root/radiance/ray/src/common/bmpfile.c
Mon Oct 4 23:04:59 2021 UTC (3 years, 7 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.20: +5 -1 lines
Diff to previous 2.20 , to selected 2.11
fix: added checks for stdio open errors
Wed Jan 23 19:13:55 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.19: +23 -23 lines
Diff to previous 2.19 , to selected 2.11
Minor fixes to comments
Tue Sep 5 17:19:42 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.18: +4 -4 lines
Fixed bug in run-length encoded write routine
Thu Jun 30 17:12:19 2016 UTC (8 years, 10 months ago) by greg
Minor improvement in code clarity
Thu Mar 10 23:18:59 2016 UTC (9 years, 2 months ago) by schorsch
make 64 bit MSC happy about shifting
Thu Mar 10 01:49:00 2016 UTC (9 years, 2 months ago) by schorsch
there's a possible 32 bit shift / 64 bit coercion issue
Tue May 10 01:08:43 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 2.14: +3 -3 lines
Fixed complaint about signed vs. unsigned pointer
Fri Apr 8 17:49:55 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.13: +5 -3 lines
Fixed problem with 8-bit headers specifying zero length color maps
Fri Mar 18 21:04:05 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.12: +21 -25 lines
Fixed bug in header size computation related to color palette
Tue Sep 14 02:53:50 2004 UTC (20 years, 7 months ago) by greg
Changes since 2.11: +3 -1 lines
Added #undef for getc/putc where they were being replaced
Wed Jul 28 00:17:58 2004 UTC (20 years, 9 months ago) by schorsch
Moved declaration of magic to start of block (fixing compile error).
Fri Apr 30 17:00:29 2004 UTC (21 years ago) by greg
Changes since 2.9: +12 -10 lines
Thu Apr 29 14:36:49 2004 UTC (21 years ago) by greg
Changes since 2.8: +6 -1 lines
Added macros to avoid flockfile(3) overhead
Sat Apr 10 02:54:44 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.7: +7 -10 lines
Minor fix in writing of bitmap length
Tue Mar 30 16:24:25 2004 UTC (21 years, 1 month ago) by schorsch
Reduced compiler warnings.
Sat Mar 27 16:33:31 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.5: +9 -8 lines
Minor code tweaks
Sat Mar 27 05:43:37 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.4: +13 -10 lines
Bug fixes in run-length encoding code
Fri Mar 26 23:30:05 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.3: +14 -14 lines
Fri Mar 26 22:58:21 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.2: +260 -70 lines
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 21:29:19 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.1: +4 -4 lines
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
Fri Mar 26 03:11:50 2004 UTC (21 years, 1 month ago) by greg
Diff to selected 2.11
