root/radiance/ray/src/common/bmpfile.c
Revision: 2.18
Committed: Thu Jun 30 17:12:19 2016 UTC (8 years, 11 months ago) by greg
Minor improvement in code clarity
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.18 static const char RCSid[] = "$Id: bmpfile.c,v 2.17 2016/03/10 23:18:59 schorsch Exp $";
3 greg 2.1 #endif
4     /*
5     * Windows and OS/2 BMP file support
6     */
7
8     #include <stdio.h>
9     #include <stdlib.h>
10     #include <string.h>
11     #include "bmpfile.h"
12
13 greg 2.9 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
14 greg 2.12 #undef getc
15     #undef putc
16 greg 2.9 #define getc getc_unlocked
17     #define putc putc_unlocked
18     #endif
19
20 greg 2.1 /* get corresponding error message */
21     const char *
22     BMPerrorMessage(int ec)
23     {
24     switch (ec) {
25     case BIR_OK:
26     return "No error";
27     case BIR_EOF:
28     return "End of BMP image";
29     case BIR_TRUNCATED:
30     return "Truncated BMP image";
31     case BIR_UNSUPPORTED:
32     return "Unsupported BMP feature";
33 greg 2.3 case BIR_RLERROR:
34     return "BMP runlength encoding error";
35 greg 2.1 case BIR_SEEKERR:
36     return "BMP seek error";
37     }
38     return "Unknown BMP error";
39     }
40
41 greg 2.3 /* check than header is sensible */
42     static int
43     BMPheaderOK(const BMPHeader *hdr)
44     {
45     if (!hdr)
46     return 0;
47 schorsch 2.4 if ((hdr->width <= 0) | (hdr->height <= 0))
48 greg 2.3 return 0;
49     switch (hdr->bpp) { /* check compression */
50     case 1:
51     case 24:
52     if (hdr->compr != BI_UNCOMPR)
53     return 0;
54     break;
55     case 16:
56     case 32:
57 schorsch 2.4 if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_BITFIELDS))
58 greg 2.3 return 0;
59     break;
60     case 4:
61 schorsch 2.4 if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_RLE4))
62 greg 2.3 return 0;
63     break;
64     case 8:
65 schorsch 2.4 if ((hdr->compr != BI_UNCOMPR) & (hdr->compr != BI_RLE8))
66 greg 2.3 return 0;
67     break;
68     default:
69     return 0;
70     }
71     if (hdr->compr == BI_BITFIELDS && (BMPbitField(hdr)[0] &
72     BMPbitField(hdr)[1] & BMPbitField(hdr)[2]))
73     return 0;
74 greg 2.13 if (hdr->bpp > 8) {
75     if (hdr->nColors != 0)
76     return 0;
77     } else {
78     if ((hdr->nColors < 0) | (hdr->nColors > 1<<hdr->bpp))
79     return 0;
80     if ((hdr->impColors < 0) | (hdr->impColors > hdr->nColors))
81     return 0;
82     }
83 greg 2.3 return 1;
84     }
85 greg 2.1
86 greg 2.3 /* compute uncompressed scan size */
87 schorsch 2.4 #define getScanSiz(h) ( ((((h)->bpp*(h)->width+7) >>3) + 3) & ~03 )
88 greg 2.1
89     /* get next byte from reader */
90     #define rdbyte(c,br) ((br)->fpos += (c=(*(br)->cget)((br)->c_data))!=EOF, c)
91
92     /* read n bytes */
93     static int
94     rdbytes(char *bp, uint32 n, BMPReader *br)
95     {
96     int c;
97
98     while (n--) {
99     if (rdbyte(c, br) == EOF)
100     return BIR_TRUNCATED;
101     *bp++ = c;
102     }
103     return BIR_OK;
104     }
105
106     /* read 32-bit integer in littlendian order */
107     static int32
108     rdint32(BMPReader *br)
109     {
110     int32 i;
111     int c;
112
113     i = rdbyte(c, br);
114     i |= rdbyte(c, br) << 8;
