); dp->bsdf = NULL;
364 return;
365 }
366 while (*sdnext && isspace(*sdnext))
367 sdnext++;
368 if (*sdnext == ',') sdnext++;
369 dp->bsdf[i] = atof(sdata);
370 sdata = sdnext;
371 }
372 while (isspace(*sdata))
373 sdata++;
374 if (*sdata) {
375 sprintf(errmsg, "%d extra characters after BSDF ScatteringData",
376 (int)strlen(sdata));
377 error(WARNING, errmsg);
378 }
379 }
380
381
382 static int
383 check_bsdf_data( /* check that BSDF data is sane */
384 struct BSDF_data *dp
385 )
386 {
387 double *omega_iarr, *omega_oarr;
388 double dom, contrib, hemi_total, full_total;
389 int nneg;
390 FVECT v;
391 int i, o;
392
393 if (dp == NULL || dp->bsdf == NULL)
394 return(0);
395 omega_iarr = (double *)calloc(dp->ninc, sizeof(double));
396 omega_oarr = (double *)calloc(dp->nout, sizeof(double));
397 if ((omega_iarr == NULL) | (omega_oarr == NULL))
398 error(SYSTEM, "out of memory in check_bsdf_data");
399 /* incoming projected solid angles */
400 hemi_total = .0;
401 for (i = dp->ninc; i--; ) {
402 dom = getBSDF_incohm(dp,i);
403 if (dom <= .0) {
404 error(WARNING, "zero/negative incoming solid angle");
405 continue;
406 }
407 if (!getBSDF_incvec(v,dp,i) || v[2] > FTINY) {
408 error(WARNING, "illegal incoming BSDF direction");
409 free(omega_iarr); free(omega_oarr);
410 return(0);
411 }
412 hemi_total += omega_iarr[i] = dom * -v[2];
413 }
414 if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) {
415 sprintf(errmsg, "incoming BSDF hemisphere off by %.1f%%",
416 100.*(hemi_total/PI - 1.));
417 error(WARNING, errmsg);
418 }
419 dom = PI / hemi_total; /* fix normalization */
420 for (i = dp->ninc; i--; )
421 omega_iarr[i] *= dom;
422 /* outgoing projected solid angles */
423 hemi_total = .0;
424 for (o = dp->nout; o--; ) {
425 dom = getBSDF_outohm(dp,o);
426 if (dom <= .0) {
427 error(WARNING, "zero/negative outgoing solid angle");
428 continue;
429 }
430 if (!getBSDF_outvec(v,dp,o) || v[2] < -FTINY) {
431 error(WARNING, "illegal outgoing BSDF direction");
432 free(omega_iarr); free(omega_oarr);
433 return(0);
434 }
435 hemi_total += omega_oarr[o] = dom * v[2];
436 }
437 if ((hemi_total > 1.02*PI) | (hemi_total < 0.98*PI)) {
438 sprintf(errmsg, "outgoing BSDF hemisphere off by %.1f%%",
439 100.*(hemi_total/PI - 1.));
440 error(WARNING, errmsg);
441 }
442 dom = PI / hemi_total; /* fix normalization */
443 for (o = dp->nout; o--; )
444 omega_oarr[o] *= dom;
445 nneg = 0; /* check outgoing totals */
446 for (i = 0; i < dp->ninc; i++) {
447 hemi_total = .0;
448 for (o = dp->nout; o--; ) {
449 double f = BSDF_value(dp,i,o);
450 if (f >= .0)
451 hemi_total += f*omega_oarr[o];
452 else {
453 nneg += (f < -FTINY);
454 BSDF_value(dp,i,o) = .0f;
455 }
456 }
457 if (hemi_total > 1.01) {
458 sprintf(errmsg,
459 "incoming BSDF direction %d passes %.1f%% of light",
460 i, 100.*hemi_total);
461 error(WARNING, errmsg);
462 }
463 }
464 if (nneg) {
465 sprintf(errmsg, "%d negative BSDF values (ignored)", nneg);
466 error(WARNING, errmsg);
467 }
468 full_total = .0; /* reverse roles and check again */
