root/radiance/ray/src/common/bmpfile.c
Revision: 2.20
Committed: Wed Jan 23 19:13:55 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.19: +23 -23 lines
Minor fixes to comments
2 static const char RCSid[] = "$Id: bmpfile.c,v 2.19 2017/09/05 17:19:42 greg Exp $";
5 * Windows and OS/2 BMP file support
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include "bmpfile.h"
12
13 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
14 #undef getc
15 #undef putc
16 #define getc getc_unlocked
17 #define putc putc_unlocked
18 #endif
19
20 /* Get corresponding error message */
21 const char *
22 BMPerrorMessage(int ec)
23 {
24 switch (ec) {
25 case BIR_OK:
26 return "No error";
27 case BIR_EOF:
28 return "End of BMP image";
29 case BIR_TRUNCATED:
30 return "Truncated BMP image";
31 case BIR_UNSUPPORTED:
32 return "Unsupported BMP feature";
33 case BIR_RLERROR:
34 return "BMP runlength encoding error";
35 case BIR_SEEKERR:
36 return "BMP seek error";
37 }
38 return "Unknown BMP error";
39 }
40
41 /* Check that header is sensible */
42 static int
43 BMPheaderOK(const BMPHeader *hdr)
44 {
45 if (!hdr)
46 return 0;
47 if ((hdr->width <= 0) | (hdr->height <= 0))
48 return 0;
49 switch (hdr->bpp) { /* check compression */
50 case 1:
51 case 24:
52 if (hdr->compr != BI_UNCOMPR)
53 return 0;
54 break;
55 case 16:
56 case 32:
57 if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_BITFIELDS))
58 return 0;
59 break;
60 case 4:
61 if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_RLE4))
62 return 0;
63 break;
64 case 8:
65 if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_RLE8))
66 return 0;
67 break;
68 default:
69 return 0;
70 }
71 if (hdr->compr == BI_BITFIELDS && (BMPbitField(hdr)[0] &
72 BMPbitField(hdr)[1] & BMPbitField(hdr)[2]))
73 return 0;
74 if (hdr->bpp > 8) {
75 if (hdr->nColors != 0)
76 return 0;
77 } else {
78 if ((hdr->nColors < 0) | (hdr->nColors > 1<<hdr->bpp))
79 return 0;
80 if ((hdr->impColors < 0) | (hdr->impColors > hdr->nColors))
81 return 0;
82 }
83 return 1;
84 }
85
86 /* compute uncompressed scan size */
87 #define getScanSiz(h) ( ((((h)->bpp*(h)->width+7) >>3) + 3) & ~03 )
88
89 /* get next byte from reader */
90 #define rdbyte(c,br) ((br)->fpos += (c=(*(br)->cget)((br)->c_data))!=EOF, c)
91
92 /* Read n bytes */
93 static int
94 rdbytes(char *bp, uint32 n, BMPReader *br)
95 {
96 int c;
97
98 while (n--) {
99 if (rdbyte(c, br) == EOF)
100 return BIR_TRUNCATED;
101 *bp++ = c;
102 }
103 return BIR_OK;
104 }
105
106 /* Read 32-bit integer in littlendian order */
107 static int32
108 rdint32(BMPReader *br)
109 {
110 int32 i;
111 int c;
112
113 i = rdbyte(c, br);
114 i |= rdbyte(c, br) << 8;
115 i |= rdbyte(c, br) << 16;
116 i |= rdbyte(c, br) << 24;
117 return i; /* -1 on EOF */
118 }
119
120 /* Read 16-bit unsigned integer in littlendian order */
121 static int
122 rduint16(BMPReader *br)
123 {
124 int i;
125 int c;
126
127 i = rdbyte(c, br);
128 i |= rdbyte(c, br) << 8;
129 return i; /* -1 on EOF */
130 }
131
132 /* Seek on reader or return 0 (BIR_OK) on success */
133 static int
134 rdseek(uint32 pos, BMPReader *br)
135 {
136 if (pos == br->fpos)