115     i |= rdbyte(c, br) << 16;
116     i |= rdbyte(c, br) << 24;
117     return i; /* -1 on EOF */
118     }
119
120     /* read 16-bit unsigned integer in littlendian order */
121     static int
122     rduint16(BMPReader *br)
123     {
124     int i;
125     int c;
126
127     i = rdbyte(c, br);
128     i |= rdbyte(c, br) << 8;
129     return i; /* -1 on EOF */
130     }
131
132     /* seek on reader or return 0 (BIR_OK) on success */
133     static int
134     rdseek(uint32 pos, BMPReader *br)
135     {
136     if (pos == br->fpos)
137     return BIR_OK;
138     if (br->seek == NULL || (*br->seek)(pos, br->c_data) != 0)
139     return BIR_SEEKERR;
140     br->fpos = pos;
141     return BIR_OK;
142     }
143
144     /* open BMP stream for reading and get first scanline */
145     BMPReader *
146     BMPopenReader(int (*cget)(void *), int (*seek)(uint32, void *), void *c_data)
147     {
148     BMPReader *br;
149 greg 2.13 uint32 bmPos, hdrSiz, palSiz;
150     int magic[2]; /* check magic number */
151 greg 2.1
152     if (cget == NULL)
153     return NULL;
154     magic[0] = (*cget)(c_data);
155     if (magic[0] != 'B')
156     return NULL;
157     magic[1] = (*cget)(c_data);
158     if (magic[1] != 'M' && magic[1] != 'A')
159     return NULL;
160     br = (BMPReader *)calloc(1, sizeof(BMPReader));
161     if (br == NULL)
162     return NULL;
163     br->cget = cget;
164     br->seek = seek;
165     br->c_data = c_data;
166     br->hdr = (BMPHeader *)malloc(sizeof(BMPHeader));
167     if (br->hdr == NULL)
168     goto err;
169     br->fpos = 2;
170     /* read & verify file header */
171     (void)rdint32(br); /* file size */
172     (void)rdint32(br); /* reserved word */
173     bmPos = rdint32(br); /* offset to bitmap */
174 greg 2.3 hdrSiz = 2 + 3*4 + rdint32(br); /* header size */
175 greg 2.1 if (hdrSiz < 2 + 6*4 + 2*2 + 6*4)
176     goto err;
177     br->hdr->width = rdint32(br); /* bitmap width */
178     br->hdr->height = rdint32(br); /* bitmap height */
179 schorsch 2.2 if (((br->hdr->width <= 0) | (br->hdr->height == 0)))
180 greg 2.1 goto err;
181     if ((br->hdr->yIsDown = br->hdr->height < 0))
182     br->hdr->height = -br->hdr->height;
183     if (rduint16(br) != 1) /* number of planes */
184     goto err;
185     br->hdr->bpp = rduint16(br); /* bits per pixel */
186     br->hdr->compr = rdint32(br); /* compression mode */
187     (void)rdint32(br); /* bitmap size */
188     br->hdr->hRes = rdint32(br); /* horizontal resolution */
189     br->hdr->vRes = rdint32(br); /* vertical resolution */
190     br->hdr->nColors = rdint32(br); /* # colors used */
191 greg 2.14 if (!br->hdr->nColors && br->hdr->bpp <= 8)
192     br->hdr->nColors = 1<<br->hdr->bpp;
193 greg 2.1 br->hdr->impColors = rdint32(br); /* # important colors */
194     if (br->hdr->impColors < 0)
195     goto err; /* catch premature EOF */
196 greg 2.3 if (!BMPheaderOK(br->hdr))
197     goto err;
198 greg 2.13 palSiz = sizeof(RGBquad)*br->hdr->nColors;
199     if (br->hdr->impColors <= 0)
200     br->hdr->impColors = br->hdr->nColors;
201 greg 2.1 /* extend header */
202 greg 2.13 if (bmPos < hdrSiz + palSiz)
203 greg 2.1 goto err;
204 greg 2.13 br->hdr->infoSiz = bmPos - (hdrSiz + palSiz);
