--- ray/src/common/bmpfile.c 2004/04/29 14:36:49 2.9 +++ ray/src/common/bmpfile.c 2005/05/10 01:08:43 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bmpfile.c,v 2.9 2004/04/29 14:36:49 greg Exp $"; +static const char RCSid[] = "$Id: bmpfile.c,v 2.15 2005/05/10 01:08:43 greg Exp $"; #endif /* * Windows and OS/2 BMP file support @@ -11,6 +11,8 @@ static const char RCSid[] = "$Id: bmpfile.c,v 2.9 2004 #include "bmpfile.h" #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ +#undef getc +#undef putc #define getc getc_unlocked #define putc putc_unlocked #endif @@ -69,12 +71,15 @@ BMPheaderOK(const BMPHeader *hdr) if (hdr->compr == BI_BITFIELDS && (BMPbitField(hdr)[0] & BMPbitField(hdr)[1] & BMPbitField(hdr)[2])) return 0; - if ((hdr->nColors < 0) | (hdr->impColors < 0)) - return 0; - if (hdr->impColors > hdr->nColors) - return 0; - if (hdr->nColors > BMPpalLen(hdr)) - return 0; + if (hdr->bpp > 8) { + if (hdr->nColors != 0) + return 0; + } else { + if ((hdr->nColors < 0) | (hdr->nColors > 1<bpp)) + return 0; + if ((hdr->impColors < 0) | (hdr->impColors > hdr->nColors)) + return 0; + } return 1; } @@ -141,12 +146,11 @@ BMPReader * BMPopenReader(int (*cget)(void *), int (*seek)(uint32, void *), void *c_data) { BMPReader *br; - uint32 bmPos, hdrSiz; - int palLen; + uint32 bmPos, hdrSiz, palSiz; + int magic[2]; /* check magic number */ if (cget == NULL) return NULL; - int magic[2]; /* check magic number */ magic[0] = (*cget)(c_data); if (magic[0] != 'B') return NULL; @@ -184,27 +188,24 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, br->hdr->hRes = rdint32(br); /* horizontal resolution */ br->hdr->vRes = rdint32(br); /* vertical resolution */ br->hdr->nColors = rdint32(br); /* # colors used */ + if (!br->hdr->nColors && br->hdr->bpp <= 8) + br->hdr->nColors = 1<hdr->bpp; br->hdr->impColors = rdint32(br); /* # important colors */ if (br->hdr->impColors < 0) goto err; /* catch premature EOF */ if (!BMPheaderOK(br->hdr)) goto err; - palLen = BMPpalLen(br->hdr); - if (br->hdr->bpp <= 8) { /* normalize color counts */ - if (br->hdr->nColors <= 0) - br->hdr->nColors = palLen; - if (br->hdr->impColors <= 0) - br->hdr->impColors = br->hdr->nColors; - } + palSiz = sizeof(RGBquad)*br->hdr->nColors; + if (br->hdr->impColors <= 0) + br->hdr->impColors = br->hdr->nColors; /* extend header */ - if (bmPos < hdrSiz + sizeof(RGBquad)*palLen) + if (bmPos < hdrSiz + palSiz) goto err; - br->hdr->infoSiz = bmPos - (hdrSiz + sizeof(RGBquad)*palLen); - if (palLen > 0 || br->hdr->infoSiz > 0) { + br->hdr->infoSiz = bmPos - (hdrSiz + palSiz); + if (br->hdr->nColors > 0 || br->hdr->infoSiz > 0) { br->hdr = (BMPHeader *)realloc((void *)br->hdr, sizeof(BMPHeader) + - sizeof(RGBquad)*palLen + - br->hdr->infoSiz); + palSiz + br->hdr->infoSiz); if (br->hdr == NULL) goto err; } @@ -213,8 +214,7 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, BMPbitField(br->hdr)[0] = (uint32)rdint32(br); BMPbitField(br->hdr)[1] = (uint32)rdint32(br); BMPbitField(br->hdr)[2] = (uint32)rdint32(br); - } else if (rdbytes((char *)br->hdr->palette, - sizeof(RGBquad)*palLen, br) != BIR_OK) + } else if (rdbytes((char *)br->hdr->palette, palSiz, br) != BIR_OK) goto err; /* read add'l information */ if (rdbytes(BMPinfo(br->hdr), br->hdr->infoSiz, br) != BIR_OK) @@ -237,9 +237,8 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, sizeof(br->scanpos[0])*br->hdr->height); } br->scanpos[0] = br->fpos; - if (BMPreadScanline(br) != BIR_OK) - goto err; - return br; + if (BMPreadScanline(br) == BIR_OK) + return br; err: if (br->hdr != NULL) free((void *)br->hdr); @@ -260,8 +259,8 @@ BMPisGrayscale(const BMPHeader *hdr) return -1; if (hdr->bpp > 8) /* assume they had a reason for it */ return 0; - for (rgbp = hdr->palette, n = hdr->nColors; n-- > 0; rgbp++) - if (((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b))) + for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++) + if ((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b)) return 0; return 1; /* all colors neutral in map */ } @@ -280,14 +279,14 @@ BMPreadScanline(BMPReader *br) if (br->hdr->compr == BI_UNCOMPR || br->hdr->compr == BI_BITFIELDS) return rdbytes((char *)br->scanline, n, br); /* - * RLE/RLE8 Decoding + * RLE4/RLE8 Decoding * * Certain aspects of this scheme are completely insane, so * we don't support them. Fortunately, they rarely appear. * One is the mid-file EOD (0x0001) and another is the ill-conceived * "delta" (0x0002), which is like a "goto" statement for bitmaps. - * Whoever thought this up should be shot, then told why - * it's impossible to support such a scheme in any reasonable way. + * Whoever thought this up should be wrestled to the ground and told + * why it's impossible to support such a scheme in any reasonable way. * Also, RLE4 mode allows runs to stop halfway through a byte, * which is likewise uncodeable, so we don't even try. * Finally, the scanline break is ambiguous -- we assume here that @@ -301,7 +300,10 @@ BMPreadScanline(BMPReader *br) * is it specified what we should assume for missing pixels. This * is undoubtedly the most brain-dead format I've ever encountered. */ - sp = br->scanline; + sp = (int8 *)br->scanline; + n = br->hdr->width; + if (br->hdr->compr == BI_RLE4) + n = (n + 1) >> 1; while (n > 0) { int skipOdd, len, val; @@ -322,6 +324,7 @@ BMPreadScanline(BMPReader *br) *sp++ = val; continue; } + /* check for escape */ switch (rdbyte(len, br)) { case EOF: return BIR_TRUNCATED; @@ -637,7 +640,7 @@ BMPopenWriter(void (*cput)(int, void *), int (*seek)(u hdrSiz = 2 + 6*4 + 2*2 + 6*4; if (hdr->compr == BI_BITFIELDS) hdrSiz += sizeof(uint32)*3; - palSiz = sizeof(RGBquad)*BMPpalLen(hdr); + palSiz = sizeof(RGBquad)*hdr->nColors; scanSiz = getScanSiz(hdr); bmSiz = hdr->height*scanSiz; /* wrong if compressed */ /* initialize writer */ @@ -733,13 +736,12 @@ BMPwriteScanline(BMPWriter *bw) * (0x0000) except for the last, which ends in a bitmap break * (0x0001). We don't support RLE4 at all; it's too awkward. */ - sp = bw->scanline; + sp = (const int8 *)bw->scanline; n = bw->hdr->width; while (n > 0) { int cnt, val; - cnt = findNextRun(sp, n); /* 0-255 < n */ - if (cnt >= 3) { /* output non-run */ + if (cnt >= 3) { /* output absolute */ int skipOdd = cnt & 1; wrbyte(0, bw); wrbyte(cnt, bw); @@ -752,8 +754,8 @@ BMPwriteScanline(BMPWriter *bw) if (n <= 0) /* was that it? */ break; val = *sp; /* output run */ - for (cnt = 1; cnt < 255; cnt++) - if ((!--n) | (*++sp != val)) + for (cnt = 1; --n && cnt < 255; cnt++) + if (*++sp != val) break; wrbyte(cnt, bw); wrbyte(val, bw);
