--- ray/src/common/bmpfile.h 2005/03/18 21:04:05 2.4 +++ ray/src/common/bmpfile.h 2017/09/05 18:41:22 2.8 @@ -1,4 +1,4 @@ -/* RCSid $Id: bmpfile.h,v 2.4 2005/03/18 21:04:05 greg Exp $ */ +/* RCSid $Id: bmpfile.h,v 2.8 2017/09/05 18:41:22 greg Exp $ */ /* * Windows and OS/2 BMP file support */ @@ -6,7 +6,7 @@ #ifndef _RAD_BMPFILE_H_ #define _RAD_BMPFILE_H_ -#include "tifftypes.h" +#include "tiff.h" /* needed for int32, etc. */ #ifdef __cplusplus extern "C" { @@ -31,7 +31,7 @@ typedef struct { int32 hRes; /* horizontal resolution pixels/meter */ int32 vRes; /* vertical resolution pixels/meter */ int nColors; /* total color palette size */ - int impColors; /* number of colors actually used */ + int impColors; /* number of colors actually used */ int compr; /* compression */ int32 width; /* bitmap width (pixels) */ int32 height; /* bitmap height (pixels) */ @@ -39,14 +39,14 @@ typedef struct { int bpp; /* bits per sample (1,4,8,16,24,32) */ uint32 infoSiz; /* info buffer size (bytes) */ /* but the color table should be filled by writer before open call */ - RGBquad palette[3]; /* color palette (extends struct) */ + RGBquad palette[3]; /* color palette (extends struct) */ } BMPHeader; /* access to bit field triple */ -#define BMPbitField(h) ((uint32 *)(h)->palette) +#define BMPbitField(h) ((uint32 *)(h)->palette) /* info buffer access */ -#define BMPinfo(h) ((char *)((h)->palette + (h)->nColors)) +#define BMPinfo(h) ((char *)((h)->palette + (h)->nColors)) /* function return values */ #define BIR_OK 0 /* all is well */ @@ -59,26 +59,26 @@ typedef struct { /* A BMP reader structure */ typedef struct BMPReader { /* members in this structure should be considered read-only */ - uint8 *scanline; /* unpacked scanline data */ + uint8 *scanline; /* unpacked scanline data */ int yscan; /* last scanline read */ - BMPHeader *hdr; /* pointer to allocated header */ + BMPHeader *hdr; /* pointer to allocated header */ uint32 fpos; /* current file position */ /* get character callback */ int (*cget)(void *); /* absolute seek callback (or NULL) */ int (*seek)(uint32, void *); void *c_data; /* client's opaque data */ - uint32 scanpos[1]; /* recorded scanline position(s) */ + uint32 scanpos[1]; /* recorded scanline position(s) */ } BMPReader; /* A BMP writer structure */ typedef struct { /* the scanline data is filled in by caller before each write */ - uint8 *scanline; /* caller-prepared scanline data */ + uint8 *scanline; /* caller-prepared scanline data */ /* modify yscan only if seek is defined & data is uncompressed */ int yscan; /* scanline for next write */ /* the following fields should not be altered directly */ - BMPHeader *hdr; /* allocated header */ + BMPHeader *hdr; /* allocated header */ uint32 fbmp; /* beginning of bitmap data */ uint32 fpos; /* current file position */ uint32 flen; /* last character written */ @@ -90,58 +90,58 @@ typedef struct { } BMPWriter; /* open BMP stream for reading */ -BMPReader *BMPopenReader(int (*cget)(void *), +extern BMPReader *BMPopenReader(int (*cget)(void *), int (*seek)(uint32, void *), void *c_data); /* determine if image is grayscale */ -int BMPisGrayscale(const BMPHeader *hdr); +extern int BMPisGrayscale(const BMPHeader *hdr); /* read next BMP scanline */ -int BMPreadScanline(BMPReader *br); +extern int BMPreadScanline(BMPReader *br); /* read a specific scanline */ -int BMPseekScanline(int y, BMPReader *br); +extern int BMPseekScanline(int y, BMPReader *br); /* get ith pixel from last scanline */ -RGBquad BMPdecodePixel(int i, const BMPReader *br); +extern RGBquad BMPdecodePixel(int i, const BMPReader *br); /* free BMP reader resources */ -void BMPfreeReader(BMPReader *br); +extern void BMPfreeReader(BMPReader *br); /* allocate uncompressed RGB header */ -BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen); +extern BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen); /* allocate color-mapped header */ -BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors); +extern BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors); /* open BMP stream for writing */ -BMPWriter *BMPopenWriter(void (*cput)(int, void *), +extern BMPWriter *BMPopenWriter(void (*cput)(int, void *), int (*seek)(uint32, void *), void *c_data, BMPHeader *hdr); /* write the prepared scanline */ -int BMPwriteScanline(BMPWriter *bw); +extern int BMPwriteScanline(BMPWriter *bw); /* free BMP writer resources */ -void BMPfreeWriter(BMPWriter *bw); +extern void BMPfreeWriter(BMPWriter *bw); /* get corresponding error message */ -const char *BMPerrorMessage(int ec); +extern const char *BMPerrorMessage(int ec); /* stdio callback functions */ -int stdio_getc(void *p); -void stdio_putc(int c, void *p); -int stdio_fseek(uint32 pos, void *p); +extern int stdio_getc(void *p); +extern void stdio_putc(int c, void *p); +extern int stdio_fseek(uint32 pos, void *p); /* open stdio input stream */ -#define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp) +#define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp) /* open input file */ -#define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \ - (void *)fopen(fn, "r")) +#define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \ + (void *)fopen(fn, "rb")) /* close stdio input file or stream */ -#define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \ +#define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \ BMPfreeReader(br) ) /* open stdio output stream */ @@ -151,10 +151,10 @@ int stdio_fseek(uint32 pos, void *p); /* open stdio output file */ #define BMPopenOutputFile(fn,hdr) \ BMPopenWriter(&stdio_putc, &stdio_fseek, \ - (void *)fopen(fn, "w"), hdr) + (void *)fopen(fn, "wb"), hdr) /* close stdio output file or stream */ -#define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \ +#define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \ BMPfreeWriter(bw) ) #ifdef __cplusplus
