root/radiance/ray/src/common/bmpfile.h
Revision: 2.9
Committed: Mon Feb 8 18:43:21 2021 UTC (4 years, 2 months ago) by greg
CVS Tags: rad5R4, HEAD
docs: corrected comment
# User Rev Content
1 greg 2.9 /* RCSid $Id: bmpfile.h,v 2.8 2017/09/05 18:41:22 greg Exp $ */
2 greg 2.1 /*
3     * Windows and OS/2 BMP file support
4     */
5
6     #ifndef _RAD_BMPFILE_H_
7     #define _RAD_BMPFILE_H_
8
9 greg 2.6 #include "tiff.h" /* needed for int32, etc. */
10 greg 2.1
11     #ifdef __cplusplus
12     extern "C" {
13     #endif
14
15     /* compression modes */
16     #define BI_UNCOMPR 0 /* no compression */
17     #define BI_RLE8 1 /* runlength on bytes */
18     #define BI_RLE4 2 /* runlength on half-bytes */
19     #define BI_BITFIELDS 3 /* uncompressed w/ bitfields */
20
21     /* A Color table entry */
22     typedef struct {
23     uint8 b, g, r; /* blue, green, & red bytes */
24     uint8 padding; /* padding to 32-bit boundary */
25     } RGBquad;
26
27     /* Allocated BMP header data */
28     typedef struct {
29 greg 2.3 /* the following fields may be altered before the open call */
30 greg 2.1 int yIsDown; /* scanlines proceed downward? */
31     int32 hRes; /* horizontal resolution pixels/meter */
32     int32 vRes; /* vertical resolution pixels/meter */
33     int nColors; /* total color palette size */
34 greg 2.8 int impColors; /* number of colors actually used */
35 greg 2.3 int compr; /* compression */
36 greg 2.1 int32 width; /* bitmap width (pixels) */
37     int32 height; /* bitmap height (pixels) */
38 greg 2.3 /* the following fields must not be altered after allocation */
39 greg 2.9 int bpp; /* bits per pixel (1,4,8,16,24,32) */
40 greg 2.1 uint32 infoSiz; /* info buffer size (bytes) */
41 greg 2.3 /* but the color table should be filled by writer before open call */
42 greg 2.8 RGBquad palette[3]; /* color palette (extends struct) */
43 greg 2.1 } BMPHeader;
44 greg 2.2
45     /* access to bit field triple */
46 greg 2.8 #define BMPbitField(h) ((uint32 *)(h)->palette)
47 greg 2.1
48     /* info buffer access */
49 greg 2.8 #define BMPinfo(h) ((char *)((h)->palette + (h)->nColors))
50 greg 2.1
51     /* function return values */
52     #define BIR_OK 0 /* all is well */
53     #define BIR_EOF (-1) /* reached end of file */
54     #define BIR_TRUNCATED 1 /* unexpected EOF */
55     #define BIR_UNSUPPORTED 2 /* unsupported encoding */
56 greg 2.2 #define BIR_RLERROR 3 /* RLE error */
57     #define BIR_SEEKERR 4 /* could not seek */
58 greg 2.1
59     /* A BMP reader structure */
60     typedef struct BMPReader {
61     /* members in this structure should be considered read-only */
62 greg 2.8 uint8 *scanline; /* unpacked scanline data */
63 greg 2.1 int yscan; /* last scanline read */
64 greg 2.8 BMPHeader *hdr; /* pointer to allocated header */
65 greg 2.1 uint32 fpos; /* current file position */
66     /* get character callback */
67     int (*cget)(void *);
68     /* absolute seek callback (or NULL) */
69     int (*seek)(uint32, void *);
70     void *c_data; /* client's opaque data */
71 greg 2.8 uint32 scanpos[1]; /* recorded scanline position(s) */
72 greg 2.1 } BMPReader;
73
74     /* A BMP writer structure */
75     typedef struct {
76     /* the scanline data is filled in by caller before each write */
77 greg 2.8 uint8 *scanline; /* caller-prepared scanline data */
