--- ray/src/common/bmpfile.c 2004/03/26 21:29:19 2.2 +++ ray/src/common/bmpfile.c 2016/03/10 01:49:00 2.16 @@ -1,17 +1,22 @@ #ifndef lint -static const char RCSid[] = "$Id: bmpfile.c,v 2.2 2004/03/26 21:29:19 schorsch Exp $"; +static const char RCSid[] = "$Id: bmpfile.c,v 2.16 2016/03/10 01:49:00 schorsch Exp $"; #endif /* * Windows and OS/2 BMP file support */ -/* XXX reading and writing of compressed files currently unsupported */ - #include #include #include #include "bmpfile.h" +#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ +#undef getc +#undef putc +#define getc getc_unlocked +#define putc putc_unlocked +#endif + /* get corresponding error message */ const char * BMPerrorMessage(int ec) @@ -25,25 +30,62 @@ BMPerrorMessage(int ec) return "Truncated BMP image"; case BIR_UNSUPPORTED: return "Unsupported BMP feature"; + case BIR_RLERROR: + return "BMP runlength encoding error"; case BIR_SEEKERR: return "BMP seek error"; } return "Unknown BMP error"; } -/* compute uncompressed scanline size */ -static uint32 -getScanSiz(BMPHeader *hdr) +/* check than header is sensible */ +static int +BMPheaderOK(const BMPHeader *hdr) { - uint32 scanSiz; - /* bytes per scanline */ - scanSiz = (hdr->bpp*hdr->width + 7) >> 3; - if (scanSiz & 3) /* 32-bit word boundary */ - scanSiz += 4 - (scanSiz & 3); - - return scanSiz; + if (!hdr) + return 0; + if ((hdr->width <= 0) | (hdr->height <= 0)) + return 0; + switch (hdr->bpp) { /* check compression */ + case 1: + case 24: + if (hdr->compr != BI_UNCOMPR) + return 0; + break; + case 16: + case 32: + if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_BITFIELDS)) + return 0; + break; + case 4: + if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_RLE4)) + return 0; + break; + case 8: + if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_RLE8)) + return 0; + break; + default: + return 0; + } + if (hdr->compr == BI_BITFIELDS && (BMPbitField(hdr)[0] & + BMPbitField(hdr)[1] & BMPbitField(hdr)[2])) + return 0; + if (hdr->bpp > 8) { + if (hdr->nColors != 0) + return 0; + } else { + if ((hdr->nColors < 0) | (hdr->nColors > 1<bpp)) + return 0; + if ((hdr->impColors < 0) | (hdr->impColors > hdr->nColors)) + return 0; + } + return 1; } + /* compute uncompressed scan size */ +#define getScanSiz(h) ( ((((h)->bpp*(h)->width+7) >>3) + 3) & ~03 ) + /* get next byte from reader */ #define rdbyte(c,br) ((br)->fpos += (c=(*(br)->cget)((br)->c_data))!=EOF, c) @@ -104,12 +146,11 @@ BMPReader * BMPopenReader(int (*cget)(void *), int (*seek)(uint32, void *), void *c_data) { BMPReader *br; - uint32 bmPos, hdrSiz; - int palLen; + uint32 bmPos, hdrSiz, palSiz; + int magic[2]; /* check magic number */ if (cget == NULL) return NULL; - int magic[2]; /* check magic number */ magic[0] = (*cget)(c_data); if (magic[0] != 'B') return NULL; @@ -130,7 +171,7 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, (void)rdint32(br); /* file size */ (void)rdint32(br); /* reserved word */ bmPos = rdint32(br); /* offset to bitmap */ - hdrSiz = rdint32(br) + 14; /* header size */ + hdrSiz = 2 + 3*4 + rdint32(br); /* header size */ if (hdrSiz < 2 + 6*4 + 2*2 + 6*4) goto err; br->hdr->width = rdint32(br); /* bitmap width */ @@ -142,49 +183,38 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, if (rduint16(br) != 1) /* number of planes */ goto err; br->hdr->bpp = rduint16(br); /* bits per pixel */ - if (br->hdr->bpp != 1 && br->hdr->bpp != 4 && - br->hdr->bpp != 8 && br->hdr->bpp != 24 && - br->hdr->bpp != 32) - goto err; br->hdr->compr = rdint32(br); /* compression mode */ - if (br->hdr->compr != BI_UNCOMPR && br->hdr->compr != BI_RLE8) - goto err; /* don't support the rest */ (void)rdint32(br); /* bitmap size */ br->hdr->hRes = rdint32(br); /* horizontal resolution */ br->hdr->vRes = rdint32(br); /* vertical resolution */ br->hdr->nColors = rdint32(br); /* # colors used */ + if (!br->hdr->nColors && br->hdr->bpp <= 8) + br->hdr->nColors = 1<hdr->bpp; br->hdr->impColors = rdint32(br); /* # important colors */ if (br->hdr->impColors < 0) goto err; /* catch premature EOF */ - palLen = 0; - if (br->hdr->bpp <= 8) { - palLen = 1 << br->hdr->bpp; - if (br->hdr->nColors <= 0) - br->hdr->nColors = palLen; - else if (br->hdr->nColors > palLen) - goto err; - if (br->hdr->impColors <= 0) - br->hdr->impColors = br->hdr->nColors; - else if (br->hdr->impColors > br->hdr->nColors) - goto err; - } else if (br->hdr->nColors > 0 || br->hdr->compr != BI_UNCOMPR) + if (!BMPheaderOK(br->hdr)) goto err; + palSiz = sizeof(RGBquad)*br->hdr->nColors; + if (br->hdr->impColors <= 0) + br->hdr->impColors = br->hdr->nColors; /* extend header */ - if (bmPos < hdrSiz + sizeof(RGBquad)*palLen) + if (bmPos < hdrSiz + palSiz) goto err; - br->hdr->infoSiz = bmPos - (hdrSiz + sizeof(RGBquad)*palLen); - if (palLen > 0 || br->hdr->infoSiz > 0) { + br->hdr->infoSiz = bmPos - (hdrSiz + palSiz); + if (br->hdr->nColors > 0 || br->hdr->infoSiz > 0) { br->hdr = (BMPHeader *)realloc((void *)br->hdr, sizeof(BMPHeader) + - sizeof(RGBquad)*palLen - - sizeof(br->hdr->palette) + - br->hdr->infoSiz); + palSiz + br->hdr->infoSiz); if (br->hdr == NULL) goto err; } - /* read color palette */ - if (rdbytes((char *)br->hdr->palette, - sizeof(RGBquad)*palLen, br) != BIR_OK) + /* read colors or fields */ + if (br->hdr->compr == BI_BITFIELDS) { + BMPbitField(br->hdr)[0] = (uint32)rdint32(br); + BMPbitField(br->hdr)[1] = (uint32)rdint32(br); + BMPbitField(br->hdr)[2] = (uint32)rdint32(br); + } else if (rdbytes((char *)br->hdr->palette, palSiz, br) != BIR_OK) goto err; /* read add'l information */ if (rdbytes(BMPinfo(br->hdr), br->hdr->infoSiz, br) != BIR_OK) @@ -194,7 +224,8 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, if (br->scanline == NULL) goto err; br->yscan = -1; - if (seek != NULL && br->hdr->compr != BI_UNCOMPR) { + if (seek != NULL && ((br->hdr->compr == BI_RLE8) | + (br->hdr->compr == BI_RLE4))) { BMPReader *newbr = (BMPReader *)realloc((void *)br, sizeof(BMPReader) + sizeof(br->scanpos[0]) * @@ -206,9 +237,8 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, sizeof(br->scanpos[0])*br->hdr->height); } br->scanpos[0] = br->fpos; - if (BMPreadScanline(br) != BIR_OK) - goto err; - return br; + if (BMPreadScanline(br) == BIR_OK) + return br; err: if (br->hdr != NULL) free((void *)br->hdr); @@ -230,7 +260,7 @@ BMPisGrayscale(const BMPHeader *hdr) if (hdr->bpp > 8) /* assume they had a reason for it */ return 0; for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++) - if (((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b))) + if ((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b)) return 0; return 1; /* all colors neutral in map */ } @@ -239,14 +269,97 @@ BMPisGrayscale(const BMPHeader *hdr) int BMPreadScanline(BMPReader *br) { + int n; + int8 *sp; + if (br->yscan + 1 >= br->hdr->height) return BIR_EOF; br->yscan++; /* prepare to read */ - if (br->hdr->compr == BI_UNCOMPR) - return rdbytes((char *)br->scanline, getScanSiz(br->hdr), br); -/* XXX