1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Windows and OS/2 BMP file support |
6 |
7 |
8 |
/* XXX reading and writing of compressed files currently unsupported */ |
9 |
10 |
#include <stdio.h> |
11 |
#include <stdlib.h> |
12 |
#include <string.h> |
13 |
#include "bmpfile.h" |
14 |
15 |
/* get corresponding error message */ |
16 |
const char * |
17 |
BMPerrorMessage(int ec) |
18 |
19 |
switch (ec) { |
20 |
case BIR_OK: |
21 |
return "No error"; |
22 |
case BIR_EOF: |
23 |
return "End of BMP image"; |
24 |
case BIR_TRUNCATED: |
25 |
return "Truncated BMP image"; |
26 |
case BIR_UNSUPPORTED: |
27 |
return "Unsupported BMP feature"; |
28 |
case BIR_SEEKERR: |
29 |
return "BMP seek error"; |
30 |
31 |
return "Unknown BMP error"; |
32 |
33 |
34 |
/* compute uncompressed scanline size */ |
35 |
static uint32 |
36 |
getScanSiz(BMPHeader *hdr) |
37 |
38 |
uint32 scanSiz; |
39 |
/* bytes per scanline */ |
40 |
scanSiz = (hdr->bpp*hdr->width + 7) >> 3; |
41 |
if (scanSiz & 3) /* 32-bit word boundary */ |
42 |
scanSiz += 4 - (scanSiz & 3); |
43 |
44 |
return scanSiz; |
45 |
46 |
47 |
/* get next byte from reader */ |
48 |
#define rdbyte(c,br) ((br)->fpos += (c=(*(br)->cget)((br)->c_data))!=EOF, c) |
49 |
50 |
/* read n bytes */ |
51 |
static int |
52 |
rdbytes(char *bp, uint32 n, BMPReader *br) |
53 |
54 |
int c; |
55 |
56 |
while (n--) { |
57 |
if (rdbyte(c, br) == EOF) |
58 |
return BIR_TRUNCATED; |
59 |
*bp++ = c; |
60 |
61 |
return BIR_OK; |
62 |
63 |
64 |
/* read 32-bit integer in littlendian order */ |
65 |
static int32 |
66 |
rdint32(BMPReader *br) |
67 |
68 |
int32 i; |
69 |
int c; |
70 |
71 |
i = rdbyte(c, br); |
72 |
i |= rdbyte(c, br) << 8; |
73 |
i |= rdbyte(c, br) << 16; |
74 |
i |= rdbyte(c, br) << 24; |
75 |
return i; /* -1 on EOF */ |
76 |
77 |
78 |
/* read 16-bit unsigned integer in littlendian order */ |
79 |
static int |
80 |
rduint16(BMPReader *br) |
81 |
82 |
int i; |
83 |
int c; |
84 |
85 |
86 |
87 |
88 |
89 |
90 |
/* seek on reader or return 0 (BIR_OK) on success */ |
91 |
static int |
92 |
rdseek(uint32 pos, BMPReader *br) |
93 |
94 |
if (pos == br->fpos) |
95 |
return BIR_OK; |
96 |
if (br->seek == NULL || (*br->seek)(pos, br->c_data) != 0) |
97 |
return BIR_SEEKERR; |
98 |
br->fpos = pos; |
99 |
return BIR_OK; |
100 |
101 |
102 |
/* open BMP stream for reading and get first scanline */ |
103 |
BMPReader * |
104 |
BMPopenReader(int (*cget)(void *), int (*seek)(uint32, void *), void *c_data) |
105 |
106 |
BMPReader *br; |
107 |
uint32 bmPos, hdrSiz; |
108 |
int palLen; |
109 |
110 |
if (cget == NULL) |
111 |
return NULL; |
112 |
int magic[2]; /* check magic number */ |
113 |
magic[0] = (*cget)(c_data); |
114 |
if (magic[0] != 'B') |
115 |
return NULL; |
116 |
magic[1] = (*cget)(c_data); |
117 |
if (magic[1] != 'M' && magic[1] != 'A') |
118 |
return NULL; |
119 |
br = (BMPReader *)calloc(1, sizeof(BMPReader)); |