78 greg 2.3 /* modify yscan only if seek is defined & data is uncompressed */
79 greg 2.1 int yscan; /* scanline for next write */
80 greg 2.3 /* the following fields should not be altered directly */
81 greg 2.8 BMPHeader *hdr; /* allocated header */
82 greg 2.1 uint32 fbmp; /* beginning of bitmap data */
83     uint32 fpos; /* current file position */
84     uint32 flen; /* last character written */
85     /* put character callback */
86     void (*cput)(int, void *);
87     /* absolute seek callback (or NULL) */
88     int (*seek)(uint32, void *);
89     void *c_data; /* client's opaque data */
90     } BMPWriter;
91
92     /* open BMP stream for reading */
93 greg 2.8 extern BMPReader *BMPopenReader(int (*cget)(void *),
94 greg 2.1 int (*seek)(uint32, void *), void *c_data);
95
96     /* determine if image is grayscale */
97 greg 2.7 extern int BMPisGrayscale(const BMPHeader *hdr);
98 greg 2.1
99     /* read next BMP scanline */
100 greg 2.7 extern int BMPreadScanline(BMPReader *br);
101 greg 2.1
102     /* read a specific scanline */
103 greg 2.7 extern int BMPseekScanline(int y, BMPReader *br);
104 greg 2.1
105     /* get ith pixel from last scanline */
106 greg 2.7 extern RGBquad BMPdecodePixel(int i, const BMPReader *br);
107 greg 2.1
108     /* free BMP reader resources */
109 greg 2.7 extern void BMPfreeReader(BMPReader *br);
110 greg 2.1
111     /* allocate uncompressed RGB header */
112 greg 2.8 extern BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen);
113 greg 2.1
114     /* allocate color-mapped header */
115 greg 2.8 extern BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors);
116 greg 2.1
117     /* open BMP stream for writing */
118 greg 2.7 extern BMPWriter *BMPopenWriter(void (*cput)(int, void *),
119 greg 2.1 int (*seek)(uint32, void *), void *c_data,
120     BMPHeader *hdr);
121
122     /* write the prepared scanline */
123 greg 2.7 extern int BMPwriteScanline(BMPWriter *bw);
124 greg 2.1
125     /* free BMP writer resources */
126 greg 2.7 extern void BMPfreeWriter(BMPWriter *bw);
127 greg 2.1
128     /* get corresponding error message */
129 greg 2.8 extern const char *BMPerrorMessage(int ec);
130 greg 2.1
131     /* stdio callback functions */
132 greg 2.7 extern int stdio_getc(void *p);
133     extern void stdio_putc(int c, void *p);
134     extern int stdio_fseek(uint32 pos, void *p);
135 greg 2.1
136     /* open stdio input stream */
137 greg 2.8 #define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp)
138 greg 2.1
139     /* open input file */
140 greg 2.8 #define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \
141 greg 2.5 (void *)fopen(fn, "rb"))
142 greg 2.1
143     /* close stdio input file or stream */
144 greg 2.8 #define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \
145 greg 2.1 BMPfreeReader(br) )
146
147     /* open stdio output stream */
148     #define BMPopenOutputStream(fp,hdr) \
149     BMPopenWriter(&stdio_putc, NULL, (void *)fp, hdr)
150
151     /* open stdio output file */
152     #define BMPopenOutputFile(fn,hdr) \
153     BMPopenWriter(&stdio_putc, &stdio_fseek, \
154 greg 2.5 (void *)fopen(fn, "wb"), hdr)
155 greg 2.1
156     /* close stdio output file or stream */
157 greg 2.8 #define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \
158 greg 2.1 BMPfreeWriter(bw) )
159
160     #ifdef __cplusplus
161     }
162     #endif
163     #endif /* ! _RAD_BMPFILE_H_ */