137 return BIR_OK;
138 if (br->seek == NULL || (*br->seek)(pos, br->c_data) != 0)
139 return BIR_SEEKERR;
140 br->fpos = pos;
141 return BIR_OK;
142 }
143
144 /* Open BMP stream for reading and get first scanline */
145 BMPReader *
146 BMPopenReader(int (*cget)(void *), int (*seek)(uint32, void *), void *c_data)
147 {
148 BMPReader *br;
149 uint32 bmPos, hdrSiz, palSiz;
150 int magic[2]; /* check magic number */
151
152 if (cget == NULL)
153 return NULL;
154 magic[0] = (*cget)(c_data);
155 if (magic[0] != 'B')
156 return NULL;
157 magic[1] = (*cget)(c_data);
158 if (magic[1] != 'M' && magic[1] != 'A')
159 return NULL;
160 br = (BMPReader *)calloc(1, sizeof(BMPReader));
161 if (br == NULL)
162 return NULL;
163 br->cget = cget;
164 br->seek = seek;
165 br->c_data = c_data;
166 br->hdr = (BMPHeader *)malloc(sizeof(BMPHeader));
167 if (br->hdr == NULL)
168 goto err;
169 br->fpos = 2;
170 /* read & verify file header */
171 (void)rdint32(br); /* file size */
172 (void)rdint32(br); /* reserved word */
173 bmPos = rdint32(br); /* offset to bitmap */
174 hdrSiz = 2 + 3*4 + rdint32(br); /* header size */
175 if (hdrSiz < 2 + 6*4 + 2*2 + 6*4)
176 goto err;
177 br->hdr->width = rdint32(br); /* bitmap width */
178 br->hdr->height = rdint32(br); /* bitmap height */
179 if (((br->hdr->width <= 0) | (br->hdr->height == 0)))
180 goto err;
181 if ((br->hdr->yIsDown = br->hdr->height < 0))
182 br->hdr->height = -br->hdr->height;
183 if (rduint16(br) != 1) /* number of planes */
184 goto err;
185 br->hdr->bpp = rduint16(br); /* bits per pixel */
186 br->hdr->compr = rdint32(br); /* compression mode */
187 (void)rdint32(br); /* bitmap size */
188 br->hdr->hRes = rdint32(br); /* horizontal resolution */
189 br->hdr->vRes = rdint32(br); /* vertical resolution */
190 br->hdr->nColors = rdint32(br); /* # colors used */
191 if (!br->hdr->nColors && br->hdr->bpp <= 8)
192 br->hdr->nColors = 1<<br->hdr->bpp;
193 br->hdr->impColors = rdint32(br); /* # important colors */
194 if (br->hdr->impColors < 0)
195 goto err; /* catch premature EOF */
196 if (!BMPheaderOK(br->hdr))
197 goto err;
198 palSiz = sizeof(RGBquad)*br->hdr->nColors;
199 if (br->hdr->impColors <= 0)
200 br->hdr->impColors = br->hdr->nColors;
201 /* extend header */
202 if (bmPos < hdrSiz + palSiz)
203 goto err;
204 br->hdr->infoSiz = bmPos - (hdrSiz + palSiz);
205 if (br->hdr->nColors > 0 || br->hdr->infoSiz > 0) {
206 br->hdr = (BMPHeader *)realloc((void *)br->hdr,
207 sizeof(BMPHeader) +
208 palSiz + br->hdr->infoSiz);
209 if (br->hdr == NULL)
210 goto err;
211 }
212 /* read colors or fields */
213 if (br->hdr->compr == BI_BITFIELDS) {
214 BMPbitField(br->hdr)[0] = (uint32)rdint32(br);
215 BMPbitField(br->hdr)[1] = (uint32)rdint32(br);
216 BMPbitField(br->hdr)[2] = (uint32)rdint32(br);
217 } else if (rdbytes((char *)br->hdr->palette, palSiz, br) != BIR_OK)
218 goto err;
219 /* read add'l information */
220 if (rdbytes(BMPinfo(br->hdr), br->hdr->infoSiz, br) != BIR_OK)
221 goto err;
222 /* read first scanline */
223 br->scanline = (uint8 *)calloc(getScanSiz(br->hdr), sizeof(uint8));
224 if (br->scanline == NULL)
225 goto err;
226 br->yscan = -1;