120 |
if (br == NULL) |
121 |
return NULL; |
122 |
br->cget = cget; |
123 |
br->seek = seek; |
124 |
br->c_data = c_data; |
125 |
br->hdr = (BMPHeader *)malloc(sizeof(BMPHeader)); |
126 |
if (br->hdr == NULL) |
127 |
goto err; |
128 |
br->fpos = 2; |
129 |
/* read & verify file header */ |
130 |
(void)rdint32(br); /* file size */ |
131 |
(void)rdint32(br); /* reserved word */ |
132 |
bmPos = rdint32(br); /* offset to bitmap */ |
133 |
hdrSiz = rdint32(br) + 14; /* header size */ |
134 |
if (hdrSiz < 2 + 6*4 + 2*2 + 6*4) |
135 |
goto err; |
136 |
br->hdr->width = rdint32(br); /* bitmap width */ |
137 |
br->hdr->height = rdint32(br); /* bitmap height */ |
138 |
if ((br->hdr->width <= 0 | br->hdr->height == 0)) |
139 |
goto err; |
140 |
if ((br->hdr->yIsDown = br->hdr->height < 0)) |
141 |
br->hdr->height = -br->hdr->height; |
142 |
if (rduint16(br) != 1) /* number of planes */ |
143 |
goto err; |
144 |
br->hdr->bpp = rduint16(br); /* bits per pixel */ |
145 |
if (br->hdr->bpp != 1 && br->hdr->bpp != 4 && |
146 |
br->hdr->bpp != 8 && br->hdr->bpp != 24 && |
147 |
br->hdr->bpp != 32) |
148 |
goto err; |
149 |
br->hdr->compr = rdint32(br); /* compression mode */ |
150 |
if (br->hdr->compr != BI_UNCOMPR && br->hdr->compr != BI_RLE8) |
151 |
goto err; /* don't support the rest */ |
152 |
(void)rdint32(br); /* bitmap size */ |
153 |
br->hdr->hRes = rdint32(br); /* horizontal resolution */ |
154 |
br->hdr->vRes = rdint32(br); /* vertical resolution */ |
155 |
br->hdr->nColors = rdint32(br); /* # colors used */ |
156 |
br->hdr->impColors = rdint32(br); /* # important colors */ |
157 |
if (br->hdr->impColors < 0) |
158 |
goto err; /* catch premature EOF */ |
159 |
palLen = 0; |
160 |
if (br->hdr->bpp <= 8) { |
161 |
palLen = 1 << br->hdr->bpp; |
162 |
if (br->hdr->nColors <= 0) |
163 |
br->hdr->nColors = palLen; |
164 |
else if (br->hdr->nColors > palLen) |
165 |
goto err; |
166 |
if (br->hdr->impColors <= 0) |
167 |
br->hdr->impColors = br->hdr->nColors; |
168 |
else if (br->hdr->impColors > br->hdr->nColors) |
169 |
goto err; |
170 |
} else if (br->hdr->nColors > 0 || br->hdr->compr != BI_UNCOMPR) |
171 |
goto err; |
172 |
/* extend header */ |
173 |
if (bmPos < hdrSiz + sizeof(RGBquad)*palLen) |
174 |
goto err; |
175 |
br->hdr->infoSiz = bmPos - (hdrSiz + sizeof(RGBquad)*palLen); |
176 |
if (palLen > 0 || br->hdr->infoSiz > 0) { |
177 |
br->hdr = (BMPHeader *)realloc((void *)br->hdr, |
178 |
sizeof(BMPHeader) + |
179 |
sizeof(RGBquad)*palLen - |
180 |
sizeof(br->hdr->palette) + |
181 |
br->hdr->infoSiz); |
182 |
183 |
goto err; |
184 |
185 |
/* read color palette */ |
186 |
if (rdbytes((char *)br->hdr->palette, |
187 |
sizeof(RGBquad)*palLen, br) != BIR_OK) |
188 |
goto err; |
189 |
/* read add'l information */ |
190 |
if (rdbytes(BMPinfo(br->hdr), br->hdr->infoSiz, br) != BIR_OK) |
191 |
goto err; |
192 |
