root/radiance/ray/src/common/bmpfile.h
Tue Sep 5 18:41:22 2017 UTC (6 years, 7 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 2.7: +18 -18 lines
Eliminated stray spaces from file
Tue Jan 10 18:24:53 2017 UTC (7 years, 3 months ago) by greg
Changes since 2.6: +16 -16 lines
Added missing (but technically optional) "extern" keywords to function decl
Sat May 31 19:38:36 2008 UTC (15 years, 11 months ago) by greg
Eliminated tifftypes.h in favor of tiff.h throughout
Thu Apr 12 22:13:28 2007 UTC (17 years ago) by greg
Fix for Windows systems
Fri Mar 18 21:04:05 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.3: +2 -5 lines
Fixed bug in header size computation related to color palette
Sat Mar 27 05:43:37 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.2: +7 -6 lines
Bug fixes in run-length encoding code
Fri Mar 26 22:58:21 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.1: +7 -3 lines
Diff to previous 2.1
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 03:11:50 2004 UTC (20 years, 1 month ago) by greg