227 if (seek != NULL && ((br->hdr->compr == BI_RLE8) |
228 (br->hdr->compr == BI_RLE4))) {
229 BMPReader *newbr = (BMPReader *)realloc((void *)br,
230 sizeof(BMPReader) +
231 sizeof(br->scanpos[0]) *
232 br->hdr->height);
233 if (newbr == NULL)
234 goto err;
235 br = newbr;
236 memset((void *)(br->scanpos + 1), 0,
237 sizeof(br->scanpos[0])*br->hdr->height);
238 }
239 br->scanpos[0] = br->fpos;
240 if (BMPreadScanline(br) == BIR_OK)
241 return br;
242 err:
243 if (br->hdr != NULL)
244 free((void *)br->hdr);
245 if (br->scanline != NULL)
246 free((void *)br->scanline);
247 free((void *)br);
248 return NULL;
249 }
250
251 /* Determine if image is grayscale */
252 int
253 BMPisGrayscale(const BMPHeader *hdr)
254 {
255 const RGBquad *rgbp;
256 int n;
257
258 if (hdr == NULL)
259 return -1;
260 if (hdr->bpp > 8) /* assume they had a reason for it */
261 return 0;
262 for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++)
263 if ((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b))
264 return 0;
265 return 1; /* all colors neutral in map */
266 }
267
268 /* Read and decode next BMP scanline */
269 int
270 BMPreadScanline(BMPReader *br)
271 {
272 int n;
273 int8 *sp;
274
275 if (br->yscan + 1 >= br->hdr->height)
276 return BIR_EOF;
277 br->yscan++; /* prepare to read */
278 n = getScanSiz(br->hdr); /* reading uncompressed data? */
279 if (br->hdr->compr == BI_UNCOMPR || br->hdr->compr == BI_BITFIELDS)
280 return rdbytes((char *)br->scanline, n, br);
281 /*
282 * RLE4/RLE8 Decoding
283 *
284 * Certain aspects of this scheme are completely insane, so
285 * we don't support them. Fortunately, they rarely appear.
286 * One is the mid-file EOD (0x0001) and another is the ill-conceived
287 * "delta" (0x0002), which is like a "goto" statement for bitmaps.
288 * Whoever thought this up should be wrestled to the ground and told
289 * why it's impossible to support such a scheme in any reasonable way.
290 * Also, RLE4 mode allows runs to stop halfway through a byte,
291 * which is likewise uncodeable, so we don't even try.
292 * Finally, the scanline break is ambiguous -- we assume here that
293 * it is required at the end of each scanline, though I haven't
294 * found anywhere this is written. Otherwise, we would read to
295 * the end of the scanline, assuming the next bit of data belongs
296 * the following scan. If a break follows the last pixel, as it
297 * seems to in the files I've tested out of Photoshop, you end up
298 * painting every other line black. Also, I assume any skipped
299 * pixels are painted with color 0, which is often black. Nowhere
300 * is it specified what we should assume for missing pixels. This
301 * is undoubtedly the most brain-dead format I've ever encountered.
302 */
303 sp = (int8 *)br->scanline;
304 n = br->hdr->width;
305 if (br->hdr->compr == BI_RLE4)
306 n = (n + 1) >> 1;
307 while (n > 0) {
308 int skipOdd, len, val;
309
310 if (rdbyte(len, br) == EOF)
311 return BIR_TRUNCATED;
312 if (len > 0) { /* got a run */
313 if (br->hdr->compr == BI_RLE4) {
314 if (len & 1)
315 return BIR_UNSUPPORTED;
316 len >>= 1;
317 }
318 if (len > n)
319 return BIR_RLERROR;
