root/radiance/ray/src/common/bmpfile.h
Thu Apr 12 22:13:28 2007 UTC (17 years ago) by greg
Fix for Windows systems
Fri Mar 18 21:04:05 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.3: +2 -5 lines
Fixed bug in header size computation related to color palette
Sat Mar 27 05:43:37 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.2: +7 -6 lines
Bug fixes in run-length encoding code
Fri Mar 26 22:58:21 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.1: +7 -3 lines
Diff to previous 2.1
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 03:11:50 2004 UTC (20 years, 1 month ago) by greg
