--- ray/src/common/bmpfile.c 2004/03/26 03:11:50 2.1 +++ ray/src/common/bmpfile.c 2004/03/26 22:58:21 2.3 @@ -1,12 +1,10 @@ #ifndef lint -static const char RCSid[] = "$Id: bmpfile.c,v 2.1 2004/03/26 03:11:50 greg Exp $"; +static const char RCSid[] = "$Id: bmpfile.c,v 2.3 2004/03/26 22:58:21 greg Exp $"; #endif /* * Windows and OS/2 BMP file support */ -/* XXX reading and writing of compressed files currently unsupported */ - #include #include #include @@ -25,25 +23,59 @@ BMPerrorMessage(int ec) return "Truncated BMP image"; case BIR_UNSUPPORTED: return "Unsupported BMP feature"; + case BIR_RLERROR: + return "BMP runlength encoding error"; case BIR_SEEKERR: return "BMP seek error"; } return "Unknown BMP error"; } -/* compute uncompressed scanline size */ -static uint32 -getScanSiz(BMPHeader *hdr) +/* check than header is sensible */ +static int +BMPheaderOK(const BMPHeader *hdr) { - uint32 scanSiz; - /* bytes per scanline */ - scanSiz = (hdr->bpp*hdr->width + 7) >> 3; - if (scanSiz & 3) /* 32-bit word boundary */ - scanSiz += 4 - (scanSiz & 3); - - return scanSiz; + if (!hdr) + return 0; + if ((hdr->width <= 0 | hdr->height <= 0)) + return 0; + switch (hdr->bpp) { /* check compression */ + case 1: + case 24: + if (hdr->compr != BI_UNCOMPR) + return 0; + break; + case 16: + case 32: + if ((hdr->compr != BI_UNCOMPR & hdr->compr != BI_BITFIELDS)) + return 0; + break; + case 4: + if ((hdr->compr != BI_UNCOMPR & hdr->compr != BI_RLE4)) + return 0; + break; + case 8: + if ((hdr->compr != BI_UNCOMPR & hdr->compr != BI_RLE8)) + return 0; + break; + default: + return 0; + } + if (hdr->compr == BI_BITFIELDS && (BMPbitField(hdr)[0] & + BMPbitField(hdr)[1] & BMPbitField(hdr)[2])) + return 0; + if ((hdr->nColors < 0 | hdr->impColors < 0)) + return 0; + if (hdr->impColors > hdr->nColors) + return 0; + if (hdr->nColors > BMPpalLen(hdr)) + return 0; + return 1; } + /* compute uncompressed scan size */ +#define getScanSiz(h) ( (((h)->bpp*(h)->width+7 >>3) + 3) & ~03 ) + /* get next byte from reader */ #define rdbyte(c,br) ((br)->fpos += (c=(*(br)->cget)((br)->c_data))!=EOF, c) @@ -130,25 +162,19 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, (void)rdint32(br); /* file size */ (void)rdint32(br); /* reserved word */ bmPos = rdint32(br); /* offset to bitmap */ - hdrSiz = rdint32(br) + 14; /* header size */ + hdrSiz = 2 + 3*4 + rdint32(br); /* header size */ if (hdrSiz < 2 + 6*4 + 2*2 + 6*4) goto err; br->hdr->width = rdint32(br); /* bitmap width */ br->hdr->height = rdint32(br); /* bitmap height */ - if ((br->hdr->width <= 0 | br->hdr->height == 0)) + if (((br->hdr->width <= 0) | (br->hdr->height == 0))) goto err; if ((br->hdr->yIsDown = br->hdr->height < 0)) br->hdr->height = -br->hdr->height; if (rduint16(br) != 1) /* number of planes */ goto err; br->hdr->bpp = rduint16(br); /* bits per pixel */ - if (br->hdr->bpp != 1 && br->hdr->bpp != 4 && - br->hdr->bpp != 8 && br->hdr->bpp != 24 && - br->hdr->bpp != 32) - goto err; br->hdr->compr = rdint32(br); /* compression mode */ - if (br->hdr->compr != BI_UNCOMPR && br->hdr->compr != BI_RLE8) - goto err; /* don't support the rest */ (void)rdint32(br); /* bitmap size */ br->hdr->hRes = rdint32(br); /* horizontal resolution */ br->hdr->vRes = rdint32(br); /* vertical resolution */ @@ -156,19 +182,15 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, br->hdr->impColors = rdint32(br); /* # important colors */ if (br->hdr->impColors < 0) goto err; /* catch premature EOF */ - palLen = 0; - if (br->hdr->bpp <= 8) { - palLen = 1 << br->hdr->bpp; + if (!BMPheaderOK(br->hdr)) + goto err; + palLen = BMPpalLen(br->hdr); + if (br->hdr->bpp <= 8) { /* normalize color counts */ if (br->hdr->nColors <= 0) br->hdr->nColors = palLen; - else if (br->hdr->nColors > palLen) - goto err; if (br->hdr->impColors <= 0) br->hdr->impColors = br->hdr->nColors; - else if (br->hdr->impColors > br->hdr->nColors) - goto err; - } else if (br->hdr->nColors > 0 || br->hdr->compr != BI_UNCOMPR) - goto err; + } /* extend header */ if (bmPos < hdrSiz + sizeof(RGBquad)*palLen) goto err; @@ -176,14 +198,17 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, if (palLen > 0 || br->hdr->infoSiz > 0) { br->hdr = (BMPHeader *)realloc((void *)br->hdr, sizeof(BMPHeader) + - sizeof(RGBquad)*palLen - - sizeof(br->hdr->palette) + + sizeof(RGBquad)*palLen + br->hdr->infoSiz); if (br->hdr == NULL) goto err; } - /* read color palette */ - if (rdbytes((char *)br->hdr->palette, + /* read colors or fields */ + if (br->hdr->compr == BI_BITFIELDS) { + BMPbitField(br->hdr)[0] = (uint32)rdint32(br); + BMPbitField(br->hdr)[1] = (uint32)rdint32(br); + BMPbitField(br->hdr)[2] = (uint32)rdint32(br); + } else if (rdbytes((char *)br->hdr->palette, sizeof(RGBquad)*palLen, br) != BIR_OK) goto err; /* read add'l information */ @@ -194,7 +219,8 @@ BMPopenReader(int (*cget)(void *), int (*seek)(uint32, if (br->scanline == NULL) goto err; br->yscan = -1; - if (seek != NULL && br->hdr->compr != BI_UNCOMPR) { + if (seek != NULL && (br->hdr->compr == BI_RLE8 | + br->hdr->compr == BI_RLE4)) { BMPReader *newbr = (BMPReader *)realloc((void *)br, sizeof(BMPReader) + sizeof(br->scanpos[0]) * @@ -230,7 +256,7 @@ BMPisGrayscale(const BMPHeader *hdr) if (hdr->bpp > 8) /* assume they had a reason for it */ return 0; for (rgbp = hdr->palette, n = hdr->impColors; n-- > 0; rgbp++) - if ((rgbp->r != rgbp->g | rgbp->g != rgbp->b)) + if (((rgbp->r != rgbp->g) | (rgbp->g != rgbp->b))) return 0; return 1; /* all colors neutral in map */ } @@ -239,14 +265,92 @@ BMPisGrayscale(const BMPHeader *hdr) int BMPreadScanline(BMPReader *br) { + int n; + int8 *sp; + if (br->yscan + 1 >= br->hdr->height) return BIR_EOF; br->yscan++; /* prepare to read */ - if (br->hdr->compr == BI_UNCOMPR) - return rdbytes((char *)br->scanline, getScanSiz(br->hdr), br); -/* XXX need to perform actual decompression */ - return BIR_UNSUPPORTED; - if (br->seek != NULL) + n = getScanSiz(br->hdr); /* reading uncompressed data? */ + if (br->hdr->compr == BI_UNCOMPR || br->hdr->compr == BI_BITFIELDS) + return rdbytes((char *)br->scanline, n, br); + /* + * RLE/RLE8 Decoding + * + * Certain aspects of this scheme are completely insane, so + * we don't support them. Fortunately, they rarely appear. + * One is the mid-file EOD (0x0001) and another is the insane + * "delta" (0x0002), which is like a "goto" statement for bitmaps. + * Whoever thought this up should be shot, then told why + * it's impossible to support in any reasonable way. + * Also, RLE4 mode allows runs to stop halfway through a byte, + * which is likewise uncodeable, so we don't even try. + * Finally, the scanline break is ambiguous -- we assume here that + * it is required at the end of each scanline, though I haven't + * found anywhere this is written. Otherwise, we would read to + * the end of the scanline, assuming the next bit of data belongs + * the following scan. If a break follows the last pixel, as it + * seems to in the files I've tested out of Photoshop, you end up + * painting every other line black. BTW, I assume any skipped + * pixels are painted with color 0, which is often black. Nowhere + * is it specified what we should assume for missing pixels. This + * is undoubtedly the most brain-dead format I've ever encountered. + */ + sp = br->scanline; + while (n > 0) { + int skipOdd, len, val; + + if (rdbyte(len, br) == EOF) + return BIR_TRUNCATED; + if (len > 0) { /* got a run */ + if (br->hdr->compr == BI_RLE4) { + if (len & 1) + return BIR_UNSUPPORTED; + len >>= 1; + } + if (len > n) + return BIR_RLERROR; + if (rdbyte(val, br) == EOF) + return BIR_TRUNCATED; + n -= len; + while (len--) + *sp++ = val; + continue; + } + switch (rdbyte(len, br)) { + case EOF: + return BIR_TRUNCATED; + case 0: /* end of line */ + while (n--) + *sp++ = 0; + continue; + case 1: /* end of bitmap */ + case 2: /* delta */ + return BIR_UNSUPPORTED; + } + /* absolute mode */ + if (br->hdr->compr == BI_RLE4) { + if (len & 1) + return BIR_UNSUPPORTED; + len >>= 1; + } + skipOdd = len & 1; + if (len > n) + return BIR_RLERROR; + n -= len; + while (len--) { + if (rdbyte(val, br) == EOF) + return BIR_TRUNCATED; + *sp++ = val; + } + if (skipOdd && rdbyte(val, br) == EOF) + return BIR_TRUNCATED; + } + /* verify break at end of line */ + if (rdbyte(n, br) != 0 || (rdbyte(n, br) != 0 && + (n != 1 || br->yscan != br->hdr->height-1))) + return BIR_RLERROR; + if (br->seek != NULL) /* record next scanline position */ br->scanpos[br->yscan + 1] = br->fpos; return BIR_OK; } @@ -270,7 +374,8 @@ BMPseekScanline(int y, BMPReader *br) if (y != br->yscan + 1 && br->seek != NULL) { int yseek; uint32 seekp; - if (br->hdr->compr == BI_UNCOMPR) { + if (br->hdr->compr == BI_UNCOMPR || + br->hdr->compr == BI_BITFIELDS) { yseek = y; seekp = br->scanpos[0] + y*getScanSiz(br->hdr); } else { @@ -295,29 +400,64 @@ BMPseekScanline(int y, BMPReader *br) /* get ith pixel from last scanline */ RGBquad -BMPdecodePixel(int i, BMPReader *br) +BMPdecodePixel(int