320 if (rdbyte(val, br) == EOF)
321 return BIR_TRUNCATED;
322 n -= len;
323 while (len--)
324 *sp++ = val;
325 continue;
326 }
327 /* check for escape */
328 switch (rdbyte(len, br)) {
329 case EOF:
330 return BIR_TRUNCATED;
331 case 0: /* end of line */
332 while (n--)
333 *sp++ = 0;
334 /* leaves n == -1 as flag for test after loop */
335 continue;
336 case 1: /* end of bitmap */
337 case 2: /* delta */
338 return BIR_UNSUPPORTED;
339 }
340 /* absolute mode */
341 if (br->hdr->compr == BI_RLE4) {
342 if (len & 1)
343 return BIR_UNSUPPORTED;
344 len >>= 1;
345 }
346 skipOdd = len & 1;
347 if (len > n)
348 return BIR_RLERROR;
349 n -= len;
350 while (len--) {
351 if (rdbyte(val, br) == EOF)
352 return BIR_TRUNCATED;
353 *sp++ = val;
354 }
355 if (skipOdd && rdbyte(val, br) == EOF)
356 return BIR_TRUNCATED;
357 }
358 /* verify break at end of line */
359 if (!n && (rdbyte(n, br) != 0 || (rdbyte(n, br) != 0 &&
360 (n != 1 || br->yscan != br->hdr->height-1))))
361 return BIR_RLERROR;
362 if (br->seek != NULL) /* record next scanline position */
363 br->scanpos[br->yscan + 1] = br->fpos;
364 return BIR_OK;
365 }
366
367 /* Read a specific scanline */
368 int
369 BMPseekScanline(int y, BMPReader *br)
370 {
371 int rv;
372 /* check arguments */
373 if (br == NULL)
374 return BIR_EOF;
375 if (y < 0)
376 return BIR_SEEKERR;
377 if (y >= br->hdr->height)
378 return BIR_EOF;
379 /* already read? */
380 if (y == br->yscan)
381 return BIR_OK;
382 /* shall we seek? */
383 if (y != br->yscan + 1 && br->seek != NULL) {
384 int yseek;
385 uint32 seekp;
386 if (br->hdr->compr == BI_UNCOMPR ||
387 br->hdr->compr == BI_BITFIELDS) {
388 yseek = y;
389 seekp = br->scanpos[0] + y*getScanSiz(br->hdr);
390 } else {
391 yseek = br->yscan + 1;
392 while (yseek < y && br->scanpos[yseek+1] != 0)
393 ++yseek;
394 if (y < yseek && br->scanpos[yseek=y] == 0)
395 return BIR_SEEKERR;
396 seekp = br->scanpos[yseek];
397 }
398 if ((rv = rdseek(seekp, br)) != BIR_OK)
399 return rv;
400 br->yscan = yseek - 1;
401 } else if (y < br->yscan) /* else we can't back up */
402 return BIR_SEEKERR;
403 /* read until we get there */
404 while (br->yscan < y)
405 if ((rv = BMPreadScanline(br)) != BIR_OK)
406 return rv;
407 return BIR_OK;
408 }
409
410 /* Get ith pixel from last scanline */
411 RGBquad
412 BMPdecodePixel(int i, const BMPReader *br)
413 {
414 static const uint32 std16mask[3] = {0x7c00, 0x3e0, 0x1f};
415 static const RGBquad black = {0, 0, 0, 0};
416 const uint32 *mask;
417 const uint8 *pp;
418 uint32 pval, v;
419 RGBquad cval;
420
421 if (((br == NULL) | (i < 0)) || i >= br->hdr->width)
422 return black;
423
424 cval.padding = 0;
425
426 switch (br->hdr->bpp) {
427 case 24:
428 pp = br->scanline + 3*i;
429 cval.b = *pp++;
430 cval.g = *pp++;
431 cval.r = *pp;
432 return cval;
433 case 32:
434 if (br->hdr->compr == BI_UNCOMPR)
435 return ((RGBquad *)br->scanline)[i];
436 /* convert bit fields */
437 pp = br->scanline + 4*i;
438 pval = *pp++;
439 pval |= *pp++ << 8;
440 pval |= *pp++ << 16;
441 pval |= *pp << 24;
442 mask = BMPbitField(br->hdr);
443 v = pval & mask[0];
444 while (v & ~0xff) v >>= 8;
445 cval.r = v;