469 for (o = 0; o < dp->nout; o++) {
470 hemi_total = .0;
471 for (i = dp->ninc; i--; )
472 hemi_total += BSDF_value(dp,i,o) * omega_iarr[i];
473
474 if (hemi_total > 1.01) {
475 sprintf(errmsg,
476 "outgoing BSDF direction %d collects %.1f%% of light",
477 o, 100.*hemi_total);
478 error(WARNING, errmsg);
479 }
480 full_total += hemi_total*omega_oarr[o];
481 }
482 full_total /= PI;
483 if (full_total > 1.00001) {
484 sprintf(errmsg, "BSDF transfers %.4f%% of light",
485 100.*full_total);
486 error(WARNING, errmsg);
487 }
488 free(omega_iarr); free(omega_oarr);
489 return(1);
490 }
491
492
493 struct BSDF_data *
494 load_BSDF( /* load BSDF data from file */
495 char *fname
496 )
497 {
498 char *path;
499 ezxml_t fl, wtl, wld, wdb;
500 struct BSDF_data *dp;
501
502 path = getpath(fname, getrlibpath(), R_OK);
503 if (path == NULL) {
504 sprintf(errmsg, "cannot find BSDF file \"%s\"", fname);
505 error(WARNING, errmsg);
506 return(NULL);
507 }
508 fl = ezxml_parse_file(path);
509 if (fl == NULL) {
510 sprintf(errmsg, "cannot open BSDF \"%s\"", path);
511 error(WARNING, errmsg);
512 return(NULL);
513 }
514 if (ezxml_error(fl)[0]) {
515 sprintf(errmsg, "BSDF \"%s\" %s", path, ezxml_error(fl));
516 error(WARNING, errmsg);
517 ezxml_free(fl);
518 return(NULL);
519 }
520 if (strcmp(ezxml_name(fl), "WindowElement")) {
521 sprintf(errmsg,
522 "BSDF \"%s\": top level node not 'WindowElement'",
523 path);
524 error(WARNING, errmsg);
525 ezxml_free(fl);
526 return(NULL);
527 }
528 wtl = ezxml_child(ezxml_child(fl, "Optical"), "Layer");
529 if (strcasecmp(ezxml_txt(ezxml_child(ezxml_child(wtl,
530 "DataDefinition"), "IncidentDataStructure")),
531 "Columns")) {
532 sprintf(errmsg,
533 "BSDF \"%s\": unsupported IncidentDataStructure",
534 path);
535 error(WARNING, errmsg);
536 ezxml_free(fl);
537 return(NULL);
538 }
539 load_angle_basis(ezxml_child(ezxml_child(wtl,
540 "DataDefinition"), "AngleBasis"));
541 dp = (struct BSDF_data *)calloc(1, sizeof(struct BSDF_data));
542 load_geometry(dp, ezxml_child(wtl, "Material"));
543 for (wld = ezxml_child(wtl, "WavelengthData");
544 wld != NULL; wld = wld->next) {
545 if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")),
546 "Visible"))
547 continue;
548 for (wdb = ezxml_child(wld, "WavelengthDataBlock");
549 wdb != NULL; wdb = wdb->next)
550 if (!strcasecmp(ezxml_txt(ezxml_child(wdb,
551 "WavelengthDataDirection")),
552 "Transmission Front"))
553 break;
554 if (wdb != NULL) { /* load front BTDF */
555 load_bsdf_data(dp, wdb);
556 break; /* ignore the rest */
557 }
558 }
559 ezxml_free(fl); /* done with XML file */
560 if (!check_bsdf_data(dp)) {
561 sprintf(errmsg, "bad/missing BTDF data in \"%s\"", path);
562 error(WARNING, errmsg);
563 free_BSDF(dp);
564 dp = NULL;
565 }
566 return(dp);
567 }
568
569
570 void
571 free_BSDF( /* free BSDF data structure */
572 struct BSDF_data *b
573 )
574 {
575 if (b == NULL)
576 return;
577 if (b->mgf != NULL)
578 free(b->mgf);
579 if (b->bsdf != NULL)
580 free(b->bsdf);
581 free(b);
582 }
583
584
585 int