/* read first scanline */ |
193 |
br->scanline = (uint8 *)calloc(getScanSiz(br->hdr), sizeof(uint8)); |
194 |
if (br->scanline == NULL) |
195 |
goto err; |
196 |
br->yscan = -1; |
197 |
if (seek != NULL && br->hdr->compr != BI_UNCOMPR) { |
198 |
BMPReader *newbr = (BMPReader *)realloc((void *)br, |
199 |
sizeof(BMPReader) + |
200 |
sizeof(br->scanpos[0]) * |
201 |
br->hdr->height); |
202 |
if (newbr == NULL) |
203 |
goto err; |
204 |
br = newbr; |
205 |
memset((void *)(br->scanpos + 1), 0, |
206 |
sizeof(br->scanpos[0])*br->hdr->height); |
207 |
208 |
br->scanpos[0] = br->fpos; |
209 |
if (BMPreadScanline(br) != BIR_OK) |
210 |
goto err; |
211 |
return br; |
212 |
err: |
213 |
if (br->hdr != NULL) |
214 |
free((void *)br->hdr); |
215 |
if (br->scanline != NULL) |
216 |
free((void *)br->scanline); |
217 |
free((void *)br); |
218 |
return NULL; |
219 |
220 |
221 |
/* determine if image is grayscale */ |
222 |
int |
223 |
BMPisGrayscale(const BMPHeader *hdr) |
224 |
225 |
const RGBquad *rgbp; |
226 |
int n; |
227 |
228 |
if (hdr == NULL) |
229 |
return -1; |
230 |
if (hdr->bpp > 8) /* assume they had a reason for it */ |
231 |
return 0; |
232 |
for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++) |
233 |
if ((rgbp->r != rgbp->g | rgbp->g != rgbp->b)) |
234 |
return 0; |
235 |
return 1; /* all colors neutral in map */ |
236 |
237 |
238 |
/* read and decode next BMP scanline */ |
239 |
int |
240 |
BMPreadScanline(BMPReader *br) |
241 |
242 |
if (br->yscan + 1 >= br->hdr->height) |
243 |
return BIR_EOF; |
244 |
br->yscan++; /* prepare to read */ |
245 |
if (br->hdr->compr == BI_UNCOMPR) |
246 |
return rdbytes((char *)br->scanline, getScanSiz(br->hdr), br); |
247 |
/* XXX need to perform actual decompression */ |
248 |
return BIR_UNSUPPORTED; |
249 |
if (br->seek != NULL) |
250 |
br->scanpos[br->yscan + 1] = br->fpos; |
251 |
return BIR_OK; |
252 |
253 |
254 |
/* read a specific scanline */ |
255 |
int |
256 |
BMPseekScanline(int y, BMPReader *br) |
257 |
258 |
int rv; |
259 |
/* check arguments */ |
260 |
if (br == NULL) |
261 |
return BIR_EOF; |
262 |
if (y < 0) |
263 |
264 |
if (y >= br->hdr->height) |
265 |
return BIR_EOF; |
266 |
/* already read? */ |
267 |
if (y == br->yscan) |
268 |
return BIR_OK; |
269 |
/* shall we seek? */ |
270 |
if (y != br->yscan + 1 && br->seek != NULL) { |
271 |
int yseek; |
272 |
uint32 seekp; |
273 |
if (br->hdr->compr == BI_UNCOMPR) { |
274 |
yseek = y; |
275 |
seekp = br->scanpos[0] + y*getScanSiz(br->hdr); |
276 |
} else { |
277 |
yseek = br->yscan + 1; |
278 |
while (yseek < y && br->scanpos[yseek+1] != 0) |
279 |
++yseek; |
280 |
if (y < yseek && br->scanpos[yseek=y] == 0) |
281 |
282 |
seekp = br->scanpos[yseek]; |
283 |
284 |
if ((rv = rdseek(seekp, br)) != BIR_OK) |
285 |
return rv; |
286 |
br->yscan = yseek - 1; |
287 |
} else if (y < br->yscan) /* else we can't back up */ |