446 v = pval & mask[1];
447 while (v & ~0xff) v >>= 8;
448 cval.g = v;
449 v = pval & mask[2];
450 while (v & ~0xff) v >>= 8;
451 cval.b = v;
452 return cval;
453 case 8:
454 return br->hdr->palette[br->scanline[i]];
455 case 1:
456 return br->hdr->palette[br->scanline[i>>3]>>(7-(i&7)) & 1];
457 case 4:
458 return br->hdr->palette[br->scanline[i>>1]>>(i&1?4:0) & 0xf];
459 case 16:
460 pp = br->scanline + 2*i;
461 pval = *pp++;
462 pval |= *pp++ << 8;
463 mask = std16mask;
464 if (br->hdr->compr == BI_BITFIELDS)
465 mask = BMPbitField(br->hdr);
466 cval.r = ((pval & mask[0]) << 8) / (mask[0] + 1);
467 cval.g = ((pval & mask[1]) << 8) / (mask[1] + 1);
468 cval.b = ((pval & mask[2]) << 8) / (mask[2] + 1);
469 return cval;
470 }
471 return black; /* should never happen */
472 }
473
474 /* Free BMP reader resources */
475 void
476 BMPfreeReader(BMPReader *br)
477 {
478 if (br == NULL)
479 return;
480 free((void *)br->hdr);
481 free((void *)br->scanline);
482 free((void *)br);
483 }
484
485 /* stdio getc() callback */
486 int
487 stdio_getc(void *p)
488 {
489 if (!p)
490 return EOF;
491 return getc((FILE *)p);
492 }
493
494 /* stdio putc() callback */
495 void
496 stdio_putc(int c, void *p)
497 {
498 if (p)
499 putc(c, (FILE *)p);
500 }
501
502 /* stdio fseek() callback */
503 int
504 stdio_fseek(uint32 pos, void *p)
505 {
506 if (!p)
507 return -1;
508 return fseek((FILE *)p, (long)pos, 0);
509 }
510
511 /* Allocate uncompressed (24-bit) RGB header */
512 BMPHeader *
513 BMPtruecolorHeader(int xr, int yr, int infolen)
514 {
515 BMPHeader *hdr;
516
517 if (xr <= 0 || yr <= 0 || infolen < 0)
518 return NULL;
519 hdr = (BMPHeader *)malloc(sizeof(BMPHeader) - sizeof(hdr->palette) +
520 infolen);
521 if (hdr == NULL)
522 return NULL;
523 hdr->width = xr;
524 hdr->height = yr;
525 hdr->yIsDown = 0; /* default to upwards order */
526 hdr->bpp = 24;
527 hdr->compr = BI_UNCOMPR;
528 hdr->hRes = hdr->vRes = 2835; /* default to 72 ppi */
529 hdr->nColors = hdr->impColors = 0;
530 hdr->infoSiz = infolen;
531 return hdr;
532 }
533
534 /* Allocate color-mapped header (defaults to minimal grayscale) */
535 BMPHeader *
536 BMPmappedHeader(int xr, int yr, int infolen, int ncolors)
537 {
538 int n;
539 BMPHeader *hdr;
540
541 if (xr <= 0 || yr <= 0 || infolen < 0 || ncolors < 2)
542 return NULL;
543 if (ncolors <= 2)
544 n = 1;
545 else if (ncolors <= 16)
546 n = 4;
547 else if (ncolors <= 256)
548 n = 8;
549 else
550 return NULL;
551 hdr = (BMPHeader *)malloc(sizeof(BMPHeader) +
552 sizeof(RGBquad)*((size_t)1<<n) -
553 sizeof(hdr->palette) +
554 infolen);
555 if (hdr == NULL)
556 return NULL;
557 hdr->width = xr;
558 hdr->height = yr;
559 hdr->yIsDown = 0; /* default to upwards order */
560 hdr->bpp = n;
561 hdr->compr = BI_UNCOMPR; /* compression needs seek */
562 hdr->hRes = hdr->vRes = 2835; /* default to 72 ppi */
563 hdr->nColors = ncolors;
564 hdr->impColors = 0; /* says all colors important */
565 hdr->infoSiz = infolen;
566 memset((void *)hdr->palette, 0, sizeof(RGBquad)*((size_t)1<<n) + infolen);
567 for (n = ncolors; n--; )
568 hdr->palette[n].r = hdr->palette[n].g =
569 hdr->palette[n].b = n*255/(ncolors-1);