need to perform actual decompression */ - return BIR_UNSUPPORTED; - if (br->seek != NULL) + n = getScanSiz(br->hdr); /* reading uncompressed data? */ + if (br->hdr->compr == BI_UNCOMPR || br->hdr->compr == BI_BITFIELDS) + return rdbytes((char *)br->scanline, n, br); + /* + * RLE4/RLE8 Decoding + * + * Certain aspects of this scheme are completely insane, so + * we don't support them. Fortunately, they rarely appear. + * One is the mid-file EOD (0x0001) and another is the ill-conceived + * "delta" (0x0002), which is like a "goto" statement for bitmaps. + * Whoever thought this up should be wrestled to the ground and told + * why it's impossible to support such a scheme in any reasonable way. + * Also, RLE4 mode allows runs to stop halfway through a byte, + * which is likewise uncodeable, so we don't even try. + * Finally, the scanline break is ambiguous -- we assume here that + * it is required at the end of each scanline, though I haven't + * found anywhere this is written. Otherwise, we would read to + * the end of the scanline, assuming the next bit of data belongs + * the following scan. If a break follows the last pixel, as it + * seems to in the files I've tested out of Photoshop, you end up + * painting every other line black. Also, I assume any skipped + * pixels are painted with color 0, which is often black. Nowhere + * is it specified what we should assume for missing pixels. This + * is undoubtedly the most brain-dead format I've ever encountered. + */ + sp = (int8 *)br->scanline; + n = br->hdr->width; + if (br->hdr->compr == BI_RLE4) + n = (n + 1) >> 1; + while (n > 0) { + int skipOdd, len, val; + + if (rdbyte(len, br) == EOF) + return BIR_TRUNCATED; + if (len > 0) { /* got a run */ + if (br->hdr->compr == BI_RLE4) { + if (len & 1) + return BIR_UNSUPPORTED; + len >>= 1; + } + if (len > n) + return BIR_RLERROR; + if (rdbyte(val, br) == EOF) + return BIR_TRUNCATED; + n -= len; + while (len--) + *sp++ = val; + continue; + } + /* check for escape */ + switch (rdbyte(len, br)) { + case EOF: + return BIR_TRUNCATED; + case 0: /* end of line */ + while (n--) + *sp++ = 0; + /* leaves n == -1 as flag for test after loop */ + continue; + case 1: /* end of bitmap */ + case 2: /* delta */ + return BIR_UNSUPPORTED; + } + /* absolute mode */ + if (br->hdr->compr == BI_RLE4) { + if (len & 1) + return BIR_UNSUPPORTED; + len >>= 1; + } + skipOdd = len & 1; + if (len > n) + return BIR_RLERROR; + n -= len; + while (len--) { + if (rdbyte(val, br) == EOF) + return BIR_TRUNCATED; + *sp++ = val; + } + if (skipOdd && rdbyte(val, br) == EOF) + return BIR_TRUNCATED; + } + /* verify break at end of line */ + if (!n && (rdbyte(n, br) != 0 || (rdbyte(n, br) != 0 && + (n != 1 || br->yscan != br->hdr->height-1)))) + return BIR_RLERROR; + if (br->seek != NULL) /* record next scanline position */ br->scanpos[br->yscan + 1] = br->fpos; return BIR_OK; } @@ -270,7 +383,8 @@ BMPseekScanline(int y, BMPReader *br) if (y != br->yscan + 1 && br->seek != NULL) { int yseek; uint32 seekp; - if (br->hdr->compr == BI_UNCOMPR) { + if (br->hdr->compr == BI_UNCOMPR || + br->hdr->compr == BI_BITFIELDS) { yseek = y; seekp = br->scanpos[0] + y*getScanSiz(br->hdr); } else { @@ -295,29 +409,64 @@ BMPseekScanline(int y, BMPReader *br) /* get ith pixel from last scanline */ RGBquad -BMPdecodePixel(int i, BMPReader *br) +BMPdecodePixel(int i, const BMPReader *br) { + static const uint32 std16mask[3] = {0x7c00, 0x3e0, 0x1f}; static const