root/radiance/ray/src/common/bmpfile.h
Revision: 2.3
Committed: Sat Mar 27 05:43:37 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.2: +7 -6 lines
Bug fixes in run-length encoding code
1 /* RCSid $Id: bmpfile.h,v 2.2 2004/03/26 22:58:21 greg Exp $ */
2 /*
3 * Windows and OS/2 BMP file support
4 */
5
6 #ifndef _RAD_BMPFILE_H_
7 #define _RAD_BMPFILE_H_
8
9 #include "tifftypes.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* compression modes */
16 #define BI_UNCOMPR 0 /* no compression */
17 #define BI_RLE8 1 /* runlength on bytes */
18 #define BI_RLE4 2 /* runlength on half-bytes */
19 #define BI_BITFIELDS 3 /* uncompressed w/ bitfields */
20
21 /* A Color table entry */
22 typedef struct {
23 uint8 b, g, r; /* blue, green, & red bytes */
24 uint8 padding; /* padding to 32-bit boundary */
25 } RGBquad;
26
27 /* Allocated BMP header data */
28 typedef struct {
29 /* the following fields may be altered before the open call */
30 int yIsDown; /* scanlines proceed downward? */
31 int32 hRes; /* horizontal resolution pixels/meter */
32 int32 vRes; /* vertical resolution pixels/meter */
33 int nColors; /* total color palette size */
34 int impColors; /* number of colors actually used */
35 int compr; /* compression */
36 int32 width; /* bitmap width (pixels) */
37 int32 height; /* bitmap height (pixels) */
38 /* the following fields must not be altered after allocation */
39 int bpp; /* bits per sample (1,4,8,16,24,32) */
40 uint32 infoSiz; /* info buffer size (bytes) */
41 /* but the color table should be filled by writer before open call */
42 RGBquad palette[3]; /* color palette (extends struct) */
43 } BMPHeader;
44
45 /* color palette length */
46 #define BMPpalLen(h) ((h)->bpp <= 8 ? 1<<(h)->bpp : 0)
47
48 /* access to bit field triple */
49 #define BMPbitField(h) ((uint32 *)(h)->palette)
50
51 /* info buffer access */
52 #define BMPinfo(h) ((char *)((h)->palette + BMPpalLen(h)))
53
54 /* function return values */
55 #define BIR_OK 0 /* all is well */
56 #define BIR_EOF (-1) /* reached end of file */
57 #define BIR_TRUNCATED 1 /* unexpected EOF */
58 #define BIR_UNSUPPORTED 2 /* unsupported encoding */
59 #define BIR_RLERROR 3 /* RLE error */
60 #define BIR_SEEKERR 4 /* could not seek */
61
62 /* A BMP reader structure */
63 typedef struct BMPReader {
64 /* members in this structure should be considered read-only */
65 uint8 *scanline; /* unpacked scanline data */
66 int yscan; /* last scanline read */
67 BMPHeader *hdr; /* pointer to allocated header */
68 uint32 fpos; /* current file position */
69 /* get character callback */
70 int (*cget)(void *);
71 /* absolute seek callback (or NULL) */
72 int (*seek)(uint32, void *);
73 void *c_data; /* client's opaque data */
74 uint32 scanpos[1]; /* recorded scanline position(s) */
75 } BMPReader;
76
77 /* A BMP writer structure */
78 typedef struct {
79 /* the scanline data is filled in by caller before each write */
80 uint8 *scanline; /* caller-prepared scanline data */
81 /* modify yscan only if seek is defined & data is uncompressed */
82 int yscan; /* scanline for next write */
83 /* the following fields should not be altered directly */
84 BMPHeader *hdr; /* allocated header */
85 uint32 fbmp; /* beginning of bitmap data */
86 uint32 fpos; /* current file position */
87 uint32 flen; /* last character written */
88 /* put character callback */
89 void (*cput)(int, void *);
90 /* absolute seek callback (or NULL) */
91 int (*seek)(uint32, void *);
92 void *c_data; /* client's opaque data */
93 } BMPWriter;
94
95 /* open BMP stream for reading */
96 BMPReader *BMPopenReader(int (*cget)(void *),
97 int (*seek)(uint32, void *), void *c_data);
98
99 /* determine if image is grayscale */
100 int BMPisGrayscale(const BMPHeader *hdr);
101
102 /* read next BMP scanline */
103 int BMPreadScanline(BMPReader *br);
104
105 /* read a specific scanline */
106 int BMPseekScanline(int y, BMPReader *br);
107
108 /* get ith pixel from last scanline */
109 RGBquad BMPdecodePixel(int i, const BMPReader *br);
110
111 /* free BMP reader resources */
112 void BMPfreeReader(BMPReader *br);
113
114 /* allocate uncompressed RGB header */
115 BMPHeader *BMPtruecolorHeader(int xr, int yr, int infolen);
116
117 /* allocate color-mapped header */
118 BMPHeader *BMPmappedHeader(int xr, int yr, int infolen, int ncolors);
119
120 /* open BMP stream for writing */
121 BMPWriter *BMPopenWriter(void (*cput)(int, void *),
122 int (*seek)(uint32, void *), void *c_data,
123 BMPHeader *hdr);
124
125 /* write the prepared scanline */
126 int BMPwriteScanline(BMPWriter *bw);
127
128 /* free BMP writer resources */
129 void BMPfreeWriter(BMPWriter *bw);
130
131 /* get corresponding error message */
132 const char *BMPerrorMessage(int ec);
133
134 /* stdio callback functions */
135 int stdio_getc(void *p);
136 void stdio_putc(int c, void *p);
137 int stdio_fseek(uint32 pos, void *p);
138
139 /* open stdio input stream */
140 #define BMPopenInputStream(fp) BMPopenReader(&stdio_getc, NULL, (void *)fp)
141
142 /* open input file */
143 #define BMPopenInputFile(fn) BMPopenReader(&stdio_getc, &stdio_fseek, \
144 (void *)fopen(fn, "r"))
145
146 /* close stdio input file or stream */
147 #define BMPcloseInput(br) ( fclose((FILE *)(br)->c_data), \
148 BMPfreeReader(br) )
149
150 /* open stdio output stream */
151 #define BMPopenOutputStream(fp,hdr) \
152 BMPopenWriter(&stdio_putc, NULL, (void *)fp, hdr)
153
154 /* open stdio output file */
155 #define BMPopenOutputFile(fn,hdr) \
156 BMPopenWriter(&stdio_putc, &stdio_fseek, \
157 (void *)fopen(fn, "w"), hdr)
158
159 /* close stdio output file or stream */
160 #define BMPcloseOutput(bw) ( fclose((FILE *)(bw)->c_data), \
161 BMPfreeWriter(bw) )
162
163 #ifdef __cplusplus
164 }
165 #endif
166 #endif /* ! _RAD_BMPFILE_H_ */