570 return hdr;
571 }
572
573 /* put byte to writer */
574 #define wrbyte(c,bw) ( (*(bw)->cput)(c,(bw)->c_data), \
575 ++(bw)->fpos > (bw)->flen ? \
576 ((bw)->flen = (bw)->fpos) : \
577 (bw)->fpos )
578
579 /* Write out a string of bytes */
580 static void
581 wrbytes(char *bp, uint32 n, BMPWriter *bw)
582 {
583 while (n--)
584 wrbyte(*bp++, bw);
585 }
586
587 /* Write 32-bit integer in littlendian order */
588 static void
589 wrint32(int32 i, BMPWriter *bw)
590 {
591 wrbyte(i& 0xff, bw);
592 wrbyte(i>>8 & 0xff, bw);
593 wrbyte(i>>16 & 0xff, bw);
594 wrbyte(i>>24 & 0xff, bw);
595 }
596
597 /* Write 16-bit unsigned integer in littlendian order */
598 static void
599 wruint16(uint16 ui, BMPWriter *bw)
600 {
601 wrbyte(ui & 0xff, bw);
602 wrbyte(ui>>8 & 0xff, bw);
603 }
604
605 /* Seek to the specified file position, returning 0 (BIR_OK) on success */
606 static int
607 wrseek(uint32 pos, BMPWriter *bw)
608 {
609 if (pos == bw->fpos)
610 return BIR_OK;
611 if (bw->seek == NULL)
612 return BIR_SEEKERR;
613 if ((*bw->seek)(pos, bw->c_data) != 0)
614 return BIR_SEEKERR;
615 bw->fpos = pos;
616 if (pos > bw->flen)
617 bw->flen = pos;
618 return BIR_OK;
619 }
620
621 /* Open BMP stream for writing */
622 BMPWriter *
623 BMPopenWriter(void (*cput)(int, void *), int (*seek)(uint32, void *),
624 void *c_data, BMPHeader *hdr)
625 {
626 BMPWriter *bw;
627 uint32 hdrSiz, palSiz, scanSiz, bmSiz;
628 /* check arguments */
629 if (cput == NULL)
630 return NULL;
631 if (!BMPheaderOK(hdr))
632 return NULL;
633 if ((hdr->bpp == 16) | (hdr->compr == BI_RLE4))
634 return NULL; /* unsupported */
635 /* no seek means we may have the wrong file length, but most app's don't care
636 if (seek == NULL && ((hdr->compr == BI_RLE8) | (hdr->compr == BI_RLE4)))
637 return NULL;
638 */
639 /* compute sizes */
640 hdrSiz = 2 + 6*4 + 2*2 + 6*4;
641 if (hdr->compr == BI_BITFIELDS)
642 hdrSiz += sizeof(uint32)*3;
643 palSiz = sizeof(RGBquad)*hdr->nColors;
644 scanSiz = getScanSiz(hdr);
645 bmSiz = hdr->height*scanSiz; /* wrong if compressed */
646 /* initialize writer */
647 bw = (BMPWriter *)malloc(sizeof(BMPWriter));
648 if (bw == NULL)
649 return NULL;
650 bw->hdr = hdr;
651 bw->yscan = 0;
652 bw->scanline = (uint8 *)calloc(scanSiz, sizeof(uint8));
653 if (bw->scanline == NULL) {
654 free((void *)bw);
655 return NULL;
656 }
657 bw->fbmp = hdrSiz + palSiz + hdr->infoSiz;
658 bw->fpos = bw->flen = 0;
659 bw->cput = cput;
660 bw->seek = seek;
661 bw->c_data = c_data;
662 /* write out header */
663 wrbyte('B', bw); wrbyte('M', bw); /* magic number */
664 wrint32(bw->fbmp + bmSiz, bw); /* file size */
665 wrint32(0, bw); /* reserved word */
666 wrint32(bw->fbmp, bw); /* offset to bitmap */
667 wrint32(hdrSiz - bw->fpos, bw); /* info header size */
668 wrint32(hdr->width, bw); /* bitmap width */
669 if (hdr->yIsDown) /* bitmap height */
670 wrint32(-hdr->height, bw);
671 else
672 wrint32(hdr->height, bw);
673 wruint16(1, bw); /* number of planes */
674 wruint16(hdr->bpp, bw); /* bits per pixel */
675 wrint32(hdr->compr, bw); /* compression mode */
676 wrint32(bmSiz, bw); /* bitmap size */
677 wrint32(hdr->hRes, bw); /* horizontal resolution */