205     if (br->hdr->nColors > 0 || br->hdr->infoSiz > 0) {
206 greg 2.1 br->hdr = (BMPHeader *)realloc((void *)br->hdr,
207     sizeof(BMPHeader) +
208 greg 2.13 palSiz + br->hdr->infoSiz);
209 greg 2.1 if (br->hdr == NULL)
210     goto err;
211     }
212 greg 2.3 /* read colors or fields */
213     if (br->hdr->compr == BI_BITFIELDS) {
214     BMPbitField(br->hdr)[0] = (uint32)rdint32(br);
215     BMPbitField(br->hdr)[1] = (uint32)rdint32(br);
216     BMPbitField(br->hdr)[2] = (uint32)rdint32(br);
217 greg 2.13 } else if (rdbytes((char *)br->hdr->palette, palSiz, br) != BIR_OK)
218 greg 2.1 goto err;
219     /* read add'l information */
220     if (rdbytes(BMPinfo(br->hdr), br->hdr->infoSiz, br) != BIR_OK)
221     goto err;
222     /* read first scanline */
223     br->scanline = (uint8 *)calloc(getScanSiz(br->hdr), sizeof(uint8));
224     if (br->scanline == NULL)
225     goto err;
226     br->yscan = -1;
227 schorsch 2.4 if (seek != NULL && ((br->hdr->compr == BI_RLE8) |
228     (br->hdr->compr == BI_RLE4))) {
229 greg 2.1 BMPReader *newbr = (BMPReader *)realloc((void *)br,
230     sizeof(BMPReader) +
231     sizeof(br->scanpos[0]) *
232     br->hdr->height);
233     if (newbr == NULL)
234     goto err;
235     br = newbr;
236     memset((void *)(br->scanpos + 1), 0,
237     sizeof(br->scanpos[0])*br->hdr->height);
238     }
239     br->scanpos[0] = br->fpos;
240 greg 2.10 if (BMPreadScanline(br) == BIR_OK)
241     return br;
242 greg 2.1 err:
243     if (br->hdr != NULL)
244     free((void *)br->hdr);
245     if (br->scanline != NULL)
246     free((void *)br->scanline);
247     free((void *)br);
248     return NULL;
249     }
250
251     /* determine if image is grayscale */
252     int
253     BMPisGrayscale(const BMPHeader *hdr)
254     {
255     const RGBquad *rgbp;
256     int n;
257
258     if (hdr == NULL)
259     return -1;
260     if (hdr->bpp > 8) /* assume they had a reason for it */
261     return 0;
262 greg 2.14 for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++)
263     if ((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b))
264 greg 2.1 return 0;
265     return 1; /* all colors neutral in map */
266     }
267
268     /* read and decode next BMP scanline */
269     int
270     BMPreadScanline(BMPReader *br)
271     {
272 greg 2.3 int n;
273     int8 *sp;
274
275 greg 2.1 if (br->yscan + 1 >= br->hdr->height)
276     return BIR_EOF;
277     br->yscan++; /* prepare to read */
278 greg 2.3 n = getScanSiz(br->hdr); /* reading uncompressed data? */
279     if (br->hdr->compr == BI_UNCOMPR || br->hdr->compr == BI_BITFIELDS)
280     return rdbytes((char *)br->scanline, n, br);
281     /*
282 greg 2.10 * RLE4/RLE8 Decoding
283 greg 2.3 *
284     * Certain aspects of this scheme are completely insane, so
285     * we don't support them. Fortunately, they rarely appear.
286 greg 2.6 * One is the mid-file EOD (0x0001) and another is the ill-conceived
287 greg 2.3 * "delta" (0x0002), which is like a "goto" statement for bitmaps.
288 greg 2.10 * Whoever thought this up should be wrestled to the ground and told
289     * why it's impossible to support such a scheme in any reasonable way.
290 greg 2.3 * Also, RLE4 mode allows runs to stop halfway through a byte,
291     * which is likewise uncodeable, so we don't even try.
