root/radiance/ray/src/common/bsdf.c
Wed Dec 15 01:38:50 2021 UTC (2 years, 5 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.61: +3 -3 lines
Diff to previous 2.61 , to selected 2.56
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
Tue Dec 7 23:49:50 2021 UTC (2 years, 5 months ago) by greg
Changes since 2.60: +11 -11 lines
Diff to previous 2.60 , to selected 2.56
Wed Apr 28 00:59:10 2021 UTC (3 years ago) by greg
Changes since 2.59: +3 -1 lines
Diff to previous 2.59 , to selected 2.56
fix: only remove suffix in final file component (i.e., allow folder suffixes)
Sat Mar 27 17:50:18 2021 UTC (3 years, 1 month ago) by greg
Changes since 2.58: +15 -11 lines
Diff to previous 2.58 , to selected 2.56
Thu May 14 19:20:13 2020 UTC (4 years ago) by greg
Changes since 2.57: +5 -2 lines
Diff to previous 2.57 , to selected 2.56
Added cumulative cache size limit (per loaded BSDF)
Fri Mar 8 03:42:12 2019 UTC (5 years, 2 months ago) by greg
Changes since 2.56: +3 -3 lines
Diff to previous 2.56
Fixed reversal that forced reciprocity evaluation on *all* transmitted rays!
Revision 2.56 - (view) (download) (annotate) - [selected]
Fri Dec 7 07:38:15 2018 UTC (5 years, 5 months ago) by greg
Changes since 2.55: +2 -2 lines
Diff to previous 2.55
Eliminated case where randX could be passed as 1.0, causing possible inf loop
Thu May 10 22:55:35 2018 UTC (6 years ago) by greg
Changes since 2.54: +4 -7 lines
Diff to previous 2.54 , to selected 2.56
Eliminated expensive and unnecessary spectral curve hallucination
Mon May 15 22:44:10 2017 UTC (7 years ago) by greg
Diff to previous 2.53 , to selected 2.56
Fixed inconsistency between evaluation and sizing operations
Thu Feb 2 04:46:38 2017 UTC (7 years, 3 months ago) by greg
Diff to previous 2.52 , to selected 2.56
Bug fixes and improvements -- sampling was not working, now reports color
Sun Aug 23 00:56:00 2015 UTC (8 years, 8 months ago) by greg
Changes since 2.51: +4 -2 lines
Diff to previous 2.51 , to selected 2.56
Added comments for placement of mutex locks to support multi-threading
Sat Aug 1 23:27:04 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.50: +3 -2 lines
Diff to previous 2.50 , to selected 2.56
Sun Feb 8 22:14:50 2015 UTC (9 years, 3 months ago) by greg
Diff to previous 2.49 , to selected 2.56
Removed stray quote
Mon Dec 8 23:51:12 2014 UTC (9 years, 5 months ago) by greg
Changes since 2.48: +2 -3 lines
Diff to previous 2.48 , to selected 2.56
Minor fixes should not affect operation
Mon Mar 24 04:00:45 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.47: +2 -3 lines
Diff to previous 2.47 , to selected 2.56
Minor optimizations should not affect results
Sun Mar 23 23:15:53 2014 UTC (10 years, 1 month ago) by greg
Diff to previous 2.46 , to selected 2.56
Fixed bug in SDsampBSDF()
Thu Jul 4 15:14:45 2013 UTC (10 years, 10 months ago) by greg
Changes since 2.45: +3 -2 lines
Diff to previous 2.45 , to selected 2.56
Added extra checks where projected solid angle is undefined
Wed Jul 3 18:56:19 2013 UTC (10 years, 10 months ago) by greg
Changes since 2.44: +11 -15 lines
Diff to previous 2.44 , to selected 2.56
Eliminated memory error caused by stray ray samples
Sun Apr 21 21:36:23 2013 UTC (11 years ago) by greg
Changes since 2.43: +9 -6 lines
Diff to previous 2.43 , to selected 2.56
Added pointer indirection to make error reporting in other languages simpler
Sat Oct 13 20:15:43 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.42: +56 -761 lines
Diff to previous 2.42 , to selected 2.56
Sun Sep 2 15:33:15 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.41: +39 -19 lines
Diff to previous 2.41 , to selected 2.56
Sat Jun 23 16:47:39 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.40: +12 -4 lines
Diff to previous 2.40 , to selected 2.56
Fixed incorrect call to multisamp()
Mon Mar 5 15:27:08 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.39: +5 -3 lines
Diff to previous 2.39 , to selected 2.56
Tweak on last change to recording name & manufacturer
Mon Mar 5 00:17:06 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.38: +9 -1 lines
Diff to previous 2.38 , to selected 2.56
Added recording of product and manufacturer names
Sun Mar 4 23:28:34 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.37: +8 -3 lines
Diff to previous 2.37 , to selected 2.56
Improved error diagnostics
Sun Mar 4 20:11:10 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.36: +24 -1 lines
Diff to previous 2.36 , to selected 2.56
Added routine for adding spectral distribution components
Sat Sep 17 22:09:33 2011 UTC (12 years, 8 months ago) by greg
Changes since 2.35: +4 -2 lines
Diff to previous 2.35 , to selected 2.56
Added missing call to free EZXML structures on error
Sun Aug 21 22:38:12 2011 UTC (12 years, 8 months ago) by greg
Diff to previous 2.34 , to selected 2.56
Minor improvements to direct specular sampling
Thu Jul 7 15:25:09 2011 UTC (12 years, 10 months ago) by greg
Changes since 2.33: +8 -5 lines
Diff to previous 2.33 , to selected 2.56
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Tue Jun 28 21:11:04 2011 UTC (12 years, 10 months ago) by greg
