--- ray/src/common/bsdf.c 2011/01/06 04:36:16 2.10 +++ ray/src/common/bsdf.c 2011/01/06 04:39:08 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf.c,v 2.10 2011/01/06 04:36:16 greg Exp $"; +static const char RCSid[] = "$Id: bsdf.c,v 2.11 2011/01/06 04:39:08 greg Exp $"; #endif /* * Routines for handling BSDF data @@ -219,7 +219,7 @@ load_angle_basis( /* load custom BSDF angle basis */ if (!abname || !*abname) return; for (i = nabases; i--; ) - if (!strcmp(abname, abase_list[i].name)) + if (!strcasecamp(abname, abase_list[i].name)) return; /* assume it's the same */ if (nabases >= MAXABASES) error(INTERNAL, "too many angle bases"); @@ -320,7 +320,7 @@ load_bsdf_data( /* load BSDF distribution for this wa return; } for (i = nabases; i--; ) - if (!strcmp(cbasis, abase_list[i].name)) { + if (!strcasecamp(cbasis, abase_list[i].name)) { dp->ninc = abase_list[i].nangles; dp->ib_priv = (void *)&abase_list[i]; dp->ib_vec = ab_getvecR; @@ -334,7 +334,7 @@ load_bsdf_data( /* load BSDF distribution for this wa return; } for (i = nabases; i--; ) - if (!strcmp(rbasis, abase_list[i].name)) { + if (!strcasecamp(rbasis, abase_list[i].name)) { dp->nout = abase_list[i].nangles; dp->ob_priv = (void *)&abase_list[i]; dp->ob_vec = ab_getvec; @@ -542,11 +542,11 @@ load_BSDF( /* load BSDF data from file */ load_geometry(dp, ezxml_child(wtl, "Material")); for (wld = ezxml_child(wtl, "WavelengthData"); wld != NULL; wld = wld->next) { - if (strcmp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible")) + if (strcasecamp(ezxml_txt(ezxml_child(wld,"Wavelength")), "Visible")) continue; wdb = ezxml_child(wld, "WavelengthDataBlock"); if (wdb == NULL) continue; - if (strcmp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")), + if (strcasecamp(ezxml_txt(ezxml_child(wdb,"WavelengthDataDirection")), "Transmission Front")) continue; load_bsdf_data(dp, wdb); /* load front BTDF */