288 |
289 |
/* read until we get there */ |
290 |
while (br->yscan < y) |
291 |
if ((rv = BMPreadScanline(br)) != BIR_OK) |
292 |
return rv; |
293 |
return BIR_OK; |
294 |
295 |
296 |
/* get ith pixel from last scanline */ |
297 |
RGBquad |
298 |
BMPdecodePixel(int i, BMPReader *br) |
299 |
300 |
static const RGBquad black = {0, 0, 0, 0}; |
301 |
302 |
if ((br == NULL | i < 0) || i >= br->hdr->width) |
303 |
return black; |
304 |
305 |
switch (br->hdr->bpp) { |
306 |
case 24: { |
307 |
uint8 *bgr = br->scanline + 3*i; |
308 |
RGBquad cval; |
309 |
cval.b = bgr[0]; cval.g = bgr[1]; cval.r = bgr[2]; |
310 |
cval.padding = 0; |
311 |
return cval; |
312 |
313 |
case 32: |
314 |
return ((RGBquad *)br->scanline)[i]; |
315 |
case 8: |
316 |
return br->hdr->palette[br->scanline[i]]; |
317 |
case 1: |
318 |
return br->hdr->palette[br->scanline[i>>3]>>(i&7) & 1]; |
319 |
case 4: |
320 |
return br->hdr->palette[br->scanline[i>>1]>>((i&1)<<2) & 0xf]; |
321 |
322 |
return black; /* should never happen */ |
323 |
324 |
325 |
/* free BMP reader resources */ |
326 |
void |
327 |
BMPfreeReader(BMPReader *br) |
328 |
329 |
if (br == NULL) |
330 |
return; |
331 |
332 |
333 |
free((void *)br); |
334 |
335 |
336 |
/* stdio getc() callback */ |
337 |
int |
338 |
stdio_getc(void *p) |
339 |
340 |
if (!p) |
341 |
return EOF; |
342 |
return getc((FILE *)p); |
343 |
344 |
345 |
/* stdio putc() callback */ |
346 |
void |
347 |
stdio_putc(int c, void *p) |
348 |
349 |
if (p) |
350 |
putc(c, (FILE *)p); |
351 |
352 |
353 |
/* stdio fseek() callback */ |
354 |
int |
355 |
stdio_fseek(uint32 pos, void *p) |
356 |
357 |
if (!p) |
358 |
return -1; |
359 |
return fseek((FILE *)p, (long)pos, 0); |
360 |
361 |
362 |
/* allocate uncompressed (24-bit) RGB header */ |
363 |
BMPHeader * |
364 |
BMPtruecolorHeader(int xr, int yr, int infolen) |
365 |
366 |
BMPHeader *hdr; |
367 |
368 |
if (xr <= 0 || yr <= 0 || infolen < 0) |
369 |
return NULL; |
370 |
hdr = (BMPHeader *)malloc(sizeof(BMPHeader) - sizeof(hdr->palette) + |
371 |
infolen); |
372 |
if (hdr == NULL) |
373 |
return NULL; |
374 |
hdr->width = xr; |
375 |
hdr->height = yr; |
376 |
hdr->yIsDown = 0; /* default to upwards order */ |
377 |
hdr->bpp = 24; |
378 |
hdr->compr = BI_UNCOMPR; |
379 |
hdr->hRes = hdr->vRes = 2835; /* default to 72 ppi */ |
380 |
hdr->nColors = hdr->impColors = 0; |
381 |
hdr->infoSiz = infolen; |
382 |
return hdr; |
383 |
384 |
385 |
/* allocate color-mapped header (defaults to minimal grayscale) */ |
386 |
BMPHeader * |
387 |
BMPmappedHeader(int xr, int yr, int infolen, int ncolors) |
388 |
389 |
int n; |
390 |
BMPHeader *hdr; |
391 |
392 |
if (xr <= 0 || yr <= 0 || infolen < 0 || ncolors < 2) |
393 |
return NULL; |
394 |
if (ncolors <= 2) |
395 |
n = 1; |
396 |
else if (ncolors <= 16) |
397 |
n = 4; |
398 |
else if (ncolors <= 256) |
399 |
n = 8; |
400 |
else |
401 |
return NULL; |