Changes since 2.32: +3 -3 lines
Diff to previous 2.32 , to selected 2.56
Minor compile fixes
Thu Jun 23 16:00:37 2011 UTC (12 years, 10 months ago) by greg
Changes since 2.31: +6 -2 lines
Diff to previous 2.31 , to selected 2.56
Additional check for empty MGF string
Fri Jun 10 01:11:26 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.30: +2 -1 lines
Diff to previous 2.30 , to selected 2.56
Added missing header
Thu Jun 9 17:09:39 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29 , to selected 2.56
Fixes for Windows and bug fix in bsdf_m.c
Fri Jun 3 18:12:58 2011 UTC (12 years, 11 months ago) by greg
Changes since 2.28: +3 -9 lines
Diff to previous 2.28 , to selected 2.56
Fixed bugs in variable-resolution isotropic BSDFs
Thu Apr 28 00:24:43 2011 UTC (13 years ago) by greg
Changes since 2.27: +1 -3 lines
Diff to previous 2.27 , to selected 2.56
Removed debugging
Wed Apr 27 23:05:51 2011 UTC (13 years ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26 , to selected 2.56
First test of variable-res BSDFs
Mon Apr 25 15:48:05 2011 UTC (13 years ago) by greg
Changes since 2.25: +8 -7 lines
Diff to previous 2.25 , to selected 2.56
Fix from last change
Sun Apr 24 20:16:52 2011 UTC (13 years ago) by greg
Changes since 2.24: +6 -6 lines
Diff to previous 2.24 , to selected 2.56
Bug fixes to last change
Sun Apr 24 19:39:21 2011 UTC (13 years ago) by greg
Changes since 2.23: +17 -15 lines
Diff to previous 2.23 , to selected 2.56
Partial implementation of variable-resolution BSDFs
Wed Apr 20 14:44:05 2011 UTC (13 years ago) by greg
Changes since 2.22: +27 -22 lines
Diff to previous 2.22 , to selected 2.56
Fixes to last change -- tested
Tue Apr 19 21:31:22 2011 UTC (13 years ago) by greg
Changes since 2.21: +9 -8 lines
Diff to previous 2.21 , to selected 2.56
Fixed interface for determining BSDF solid angles
Sun Apr 17 17:45:13 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.20: +9 -5 lines
Diff to previous 2.20 , to selected 2.56
Minor fixes
Mon Apr 11 03:47:46 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.19: +8 -4 lines
Diff to previous 2.19 , to selected 2.56
Final fix to Klems angles -- I hope
Sat Apr 9 15:39:16 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.18 , to selected 2.56
Fixed range of rand() -> double conversion
Fri Apr 8 23:23:28 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.17 , to selected 2.56
Eliminated calls to drand48()
Sat Feb 19 23:42:09 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.16: +11 -5 lines
Diff to previous 2.16 , to selected 2.56
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.15: +56 -25 lines
Diff to previous 2.15 , to selected 2.56
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 00:40:25 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.14: +756 -19 lines
Diff to previous 2.14 , to selected 2.56
Fri Feb 11 17:31:25 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.13 , to selected 2.56
Fixed comment type
Thu Jan 6 22:27:56 2011 UTC (13 years, 4 months ago) by greg
Changes since 2.12: +12 -8 lines
Diff to previous 2.12 , to selected 2.56
Fixed handling of multiple WavelengthDataBlock's
Thu Jan 6 04:40:22 2011 UTC (13 years, 4 months ago) by greg
Changes since 2.11: +6 -6 lines
Diff to previous 2.11 , to selected 2.56
Typo!
Thu Jan 6 04:39:08 2011 UTC (13 years, 4 months ago) by greg
Changes since 2.10: +6 -6 lines
Diff to previous 2.10 , to selected 2.56
Removed some case-dependent string comparisons
Thu Jan 6 04:36:16 2011 UTC (13 years, 4 months ago) by greg
Changes since 2.9: +11 -1 lines
Diff to previous 2.9 , to selected 2.56
Added check to ensure column ordering of BTDF
Mon Jan 3 19:27:00 2011 UTC (13 years, 4 months ago) by greg
Changes since 2.8: +11 -3 lines
Diff to previous 2.8 , to selected 2.56
Slight improvement to conditional
Sun Sep 26 15:43:26 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.7: +6 -5 lines
Diff to previous 2.7 , to selected 2.56
Slight change to reporting thresholds for dubious BSDFs
Tue Sep 7 23:10:50 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.6: +10 -3 lines
Diff to previous 2.6 , to selected 2.56
Added test for full light transfer in BSDF
Fri Sep 3 23:53:50 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.5: +72 -2 lines
Diff to previous 2.5 , to selected 2.56
Sun Aug 1 22:26:37 2010 UTC (13 years, 9 months ago) by greg
Diff to previous 2.4 , to selected 2.56
Minor warning for 64-bit architectures
Sat Jul 3 05:28:05 2010 UTC (13 years, 10 months ago) by greg
Changes since 2.3: +9 -10 lines
Diff to previous 2.3 , to selected 2.56
Minor changes related to angle basis support
Sat Jul 3 02:50:22 2010 UTC (13 years, 10 months ago) by greg
Changes since 2.2: +72 -6 lines
Diff to previous 2.2 , to selected 2.56
Added support for custom angle bases
Fri Jun 19 06:49:25 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.1: +70 -30 lines
Diff to previous 2.1 , to selected 2.56
Improved error-checking
Wed Jun 17 20:41:47 2009 UTC (14 years, 11 months ago) by greg
Diff to selected 2.56