586 r_BSDF_incvec( /* compute random input vector at given location */
587 FVECT v,
588 struct BSDF_data *b,
589 int i,
590 double rv,
591 MAT4 xm
592 )
593 {
594 FVECT pert;
595 double rad;
596 int j;
597
598 if (!getBSDF_incvec(v, b, i))
599 return(0);
600 rad = sqrt(getBSDF_incohm(b, i) / PI);
601 multisamp(pert, 3, rv);
602 for (j = 0; j < 3; j++)
603 v[j] += rad*(2.*pert[j] - 1.);
604 if (xm != NULL)
605 multv3(v, v, xm);
606 return(normalize(v) != 0.0);
607 }
608
609
610 int
611 r_BSDF_outvec( /* compute random output vector at given location */
612 FVECT v,
613 struct BSDF_data *b,
614 int o,
615 double rv,
616 MAT4 xm
617 )
618 {
619 FVECT pert;
620 double rad;
621 int j;
622
623 if (!getBSDF_outvec(v, b, o))
624 return(0);
625 rad = sqrt(getBSDF_outohm(b, o) / PI);
626 multisamp(pert, 3, rv);
627 for (j = 0; j < 3; j++)
628 v[j] += rad*(2.*pert[j] - 1.);
629 if (xm != NULL)
630 multv3(v, v, xm);
631 return(normalize(v) != 0.0);
632 }
633
634
635 static int
636 addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
637 char *xfarg[],
638 FVECT xp,
639 FVECT yp,
640 FVECT zp
641 )
642 {
643 static char bufs[3][16];
644 int bn = 0;
645 char **xfp = xfarg;
646 double theta;
647
648 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
649 /* Special case for X' along Z-axis */
650 theta = -atan2(yp[0], yp[1]);
651 *xfp++ = "-ry";
652 *xfp++ = xp[2] < 0.0 ? "90" : "-90";
653 *xfp++ = "-rz";
654 sprintf(bufs[bn], "%f", theta*(180./PI));
655 *xfp++ = bufs[bn++];
656 return(xfp - xfarg);
657 }
658 theta = atan2(yp[2], zp[2]);
659 if (!FEQ(theta,0.0)) {
660 *xfp++ = "-rx";
661 sprintf(bufs[bn], "%f", theta*(180./PI));
662 *xfp++ = bufs[bn++];
663 }
664 theta = asin(-xp[2]);
665 if (!FEQ(theta,0.0)) {
666 *xfp++ = "-ry";
667 sprintf(bufs[bn], " %f", theta*(180./PI));
668 *xfp++ = bufs[bn++];
669 }
670 theta = atan2(xp[1], xp[0]);
671 if (!FEQ(theta,0.0)) {
672 *xfp++ = "-rz";
673 sprintf(bufs[bn], "%f", theta*(180./PI));
674 *xfp++ = bufs[bn++];
675 }
676 *xfp = NULL;
677 return(xfp - xfarg);
678 }
679
680
681 int
682 getBSDF_xfm( /* compute BSDF orient. -> world orient. transform */
683 MAT4 xm,
684 FVECT nrm,
685 UpDir ud,
686 char *xfbuf
687 )
688 {
689 char *xfargs[7];
690 XF myxf;
691 FVECT updir, xdest, ydest;
692 int i;
693
694 updir[0] = updir[1] = updir[2] = 0.;
695 switch (ud) {
696 case UDzneg:
697 updir[2] = -1.;
698 break;
699 case UDyneg:
700 updir[1] = -1.;
701 break;
702 case UDxneg:
703 updir[0] = -1.;
704 break;
705 case UDxpos:
706 updir[0] = 1.;
707 break;
708 case UDypos:
709 updir[1] = 1.;
710 break;
711 case UDzpos:
712 updir[2] = 1.;
713 break;
714 case UDunknown:
715 return(0);
716 }
717 fcross(xdest, updir, nrm);
718 if (normalize(xdest) == 0.0)
719 return(0);
720 fcross(ydest, nrm, xdest);
721 xf(&myxf, addrot(xfargs, xdest, ydest, nrm), xfargs);
722 copymat4(xm, myxf.xfm);
723 if (xfbuf == NULL)
724 return(1);
725 /* return xf arguments as well */
726 for (i = 0; xfargs[i] != NULL; i++) {
727 *xfbuf++ = ' ';
728 strcpy(xfbuf, xfargs[i]);
729 while (*xfbuf) ++xfbuf;
730 }
731 return(1);
732 }