402 |
hdr = (BMPHeader *)malloc(sizeof(BMPHeader) + |
403 |
sizeof(RGBquad)*(1<<n) - |
404 |
405 |
infolen); |
406 |
if (hdr == NULL) |
407 |
return NULL; |
408 |
hdr->width = xr; |
409 |
hdr->height = yr; |
410 |
411 |
hdr->bpp = n; |
412 |
413 |
414 |
hdr->nColors = ncolors; |
415 |
hdr->impColors = 0; /* says all colors important */ |
416 |
417 |
memset((void *)hdr->palette, 0, sizeof(RGBquad)*(1<<n) + infolen); |
418 |
for (n = ncolors; n--; ) |
419 |
hdr->palette[n].r = hdr->palette[n].g = |
420 |
hdr->palette[n].b = n*255/(ncolors-1); |
421 |
return hdr; |
422 |
423 |
424 |
/* put byte to writer */ |
425 |
#define wrbyte(c,bw) ( (*(bw)->cput)(c,(bw)->c_data), \ |
426 |
++((bw)->fpos) > (bw)->flen ? \ |
427 |
((bw)->flen = (bw)->fpos) : \ |
428 |
(bw)->fpos ) |
429 |
430 |
/* write out a string of bytes */ |
431 |
static void |
432 |
wrbytes(char *bp, uint32 n, BMPWriter *bw) |
433 |
434 |
while (n--) |
435 |
wrbyte(*bp++, bw); |
436 |
437 |
438 |
/* write 32-bit integer in littlendian order */ |
439 |
static void |
440 |
wrint32(int32 i, BMPWriter *bw) |
441 |
442 |
wrbyte(i& 0xff, bw); |
443 |
wrbyte(i>>8 & 0xff, bw); |
444 |
wrbyte(i>>16 & 0xff, bw); |
445 |
wrbyte(i>>24 & 0xff, bw); |
446 |
447 |
448 |
/* write 16-bit unsigned integer in littlendian order */ |
449 |
static void |
450 |
wruint16(uint16 ui, BMPWriter *bw) |
451 |
452 |
wrbyte(ui & 0xff, bw); |
453 |
wrbyte(ui>>8 & 0xff, bw); |
454 |
455 |
456 |
/* seek to the specified file position, returning 0 (BIR_OK) on success */ |
457 |
static int |
458 |
wrseek(uint32 pos, BMPWriter *bw) |
459 |
460 |
if (pos == bw->fpos) |
461 |
return BIR_OK; |
462 |
if (bw->seek == NULL) { |
463 |
if (pos < bw->fpos) |
464 |
465 |
while (bw->fpos < pos) |
466 |
wrbyte(0, bw); |
467 |
return BIR_OK; |
468 |
469 |
if ((*bw->seek)(pos, bw->c_data) != 0) |
470 |
471 |
bw->fpos = pos; |
472 |
if (pos > bw->flen) |
473 |
bw->flen = pos; |
474 |
return BIR_OK; |
475 |
476 |
477 |
/* open BMP stream for writing */ |
478 |
BMPWriter * |
479 |
BMPopenWriter(void (*cput)(int, void *), int (*seek)(uint32, void *), |
480 |
void *c_data, BMPHeader *hdr) |
481 |
482 |
BMPWriter *bw; |
483 |
uint32 hdrSiz, palSiz, scanSiz, bmSiz; |
484 |
485 |
if (cput == NULL || hdr == NULL) |
486 |
return NULL; |
487 |
if (hdr->width <= 0 || hdr->height <= 0) |
488 |
return NULL; |
489 |
if (hdr->compr != BI_UNCOMPR && hdr->compr != BI_RLE8) |
490 |
return NULL; /* unsupported */ |
491 |
if (hdr->bpp > 8 && hdr->compr != BI_UNCOMPR) |
492 |
return NULL; |
493 |
palSiz = BMPpalLen(hdr); |
494 |
if (hdr->nColors > palSiz) |
495 |
return NULL; |
496 |
if (hdr->compr != BI_UNCOMPR && seek == NULL) |
497 |
return NULL; |
498 |
/* compute sizes */ |
499 |
hdrSiz = 2 + 6*4 + 2*2 + 6*4; |
500 |
palSiz *= sizeof(RGBquad); |
501 |
scanSiz = getScanSiz(hdr); |
502 |
bmSiz = hdr->height*scanSiz; /* wrong if compressed */ |