RGBquad black = {0, 0, 0, 0}; + const uint32 *mask; + const uint8 *pp; + uint32 pval, v; + RGBquad cval; if (((br == NULL) | (i < 0)) || i >= br->hdr->width) return black; + cval.padding = 0; + switch (br->hdr->bpp) { - case 24: { - uint8 *bgr = br->scanline + 3*i; - RGBquad cval; - cval.b = bgr[0]; cval.g = bgr[1]; cval.r = bgr[2]; - cval.padding = 0; + case 24: + pp = br->scanline + 3*i; + cval.b = *pp++; + cval.g = *pp++; + cval.r = *pp; return cval; - } case 32: - return ((RGBquad *)br->scanline)[i]; + if (br->hdr->compr == BI_UNCOMPR) + return ((RGBquad *)br->scanline)[i]; + /* convert bit fields */ + pp = br->scanline + 4*i; + pval = *pp++; + pval |= *pp++ << 8; + pval |= *pp++ << 16; + pval |= *pp << 24; + mask = BMPbitField(br->hdr); + v = pval & mask[0]; + while (v & ~0xff) v >>= 8; + cval.r = v; + v = pval & mask[1]; + while (v & ~0xff) v >>= 8; + cval.g = v; + v = pval & mask[2]; + while (v & ~0xff) v >>= 8; + cval.b = v; + return cval; case 8: return br->hdr->palette[br->scanline[i]]; case 1: - return br->hdr->palette[br->scanline[i>>3]>>(i&7) & 1]; + return br->hdr->palette[br->scanline[i>>3]>>((7-i)&7) & 1]; case 4: - return br->hdr->palette[br->scanline[i>>1]>>((i&1)<<2) & 0xf]; + return br->hdr->palette[br->scanline[i>>1]>>(i&1?4:0) & 0xf]; + case 16: + pp = br->scanline + 2*i; + pval = *pp++; + pval |= *pp++ << 8; + mask = std16mask; + if (br->hdr->compr == BI_BITFIELDS) + mask = BMPbitField(br->hdr); + cval.r = ((pval & mask[0]) << 8) / (mask[0] + 1); + cval.g = ((pval & mask[1]) << 8) / (mask[1] + 1); + cval.b = ((pval & mask[2]) << 8) / (mask[2] + 1); + return cval; } return black; /* should never happen */ } @@ -399,6 +548,7 @@ BMPmappedHeader(int xr, int yr, int infolen, int ncolo n = 8; else return NULL; + /* XXX VC warns about 32 bit shift coerced to 64 bit */ hdr = (BMPHeader *)malloc(sizeof(BMPHeader) + sizeof(RGBquad)*(1<palette) + @@ -409,11 +559,12 @@ BMPmappedHeader(int xr, int yr, int infolen, int ncolo hdr->height = yr; hdr->yIsDown = 0; /* default to upwards order */ hdr->bpp = n; - hdr->compr = BI_UNCOMPR; + hdr->compr = BI_UNCOMPR; /* compression needs seek */ hdr->hRes = hdr->vRes = 2835; /* default to 72 ppi */ hdr->nColors = ncolors; hdr->impColors = 0; /* says all colors important */ hdr->infoSiz = infolen; + /* XXX VC warns about 32 bit shift coerced to 64 bit */ memset((void *)hdr->palette, 0, sizeof(RGBquad)*(1<palette[n].r = hdr->palette[n].g = @@ -423,7 +574,7 @@ BMPmappedHeader(int xr, int yr, int infolen, int ncolo /* put byte to writer */ #define wrbyte(c,bw) ( (*(bw)->cput)(c,(bw)->c_data), \ - ++((bw)->fpos) > (bw)->flen ? \ + ++(bw)->fpos > (bw)->flen ? \ ((bw)->flen = (bw)->fpos) : \ (bw)->fpos ) @@ -442,7 +593,7 @@ wrint32(int32 i, BMPWriter *bw) wrbyte(i& 0xff, bw); wrbyte(i>>8 & 0xff, bw); wrbyte(i>>16 & 0xff, bw); - wrbyte(i>>24 & 0xff, bw); + wrbyte(i>>24 & 0xff, bw); } /* write 16-bit unsigned integer in littlendian order */ @@ -459,13 +610,8 @@ wrseek(uint32 pos, BMPWriter *bw) { if (pos == bw->fpos) return BIR_OK; - if (bw->seek == NULL) { - if (pos < bw->fpos) - return BIR_SEEKERR; - while (bw->fpos < pos) - wrbyte(0, bw); - return BIR_OK; - } + if (bw->seek == NULL) + return BIR_SEEKERR; if ((*bw->seek)(pos, bw->c_data) != 0) return BIR_SEEKERR; bw->fpos = pos; @@ -482,22 +628,21 @@ BMPopenWriter(void (*cput)(int, void *), int (*seek)(u BMPWriter *bw; uint32 hdrSiz, palSiz, scanSiz, bmSiz; /* check arguments */ - if (cput == NULL || hdr == NULL) + if (cput == NULL) return NULL; - if (hdr->width <= 0 || hdr->height <= 0) + if (!BMPheaderOK(hdr)) return NULL; - if (hdr->compr != BI_UNCOMPR && hdr->compr != BI_RLE8) + if ((hdr->bpp == 16) | (hdr->compr == BI_RLE4)) return NULL; /* unsupported */ - if (hdr->bpp > 8 && hdr->compr != BI_UNCOMPR) +/* no seek means we may have the wrong file length, but most app's don't care + if (seek == NULL && ((hdr->compr == BI_RLE8) | (hdr->compr == BI_RLE4))) return NULL; - palSiz = BMPpalLen(hdr); - if (hdr->nColors > palSiz) - return NULL; - if (hdr->compr != BI_UNCOMPR && seek == NULL) - return NULL; +*/ /* compute sizes */ hdrSiz = 2 + 6*4 + 2*2 + 6*4; - palSiz *= sizeof(RGBquad); + if (hdr->compr == BI_BITFIELDS) + hdrSiz += sizeof(uint32)*3; + palSiz = sizeof(RGBquad)*hdr->nColors; scanSiz = getScanSiz(hdr); bmSiz = hdr->height*scanSiz; /* wrong if compressed */ /* initialize writer */ @@ -547,15 +692,35 @@ BMPopenWriter(void (*cput)(int, void *), int (*seek)(u #endif return bw; } + +/* find position of next run of 5 or more identical bytes, or 255 if none */ +static int +findNextRun(const int8 *bp, int len) +{ + int pos, cnt; + /* look for run */ + for (pos = 0; (len > 0) & (pos < 255); pos++, bp++, len--) { + if (len < 5) /* no hope left? */ + continue; + cnt = 1; /* else let's try it */ + while (bp[cnt] == bp[0]) + if (++cnt >= 5) + return pos; /* long enough */ + } + return pos; /* didn't find any */ +} /* write the current scanline */ int BMPwriteScanline(BMPWriter *bw) { + const int8 *sp; + int n; + if (bw->yscan >= bw->hdr->height) return BIR_EOF; /* writing uncompressed? */ - if (bw->hdr->compr == BI_UNCOMPR) { + if (bw->hdr->compr == BI_UNCOMPR || bw->hdr->compr == BI_BITFIELDS) { uint32 scanSiz = getScanSiz(bw->hdr); uint32 slpos = bw->fbmp + bw->yscan*scanSiz; if (wrseek(slpos, bw) != BIR_OK) @@ -564,15 +729,50 @@ BMPwriteScanline(BMPWriter *bw) bw->yscan++; return BIR_OK; } - /* else write compressed */ -/* XXX need to do actual compression */ - return BIR_UNSUPPORTED; - /* write file length at end */ + /* + * RLE8 Encoding + * + * See the notes in BMPreadScanline() on this encoding. Needless + * to say, we avoid the nuttier aspects of this specification. + * We also assume that every scanline ends in a line break + * (0x0000) except for the last, which ends in a bitmap break + * (0x0001). We don't support RLE4 at all; it's too awkward. + */ + sp = (const int8 *)bw->scanline; + n = bw->hdr->width; + while (n > 0) { + int cnt, val; + cnt = findNextRun(sp, n); /* 0-255 < n */ + if (cnt >= 3) { /* output absolute */ + int skipOdd = cnt & 1; + wrbyte(0, bw); + wrbyte(cnt, bw); + n -= cnt; + while (cnt--) + wrbyte(*sp++, bw); + if (skipOdd) + wrbyte(0, bw); + } + if (n <= 0) /* was that it? */ + break; + val = *sp; /* output run */ + for (cnt = 1; --n && cnt < 255; cnt++) + if (*++sp != val) + break; + wrbyte(cnt, bw); + wrbyte(val, bw); + } + bw->yscan++; /* write line break or EOD */ if (bw->yscan == bw->hdr->height) { - if (bw->seek == NULL || (*bw->seek)(2, bw->c_data) != 0) - return BIR_SEEKERR; - bw->fpos = 2; - wrint32(bw->flen, bw); + wrbyte(0, bw); wrbyte(1, bw); /* end of bitmap marker */ + if (wrseek(2, bw) != BIR_OK) + return BIR_OK; /* no one may care */ + wrint32(bw->flen, bw); /* correct file length */ + if (wrseek(34, bw) != BIR_OK) + return BIR_OK; + wrint32(bw->flen-bw->fbmp, bw); /* correct bitmap length */ + } else { + wrbyte(0, bw); wrbyte(0, bw); /* end of line marker */ } return BIR_OK; }
