--- ray/src/common/bmpfile.h 2004/03/26 22:58:21 2.2 +++ ray/src/common/bmpfile.h 2004/03/27 05:43:37 2.3 @@ -1,4 +1,4 @@ -/* RCSid $Id: bmpfile.h,v 2.2 2004/03/26 22:58:21 greg Exp $ */ +/* RCSid $Id: bmpfile.h,v 2.3 2004/03/27 05:43:37 greg Exp $ */ /* * Windows and OS/2 BMP file support */ @@ -26,19 +26,19 @@ typedef struct { /* Allocated BMP header data */ typedef struct { - /* the following fields may be altered before open call */ + /* the following fields may be altered before the open call */ int yIsDown; /* scanlines proceed downward? */ int32 hRes; /* horizontal resolution pixels/meter */ int32 vRes; /* vertical resolution pixels/meter */ int nColors; /* total color palette size */ int impColors; /* number of colors actually used */ - /* the following fields should not be altered after allocation */ + int compr; /* compression */ int32 width; /* bitmap width (pixels) */ int32 height; /* bitmap height (pixels) */ + /* the following fields must not be altered after allocation */ int bpp; /* bits per sample (1,4,8,16,24,32) */ - int compr; /* compression */ uint32 infoSiz; /* info buffer size (bytes) */ - /* the color table should be filled by writer before open call */ + /* but the color table should be filled by writer before open call */ RGBquad palette[3]; /* color palette (extends struct) */ } BMPHeader; @@ -78,8 +78,9 @@ typedef struct BMPReader { typedef struct { /* the scanline data is filled in by caller before each write */ uint8 *scanline; /* caller-prepared scanline data */ + /* modify yscan only if seek is defined & data is uncompressed */ int yscan; /* scanline for next write */ - /* the following fields should not be altered by the caller */ + /* the following fields should not be altered directly */ BMPHeader *hdr; /* allocated header */ uint32 fbmp; /* beginning of bitmap data */ uint32 fpos; /* current file position */