678 wrint32(hdr->vRes, bw); /* vertical resolution */
679 wrint32(hdr->nColors, bw); /* # colors used */
680 wrint32(hdr->impColors, bw); /* # important colors */
681 /* write out color palette */
682 wrbytes((char *)hdr->palette, palSiz, bw);
683 /* write add'l information */
684 wrbytes(BMPinfo(hdr), hdr->infoSiz, bw);
685 #ifndef NDEBUG
686 if (bw->fpos != bw->fbmp) {
687 fputs("Coding error 1 in BMPopenWriter\n", stderr);
688 exit(1);
689 }
690 #endif
691 return bw;
692 }
693
694 /* Find position of next run of 5 or more identical bytes, or 255 if none */
695 static int
696 findNextRun(const int8 *bp, int len)
697 {
698 int pos, cnt;
699 /* look for run */
700 for (pos = 0; (len > 0) & (pos < 255); pos++, bp++, len--) {
701 if (len < 5) /* no hope left? */
702 continue;
703 cnt = 1; /* else let's try it */
704 while (bp[cnt] == bp[0])
705 if (++cnt >= 5)
706 return pos; /* long enough */
707 }
708 return pos; /* didn't find any */
709 }
710
711 /* Write the current scanline */
712 int
713 BMPwriteScanline(BMPWriter *bw)
714 {
715 const int8 *sp;
716 int n;
717
718 if (bw->yscan >= bw->hdr->height)
719 return BIR_EOF;
720 /* writing uncompressed? */
721 if (bw->hdr->compr == BI_UNCOMPR || bw->hdr->compr == BI_BITFIELDS) {
722 uint32 scanSiz = getScanSiz(bw->hdr);
723 uint32 slpos = bw->fbmp + bw->yscan*scanSiz;
724 if (wrseek(slpos, bw) != BIR_OK)
725 return BIR_SEEKERR;
726 wrbytes((char *)bw->scanline, scanSiz, bw);
727 bw->yscan++;
728 return BIR_OK;
729 }
730 /*
731 * RLE8 Encoding
732 *
733 * See the notes in BMPreadScanline() on this encoding. Needless
734 * to say, we avoid the nuttier aspects of this specification.
735 * We also assume that every scanline ends in a line break
736 * (0x0000) except for the last, which ends in a bitmap break
737 * (0x0001). We don't support RLE4 at all; it's too awkward.
738 */
739 sp = (const int8 *)bw->scanline;
740 n = bw->hdr->width;
741 while (n > 0) {
742 int cnt, val;
743 cnt = findNextRun(sp, n); /* 0-255 < n */
744 if (cnt >= 3) { /* output absolute */
745 int skipOdd = cnt & 1;
746 wrbyte(0, bw);
747 wrbyte(cnt, bw);
748 n -= cnt;
749 while (cnt--)
750 wrbyte(*sp++, bw);
751 if (skipOdd)
752 wrbyte(0, bw);
753 }
754 if (n <= 0) /* was that it? */
755 break;
756 val = *sp++; /* output run */
757 for (cnt = 1; --n && cnt < 255; cnt++, sp++)
758 if (*sp != val)
759 break;
760 wrbyte(cnt, bw);
761 wrbyte(val, bw);
762 }
763 bw->yscan++; /* write line break or EOD */
764 if (bw->yscan == bw->hdr->height) {
765 wrbyte(0, bw); wrbyte(1, bw); /* end of bitmap marker */
766 if (wrseek(2, bw) != BIR_OK)
767 return BIR_OK; /* no one may care */
768 wrint32(bw->flen, bw); /* correct file length */
769 if (wrseek(34, bw) != BIR_OK)
770 return BIR_OK;
771 wrint32(bw->flen-bw->fbmp, bw); /* correct bitmap length */
772 } else {
773 wrbyte(0, bw); wrbyte(0, bw); /* end of line marker */
774 }
775 return BIR_OK;
776 }
777
778 /* Free BMP writer resources */
779 void
780 BMPfreeWriter(BMPWriter *bw)
781 {
782 if (bw == NULL)
783 return;
784 free((void *)bw->hdr);
785 free((void *)bw->scanline);
786 free((void *)bw);
787 }
