feat: Eliminated unneeded casts and made sure info field is nuls, initially
fix: added checks for stdio open errors
Minor fixes to comments
Fixed bug in run-length encoded write routine
Minor improvement in code clarity
make 64 bit MSC happy about shifting
there's a possible 32 bit shift / 64 bit coercion issue
Fixed complaint about signed vs. unsigned pointer
Fixed problem with 8-bit headers specifying zero length color maps
Fixed bug in header size computation related to color palette
Added #undef for getc/putc where they were being replaced
Moved declaration of magic to start of block (fixing compile error).
Added macros to avoid flockfile(3) overhead
Minor fix in writing of bitmap length
Reduced compiler warnings.
Minor code tweaks
Bug fixes in run-length encoding code
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