292     * Finally, the scanline break is ambiguous -- we assume here that
293     * it is required at the end of each scanline, though I haven't
294     * found anywhere this is written. Otherwise, we would read to
295     * the end of the scanline, assuming the next bit of data belongs
296     * the following scan. If a break follows the last pixel, as it
297     * seems to in the files I've tested out of Photoshop, you end up
298 greg 2.6 * painting every other line black. Also, I assume any skipped
299 greg 2.3 * pixels are painted with color 0, which is often black. Nowhere
300     * is it specified what we should assume for missing pixels. This
301     * is undoubtedly the most brain-dead format I've ever encountered.
302     */
303 greg 2.15 sp = (int8 *)br->scanline;
304 greg 2.10 n = br->hdr->width;
305     if (br->hdr->compr == BI_RLE4)
306     n = (n + 1) >> 1;
307 greg 2.3 while (n > 0) {
308     int skipOdd, len, val;
309
310     if (rdbyte(len, br) == EOF)
311     return BIR_TRUNCATED;
312     if (len > 0) { /* got a run */
313     if (br->hdr->compr == BI_RLE4) {
314     if (len & 1)
315     return BIR_UNSUPPORTED;
316     len >>= 1;
317     }
318     if (len > n)
319     return BIR_RLERROR;
320     if (rdbyte(val, br) == EOF)
321     return BIR_TRUNCATED;
322     n -= len;
323     while (len--)
324     *sp++ = val;
325     continue;
326     }
327 greg 2.10 /* check for escape */
328 greg 2.3 switch (rdbyte(len, br)) {
329     case EOF:
330     return BIR_TRUNCATED;
331     case 0: /* end of line */
332     while (n--)
333     *sp++ = 0;
334 greg 2.6 /* leaves n == -1 as flag for test after loop */
335 greg 2.3 continue;
336     case 1: /* end of bitmap */
337     case 2: /* delta */
338     return BIR_UNSUPPORTED;
339     }
340     /* absolute mode */
341     if (br->hdr->compr == BI_RLE4) {
342     if (len & 1)
343     return BIR_UNSUPPORTED;
344     len >>= 1;
345     }
346     skipOdd = len & 1;
347     if (len > n)
348     return BIR_RLERROR;
349     n -= len;
350     while (len--) {
351     if (rdbyte(val, br) == EOF)
352     return BIR_TRUNCATED;
353     *sp++ = val;
354     }
355     if (skipOdd && rdbyte(val, br) == EOF)
356     return BIR_TRUNCATED;
357     }
358     /* verify break at end of line */
359 greg 2.6 if (!n && (rdbyte(n, br) != 0 || (rdbyte(n, br) != 0 &&
360     (n != 1 || br->yscan != br->hdr->height-1))))
361 greg 2.3 return BIR_RLERROR;
362     if (br->seek != NULL) /* record next scanline position */
363 greg 2.1 br->scanpos[br->yscan + 1] = br->fpos;
364     return BIR_OK;
365     }
366
367     /* read a specific scanline */
368     int
369     BMPseekScanline(int y, BMPReader *br)
370     {
371     int rv;
372     /* check arguments */
373     if (br == NULL)
374     return BIR_EOF;
375     if (y < 0)
376     return BIR_SEEKERR;
377     if (y >= br->hdr->height)
378     return BIR_EOF;
379     /* already read? */
380     if (y == br->yscan)
381     return BIR_OK;
382     /* shall we seek? */
383     if (y != br->yscan + 1 && br->seek != NULL) {
384     int yseek;
385     uint32 seekp;
386 greg 2.3 if (br->hdr->compr == BI_UNCOMPR ||
387     br->hdr->compr == BI_BITFIELDS) {
388 greg 2.1 yseek = y;
