root/Development/ray/src/common/bmpfile.h
Revision: 2.2
Committed: Fri Mar 26 22:58:21 2004 UTC (21 years, 8 months ago) by greg
Changes since 2.1: +7 -3 lines
Added support to ra_bmp for 16-bit images and RLE, plus created man page
1 /* RCSid $Id$ */
2 /*
3 * Windows and OS/2 BMP file support
4 */
5
6 #ifndef _RAD_BMPFILE_H_
7 #define _RAD_BMPFILE_H_
8
9 #include "tifftypes.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* compression modes */
16 #define BI_UNCOMPR 0 /* no compression */
17 #define BI_RLE8 1 /* runlength on bytes */
18 #define BI_RLE4 2 /* runlength on half-bytes */
19 #define BI_BITFIELDS 3 /* uncompressed w/ bitfields */
20
21 /* A Color table entry */
22 typedef struct {
23 uint8 b, g, r; /* blue, green, & red bytes */
24 uint8 padding; /* padding to 32-bit boundary */
25 } RGBquad;
26
27 /* Allocated BMP header data */
28 typedef struct {
29 /* the following fields may be altered before open call */
30 int yIsDown; /* scanlines proceed downward? */
31 int32 hRes; /* horizontal resolution pixels/meter */
32 int32 vRes; /* vertical resolution pixels/meter */
33 int nColors; /* total color palette size */
34 int impColors; /* number of colors actually used */
35 /* the following fields should not be altered after allocation */
36 int32 width; /* bitmap width (pixels) */
37 int32 height; /* bitmap height (pixels) */
38 int bpp; /* bits per sample (1,4,8,16,24,32) */
39 int compr; /* compression */
40 uint32 infoSiz; /* info buffer size (bytes) */
41 /* the color table should be filled by writer before open call */
42 RGBquad palette[3]; /* color palette (extends struct) */
43 } BMPHeader;
44
45 /* color palette length */
46 #define BMPpalLen(h) ((h)->bpp <= 8 ? 1<<(h)->bpp : 0)
47
48 /* access to bit field triple */
49 #define BMPbitField(h) ((uint32 *)(h)->palette)
50
51 /* info buffer access */
52 #define BMPinfo(h) ((char *)((h)->palette + BMPpalLen(h)))
53
54 /* function return values */
55 #define BIR_OK 0 /* all is well */
56 #define BIR_EOF (-1) /* reached end of file */
57 #define BIR_TRUNCATED 1 /* unexpected EOF */
58 #define BIR_UNSUPPORTED 2 /* unsupported encoding */
59 #define BIR_RLERROR 3 /* RLE error */
60 #define BIR_SEEKERR 4 /* could not seek */
61
62 /* A BMP reader structure */
63 typedef struct BMPReader {
64 /* members in this structure should be considered read-only */
65 uint8 *scanline; /* unpacked scanline data */
66 int yscan; /* last scanline read */
67 BMPHeader *hdr; /* pointer to allocated header */
68 uint32 fpos; /* current file position */
69 /* get character callback */
70 int (*cget)(void *);
71 /* absolute seek callback (or NULL) */
72 int (*seek)(uint32, void *);
73 void *c_data; /* client's opaque data */
74 uint32 scanpos[1]; /* recorded scanline position(s) */
75 } BMPReader;
76
77 /* A BMP writer structure */
78 typedef struct {
79 /* the scanline data is filled in by caller before each write */
80 uint8 *scanline; /* caller-prepared scanline data */
81 int yscan; /* scanline for next write */
82 /* the following fields should not be altered by the caller */
83 BMPHeader *hdr; /* allocated header */
84 uint32 fbmp; /* beginning of bitmap data */
85 uint32 fpos; /* current file position */
86 uint32 flen; /* last character written */
87 /* put character callback */
88 void (*cput)(int, void *);
89 /* absolute seek callback (or NULL) */
90 int (*seek)(uint32, void *);
91 void *c_data; /* client's opaque data */
92 } BMPWriter;
93
94 /* open BMP stream for reading */
95 BMPReader *BMPopenReader(int (*cget)(void *),
96 int (*seek)(uint32, void *), void *c_data);
97
98 /* determine if image is grayscale */
99 int BMPisGrayscale(const BMPHeader *hdr);
100
101 /* read next BMP scanline */
102 int BMPreadScanline(BMPReader *br);
103
104 /* read a specific scanline */
105 int BMPseekScanline(int y, BMPReader *br);
106
107 /* get ith pixel from last scanline */
108 RGBquad BMPdecodePixel(int i, const BMPReader *br);
109
110 /* free BMP reader resources */
111 void BMPfreeReader(BMPReader *br);
112
113 /* allocate uncompressed RGB header */
114 BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen);
115
116 /* allocate color-mapped header */
117 BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors);
118
119 /* open BMP stream for writing */
120 BMPWriter *BMPopenWriter(void (*cput)(int, void *),
121 int (*seek)(uint32, void *), void *c_data,
122 BMPHeader *hdr);
123
124 /* write the prepared scanline */
125 int BMPwriteScanline(BMPWriter *bw);
126
127 /* free BMP writer resources */
128 void BMPfreeWriter(BMPWriter *bw);
129
130 /* get corresponding error message */
131 const char *BMPerrorMessage(int ec);
132
133 /* stdio callback functions */
134 int stdio_getc(void *p);
135 void stdio_putc(int c, void *p);
136 int stdio_fseek(uint32 pos, void *p);
137
138 /* open stdio input stream */
139 #define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp)
140
141 /* open input file */
142 #define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \
143 (void *)fopen(fn, "r"))
144
145 /* close stdio input file or stream */
146 #define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \
147 BMPfreeReader(br) )
148
149 /* open stdio output stream */
150 #define BMPopenOutputStream(fp,hdr) \
151 BMPopenWriter(&stdio_putc, NULL, (void *)fp, hdr)
152
153 /* open stdio output file */
154 #define BMPopenOutputFile(fn,hdr) \
155 BMPopenWriter(&stdio_putc, &stdio_fseek, \
156 (void *)fopen(fn, "w"), hdr)
157
158 /* close stdio output file or stream */
159 #define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \
160 BMPfreeWriter(bw) )
161
162 #ifdef __cplusplus
163 }
164 #endif
165 #endif /* ! _RAD_BMPFILE_H_ */
