--- ray/src/common/bsdf.c 2011/02/19 01:48:59 2.16 +++ ray/src/common/bsdf.c 2011/02/19 23:42:09 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf.c,v 2.16 2011/02/19 01:48:59 greg Exp $"; +static const char RCSid[] = "$Id: bsdf.c,v 2.17 2011/02/19 23:42:09 greg Exp $"; #endif /* * bsdf.c @@ -85,7 +85,6 @@ SDloadGeometry(SDData *sd, ezxml_t wdb) if (wdb == NULL) /* no geometry section? */ return SDEnone; - sprintf(SDerrorDetail, "Negative size in \"%s\"", sd->name); sd->dim[0] = sd->dim[1] = sd->dim[2] = .0; if ((geom = ezxml_child(wdb, "Width")) != NULL) sd->dim[0] = atof(ezxml_txt(geom)) * @@ -96,8 +95,10 @@ SDloadGeometry(SDData *sd, ezxml_t wdb) if ((geom = ezxml_child(wdb, "Thickness")) != NULL) sd->dim[2] = atof(ezxml_txt(geom)) * to_meters(ezxml_attr(geom, "unit")); - if ((sd->dim[0] < .0) | (sd->dim[1] < .0) | (sd->dim[2] < .0)) + if ((sd->dim[0] < .0) | (sd->dim[1] < .0) | (sd->dim[2] < .0)) { + sprintf(SDerrorDetail, "Negative size in \"%s\"", sd->name); return SDEdata; + } if ((geom = ezxml_child(wdb, "Geometry")) == NULL || (mgfstr = ezxml_txt(geom)) == NULL) return SDEnone; @@ -488,7 +489,7 @@ SDsizeBSDF(double *projSA, const FVECT vec, int qflags if ((projSA == NULL) | (vec == NULL) | (sd == NULL)) return SDEargument; /* initialize extrema */ - switch (qflags & SDqueryMin+SDqueryMax) { + switch (qflags) { case SDqueryMax: projSA[0] = .0; break; @@ -518,7 +519,12 @@ SDsizeBSDF(double *projSA, const FVECT vec, int qflags if (ec) return ec; } - return ec; + if (ec) { /* all diffuse? */ + projSA[0] = M_PI; + if (qflags == SDqueryMin+SDqueryMax) + projSA[1] = M_PI; + } + return SDEnone; } /* Return BSDF for the given incident and scattered ray vectors */