389     seekp = br->scanpos[0] + y*getScanSiz(br->hdr);
390     } else {
391     yseek = br->yscan + 1;
392     while (yseek < y && br->scanpos[yseek+1] != 0)
393     ++yseek;
394     if (y < yseek && br->scanpos[yseek=y] == 0)
395     return BIR_SEEKERR;
396     seekp = br->scanpos[yseek];
397     }
398     if ((rv = rdseek(seekp, br)) != BIR_OK)
399     return rv;
400     br->yscan = yseek - 1;
401     } else if (y < br->yscan) /* else we can't back up */
402     return BIR_SEEKERR;
403     /* read until we get there */
404     while (br->yscan < y)
405     if ((rv = BMPreadScanline(br)) != BIR_OK)
406     return rv;
407     return BIR_OK;
408     }
409
410     /* get ith pixel from last scanline */
411     RGBquad
412 greg 2.3 BMPdecodePixel(int i, const BMPReader *br)
413 greg 2.1 {
414 greg 2.3 static const uint32 std16mask[3] = {0x7c00, 0x3e0, 0x1f};
415 greg 2.1 static const RGBquad black = {0, 0, 0, 0};
416 greg 2.3 const uint32 *mask;
417     const uint8 *pp;
418     uint32 pval, v;
419     RGBquad cval;
420 greg 2.1
421 schorsch 2.2 if (((br == NULL) | (i < 0)) || i >= br->hdr->width)
422 greg 2.1 return black;
423
424 greg 2.3 cval.padding = 0;
425
426 greg 2.1 switch (br->hdr->bpp) {
427 greg 2.3 case 24:
428     pp = br->scanline + 3*i;
429     cval.b = *pp++;
430     cval.g = *pp++;
431     cval.r = *pp;
432 greg 2.1 return cval;
433     case 32:
434 greg 2.3 if (br->hdr->compr == BI_UNCOMPR)
435     return ((RGBquad *)br->scanline)[i];
436     /* convert bit fields */
437     pp = br->scanline + 4*i;
438     pval = *pp++;
439     pval |= *pp++ << 8;
440     pval |= *pp++ << 16;
441     pval |= *pp << 24;
442     mask = BMPbitField(br->hdr);
443     v = pval & mask[0];
444     while (v & ~0xff) v >>= 8;
445     cval.r = v;
446     v = pval & mask[1];
447     while (v & ~0xff) v >>= 8;
448     cval.g = v;
449     v = pval & mask[2];
450     while (v & ~0xff) v >>= 8;
451     cval.b = v;
452     return cval;
453 greg 2.1 case 8:
454     return br->hdr->palette[br->scanline[i]];
455     case 1:
456 greg 2.18 return br->hdr->palette[br->scanline[i>>3]>>(7-(i&7)) & 1];
457 greg 2.1 case 4:
458 greg 2.3 return br->hdr->palette[br->scanline[i>>1]>>(i&1?4:0) & 0xf];
459     case 16:
460     pp = br->scanline + 2*i;
461     pval = *pp++;
462     pval |= *pp++ << 8;
463     mask = std16mask;
464     if (br->hdr->compr == BI_BITFIELDS)
465     mask = BMPbitField(br->hdr);
466     cval.r = ((pval & mask[0]) << 8) / (mask[0] + 1);
467     cval.g = ((pval & mask[1]) << 8) / (mask[1] + 1);
468     cval.b = ((pval & mask[2]) << 8) / (mask[2] + 1);
469     return cval;
470 greg 2.1 }
471     return black; /* should never happen */
472     }
473
474     /* free BMP reader resources */
475     void
476     BMPfreeReader(BMPReader *br)
477     {
478     if (br == NULL)
479     return;
480     free((void *)br->hdr);
481     free((void *)br->scanline);
482     free((void *)br);
483     }
484
485     /* stdio getc() callback */
486     int
487     stdio_getc(void *p)
488     {
489     if (!p)
490     return EOF;
491     return getc((FILE *)p);
492     }
493
494     /* stdio putc() callback */
495     void
496     stdio_putc(int c, void *p)
497     {
498     if (p)
