--- ray/src/common/bmpfile.c 2004/03/27 05:43:37 2.5 +++ ray/src/common/bmpfile.c 2004/04/10 02:54:44 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bmpfile.c,v 2.5 2004/03/27 05:43:37 greg Exp $"; +static const char RCSid[] = "$Id: bmpfile.c,v 2.8 2004/04/10 02:54:44 greg Exp $"; #endif /* * Windows and OS/2 BMP file support @@ -255,7 +255,7 @@ BMPisGrayscale(const BMPHeader *hdr) return -1; if (hdr->bpp > 8) /* assume they had a reason for it */ return 0; - for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++) + for (rgbp = hdr->palette, n = hdr->nColors; n-- > 0; rgbp++) if (((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b))) return 0; return 1; /* all colors neutral in map */ @@ -279,10 +279,10 @@ BMPreadScanline(BMPReader *br) * * Certain aspects of this scheme are completely insane, so * we don't support them. Fortunately, they rarely appear. - * One is the mid-file EOD (0x0001) and another is the insane + * One is the mid-file EOD (0x0001) and another is the ill-conceived * "delta" (0x0002), which is like a "goto" statement for bitmaps. * Whoever thought this up should be shot, then told why - * it's impossible to support in any reasonable way. + * it's impossible to support such a scheme in any reasonable way. * Also, RLE4 mode allows runs to stop halfway through a byte, * which is likewise uncodeable, so we don't even try. * Finally, the scanline break is ambiguous -- we assume here that @@ -291,7 +291,7 @@ BMPreadScanline(BMPReader *br) * the end of the scanline, assuming the next bit of data belongs * the following scan. If a break follows the last pixel, as it * seems to in the files I've tested out of Photoshop, you end up - * painting every other line black. BTW, I assume any skipped + * painting every other line black. Also, I assume any skipped * pixels are painted with color 0, which is often black. Nowhere * is it specified what we should assume for missing pixels. This * is undoubtedly the most brain-dead format I've ever encountered. @@ -323,6 +323,7 @@ BMPreadScanline(BMPReader *br) case 0: /* end of line */ while (n--) *sp++ = 0; + /* leaves n == -1 as flag for test after loop */ continue; case 1: /* end of bitmap */ case 2: /* delta */ @@ -347,8 +348,8 @@ BMPreadScanline(BMPReader *br) return BIR_TRUNCATED; } /* verify break at end of line */ - if (rdbyte(n, br) != 0 || (rdbyte(n, br) != 0 && - (n != 1 || br->yscan != br->hdr->height-1))) + if (!n && (rdbyte(n, br) != 0 || (rdbyte(n, br) != 0 && + (n != 1 || br->yscan != br->hdr->height-1)))) return BIR_RLERROR; if (br->seek != NULL) /* record next scanline position */ br->scanpos[br->yscan + 1] = br->fpos; @@ -599,13 +600,8 @@ wrseek(uint32 pos, BMPWriter *bw) { if (pos == bw->fpos) return BIR_OK; - if (bw->seek == NULL) { - if (pos < bw->fpos) - return BIR_SEEKERR; - while (bw->fpos < pos) - wrbyte(0, bw); - return BIR_OK; - } + if (bw->seek == NULL) + return BIR_SEEKERR; if ((*bw->seek)(pos, bw->c_data) != 0) return BIR_SEEKERR; bw->fpos = pos; @@ -752,7 +748,7 @@ BMPwriteScanline(BMPWriter *bw) break; val = *sp; /* output run */ for (cnt = 1; cnt < 255; cnt++) - if (!--n | *++sp != val) + if ((!--n) | (*++sp != val)) break; wrbyte(cnt, bw); wrbyte(val, bw); @@ -760,10 +756,12 @@ BMPwriteScanline(BMPWriter *bw) bw->yscan++; /* write line break or EOD */ if (bw->yscan == bw->hdr->height) { wrbyte(0, bw); wrbyte(1, bw); /* end of bitmap marker */ - if (bw->seek == NULL || (*bw->seek)(2, bw->c_data) != 0) + if (wrseek(2, bw) != BIR_OK) return BIR_OK; /* no one may care */ - bw->fpos = 2; - wrint32(bw->flen-bw->fbmp, bw); /* output correct bitmap length */ + wrint32(bw->flen, bw); /* correct file length */ + if (wrseek(34, bw) != BIR_OK) + return BIR_OK; + wrint32(bw->flen-bw->fbmp, bw); /* correct bitmap length */ } else { wrbyte(0, bw); wrbyte(0, bw); /* end of line marker */ }