503 |
/* initialize writer */ |
504 |
bw = (BMPWriter *)malloc(sizeof(BMPWriter)); |
505 |
if (bw == NULL) |
506 |
return NULL; |
507 |
bw->hdr = hdr; |
508 |
bw->yscan = 0; |
509 |
bw->scanline = (uint8 *)calloc(scanSiz, sizeof(uint8)); |
510 |
if (bw->scanline == NULL) { |
511 |
free((void *)bw); |
512 |
return NULL; |
513 |
514 |
bw->fbmp = hdrSiz + palSiz + hdr->infoSiz; |
515 |
bw->fpos = bw->flen = 0; |
516 |
bw->cput = cput; |
517 |
bw->seek = seek; |
518 |
bw->c_data = c_data; |
519 |
/* write out header */ |
520 |
wrbyte('B', bw); wrbyte('M', bw); /* magic number */ |
521 |
wrint32(bw->fbmp + bmSiz, bw); /* file size */ |
522 |
wrint32(0, bw); /* reserved word */ |
523 |
wrint32(bw->fbmp, bw); /* offset to bitmap */ |
524 |
wrint32(hdrSiz - bw->fpos, bw); /* info header size */ |
525 |
wrint32(hdr->width, bw); /* bitmap width */ |
526 |
if (hdr->yIsDown) /* bitmap height */ |
527 |
wrint32(-hdr->height, bw); |
528 |
else |
529 |
wrint32(hdr->height, bw); |
530 |
wruint16(1, bw); /* number of planes */ |
531 |
wruint16(hdr->bpp, bw); /* bits per pixel */ |
532 |
wrint32(hdr->compr, bw); /* compression mode */ |
533 |
wrint32(bmSiz, bw); /* bitmap size */ |
534 |
wrint32(hdr->hRes, bw); /* horizontal resolution */ |
535 |
wrint32(hdr->vRes, bw); /* vertical resolution */ |
536 |
wrint32(hdr->nColors, bw); /* # colors used */ |
537 |
wrint32(hdr->impColors, bw); /* # important colors */ |
538 |
/* write out color palette */ |
539 |
wrbytes((char *)hdr->palette, palSiz, bw); |
540 |
/* write add'l information */ |
541 |
wrbytes(BMPinfo(hdr), hdr->infoSiz, bw); |
542 |
#ifndef NDEBUG |
543 |
if (bw->fpos != bw->fbmp) { |
544 |
fputs("Coding error 1 in BMPopenWriter\n", stderr); |
545 |
exit(1); |
546 |
547 |
#endif |
548 |
return bw; |
549 |
550 |
551 |
/* write the current scanline */ |
552 |
int |
553 |
BMPwriteScanline(BMPWriter *bw) |
554 |
555 |
if (bw->yscan >= bw->hdr->height) |
556 |
return BIR_EOF; |
557 |
/* writing uncompressed? */ |
558 |
if (bw->hdr->compr == BI_UNCOMPR) { |
559 |
uint32 scanSiz = getScanSiz(bw->hdr); |
560 |
uint32 slpos = bw->fbmp + bw->yscan*scanSiz; |
561 |
if (wrseek(slpos, bw) != BIR_OK) |
562 |
563 |
wrbytes((char *)bw->scanline, scanSiz, bw); |
564 |
bw->yscan++; |
565 |
return BIR_OK; |
566 |
567 |
/* else write compressed */ |
568 |
/* XXX need to do actual compression */ |
569 |
570 |
/* write file length at end */ |
571 |
if (bw->yscan == bw->hdr->height) { |
572 |
if (bw->seek == NULL || (*bw->seek)(2, bw->c_data) != 0) |
573 |
574 |
bw->fpos = 2; |
575 |
wrint32(bw->flen, bw); |
576 |
577 |
return BIR_OK; |
578 |
579 |
580 |
/* free BMP writer resources */ |
581 |
void |
582 |
BMPfreeWriter(BMPWriter *bw) |
583 |
584 |
if (bw == NULL) |
585 |
return; |
586 |
free((void *)bw->hdr); |
587 |
free((void *)bw->scanline); |
588 |
free((void *)bw); |
589 |