499     putc(c, (FILE *)p);
500     }
501
502     /* stdio fseek() callback */
503     int
504     stdio_fseek(uint32 pos, void *p)
505     {
506     if (!p)
507     return -1;
508     return fseek((FILE *)p, (long)pos, 0);
509     }
510
511     /* allocate uncompressed (24-bit) RGB header */
512     BMPHeader *
513     BMPtruecolorHeader(int xr, int yr, int infolen)
514     {
515     BMPHeader *hdr;
516
517     if (xr <= 0 || yr <= 0 || infolen < 0)
518     return NULL;
519     hdr = (BMPHeader *)malloc(sizeof(BMPHeader) - sizeof(hdr->palette) +
520     infolen);
521     if (hdr == NULL)
522     return NULL;
523     hdr->width = xr;
524     hdr->height = yr;
525     hdr->yIsDown = 0; /* default to upwards order */
526     hdr->bpp = 24;
527     hdr->compr = BI_UNCOMPR;
528     hdr->hRes = hdr->vRes = 2835; /* default to 72 ppi */
529     hdr->nColors = hdr->impColors = 0;
530     hdr->infoSiz = infolen;
531     return hdr;
532     }
533
534 greg 2.5 /* allocate color-mapped header (defaults to minimal grayscale) */
535 greg 2.1 BMPHeader *
536     BMPmappedHeader(int xr, int yr, int infolen, int ncolors)
537     {
538     int n;
539     BMPHeader *hdr;
540
541     if (xr <= 0 || yr <= 0 || infolen < 0 || ncolors < 2)
542     return NULL;
543     if (ncolors <= 2)
544     n = 1;
545     else if (ncolors <= 16)
546     n = 4;
547     else if (ncolors <= 256)
548     n = 8;
549     else
550     return NULL;
551     hdr = (BMPHeader *)malloc(sizeof(BMPHeader) +
552 schorsch 2.17 sizeof(RGBquad)*((size_t)1<<n) -
553 greg 2.1 sizeof(hdr->palette) +
554     infolen);
555     if (hdr == NULL)
556     return NULL;
557     hdr->width = xr;
558     hdr->height = yr;
559     hdr->yIsDown = 0; /* default to upwards order */
560     hdr->bpp = n;
561 greg 2.5 hdr->compr = BI_UNCOMPR; /* compression needs seek */
562 greg 2.1 hdr->hRes = hdr->vRes = 2835; /* default to 72 ppi */
563     hdr->nColors = ncolors;
564     hdr->impColors = 0; /* says all colors important */
565     hdr->infoSiz = infolen;
566 schorsch 2.17 memset((void *)hdr->palette, 0, sizeof(RGBquad)*((size_t)1<<n) + infolen);
567 greg 2.1 for (n = ncolors; n--; )
568     hdr->palette[n].r = hdr->palette[n].g =
569     hdr->palette[n].b = n*255/(ncolors-1);
570     return hdr;
571     }
572
573     /* put byte to writer */
574     #define wrbyte(c,bw) ( (*(bw)->cput)(c,(bw)->c_data), \
575 greg 2.3 ++(bw)->fpos > (bw)->flen ? \
576 greg 2.1 ((bw)->flen = (bw)->fpos) : \
577     (bw)->fpos )
578
579     /* write out a string of bytes */
580     static void
581     wrbytes(char *bp, uint32 n, BMPWriter *bw)
582     {
583     while (n--)
584     wrbyte(*bp++, bw);
585     }
586
587     /* write 32-bit integer in littlendian order */
588     static void
589     wrint32(int32 i, BMPWriter *bw)
590     {
591     wrbyte(i& 0xff, bw);
592     wrbyte(i>>8 & 0xff, bw);
593     wrbyte(i>>16 & 0xff, bw);
594 greg 2.3 wrbyte(i>>24 & 0xff, bw);
595 greg 2.1 }
596
597     /* write 16-bit unsigned integer in littlendian order */
598     static void
599     wruint16(uint16 ui, BMPWriter *bw)
600     {
601     wrbyte(ui & 0xff, bw);
602     wrbyte(ui>>8 & 0xff, bw);
603     }
604