i, const BMPReader *br) { + static const uint32 std16mask[3] = {0x7c00, 0x3e0, 0x1f}; static const RGBquad black = {0, 0, 0, 0}; + const uint32 *mask; + const uint8 *pp; + uint32 pval, v; + RGBquad cval; - if ((br == NULL | i < 0) || i >= br->hdr->width) + if (((br == NULL) | (i < 0)) || i >= br->hdr->width) return black; + cval.padding = 0; + switch (br->hdr->bpp) { - case 24: { - uint8 *bgr = br->scanline + 3*i; - RGBquad cval; - cval.b = bgr[0]; cval.g = bgr[1]; cval.r = bgr[2]; - cval.padding = 0; + case 24: + pp = br->scanline + 3*i; + cval.b = *pp++; + cval.g = *pp++; + cval.r = *pp; return cval; - } case 32: - return ((RGBquad *)br->scanline)[i]; + if (br->hdr->compr == BI_UNCOMPR) + return ((RGBquad *)br->scanline)[i]; + /* convert bit fields */ + pp = br->scanline + 4*i; + pval = *pp++; + pval |= *pp++ << 8; + pval |= *pp++ << 16; + pval |= *pp << 24; + mask = BMPbitField(br->hdr); + v = pval & mask[0]; + while (v & ~0xff) v >>= 8; + cval.r = v; + v = pval & mask[1]; + while (v & ~0xff) v >>= 8; + cval.g = v; + v = pval & mask[2]; + while (v & ~0xff) v >>= 8; + cval.b = v; + return cval; case 8: return br->hdr->palette[br->scanline[i]]; case 1: - return br->hdr->palette[br->scanline[i>>3]>>(i&7) & 1]; + return br->hdr->palette[br->scanline[i>>3]>>(7-i&7) & 1]; case 4: - return br->hdr->palette[br->scanline[i>>1]>>((i&1)<<2) & 0xf]; + return br->hdr->palette[br->scanline[i>>1]>>(i&1?4:0) & 0xf]; + case 16: + pp = br->scanline + 2*i; + pval = *pp++; + pval |= *pp++ << 8; + mask = std16mask; + if (br->hdr->compr == BI_BITFIELDS) + mask = BMPbitField(br->hdr); + cval.r = ((pval & mask[0]) << 8) / (mask[0] + 1); + cval.g = ((pval & mask[1]) << 8) / (mask[1] + 1); + cval.b = ((pval & mask[2]) << 8) / (mask[2] + 1); + return cval; } return black; /* should never happen */ } @@ -382,7 +522,7 @@ BMPtruecolorHeader(int xr, int yr, int infolen) return hdr; } -/* allocate color-mapped header (defaults to minimal grayscale) */ +/* allocate color-mapped header (defaults minimal grayscale) */ BMPHeader * BMPmappedHeader(int xr, int yr, int infolen, int ncolors) { @@ -423,7 +563,7 @@ BMPmappedHeader(int xr, int yr, int infolen, int ncolo /* put byte to writer */ #define wrbyte(c,bw) ( (*(bw)->cput)(c,(bw)->c_data), \ - ++((bw)->fpos) > (bw)->flen ? \ + ++(bw)->fpos > (bw)->flen ? \ ((bw)->flen = (bw)->fpos) : \ (bw)->fpos ) @@ -442,7 +582,7 @@ wrint32(int32 i, BMPWriter *bw) wrbyte(i& 0xff, bw); wrbyte(i>>8 & 0xff, bw); wrbyte(i>>16 & 0xff, bw); - wrbyte(i>>24 & 0xff, bw); + wrbyte(i>>24 & 0xff, bw); } /* write 16-bit unsigned integer in littlendian order */ @@ -482,22 +622,19 @@ BMPopenWriter(void (*cput)(int, void *), int (*seek)(u BMPWriter *bw; uint32 hdrSiz, palSiz, scanSiz, bmSiz; /* check arguments */ - if (cput == NULL || hdr == NULL) + if (cput == NULL) return NULL; - if (hdr->width <= 0 || hdr->height <= 0) + if (!BMPheaderOK(hdr)) return NULL; - if (hdr->compr != BI_UNCOMPR && hdr->compr != BI_RLE8) + if ((hdr->bpp == 16 | hdr->compr == BI_RLE4)) return NULL; /* unsupported */ - if (hdr->bpp > 8 && hdr->compr != BI_UNCOMPR) + if (seek == NULL && (hdr->compr == BI_RLE8 | hdr->compr == BI_RLE4)) return NULL; - palSiz = BMPpalLen(hdr); - if (hdr->nColors > palSiz) - return NULL; - if (hdr->compr != BI_UNCOMPR && seek == NULL) - return NULL; /* compute sizes */ hdrSiz = 2 + 6*4 + 2*2 + 6*4; - palSiz *= sizeof(RGBquad); + if (hdr->compr == BI_BITFIELDS) + hdrSiz += sizeof(uint32)*3; + palSiz = sizeof(RGBquad)*BMPpalLen(hdr); scanSiz = getScanSiz(hdr); bmSiz = hdr->height*scanSiz; /* wrong if compressed */ /* initialize writer */ @@ -547,15 +684,35 @@ BMPopenWriter(void (*cput)(int, void *), int (*seek)(u #endif return bw; } + +/* find position of next run of 5 or more identical bytes, or 255 if none */ +static int +findNextRun(const int8 *bp, int len) +{ + int pos, cnt; + /* look for run */ + for (pos = 0; len > 0 & pos < 255; pos++, bp++, len--) { + if (len < 5) /* no hope left? */ + continue; + cnt = 1; /* else let's try it */ + while (bp[cnt] == bp[0]) + if (++cnt >= 5) /* long enough */ + return pos; + } + return pos; /* didn't find any */ +} /* write the current scanline */ int BMPwriteScanline(BMPWriter *bw) { + const int8 *sp; + int n; + if (bw->yscan >= bw->hdr->height) return BIR_EOF; /* writing uncompressed? */ - if (bw->hdr->compr == BI_UNCOMPR) { + if (bw->hdr->compr == BI_UNCOMPR || bw->hdr->compr == BI_BITFIELDS) { uint32 scanSiz = getScanSiz(bw->hdr); uint32 slpos = bw->fbmp + bw->yscan*scanSiz; if (wrseek(slpos, bw) != BIR_OK) @@ -564,15 +721,48 @@ BMPwriteScanline(BMPWriter *bw) bw->yscan++; return BIR_OK; } - /* else write compressed */ -/* XXX need to do actual compression */ - return BIR_UNSUPPORTED; - /* write file length at end */ + /* + * RLE8 Encoding + * + * See the notes in BMPreadScanline() on this encoding. Needless + * to say, we avoid the nuttier aspects of this specification. + * We also assume that every scanline ends in a line break + * (0x0000) except for the last, which ends in a bitmap break + * (0x0001). We don't support RLE4 at all; it's too awkward. + */ + sp = bw->scanline; + n = bw->hdr->width; + while (n > 0) { + int cnt, val; + + cnt = findNextRun(sp, n); /* 0-255 < n */ + if (cnt >= 3) { /* output non-run */ + int skipOdd = cnt & 1; + wrbyte(0, bw); + wrbyte(cnt, bw); + n -= cnt; + while (cnt--) + wrbyte(*sp++, bw); + if (skipOdd) + wrbyte(0, bw); + } + if (n <= 0) /* was that it? */ + break; + val = *sp; /* output run */ + for (cnt = 1; --n > 0 & *++sp == val; cnt++) + ; + wrbyte(cnt, bw); + wrbyte(val, bw); + } + bw->yscan++; /* write file length at end */ if (bw->yscan == bw->hdr->height) { + wrbyte(0, bw); wrbyte(1, bw); /* end of bitmap marker */ if (bw->seek == NULL || (*bw->seek)(2, bw->c_data) != 0) return BIR_SEEKERR; bw->fpos = 2; - wrint32(bw->flen, bw); + wrint32(bw->flen, bw); /* corrected file length */ + } else { + wrbyte(0, bw); wrbyte(0, bw); /* end of line marker */ } return BIR_OK; }
