root/radiance/ray/src/common/bmpfile.h
Revision: 2.5
Committed: Thu Apr 12 22:13:28 2007 UTC (18 years, 3 months ago) by greg
Fix for Windows systems
1 /* RCSid $Id: bmpfile.h,v 2.4 2005/03/18 21:04:05 greg Exp $ */
2 /*
3 * Windows and OS/2 BMP file support
4 */
5
6 #ifndef _RAD_BMPFILE_H_
7 #define _RAD_BMPFILE_H_
8
9 #include "tifftypes.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* compression modes */
16 #define BI_UNCOMPR 0 /* no compression */
17 #define BI_RLE8 1 /* runlength on bytes */
18 #define BI_RLE4 2 /* runlength on half-bytes */
19 #define BI_BITFIELDS 3 /* uncompressed w/ bitfields */
20
21 /* A Color table entry */
22 typedef struct {
23 uint8 b, g, r; /* blue, green, & red bytes */
24 uint8 padding; /* padding to 32-bit boundary */
25 } RGBquad;
26
27 /* Allocated BMP header data */
28 typedef struct {
29 /* the following fields may be altered before the open call */
30 int yIsDown; /* scanlines proceed downward? */
31 int32 hRes; /* horizontal resolution pixels/meter */
32 int32 vRes; /* vertical resolution pixels/meter */
33 int nColors; /* total color palette size */
34 int impColors; /* number of colors actually used */
35 int compr; /* compression */
36 int32 width; /* bitmap width (pixels) */
37 int32 height; /* bitmap height (pixels) */
38 /* the following fields must not be altered after allocation */
39 int bpp; /* bits per sample (1,4,8,16,24,32) */
40 uint32 infoSiz; /* info buffer size (bytes) */
41 /* but the color table should be filled by writer before open call */
42 RGBquad palette[3]; /* color palette (extends struct) */
43 } BMPHeader;
44
45 /* access to bit field triple */
46 #define BMPbitField(h) ((uint32 *)(h)->palette)
47
48 /* info buffer access */
49 #define BMPinfo(h) ((char *)((h)->palette + (h)->nColors))
50
51 /* function return values */
52 #define BIR_OK 0 /* all is well */
53 #define BIR_EOF (-1) /* reached end of file */
54 #define BIR_TRUNCATED 1 /* unexpected EOF */
55 #define BIR_UNSUPPORTED 2 /* unsupported encoding */
56 #define BIR_RLERROR 3 /* RLE error */
57 #define BIR_SEEKERR 4 /* could not seek */
58
59 /* A BMP reader structure */
60 typedef struct BMPReader {
61 /* members in this structure should be considered read-only */
62 uint8 *scanline; /* unpacked scanline data */
63 int yscan; /* last scanline read */
64 BMPHeader *hdr; /* pointer to allocated header */
65 uint32 fpos; /* current file position */
66 /* get character callback */
67 int (*cget)(void *);
68 /* absolute seek callback (or NULL) */
69 int (*seek)(uint32, void *);
70 void *c_data; /* client's opaque data */
71 uint32 scanpos[1]; /* recorded scanline position(s) */
72 } BMPReader;
73
74 /* A BMP writer structure */
75 typedef struct {
76 /* the scanline data is filled in by caller before each write */
77 uint8 *scanline; /* caller-prepared scanline data */
78 /* modify yscan only if seek is defined & data is uncompressed */
79 int yscan; /* scanline for next write */
80 /* the following fields should not be altered directly */
81 BMPHeader *hdr; /* allocated header */
82 uint32 fbmp; /* beginning of bitmap data */
83 uint32 fpos; /* current file position */
84 uint32 flen; /* last character written */
85 /* put character callback */
86 void (*cput)(int, void *);
87 /* absolute seek callback (or NULL) */
88 int (*seek)(uint32, void *);
89 void *c_data; /* client's opaque data */
90 } BMPWriter;
91
92 /* open BMP stream for reading */
93 BMPReader *BMPopenReader(int (*cget)(void *),
94 int (*seek)(uint32, void *), void *c_data);
95
96 /* determine if image is grayscale */
97 int BMPisGrayscale(const BMPHeader *hdr);
98
99 /* read next BMP scanline */
100 int BMPreadScanline(BMPReader *br);
101
102 /* read a specific scanline */
103 int BMPseekScanline(int y, BMPReader *br);
104
105 /* get ith pixel from last scanline */
106 RGBquad BMPdecodePixel(int i, const BMPReader *br);
107
108 /* free BMP reader resources */
109 void BMPfreeReader(BMPReader *br);
110
111 /* allocate uncompressed RGB header */
112 BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen);
113
114 /* allocate color-mapped header */
115 BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors);
116
117 /* open BMP stream for writing */
118 BMPWriter *BMPopenWriter(void (*cput)(int, void *),
119 int (*seek)(uint32, void *), void *c_data,
120 BMPHeader *hdr);
121
122 /* write the prepared scanline */
123 int BMPwriteScanline(BMPWriter *bw);
124
125 /* free BMP writer resources */
126 void BMPfreeWriter(BMPWriter *bw);
127
128 /* get corresponding error message */
129 const char *BMPerrorMessage(int ec);
130
131 /* stdio callback functions */
132 int stdio_getc(void *p);
133 void stdio_putc(int c, void *p);
134 int stdio_fseek(uint32 pos, void *p);
135
136 /* open stdio input stream */
137 #define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp)
138
139 /* open input file */
140 #define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \
141 (void *)fopen(fn, "rb"))
142
143 /* close stdio input file or stream */
144 #define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \
145 BMPfreeReader(br) )
146
147 /* open stdio output stream */
148 #define BMPopenOutputStream(fp,hdr) \
149 BMPopenWriter(&stdio_putc, NULL, (void *)fp, hdr)
150
151 /* open stdio output file */
152 #define BMPopenOutputFile(fn,hdr) \
153 BMPopenWriter(&stdio_putc, &stdio_fseek, \
154 (void *)fopen(fn, "wb"), hdr)
155
156 /* close stdio output file or stream */
157 #define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \
158 BMPfreeWriter(bw) )
159
160 #ifdef __cplusplus
161 }
162 #endif
163 #endif /* ! _RAD_BMPFILE_H_ */