605     /* seek to the specified file position, returning 0 (BIR_OK) on success */
606     static int
607     wrseek(uint32 pos, BMPWriter *bw)
608     {
609     if (pos == bw->fpos)
610     return BIR_OK;
611 greg 2.8 if (bw->seek == NULL)
612     return BIR_SEEKERR;
613 greg 2.1 if ((*bw->seek)(pos, bw->c_data) != 0)
614     return BIR_SEEKERR;
615     bw->fpos = pos;
616     if (pos > bw->flen)
617     bw->flen = pos;
618     return BIR_OK;
619     }
620
621     /* open BMP stream for writing */
622     BMPWriter *
623     BMPopenWriter(void (*cput)(int, void *), int (*seek)(uint32, void *),
624     void *c_data, BMPHeader *hdr)
625     {
626     BMPWriter *bw;
627     uint32 hdrSiz, palSiz, scanSiz, bmSiz;
628     /* check arguments */
629 greg 2.3 if (cput == NULL)
630 greg 2.1 return NULL;
631 greg 2.3 if (!BMPheaderOK(hdr))
632 greg 2.1 return NULL;
633 schorsch 2.4 if ((hdr->bpp == 16) | (hdr->compr == BI_RLE4))
634 greg 2.1 return NULL; /* unsupported */
635 greg 2.5 /* no seek means we may have the wrong file length, but most app's don't care
636 schorsch 2.4 if (seek == NULL && ((hdr->compr == BI_RLE8) | (hdr->compr == BI_RLE4)))
637 greg 2.1 return NULL;
638 greg 2.5 */
639 greg 2.1 /* compute sizes */
640     hdrSiz = 2 + 6*4 + 2*2 + 6*4;
641 greg 2.3 if (hdr->compr == BI_BITFIELDS)
642     hdrSiz += sizeof(uint32)*3;
643 greg 2.13 palSiz = sizeof(RGBquad)*hdr->nColors;
644 greg 2.1 scanSiz = getScanSiz(hdr);
645     bmSiz = hdr->height*scanSiz; /* wrong if compressed */
646     /* initialize writer */
647     bw = (BMPWriter *)malloc(sizeof(BMPWriter));
648     if (bw == NULL)
649     return NULL;
650     bw->hdr = hdr;
651     bw->yscan = 0;
652     bw->scanline = (uint8 *)calloc(scanSiz, sizeof(uint8));
653     if (bw->scanline == NULL) {
654     free((void *)bw);
655     return NULL;
656     }
657     bw->fbmp = hdrSiz + palSiz + hdr->infoSiz;
658     bw->fpos = bw->flen = 0;
659     bw->cput = cput;
660     bw->seek = seek;
661     bw->c_data = c_data;
662     /* write out header */
663     wrbyte('B', bw); wrbyte('M', bw); /* magic number */
664     wrint32(bw->fbmp + bmSiz, bw); /* file size */
665     wrint32(0, bw); /* reserved word */
666     wrint32(bw->fbmp, bw); /* offset to bitmap */
667     wrint32(hdrSiz - bw->fpos, bw); /* info header size */
668     wrint32(hdr->width, bw); /* bitmap width */
669     if (hdr->yIsDown) /* bitmap height */
670     wrint32(-hdr->height, bw);
671     else
672     wrint32(hdr->height, bw);
673     wruint16(1, bw); /* number of planes */
674     wruint16(hdr->bpp, bw); /* bits per pixel */
675     wrint32(hdr->compr, bw); /* compression mode */
676     wrint32(bmSiz, bw); /* bitmap size */
677     wrint32(hdr->hRes, bw); /* horizontal resolution */
678     wrint32(hdr->vRes, bw); /* vertical resolution */
679     wrint32(hdr->nColors, bw); /* # colors used */
680     wrint32(hdr->impColors, bw); /* # important colors */
681     /* write out color palette */
682     wrbytes((char *)hdr->palette, palSiz, bw);
683     /* write add'l information */
684     wrbytes(BMPinfo(hdr), hdr->infoSiz, bw);
685     #ifndef NDEBUG
686     if (bw->fpos != bw->fbmp) {
687     fputs("Coding error 1 in BMPopenWriter\n", stderr);
