| 1 |
/* RCSid $Id: bmpfile.h,v 2.4 2005/03/18 21:04:05 greg Exp $ */
| 2 |
| 3 |
* Windows and OS/2 BMP file support
| 4 |
| 5 |
| 6 |
#ifndef _RAD_BMPFILE_H_
| 7 |
#define _RAD_BMPFILE_H_
| 8 |
| 9 |
#include "tifftypes.h"
| 10 |
| 11 |
#ifdef __cplusplus
| 12 |
extern "C" {
| 13 |
#endif
| 14 |
| 15 |
/* compression modes */
| 16 |
#define BI_UNCOMPR 0 /* no compression */
| 17 |
#define BI_RLE8 1 /* runlength on bytes */
| 18 |
#define BI_RLE4 2 /* runlength on half-bytes */
| 19 |
#define BI_BITFIELDS 3 /* uncompressed w/ bitfields */
| 20 |
| 21 |
/* A Color table entry */
| 22 |
typedef struct {
| 23 |
uint8 b, g, r; /* blue, green, & red bytes */
| 24 |
uint8 padding; /* padding to 32-bit boundary */
| 25 |
} RGBquad;
| 26 |
| 27 |
/* Allocated BMP header data */
| 28 |
typedef struct {
| 29 |
/* the following fields may be altered before the open call */
| 30 |
int yIsDown; /* scanlines proceed downward? */
| 31 |
int32 hRes; /* horizontal resolution pixels/meter */
| 32 |
int32 vRes; /* vertical resolution pixels/meter */
| 33 |
int nColors; /* total color palette size */
| 34 |
int impColors; /* number of colors actually used */
| 35 |
int compr; /* compression */
| 36 |
int32 width; /* bitmap width (pixels) */
| 37 |
int32 height; /* bitmap height (pixels) */
| 38 |
/* the following fields must not be altered after allocation */
| 39 |
int bpp; /* bits per sample (1,4,8,16,24,32) */
| 40 |
uint32 infoSiz; /* info buffer size (bytes) */
| 41 |
/* but the color table should be filled by writer before open call */
| 42 |
RGBquad palette[3]; /* color palette (extends struct) */
| 43 |
} BMPHeader;
| 44 |
| 45 |
/* access to bit field triple */
| 46 |
#define BMPbitField(h) ((uint32 *)(h)->palette)
| 47 |
| 48 |
/* info buffer access */
| 49 |
#define BMPinfo(h) ((char *)((h)->palette + (h)->nColors))
| 50 |
| 51 |
/* function return values */
| 52 |
#define BIR_OK 0 /* all is well */
| 53 |
#define BIR_EOF (-1) /* reached end of file */
| 54 |
#define BIR_TRUNCATED 1 /* unexpected EOF */
| 55 |
#define BIR_UNSUPPORTED 2 /* unsupported encoding */
| 56 |
#define BIR_RLERROR 3 /* RLE error */
| 57 |
#define BIR_SEEKERR 4 /* could not seek */
| 58 |
| 59 |
/* A BMP reader structure */
| 60 |
typedef struct BMPReader {
| 61 |
/* members in this structure should be considered read-only */
| 62 |
uint8 *scanline; /* unpacked scanline data */
| 63 |
int yscan; /* last scanline read */
| 64 |
BMPHeader *hdr; /* pointer to allocated header */
| 65 |
uint32 fpos; /* current file position */
| 66 |
/* get character callback */
| 67 |
int (*cget)(void *);
| 68 |
/* absolute seek callback (or NULL) */
| 69 |
int (*seek)(uint32, void *);
| 70 |
void *c_data; /* client's opaque data */
| 71 |
uint32 scanpos[1]; /* recorded scanline position(s) */
| 72 |
} BMPReader;
| 73 |
| 74 |
/* A BMP writer structure */
| 75 |
typedef struct {
| 76 |
/* the scanline data is filled in by caller before each write */
| 77 |
uint8 *scanline; /* caller-prepared scanline data */
| 78 |
/* modify yscan only if seek is defined & data is uncompressed */
| 79 |
int yscan; /* scanline for next write */
| 80 |
/* the following fields should not be altered directly */
| 81 |
BMPHeader *hdr; /* allocated header */
| 82 |
uint32 fbmp; /* beginning of bitmap data */
| 83 |
| 84 |
uint32 flen; /* last character written */
| 85 |
/* put character callback */
| 86 |
void (*cput)(int, void *);
| 87 |
| 88 |
| 89 |
| 90 |
} BMPWriter;
| 91 |
| 92 |
/* open BMP stream for reading */
| 93 |
BMPReader *BMPopenReader(int (*cget)(void *),
| 94 |
int (*seek)(uint32, void *), void *c_data);
| 95 |
| 96 |
/* determine if image is grayscale */
| 97 |
int BMPisGrayscale(const BMPHeader *hdr);
| 98 |
| 99 |
/* read next BMP scanline */
| 100 |
int BMPreadScanline(BMPReader *br);
| 101 |
| 102 |
/* read a specific scanline */
| 103 |
int BMPseekScanline(int y, BMPReader *br);
| 104 |
| 105 |
/* get ith pixel from last scanline */
| 106 |
RGBquad BMPdecodePixel(int i, const BMPReader *br);
| 107 |
| 108 |
/* free BMP reader resources */
| 109 |
void BMPfreeReader(BMPReader *br);
| 110 |
| 111 |
/* allocate uncompressed RGB header */
| 112 |
BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen);
| 113 |
| 114 |
/* allocate color-mapped header */
| 115 |
BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors);
| 116 |
| 117 |
/* open BMP stream for writing */
| 118 |
BMPWriter *BMPopenWriter(void (*cput)(int, void *),
| 119 |
int (*seek)(uint32, void *), void *c_data,
| 120 |
BMPHeader *hdr);
| 121 |
| 122 |
/* write the prepared scanline */
| 123 |
int BMPwriteScanline(BMPWriter *bw);
| 124 |
| 125 |
/* free BMP writer resources */
| 126 |
void BMPfreeWriter(BMPWriter *bw);
| 127 |
| 128 |
/* get corresponding error message */
| 129 |
const char *BMPerrorMessage(int ec);
| 130 |
| 131 |
/* stdio callback functions */
| 132 |
int stdio_getc(void *p);
| 133 |
void stdio_putc(int c, void *p);
| 134 |
int stdio_fseek(uint32 pos, void *p);
| 135 |
| 136 |
/* open stdio input stream */
| 137 |
#define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp)
| 138 |
| 139 |
/* open input file */
| 140 |
#define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \
| 141 |
(void *)fopen(fn, "rb"))
| 142 |
| 143 |
/* close stdio input file or stream */
| 144 |
#define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \
| 145 |
BMPfreeReader(br) )
| 146 |
| 147 |
/* open stdio output stream */
| 148 |
#define BMPopenOutputStream(fp,hdr) \
| 149 |
BMPopenWriter(&stdio_putc, NULL, (void *)fp, hdr)
| 150 |
| 151 |
/* open stdio output file */
| 152 |
#define BMPopenOutputFile(fn,hdr) \
| 153 |
BMPopenWriter(&stdio_putc, &stdio_fseek, \
| 154 |
(void *)fopen(fn, "wb"), hdr)
| 155 |
| 156 |
/* close stdio output file or stream */
| 157 |
#define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \
| 158 |
BMPfreeWriter(bw) )
| 159 |
| 160 |
#ifdef __cplusplus
| 161 |
| 162 |
#endif
| 163 |
#endif /* ! _RAD_BMPFILE_H_ */
