root/Development/ray/src/common/bmpfile.h
Revision: 2.1
Committed: Fri Mar 26 03:11:50 2004 UTC (21 years, 8 months ago) by greg
1 /* RCSid $Id$ */
2 /*
3 * Windows and OS/2 BMP file support
4 */
5
6 #ifndef _RAD_BMPFILE_H_
7 #define _RAD_BMPFILE_H_
8
9 #include "tifftypes.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* compression modes */
16 #define BI_UNCOMPR 0 /* no compression */
17 #define BI_RLE8 1 /* runlength on bytes */
18 #define BI_RLE4 2 /* runlength on half-bytes */
19 #define BI_BITFIELDS 3 /* uncompressed w/ bitfields */
20
21 /* A Color table entry */
22 typedef struct {
23 uint8 b, g, r; /* blue, green, & red bytes */
24 uint8 padding; /* padding to 32-bit boundary */
25 } RGBquad;
26
27 /* Allocated BMP header data */
28 typedef struct {
29 /* the following fields may be altered before open call */
30 int yIsDown; /* scanlines proceed downward? */
31 int32 hRes; /* horizontal resolution pixels/meter */
32 int32 vRes; /* vertical resolution pixels/meter */
33 int nColors; /* total color palette size */
34 int impColors; /* number of colors actually used */
35 /* the following fields should not be altered after allocation */
36 int32 width; /* bitmap width (pixels) */
37 int32 height; /* bitmap height (pixels) */
38 int bpp; /* bits per sample (1,4,8,16,24,32) */
39 int compr; /* compression */
40 uint32 infoSiz; /* info buffer size (bytes) */
41 /* the color table should be filled by writer before open call */
42 RGBquad palette[2]; /* color palette (extends struct) */
43 } BMPHeader;
44
45 /* color palette length */
46 #define BMPpalLen(h) ((h)->bpp <= 8 ? 1<<(h)->bpp : 0)
47
48 /* info buffer access */
49 #define BMPinfo(h) ((char *)((h)->palette + BMPpalLen(h)))
50
51 /* function return values */
52 #define BIR_OK 0 /* all is well */
53 #define BIR_EOF (-1) /* reached end of file */
54 #define BIR_TRUNCATED 1 /* unexpected EOF */
55 #define BIR_UNSUPPORTED 2 /* unsupported encoding */
56 #define BIR_SEEKERR 3 /* could not seek */
57
58 /* A BMP reader structure */
59 typedef struct BMPReader {
60 /* members in this structure should be considered read-only */
61 uint8 *scanline; /* unpacked scanline data */
62 int yscan; /* last scanline read */
63 BMPHeader *hdr; /* pointer to allocated header */
64 uint32 fpos; /* current file position */
65 /* get character callback */
66 int (*cget)(void *);
67 /* absolute seek callback (or NULL) */
68 int (*seek)(uint32, void *);
69 void *c_data; /* client's opaque data */
70 uint32 scanpos[1]; /* recorded scanline position(s) */
71 } BMPReader;
72
73 /* A BMP writer structure */
74 typedef struct {
75 /* the scanline data is filled in by caller before each write */
76 uint8 *scanline; /* caller-prepared scanline data */
77 int yscan; /* scanline for next write */
78 /* the following fields should not be altered by the caller */
79 BMPHeader *hdr; /* allocated header */
80 uint32 fbmp; /* beginning of bitmap data */
81 uint32 fpos; /* current file position */
82 uint32 flen; /* last character written */
83 /* put character callback */
84 void (*cput)(int, void *);
85 /* absolute seek callback (or NULL) */
86 int (*seek)(uint32, void *);
87 void *c_data; /* client's opaque data */
88 } BMPWriter;
89
90 /* open BMP stream for reading */
91 BMPReader *BMPopenReader(int (*cget)(void *),
92 int (*seek)(uint32, void *), void *c_data);
93
94 /* determine if image is grayscale */
95 int BMPisGrayscale(const BMPHeader *hdr);
96
97 /* read next BMP scanline */
98 int BMPreadScanline(BMPReader *br);
99
100 /* read a specific scanline */
101 int BMPseekScanline(int y, BMPReader *br);
102
103 /* get ith pixel from last scanline */
104 RGBquad BMPdecodePixel(int i, BMPReader *br);
105
106 /* free BMP reader resources */
107 void BMPfreeReader(BMPReader *br);
108
109 /* allocate uncompressed RGB header */
110 BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen);
111
112 /* allocate color-mapped header */
113 BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors);
114
115 /* open BMP stream for writing */
116 BMPWriter *BMPopenWriter(void (*cput)(int, void *),
117 int (*seek)(uint32, void *), void *c_data,
118 BMPHeader *hdr);
119
120 /* write the prepared scanline */
121 int BMPwriteScanline(BMPWriter *bw);
122
123 /* free BMP writer resources */
124 void BMPfreeWriter(BMPWriter *bw);
125
126 /* get corresponding error message */
127 const char *BMPerrorMessage(int ec);
128
129 /* stdio callback functions */
130 int stdio_getc(void *p);
131 void stdio_putc(int c, void *p);
132 int stdio_fseek(uint32 pos, void *p);
133
134 /* open stdio input stream */
135 #define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp)
136
137 /* open input file */
138 #define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \
139 (void *)fopen(fn, "r"))
140
141 /* close stdio input file or stream */
142 #define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \
143 BMPfreeReader(br) )
144
145 /* open stdio output stream */
146 #define BMPopenOutputStream(fp,hdr) \
147 BMPopenWriter(&stdio_putc, NULL, (void *)fp, hdr)
148
149 /* open stdio output file */
150 #define BMPopenOutputFile(fn,hdr) \
151 BMPopenWriter(&stdio_putc, &stdio_fseek, \
152 (void *)fopen(fn, "w"), hdr)
153
154 /* close stdio output file or stream */
155 #define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \
156 BMPfreeWriter(bw) )
157
158 #ifdef __cplusplus
159 }
160 #endif
161 #endif /* ! _RAD_BMPFILE_H_ */