688     exit(1);
689     }
690     #endif
691     return bw;
692     }
693 greg 2.3
694     /* find position of next run of 5 or more identical bytes, or 255 if none */
695     static int
696     findNextRun(const int8 *bp, int len)
697     {
698     int pos, cnt;
699     /* look for run */
700 schorsch 2.4 for (pos = 0; (len > 0) & (pos < 255); pos++, bp++, len--) {
701 greg 2.3 if (len < 5) /* no hope left? */
702     continue;
703     cnt = 1; /* else let's try it */
704     while (bp[cnt] == bp[0])
705 greg 2.5 if (++cnt >= 5)
706     return pos; /* long enough */
707 greg 2.3 }
708     return pos; /* didn't find any */
709     }
710 greg 2.1
711     /* write the current scanline */
712     int
713     BMPwriteScanline(BMPWriter *bw)
714     {
715 greg 2.3 const int8 *sp;
716     int n;
717
718 greg 2.1 if (bw->yscan >= bw->hdr->height)
719     return BIR_EOF;
720     /* writing uncompressed? */
721 greg 2.3 if (bw->hdr->compr == BI_UNCOMPR || bw->hdr->compr == BI_BITFIELDS) {
722 greg 2.1 uint32 scanSiz = getScanSiz(bw->hdr);
723     uint32 slpos = bw->fbmp + bw->yscan*scanSiz;
724     if (wrseek(slpos, bw) != BIR_OK)
725     return BIR_SEEKERR;
726     wrbytes((char *)bw->scanline, scanSiz, bw);
727     bw->yscan++;
728     return BIR_OK;
729     }
730 greg 2.3 /*
731     * RLE8 Encoding
732     *
733     * See the notes in BMPreadScanline() on this encoding. Needless
734     * to say, we avoid the nuttier aspects of this specification.
735     * We also assume that every scanline ends in a line break
736     * (0x0000) except for the last, which ends in a bitmap break
737     * (0x0001). We don't support RLE4 at all; it's too awkward.
738     */
739 greg 2.15 sp = (const int8 *)bw->scanline;
740 greg 2.3 n = bw->hdr->width;
741     while (n > 0) {
742     int cnt, val;
743     cnt = findNextRun(sp, n); /* 0-255 < n */
744 greg 2.10 if (cnt >= 3) { /* output absolute */
745 greg 2.3 int skipOdd = cnt & 1;
746     wrbyte(0, bw);
747     wrbyte(cnt, bw);
748     n -= cnt;
749     while (cnt--)
750     wrbyte(*sp++, bw);
751     if (skipOdd)
752     wrbyte(0, bw);
753     }
754     if (n <= 0) /* was that it? */
755     break;
756     val = *sp; /* output run */
757 greg 2.10 for (cnt = 1; --n && cnt < 255; cnt++)
758     if (*++sp != val)
759 greg 2.5 break;
760 greg 2.3 wrbyte(cnt, bw);
761     wrbyte(val, bw);
762     }
763 greg 2.5 bw->yscan++; /* write line break or EOD */
764 greg 2.1 if (bw->yscan == bw->hdr->height) {
765 greg 2.3 wrbyte(0, bw); wrbyte(1, bw); /* end of bitmap marker */
766 greg 2.8 if (wrseek(2, bw) != BIR_OK)
767 greg 2.5 return BIR_OK; /* no one may care */
768 greg 2.8 wrint32(bw->flen, bw); /* correct file length */
769     if (wrseek(34, bw) != BIR_OK)
770     return BIR_OK;
771 greg 2.6 wrint32(bw->flen-bw->fbmp, bw); /* correct bitmap length */
772 greg 2.3 } else {
773     wrbyte(0, bw); wrbyte(0, bw); /* end of line marker */
774 greg 2.1 }
775     return BIR_OK;
776     }
777
778     /* free BMP writer resources */
779     void
780     BMPfreeWriter(BMPWriter *bw)
781     {
782     if (bw == NULL)
783     return;
784     free((void *)bw->hdr);
785     free((void *)bw->scanline);
786     free((void *)bw);
787     }
