--- ray/src/common/bmpfile.c 2004/03/27 16:33:31 2.6 +++ ray/src/common/bmpfile.c 2004/04/30 17:00:29 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bmpfile.c,v 2.6 2004/03/27 16:33:31 greg Exp $"; +static const char RCSid[] = "$Id: bmpfile.c,v 2.10 2004/04/30 17:00:29 greg Exp $"; #endif /* * Windows and OS/2 BMP file support @@ -10,6 +10,11 @@ static const char RCSid[] = "$Id: bmpfile.c,v 2.6 2004 #include #include "bmpfile.h" +#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ +#define getc getc_unlocked +#define putc putc_unlocked +#endif + /* get corresponding error message */ const char * BMPerrorMessage(int ec) @@ -232,9 +237,8 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, sizeof(br->scanpos[0])*br->hdr->height); } br->scanpos[0] = br->fpos; - if (BMPreadScanline(br) != BIR_OK) - goto err; - return br; + if (BMPreadScanline(br) == BIR_OK) + return br; err: if (br->hdr != NULL) free((void *)br->hdr); @@ -275,14 +279,14 @@ BMPreadScanline(BMPReader *br) if (br->hdr->compr == BI_UNCOMPR || br->hdr->compr == BI_BITFIELDS) return rdbytes((char *)br->scanline, n, br); /* - * RLE/RLE8 Decoding + * RLE4/RLE8 Decoding * * Certain aspects of this scheme are completely insane, so * we don't support them. Fortunately, they rarely appear. * One is the mid-file EOD (0x0001) and another is the ill-conceived * "delta" (0x0002), which is like a "goto" statement for bitmaps. - * Whoever thought this up should be shot, then told why - * it's impossible to support such a scheme in any reasonable way. + * Whoever thought this up should be wrestled to the ground and told + * why it's impossible to support such a scheme in any reasonable way. * Also, RLE4 mode allows runs to stop halfway through a byte, * which is likewise uncodeable, so we don't even try. * Finally, the scanline break is ambiguous -- we assume here that @@ -297,6 +301,9 @@ BMPreadScanline(BMPReader *br) * is undoubtedly the most brain-dead format I've ever encountered. */ sp = br->scanline; + n = br->hdr->width; + if (br->hdr->compr == BI_RLE4) + n = (n + 1) >> 1; while (n > 0) { int skipOdd, len, val; @@ -317,6 +324,7 @@ BMPreadScanline(BMPReader *br) *sp++ = val; continue; } + /* check for escape */ switch (rdbyte(len, br)) { case EOF: return BIR_TRUNCATED; @@ -600,13 +608,8 @@ wrseek(uint32 pos, BMPWriter *bw) { if (pos == bw->fpos) return BIR_OK; - if (bw->seek == NULL) { - if (pos < bw->fpos) - return BIR_SEEKERR; - while (bw->fpos < pos) - wrbyte(0, bw); - return BIR_OK; - } + if (bw->seek == NULL) + return BIR_SEEKERR; if ((*bw->seek)(pos, bw->c_data) != 0) return BIR_SEEKERR; bw->fpos = pos; @@ -737,9 +740,8 @@ BMPwriteScanline(BMPWriter *bw) n = bw->hdr->width; while (n > 0) { int cnt, val; - cnt = findNextRun(sp, n); /* 0-255 < n */ - if (cnt >= 3) { /* output non-run */ + if (cnt >= 3) { /* output absolute */ int skipOdd = cnt & 1; wrbyte(0, bw); wrbyte(cnt, bw); @@ -752,8 +754,8 @@ BMPwriteScanline(BMPWriter *bw) if (n <= 0) /* was that it? */ break; val = *sp; /* output run */ - for (cnt = 1; cnt < 255; cnt++) - if (!--n | *++sp != val) + for (cnt = 1; --n && cnt < 255; cnt++) + if (*++sp != val) break; wrbyte(cnt, bw); wrbyte(val, bw); @@ -761,9 +763,11 @@ BMPwriteScanline(BMPWriter *bw) bw->yscan++; /* write line break or EOD */ if (bw->yscan == bw->hdr->height) { wrbyte(0, bw); wrbyte(1, bw); /* end of bitmap marker */ - if (bw->seek == NULL || (*bw->seek)(2, bw->c_data) != 0) + if (wrseek(2, bw) != BIR_OK) return BIR_OK; /* no one may care */ - bw->fpos = 2; + wrint32(bw->flen, bw); /* correct file length */ + if (wrseek(34, bw) != BIR_OK) + return BIR_OK; wrint32(bw->flen-bw->fbmp, bw); /* correct bitmap length */ } else { wrbyte(0, bw); wrbyte(0, bw); /* end of line marker */
